16th February 2020, 06:07 | #7165 | Link | |
Open ISO directly.
17th February 2020, 11:33 | #7166 | Link |
Hi guys, when I download the installer-zip and unpack it using 7zip then I can install BE without further issues. However, when I use the unpacker within Windows explorer then I am alarmed that BE is not digitally signed.
Most likely something wrong within Windows - any ideas ?? |
17th February 2020, 12:37 | #7167 | Link |
on SF all builds are digitally signed.
SVN build - not.
18th February 2020, 01:49 | #7168 | Link |
Update for translation of Traditional Chinese, Dutch and Simplified Chinese
For Simplified Chinese, I edited one line due to his misunderstanding. That "Filter" is not "Source Filter", and should be text filter for the items in the list instead. https://www.sendspace.com/file/n3fcqj |
18th February 2020, 11:45 | #7169 | Link | |
Matroska find' ich toll
MPC-HC/BE are the only good players. Is there no chance to compile MPC-BE for Linux? |
18th February 2020, 14:35 | #7170 | Link |
how clear do you need this to be?
the majority of the code asks for windows exclusive libs and other stuff windows provides. there are no alternatives you can switch them with no you can't compile it for linux. what is so hard to understand about this? |
18th February 2020, 17:36 | #7171 | Link |
The audio dropout problem I reported before is a general efficiency issue I found out now.
I tried all popular players now using hw decoding and Kodi is the only player that can play it fluidly without audio or video dropouts! ------- G: Matroska, 24.8 GiB, 1 h 57 min, 30.3 Mb/s V: HEVC, Main 10@L5.1@High, 3840x2076, 59.940 FPS, 20.4 Mb/s A: German, MLP FBA, 4 211 kb/s, 8ch, 48.0 kHz, Default A: German, AC-3, 640 kb/s, 6ch, 48.0 kHz A: English, MLP FBA, 4 204 kb/s, 8ch, 48.0 kHz A: English, AC-3, 640 kb/s, 6ch, 48.0 kHz S: German, UTF-8, Default, Forced S: German, PGS, Forced S: German, PGS S: English, PGS ------- G: MPEG-4, 1.83 GiB, 58 min 40 s, 4 468 kb/s V: HEVC, Main 10@L5.1@Main, 3840x2160, 50 FPS, 4 330 kb/s A: German, AAC, 128 kb/s, 2ch, 48.0 kHz ------- HP Pavilion 590-p0599ng Desktop PC i5-8400 8GB 256GB SSD Silver MSI GeForce GT 1030 2GHD4 LP OC 2GB GDDR
18th February 2020, 18:00 | #7172 | Link |
@beter
Thanks. Updated in r5083+r5084.
20th February 2020, 09:11 | #7173 | Link |
I was able to speed up copying a frame to a D3D11 texture on an Intel graphics card when using a software or DXVA decoder.
Regular version - MPCVideoRenderer-v0.4.2.1143_git2020.02.19-63d3620 Modified version - mpcvr_1144_d3d11vp_UpdateSubresource_Intel Example for Intel HD 4000 (before / after): Please check on other Intel graphics cards.
20th February 2020, 12:05 | #7175 | Link |
There is an issue with MPC VR:
When I set it to use 16 bit FP, HEVC 10 bit video looks too dark (tested with D3D11VA in MPC HC). Imho this format should also be the default once there are no known bugs, it should work on the slowest GPUs (if not too ancient). |
20th February 2020, 12:15 | #7176 | Link |
Test on latest git version - link in post above.
20th February 2020, 12:47 | #7177 | Link |
What is your graphics adapter?
20th February 2020, 14:03 | #7179 | Link | |
Try using shader for color convert - uncheck P010/P016 and test again. Also can select Chroma scaling -> Catmull-Rom. For shader can select 16bit float texture
