Old 27th January 2016, 17:14   #35661  |  Link
madshi
Originally Posted by Backflash View Post
Ran build 2 on both x64/x86, 70 times on different videos, from sd to 720p 10bit - couldn't crash it.
That's quite interesting. Practically this means that probably in x64 the GPU driver crashes when madVR tries to create multiple DirectCompute shaders at the same time in different threads. This looks like a GPU driver bug because in theory D3D11 should be thread safe.
So I'll have to redesign the DirectCompute stuff to be done in one thread, only. Very sad, but not a big problem.
Edit: Which GPU and OS are you using?
Old 27th January 2016, 18:12   #35662  |  Link
Backflash
R9 390(i7 2600/8Gb) Windows 10 Pro 1511(10586.63) x64, Crimson 16.1
Backflash is offline   Reply With Quote
Old 27th January 2016, 23:56   #35663  |  Link
BetA13
cosmic entity
BetA13's Avatar
Thanks. No need to test builds 1 and 2. How reliable is the "fail/works" for you? Are you 100% sure 5 is fine and 4 has a problem? Or is there a bit of randomness involved? Just asking, to be safe.
hy there,
yes, "5" is working everytime i think. i didnt had any odd behavior with it. testet most settings with it and watched about 3 movies..
resizing works, fullscreen switching works, no drops, no stutter when i move teh mouse, video is in sync and normal speed, shaders work, just like with 0.89.19
Sidenote:
only thing i noticed wich is different (i think, i didnt see that change before) is that in windowed mode, videos are played with 48fps and in Fullscreen (exclusive) mode its 60fps.
Wasnt it 60fps in windowed and fullscreen before? Of course only if you have 60hz ??
Or was this changed? Anyway, im totaly fine with that because it eats less power from my gpu in 48fps (windowed) in fullscreen i prefer teh 60fps like it is...
"4" and downwards allways produce the error i have been struggling with in the start.
so, im 99% shure that 5 is the winner for me...
greetings
BetA13 is offline   Reply With Quote
Old 28th January 2016, 00:06   #35664  |  Link
daglax
I dont get it. If i start any .mkv-movie (SBS-format) the madvr on screen display never shows 4:2:0 (3D), it's always 4:2:0.
I installed the latest LAV Filters and activated the filters in MPC's external filter section, but still no sign of 3D. Why is LAV not decoding in 3D?
daglax is offline   Reply With Quote
Old 28th January 2016, 00:09   #35665  |  Link
sneaker_ger
At the moment the new 3D features of LAV and madVR are for MVC-in-MKV only. There is no special handling of SBS files.
Old 28th January 2016, 00:28   #35666  |  Link
daglax
Lol that makes sense. Didn't find any information about that the last couple of pages or maybe i didn't understand.
Thank you for clarification.
Is SBS- Playback planned eventually?
Old 28th January 2016, 01:18   #35667  |  Link
scollaco
Does someone have an example code of how they are using profiles for including 3d now? I'm not very code savvy and would appreciate the help.
Also what settings are people using for 3d as my scaling algorithms etc...seem to be too much to play 3D
scollaco is offline   Reply With Quote
Old 28th January 2016, 01:24   #35668  |  Link
madVR can already do that.
Originally Posted by MSL_DK View Post
Thank you for looking at it.
While we're at it, can I get you to test properties> the native display bitdepth is> 10 bit (or higher) and Rendering> General settings> use Direct3D 11 for presentation> present a frame for every VSync
and tell me the result of your monitor behavior?
My screen seems to switch modes and render and present queue queue is not filled out. (1-3 / 14 and 1-3 / 14)
i don't have the card at the Tv anymore.
but don't waste your time on 10 bit and this screen.
Old 28th January 2016, 02:07   #35669  |  Link
derpycat
Sorry I'm a noob. Does this mean we can't play 3d Bluray yet?
derpycat is offline   Reply With Quote
Old 28th January 2016, 02:17   #35670  |  Link
SamuriHL
SamuriHL's Avatar
Correct. Right now it only works with MKV's made with MakeMKV. At some point, once it matures a bit and some bugs are worked out, they'll expand support for blu-ray itself, albeit with some limitations. We'll get there, but, right now at this time, we're not there yet.
Old 28th January 2016, 02:38   #35671  |  Link
derpycat
Thanks, I guess it's easy enough to make my own MKVs. Was wondering why I couldn't get 3d working
Old 28th January 2016, 03:17   #35672  |  Link
derpycat
Edit: silly question
Old 28th January 2016, 19:07   #35673  |  Link
madshi
Sidenote:
Can you please try this build:
http://madshi.net/madVRBetA13.rar
Does it work? If not, please create a debug log for me with this build (don't attach to this forum, upload it somewhere else and link here), which shows the "too fast playback". Also, please compare which refresh rates madVR lists in both windowed and fullscreen mode, with this build compared to v0.89.19. I suppose if you get the "too fast playback", probably the refresh rate isn't shown correctly?
Old 28th January 2016, 19:37   #35674  |  Link
MSL_DK
Could be running out of RAM
Yes, it is true in my case.
MSL_DK is offline   Reply With Quote
Old 28th January 2016, 20:30   #35675  |  Link
BetA13
cosmic entity
BetA13's Avatar
hy there,
nope this build also has the problem occuring..
umm, sorry for teh noobish question, but how do i do an debug report? i did try to look for an key combo but couldnt find one.
What i did do is compared teh OSD and refresh rate from windowed to fullscreen and from 0.89.19 to your Beta13 build..
And yes, you are correct, theres is something wrong with the "hz"
i made some screenshots:
madVRBetA13 build:
windowed mode:
Fullscreen mode:
0.89.19 Build (working Build):
windowed mode:
Fullscreen Mode:
Got the error report also, its quite big lol..
Steps i did:
Started debug log - started movie in windowed mode - after 3-5 sek. i changed to fullscreen mode - 2 sek. later i changed to windowed and quit the player, enden debug mode..
Link to Log:
http://filehorst.de/d/bAuhGbwH
i hope this will help you a bit...
greetings
Old 28th January 2016, 20:46   #35676  |  Link
MSL_DK
In the madVR folder run the debug.bat Can't remember the exact name of the file.
Then play a movie. On the desktop you will find the debug result, a txt file.
Old 28th January 2016, 21:20   #35677  |  Link
BetA13
cosmic entity
BetA13's Avatar
ok, found teh bat. started it. left it open (teh cmd window) and started teh movie..etc.
now, wheres teh LOG?
i cant find it in the madvr folder or in c:/
Old 28th January 2016, 21:32   #35678  |  Link
MSL_DK
Right click the .bat run as admin, play a movie. After that, run the .bat again for leaving debug-mode
Old 28th January 2016, 21:37   #35679  |  Link
BetA13
cosmic entity
BetA13's Avatar
right worked as intended. debug mode was started, video was played by me, video was stopped player exited and run the bat again to release debugmode again.
i feel very noobish about now since i still cant find a file .. theres no new file made , not in the madvr folder or c:
im pretty confused now haha
aha, you edited your comment, its on the desktop.. THANK you a lot mate.. haha
Old 28th January 2016, 21:47   #35680  |  Link
apgood
It should be on your desktop
apgood is offline   Reply With Quote
