8th May 2019, 03:48 | #6221 | Link |
vlc has brm support
but it has no wasapi exclusiv output mpc be has better codec support and image quality :-) take a look at their source code how they read blu ray menus won't help ? vlc brm support is better than dvdfab player 5 brm support (have not tried powerdvd 19 yet, but 18 also had some probs with some menus) edit: when i start an episode and press pause immedialety and then press play again there is no drop out. may be it has something to do with audio buffer ? only a minor bug but i wonder what is the reason :-) Last edited by peter0815x; 8th May 2019 at 05:01. |
8th May 2019, 04:53 | #6222 | Link |
If somebody implement blu-ray menu support - i add it to MPC-BE
8th May 2019, 05:09 | #6224 | Link | |
it had no effect same for device buffer. using shared mode would also not help i need exclusiv mode to play audio like it was encoded in 48khz for dvds. edit: and its not my usb dac (yamaha mcr 870d) i tried it with an old creative headset (has a simple usb soundblaster) same drop out Last edited by peter0815x; 8th May 2019 at 05:16. |
8th May 2019, 05:20 | #6226 | Link |
As i testing - some audio drops when "enter" to episodes on WASAPI/DS, when the transition between menus and episodes. But when episode start playback - all is good on WASAPI/DS.
I can't help more
8th May 2019, 05:33 | #6227 | Link | |
i have 1 audio drop for a few ms when i enter an episode from dvd menu. audio drop happens after about 1 sec of playback. when i go back to dvd menu and start episode again audio drop will come again after 1 sec. with ds i have no audio drop. |
8th May 2019, 05:36 | #6228 | Link | |
i use a yamaha mcr 870d as dac https://de.yamaha.com/de/products/au...70d/index.html connected over usb (i use latest driver and firmware) with an old creative tactical alpha headset i have same drop out could u test the dvd klaus ? with mpc audio render (best with episode 2,3,4,5 or 6) https://drive.google.com/open?id=1W5...s4csWjLKfXyTRE |
8th May 2019, 06:49 | #6229 | Link |
AMD Ryzen 5 3600 /GIGABYTE B450 Gaming X /Patriot 32Gb@3200 /Kingston 500Gb M.2 /RTX 4060 /Samsung U28R550UQI /OLED Philips 55OLED707 /Yamaha RX-V471 + NS-555 + NS-C444 + NS-333 + YST-SW215 Last edited by Aleksoid1978; 8th May 2019 at 08:08. |
8th May 2019, 16:12 | #6230 | Link | |
perfect ! its fixed. thx for fixing all of my reported dvd problems i wonder why people still use other media players like vlc,dvdfab,zoom,mplayer etc. mpc be is the perfect player: -best codec support (is the only player which plays all of my 4k test files) -best image and audio quality -wasapi and high res audio support -cue file support -plays dvd and audio cd from disc silent without unnecessary spin up. -fast, stable and good gui -and nice devs |
8th May 2019, 16:36 | #6231 | Link |
its me again
i found another small problem.... :-) i have this for a longer time playing audio files with mpc be..... sometimes i have some random drop outs playing audio in mpc be its random happens with audio cd, flac files, etc. happens often after a few minutes of playback. this time i know the reason :-) i set device buffer from 50ms to 100ms and it seems to improve it... but its not fully gone. foobar2k default buffer is set to 1000ms. there are no drop outs, but when i set buffer in foobar2k to 50ms i have drop outs there as well. is it possible for u to create a new test version of mpc be ? and change mpc audio render ? there are 3 options default, 50ms and 100ms can u add 4th option 1000ms ? (or a custom setting so users can put there own value into it) i am 100% sure this would fix it Last edited by peter0815x; 8th May 2019 at 16:44. |
8th May 2019, 16:37 | #6232 | Link | |
8th May 2019, 18:40 | #6233 | Link |
@peter0815x
Try setting the "Default" value for "Device buffer" option.
MPC-BE 1.6.11 and Nightly builds | VideoRenderer | ImageSource | ScriptSource | BassAudioSource |
9th May 2019, 07:04 | #6235 | Link |
@peter0815x
Ok. I will do a test build with a few new buffer sizes tomorrow. What is the full name of your audio device?
9th May 2019, 12:14 | #6237 | Link | ||
but this will have no effect for wasapi. Quote:
Yamaha A-U670/A-U671 mpc audio render shows this name under sound device for it: (windows 10 shows it also like this under system > sound) Lautsprecher (Yamaha A-U670/A-U671) windows device manager shows this: Yamaha HiFi USB Driver > Yamaha A-U670/A-U671 thats it: https://de.yamaha.com/de/products/au...70d/index.html in english https://europe.yamaha.com/en/product...70d/index.html hope this helps :-) Last edited by peter0815x; 9th May 2019 at 12:18. |
10th May 2019, 10:30 | #6238 | Link |
@peter0815x
Test build - mpc-be_4544_wasapi_buffer_1. Added 200, 500, 1000 ms.
10th May 2019, 10:41 | #6239 | Link |
10th May 2019, 18:32 | #6240 | Link | ||
seems there is a problem when i select 1000ms (or 200 or 500) and press ok it goes back to 100. i reseted all settings of mpc be to default when i select now 200 or 500 or 1000 it goes back to 50. settings higher than 100ms won't be saved Quote:
dvds play perfect but your version (with max 100ms buffer) still have audio drop outs with audio files. Last edited by peter0815x; 10th May 2019 at 18:45. |
