30th June 2015, 07:27 | #2782 | Link |
It just sets the DVD file system on startup, nothing gets 'locked'. If you want to burn an XviD AVI it will pop up a window asking you to use the ISO + Joliet file system just like it did before. But on the next start the DVD file system will be active again.
So if you want to burn XviD AVIs most of the time, the new behavior could be a little annoying, because you have to change the file system to ISO + Joliet after every restart of IMGBurn. Cheers manolito Last edited by manolito; 30th June 2015 at 07:29. |
7th July 2015, 07:14 | #2785 | Link | |
A delay this large is certainly an error. Most likely reason are your DirectShow source filters (if you are on Win7 or Win8). Microsoft prevents that other installed filters get used, and the M$ filters are mostly crap.
You should change the preferred DirectShow Filtes to LAV. Quote by MrC from a VideoHelp post: Quote:
Cheers manolito |
7th July 2015, 10:12 | #2786 | Link |
Oh....You mean the audio and video are out of sync? If that is the case, I'll try changing codecs tonight! I had one problematic video driving me nuts. I tried like 7-8 times with different settings but the audio kept getting out of sync with the video!
Thanks! |
7th July 2015, 17:51 | #2787 | Link | |
Thanks for the suggestion, but I'm using all LAV filters - I just checked with FilterTweaker and ran it again to make sure. I did get a better result (closer sync) when I replaced "VFR" with "true" in /lib/ A2DSource.avsi but I don't want to fiddle with _MrC_'s scripts if I can help it. Thanks again for your help. adam933 |
7th July 2015, 18:36 | #2788 | Link |
Hi adam933,
your A2D log would be helpful. On Doom9 it always takes a while to get attachments approved, so please post your log directly or upload it to SendSpace or ZippyShare or some other hoster. Using convertfps = true all the time is a good idea IMO, from my experience this never hurts. (MrC might disagree...) Personally I use DSS2Mod instead of DirectShowSource all the time for more than half a year, and DSS2 always uses convertfps=true, no way to disable it. And I never had issues with it. Other things you could try is to use FFMpegSource instead of A2DSource for you video and audio. If your source has AVC video you could also try to repack it into an MKV container before feeding it to AVStoDVD. Cheers manolito |
7th July 2015, 20:06 | #2793 | Link |
This is how your original post looks to others:
http://i.imgur.com/Qa4ZKCg.jpg Doom9 is a little paranoid about attachments, it's a good idea to post text directly and larger stuff via a hosting service. Cheers manolito |
7th July 2015, 20:17 | #2794 | Link |
woops!.
Here is the log: <7/7/2015 11:03:36 AM> START PROCESS <> <7/7/2015 11:03:36 AM> PROJECT SETTINGS DVD Video Standard: NTSC DVD Titles number: 1 DVD Size: 4450/4450 MB (100%) DVD Output Setup: DVD Folder DVD Label: BR_LAVcheck DVD Menu: Static Menu Output Folder: C:\Users\bill\Videos Delete Temp Assets Files: Yes Delete Temp Working Files: Yes Edit Command Parameters: No Post Process Task: Show Progress Status window PREFERENCES MultiThread: 1 AVS Video Source Filter: A2DSource AVS Audio Source Filter: A2DSource AVS UpSize/DownSize Filter: Lanczos4Resize/Spline16Resize Frame Adjust Strategy: 0 FPS Hard Conversion: 0 PAL SpeedUp: 0 NTSC SlowDown: 0 Video Resolution: 0 Video Encoder: 3 Video BitRate Min: 2500 Video BitRate Max: 8500 Keep DVD Compliant Video: 0 AC3 Audio Encoder: 0 Force FFmpeg for Long