9th July 2012, 10:27 | #101 | Link |
ozok
TX264 can't convert file (see link). It stops with error. http://narod.ru/disk/55770809001.23b...bd/02.avi.html p.s. Sorry for big size. |
11th July 2012, 13:02 | #107 | Link |
TEncoder, TX264, TAC
I am trying to upload new version to SourceForge but there seems to be a problem. Meanwhile you can download latest version from here.
I'll update topic and add what's new when i finish uploading to SourceForge. |
11th July 2012, 21:12 | #108 | Link | |
Update
13th July 2012, 02:52 | #109 | Link |
does any body knows the way this works....
general tab: how does checkbox size works??? simple options frame: combine with profiles... does the "edit" options override the profile, preset, and tune?.... -same as source option does not disable the output path textbox and open button -it will be easier for the user to increase or decrease the bitrate by 8 or 16 -same as source option checked throws output folder does not exist error message.. i really like the minimal gui and its first try... i will comment later... |
13th July 2012, 11:28 | #110 | Link | |||
It will calculate necessary bitrate to get that size in mb using audio size etc. Ofc that is not that precise at the moment.
Are you sure directory in the "Output Folder" textbox exists? Because TX264 checks if "Output Folder" directory exists, not the source's directory which should already exists as we are encoding a file from that directory. |
13th July 2012, 13:07 | #111 | Link |
@ozok
Hi, thanks for the updates and fixes. I have checked the newer TX264 0.8.1.2063, and here are my findings: - it seems that TX264 wouldn't copy the embedded fonts from videos in MKV container into the encoded/outputted video; - it seems that TX264 has a problem with videos with variable frame-rates and/or audio (in this case AAC-LC) with variable bit-rates. Result is that no video will be outputted because of an error; -forcing constant fps by checking the setting under the general tab results in an encoded video that's out of sync with the audio; this out-of-sync issue also happens when trying to force a certain frame-rate via the custom options in TX264 for x264.exe (e.g. --fps 25.00); - using ultra fast preset (without making use of or combining it with "advanced options") will result in outputted/encoded videos with baseline profile, though don't know if it's a bug or if it's intentional. Thanks in advance! Last edited by TC-man; 13th July 2012 at 13:29. |
13th July 2012, 13:37 | #112 | Link | |||
That may depend on many things. Try specifying "Profile" yourself. |
13th July 2012, 16:38 | #113 | Link | ||
another one i noticed yesterday... first resize the movie and then it crops... i guess it will crop first and then resize... and finally about the size box, i check it and set size to 120 but bitrate spiner was at 512 kbps, but the log shows that bit rate used was 512 and not hit que desired size... |
13th July 2012, 17:01 | #114 | Link |
@fantasmanegro you are right on both accounts, it should not check output folder if same as source is selected and cropping should be done before resizing.
size options may not produce desired file size, i said that earlier. Try specifying "Tolerance" value. Doing two pass may help, too. |
13th July 2012, 17:29 | #116 | Link |
yup i know that but my point is that it uses the bitrate set before and the app is not calculating the new bitrate using estaimated file size...
and about the increments of 8 or 16 is because the byte (8 bits)... i guess the word is multple of 8 (8 , 16, 32) and for crop is better using multiple of 8 or 16... even for resize... that is just my point of view... whatever you decide will be ok... |
14th July 2012, 07:47 | #117 | Link |
@WasF not at the moment but i'll surely add it.
@fantasmanegro it uses bitrate calculated. If you are talking about bitrate value you see in "Summary" tab, it shows bitrate you specified so it is wrong for now. Maybe you should send me log. |
16th July 2012, 05:53 | #118 | Link |
@Ozok
Thanks for adding the ability to resize the program, it helps a lot Also. any chance that we could see a queue option so we could add different settings to different files instead of having to wait for each single encode to finish before changing settings and starting another encode.....for example queue file one using crf encoding and queue file 2 using 2pass encoding |
19th July 2012, 17:36 | #120 | Link | |
Update:
faac, mkv, mp4, neroaacenc, x264 |
