10th August 2019, 13:52 | #23561 | Link |
Alternatively, you can use a tool like DSF/MFT Viewer that conveniently lists all the filters installed and lets you unregister them (or register new ones) with a button: https://bluesky23.yukishigure.com/en/DsfMftViewer.html
TS Doctor is one app that forcefully reinstalls Haali Splitter with each update, and the uninstaller in the Start Menu only uninstalls the 64-bit version and I have to unregister the 32-bit one manually.
10th August 2019, 14:22 | #23562 | Link |
Thanks guys for the ideas will try it once I finish work.
Can anyone of you have idea how come this even happened? Like I didn't change nothing in my filter neither settings that's why I'm curious why out of nowhere haali is used instead of LAV |
10th August 2019, 15:22 | #23563 | Link | ||
NoHaaliInstall.reg Quote:
10th August 2019, 15:53 | #23564 | Link |
Source filters can set themselves as preferred for specific file extensions. This overrides filter merits, and also the preferred external filter list in MPC-HC.
Haali became preferred because your installed that last. Re-installing LAVFilters would make LAV default again. If you need both installed, then you can use Codec Tweak Tool to change the preferred splitter. |
10th August 2019, 15:58 | #23565 | Link |
The thing is I didn't install haali codecs so either they came with something else or I really don't know what happened, cause I always used only LAV + madvr + mpc-hc and nothing else cause everythins was working perfectly fine thats why I'm so confused how come those haali got "activated" probably I wouldn't notice but I wanted to re-watch a movie in 4k and I had no video and I was like yyyy I'm watched all my movies and everything was fine now nothing has video and the only thing what I notice is different to what it was its the Haali splitter in filters when I checked in mpc hc
10th August 2019, 16:41 | #23567 | Link |
Ok i think i've sorted it : first thing what i did was to add haali in external filter in mpc-hc then block it and voila everything started working how it should, so then i downloaded DSF/MFT Viewer and unregistered haali from my system.
So now i see all LAV filter are in use the only thing what im not sure was there is " FileSource ( Async ) " but when i click on it its just showd PinInfo so i think this is ok nah? |
14th August 2019, 16:01 | #23570 | Link |
It's a pity as minimum quasi-interlaced h265 (SD and HD) still not supported well.
So I have to write instruction to use ffdshow raw video filter with Avisynth script between LAV Video Decoder and Renderer (i.e. EVR) for that mostly from satellites streams. Last edited by VictorLS; 14th August 2019 at 16:11. |
15th August 2019, 15:11 | #23572 | Link |
This video crashes LAV Splitter:
https://mega.nz/#!1cUDnIwR!lKzYVG5Uo...A-nY3oJuzB_vpE |
16th August 2019, 12:10 | #23575 | Link |
Alright, this was before my time...
Did a few more tests with this file, looks like most source filters do not get along with the OGM container. In addition to the LAV splitter FFMS2 and LSMASH also refuse to decode this file. Trying to open it with Handbrake does not give me any audio tracks. Using FFmpeg to repack the file also did not work. Remuxing to MKV did not work at all, remuxing to MP4 produced a file without audio. What did work was playing the file with VLC, and using MKVToolnix to repack it to MKV also worked (with some warnings about the Japanese chapters). Cheers manolito Last edited by manolito; 16th August 2019 at 12:45. |
16th August 2019, 12:48 | #23577 | Link |
Of course he knows how to fix it, but I am not so sure if it is really a bug in LAV Splitter. Since most other source filters also refuse to decode this clip it might well be an issue with this specific file.