Audio: 1 DVD Audio Format: 0 DVD Audio BitRate: 192 Keep DVD Compliant Audio: 0 Normalize Audio: 0 Auto Delay Audio: 1 DVD Audio Language (Primary): EN - English DVD Audio Language (Secondary): EN - English DVD Subs Language (Primary): EN - English DVD Subs Language (Secondary): EN - English DVD Subs Font: Verdana 12pt (255,255,255) Chapters Interval: 5 Use Source Chapters: 1 DVD Burning Drive: D: HL-DT-ST DVDRAM GH24NSB0 LN00 DVD Burning Speed: 4x Auto Erase DVD RW: 1 Unload ActiveMovie library: 1 Adjust DirectShow Filters at runtime: 1 Save General Settings: 1 SYSTEM INFO Processor Name: Intel(R) Core(TM) i5-4670K CPU @ 3.40GHz Operating System: Windows 7 Service Pack 1 (64 bit) Current user is Admin: YES Available Output Disc Space: 198 GB AviSynth is installed: YES (release 2.6.0) LAV Filters is installed: YES (release 0.65.0) ffdshow is installed: NO CODECS REPORT H.264/AVC: LAV Video Decoder {EE30215D-164F-4A92-A4EB-9D4C13390F9F} Xvid: LAV Video Decoder {EE30215D-164F-4A92-A4EB-9D4C13390F9F} DivX 4/5/6: LAV Video Decoder {EE30215D-164F-4A92-A4EB-9D4C13390F9F} Other MPG4: LAV Video Decoder {EE30215D-164F-4A92-A4EB-9D4C13390F9F} DV: LAV Video Decoder {EE30215D-164F-4A92-A4EB-9D4C13390F9F} MPEG1: LAV Video Decoder {EE30215D-164F-4A92-A4EB-9D4C13390F9F} MPEG2: LAV Video Decoder {EE30215D-164F-4A92-A4EB-9D4C13390F9F} MP2: LAV Audio Decoder {E8E73B6B-4CB3-44A4-BE99-4F7BCB96E491} MP3: LAV Audio Decoder {E8E73B6B-4CB3-44A4-BE99-4F7BCB96E491} AAC: LAV Audio Decoder {E8E73B6B-4CB3-44A4-BE99-4F7BCB96E491} AC3: LAV Audio Decoder {E8E73B6B-4CB3-44A4-BE99-4F7BCB96E491} <> <7/7/2015 11:03:36 AM> TITLE 1 SOURCE FILES Video: C:\Video\BR\BR.mkv Info: MPEG-2 Video - 4598 kbps - 720x480 - DAR 16:9 - 23.976 fps (CFR) - Progressive (2:3 Pulldown) - 1:56:40 hours - 209780 frames Audio 1: C:\Video\BR\BR.mkv Info: AC3 - 192 kbps - CBR - 2 ch - 48000 Hz - 1:56:40 hours (2002 ms delay) - EN Subs 1: C:\Video\BR\BR.mkv Info: VobSub (IDX) - EN [MediaInfoLib - v0.7.74] <> <7/7/2015 11:03:36 AM> AVISYNTH SCRIPT Import("C:\Program Files (x86)\AVStoDVD_282_NoInstall\Lib\A2DSource.avsi") Video = A2DVideoSource("C:\Video\BR\BR.mkv", CacheFolder="C:\Users\bill\AppData\Local\Temp", FrameRate=23.976, VFR=false) Audio = A2DAudioSource("C:\Video\BR\BR.mkv", CacheFolder="C:\Users\bill\AppData\Local\Temp") Video = Video.ConvertToYV12() #PullDown: using DGPulldown/HCenc to upsize FPS Audio = Audio.DelayAudio(2.002) AudioDub(Video, Audio) <> <7/7/2015 11:03:36 AM> START VIDEO ENCODING OPERATIONS Video Encoding Profile: HCenc VBR 2-pass Target Video FileSize: 4170.7 MB Encoding Parameters: -ini "C:\Users\bill\AppData\Local\Temp\BR_LAVcheck_BR_LAVcheck.HCenc.ini" HCenc ini file: *INFILE C:\Users\bill\AppData\Local\Temp\BR_LAVcheck_BR_LAVcheck_1.avs *AVSRELOAD *OUTFILE C:\Users\bill\Videos\BR_LAVcheck_BR_LAVcheck.m2v *LOGFILE C:\Users\bill\AppData\Local\Temp\BR_LAVcheck_BR_LAVcheck.HCenc.log *MAXBITRATE 9000 *BITRATE 4998 *PROFILE BEST *ASPECT 16:9 *PROGRESSIVE *TFF *PULLDOWN *BIAS 50 *DC_PREC 9 *MATRIX MPEG *AQ 2 *LUMGAIN 2 *SMP *PRIORITY IDLE *DBPATH C:\Users\bill\AppData\Local\Temp *WAIT 2 <> <7/7/2015 11:29:17 AM> END VIDEO ENCODING OPERATIONS Video Source Filter: A2DSource (DirectShowSource) Created File: C:\Users\bill\Videos\BR_LAVcheck_BR_LAVcheck.m2v (4172.5 MB) OUTPUT VIDEO INFO: MPEG-2 Video - 5000 kbps - 720x480 - DAR 16:9 - 23.976 fps - Progressive (2:3 Pulldown) - 1:56:40 hours - 209776 frames <> <7/7/2015 11:29:18 AM> DIRECTSHOW AUDIO MIXER OPERATIONS: No