15th February 2021, 09:30 | #8301 | Link |
Just copy the files (choose one of each toolbar/flybar) to your installation directory, typically C:\Program Files\MPC-BE
@cmhrky, could you add extra thickness to the toolbar ones as well? Last edited by ryrynz; 15th February 2021 at 09:34. |
21st February 2021, 00:09 | #8305 | Link |
What's wrong ?
21st February 2021, 06:19 | #8306 | Link |
I believe the poster is saying that the "&" character doesn't display properly in some of the areas of the player where a title is displayed.
As an example, I changed the title to a mp4 file from "laptop diagnose and repair" to "laptop diagnose & repair" - looking at the title of the video in the playlist, the "&" is missing from the title and the R in repair has an underscore. Simply add the "&" character to a title and have a look. BTW, I'm running mpcbe 157.6022.x64.7z nightly. |
21st February 2021, 06:49 | #8307 | Link | |
P.S. Fixed.
AMD Ryzen 5 3600 /GIGABYTE B450 Gaming X /Patriot 32Gb@3200 /Kingston 500Gb M.2 /RTX 4060 /Samsung U28R550UQI /OLED Philips 55OLED707 /Yamaha RX-V471 + NS-555 + NS-C444 + NS-333 + YST-SW215 Last edited by Aleksoid1978; 21st February 2021 at 10:46. |
21st February 2021, 13:01 | #8308 | Link |
As best I can tell, the Playlist is the only area of the player having trouble with the "&" character. I bounced thru the Options -> Player settings, changing the Title bar text, Seek bar text, and OSD (name of media file) settings -- Title, File name, and Full path... all displayed the "&" character just fine.
One thing I did notice with the Title bar text setting, when you change from Nothing to any of the other 3 choices and hit Apply... the dash (-) character pops up to the left of the player version info, like it does when a file is playing. You only see this for the short time you're changing settings, it clears when a file is played then closes or you simply exit the player. |
21st February 2021, 13:38 | #8309 | Link | |
21st February 2021, 14:29 | #8310 | Link |
My preferred setting for Title bar text is to show Nothing. I noticed when I changed the setting to Title or File name and hit apply to save the setting the Title bar text added a - (dash) to the left of the player version information in the title bar. Like I said it only appears until you close the player (and reopen), or if you play a file and then stop & close it the dash will disappear.
21st February 2021, 14:40 | #8311 | Link | |
P.S. Picture better upload to any file hosting and post link here.
4th March 2021, 19:03 | #8312 | Link |
I came across a strange, but very interesting file here:
https://forum.doom9.org/showthread.p...62#post1919062 The file can be downloaded here: https://yadi.sk/i/X1nPqEAqIAZXoQ I use latest MPC-BE 1.5.6 stable with latest MPC-VR nightly and latest LAV Filters nightly as of today: If I use external LAV Filters the aspect ratio is 16:9 1920x1080, see here: https://drive.google.com/file/d/1yFW...UUcxQER5L/view If I use the internal filters of MPC-BE, I do get 120:67 1920x1072, see here: https://drive.google.com/file/d/1VrE...E1IYMsOGB/view The reason I used EVR custom presenter is, that Nvidia HW deinterlacer does not apply in MPC-VR, I tried unchecked D3D11 mode -> should be D3D9. And I also tried D3D11 checked. Both are the same. Note: in LAV filters I must set Software deinterlaing to none, to get HW deinterlacer "kick in" lol, reminds me of "VTEC kicked in yo"" In EVR custom presenter the HW deinterlacer of my RTX30 card does apply. And in the second last line there is Procssing listed in display stats: Fix Nvidia YUY2 What does that fix of Nvidia? In MPC-VR it is not displayed, but I suspect it is also processing the file this way, is it? |
5th March 2021, 00:20 | #8313 | Link | |
2). About 120:67 1920x1072 - fixed.
AMD Ryzen 5 3600 /GIGABYTE B450 Gaming X /Patriot 32Gb@3200 /Kingston 500Gb M.2 /RTX 4060 /Samsung U28R550UQI /OLED Philips 55OLED707 /Yamaha RX-V471 + NS-555 + NS-C444 + NS-333 + YST-SW215 Last edited by Aleksoid1978; 5th March 2021 at 03:03. |
5th March 2021, 13:15 | #8314 | Link |
Thank you for quick fix.
I still do not understand why Nvidia HW deinterlacing does not trigger in MPC VR, but it does trigger in EVR cp and madVR with this file. Same source and decoder filters for the different renderers. I tried both internal MPC-BE filters and external LAV Filters, but it is the same. |
5th March 2021, 15:53 | #8316 | Link |
@Klaus1189
Disable in the decoder all formats that are not supported by your video card when using DXVA2 VP and D3D11 VP. You can see the list of input formats for DXVA2 VP and D3D11 VP in DXVA Checker.
5th March 2021, 16:51 | #8318 | Link | |
If so, it doesn't help. In my screenshots there is no GPU icon in toolbar, so software decoding is used anyway, but with EVR cp and madVR the HW deinterlacer of the Nvidia gets triggered, but not in MPC VR. Would that be an option? |
5th March 2021, 17:39 | #8319 | Link |
5th March 2021, 18:08 | #8320 | Link |
OK, thanks, I think I understand it now. I disabled "P210" (10-bit), then it displayed "P216" (16-bit) and deinterlacer didn't work either. Then I disabled "P216" and then it displayed YUY2 (8-bit) and deinterlacer works now.
In EVR cp it always shows YUY2. I think it converts P210 automatically to YUY2. This P210 is also very rare. I doubt this recording was broadcasted in 1920x1080 - 4:2:2 - 10 bit, was it? User who created it probably used an external recorder and set it up this way. Anyway. Thank you for clarifying and helping me to understand that issue. |