LAV Filters mixer ON/OFF adjustment required at runtime <> <7/7/2015 11:29:18 AM> START AUDIO ENCODING OPERATIONS (Track 1) Wavi+Aften Parameters: "C:\Users\bill\AppData\Local\Temp\BR_LAVcheck_BR_LAVcheck_1.avs" - | "C:\Program Files (x86)\AVStoDVD_282_NoInstall\Aften\aften.exe" -b 192 -pad 0 -dynrng 5 -bwfilter 0 - "C:\Users\bill\Videos\BR_LAVcheck_BR_LAVcheck_1.ac3" <> <7/7/2015 11:30:00 AM> END AUDIO ENCODING OPERATIONS (Track 1) Audio Source Filter: A2DSource (DirectShowSource) Created File: C:\Users\bill\Videos\BR_LAVcheck_BR_LAVcheck_1.ac3 (160.3 MB) OUTPUT AUDIO INFO: AC3 - 192 kbps - CBR - 2 ch - 48000 Hz - 1:56:42 hours (0 ms delay) <> <7/7/2015 11:30:00 AM> START SUBS EXTRACTING OPERATIONS (Track 1) MKVExtract Parameters: tracks "C:\Video\BR\BR.mkv" 2:"C:\Users\bill\AppData\Local\Temp\BR_LAVcheck_BR_LAVcheck.idx" <> <7/7/2015 11:30:14 AM> END SUBS EXTRACTING OPERATIONS (Track 1) Created File: C:\Users\bill\AppData\Local\Temp\BR_LAVcheck_BR_LAVcheck.idx (33.3 KB) <> <7/7/2015 11:30:14 AM> START SUBS ENCODING OPERATIONS (Track 1) IDX errors fixing routine applied (0 errors fixed). VSConv Parameters: -f sup -i "C:\Users\bill\AppData\Local\Temp\BR_LAVcheck_BR_LAVcheck.idx" -o "C:\Users\bill\Videos\BR_LAVcheck_BR_LAVcheck_1" -id 0 <> <7/7/2015 11:30:15 AM> END SUBS ENCODING OPERATIONS (Track 1) Created File: C:\Users\bill\Videos\BR_LAVcheck_BR_LAVcheck_1.sup (1.1 MB) <> <7/7/2015 11:30:15 AM> DVD CHAPTERS CREATION OPERATIONS Title 1 Input Chapters List: 4609 6844 10992 16594 19598 24280 33518 37017 41179 44611 53187 60644 62004 67087 70716 79610 82688 85987 88970 91045 97479 104555 109687 115415 118818 125501 127707 135049 139175 145339 147395 150118 152123 156844 161593 Title 1 Output Chapters List: 4609 6844 10992 16594 19598 24280 33518 37017 41179 44611 53187 60644 62004 67087 70716 79610 82688 85987 88970 91045 97479 104555 109687 115415 118818 125501 127707 135049 139175 145339 147395 150118 152123 156844 161593 Created File: C:\Users\bill\Videos\BR_LAVcheck_BR_LAVcheck_Chapters.txt (259 Byte) <> <7/7/2015 11:30:15 AM> START DVD MENU BUILDING OPERATIONS DVD Menu settings: Style: 0 Aspect Ratio: 1 Titles Format: 0 Template: Blue Rain Max Titles Page: 12 Enable Play All: 1 Force Play All: 0 Background Audio: 0 Max Thumbs Row: 4 Thumb Image Source: 0 Thumb Frame Position: 10% HL Frame Format: 0 HL Selection Color: 5 HL Play Color: 0 Menu Video BitRate: 6000 kbps Motion Menu Duration: 15 seconds Thumb Drop Shadow: 2 Play All Shadow: 2 Arrows Shadow: 0 <> <7/7/2015 11:30:17 AM> END DVD MENU BUILDING OPERATIONS Created File (Menu Page 1): C:\Users\bill\Videos\BR_LAVcheck_MenuPage1.bmp (1 MB) <> <7/7/2015 11:30:17 AM> START DVD AUTHORING OPERATIONS BatchMux Parameters: -arglist "C:\Users\bill\AppData\Local\Temp\BR_LAVcheck_BatchMux.ini" BatchMux ini file: -d "C:\Users\bill\Videos\BR_LAVcheck\VIDEO_TS" -mxp "C:\Users\bill\AppData\Local\Temp\BR_LAVcheck_MuxMan.mxp" -l "C:\Users\bill\AppData\Local\Temp\BR_LAVcheck_MuxMan.log" -muxman "C:\Program Files (x86)\AVStoDVD_282_NoInstall\MuxMan" -prio LOW -palette "C:\Users\bill\AppData\Local\Temp\BR_LAVcheck_Palette.txt" -v "C:\Users\bill\Videos\BR_LAVcheck_BR_LAVcheck.m2v" -vidmode LB -a1 "C:\Users\bill\Videos\BR_LAVcheck_BR_LAVcheck_1.ac3" -a1lang en -s1 "C:\Users\bill\Videos\BR_LAVcheck_BR_LAVcheck_1.sup" -s1lang en -s1ext 1 -cellfr "C:\Users\bill\Videos\BR_LAVcheck_BR_LAVcheck_Chapters.txt" -progfr "C:\Users\bill\Videos\BR_LAVcheck_BR_LAVcheck_Chapters.txt" -chapfr "C:\Users\bill\Videos\BR_LAVcheck_BR_LAVcheck_Chapters.txt" -SEG2v "C:\Users\bill\Videos\BR_LAVcheck_MenuPage1.bmp" -SEG2vidmode LB -SEG2s1 "C:\Users\bill\Videos\BR_LAVcheck_Menu.sst" -SEG2s1dmode WIDE_LB -SEG2hlmnu "C:\Users\bill\AppData\Local\Temp\BR_LAVcheck_MenuPage1_Buttons.mnu" -SEG2hlcsm "C:\Users\bill\AppData\Local\Temp\BR_LAVcheck_HighlightScheme.csm -hcn "C:\Users\bill\AppData\Local\Temp\BR_LAVcheck_BatchMux.hcn" <> <7/7/2015 11:33:29 AM> END DVD AUTHORING OPERATIONS Created Folder: C:\Users\bill\Videos\BR_LAVcheck (4426.1 MB) CHECK DVD SIZE DVD Folder (actual) Size: 4426.1 MB vs Assets Size: 4334.9 MB -> OK vs Estimated Size: 4450 MB -> 0.5% undersize <> <7/7/2015 11:33:30 AM> Log file created by AVStoDVD Release 2.8.2 <> |
7th July 2015, 22:09 | #2795 | Link |
Thanks for the log file...
Looks OK to me except for the delay for the audio track. How did you create the MKV? MakeMKV or MKVMerge? In my experience large delay values like yours appear when the source file has problems at the beginning. Does the file come from a TV capture or from a DVD recorder? Was it a transport stream originally? If the file was captured from DVB-S or DVB-T you should run it through ProjectX or PVAStrumento to convert it from TS to PS. And what happens if you just ignore the delay (specify to not correct the delay in the audio settings) ? Maybe you should cut out a short sample of your source (use DGIndex) and upload it somewhere... Cheers manolito |
8th July 2015, 03:03 | #2797 | Link |
_MrC_ and manolito,
Thanks for the suggestions; I will try all of them. Manolito - I have downloaded DSS2 mod + LAVFilters.zip. I already have LAV Filters installed. How do you "install" DSS2 mod ? The BR title is from a DVD I purchased several years ago, and I used MakeMKV on it. I'm still working on the clip. Thanks for your help. adam933 |
8th July 2015, 09:12 | #2798 | Link | ||
1. All you need from the DSS2Mod archive is the file "avss.dll" (or avss_26.dll for AviSynth 2.6). Copy the file (only one of them) into your "AviSynth\plugins" folder. 2. Load "A2Dsource.avsi" from the A2D\lib folder into notepad and replace the DirectShowSource part (starts at line 29) with the following: Quote:
Since you have LAVFilters already installed you can disregard the LAV which comes together with DSS2Mod. (Basically DSS2Mod provides the possibility to use LAVFilters without installing them, but I have never used it this way). Let me know how it works for you... Cheers manolito |
9th July 2015, 18:34 | #2799 | Link | |
11th July 2015, 18:55 | #2800 | Link |
AVStoDVD Dev
AVStoDVD release 2.8.3 Alpha 150711 is out.
Change log: - Some bugs fixed - Added 'Open Project Log file' option in main window menu 'View'/'Operations Log' - Added 'Video FrameRated Mode' option in main window menu 'Title'/'Edit Source Title Info' - Added 'A2D Projects Path' option in 'Preferences'/'Paths' - Added 'fpsnum' and 'fpsden' flags to FFmpegSource calls when source video is not CFR - Added '-readtoeof 1' command to Aften CL when wave input is potentially over 4 GB - Added '/FILESYSTEM "ISO9660 + UDF" /UDFREVISION "1.02"' switches to ImgBurn command line - Improved handling of VFR sources - Updated A2DSource.avsi to handle FrameRateNum and FrameRateDen as input parameters to A2DVideoSource() - Updated AviSynth warning at startup if currently installed release is below 2.6.0 - AVSMeter updated to release 2.0.6 (changed ConUseSTDOUT=1 and TimeLimit=3600 in AVSMeter.ini) - Improved log activity Bye |
