19th January 2020, 09:58 | #281 | Link | |
Here described progress is same as while using BDEdit either it is impossible immediately from tsMuxer create Bluray ISO. Issue #126 is old already 10 days and yet no work Test 3D-plane - keep on don't work right. Will added and support for Dolby Atmos without core used in the MKV? Always test with latest available version. Thank for answer Staina |
19th January 2020, 11:14 | #282 | Link |
PgcEdit daemon
What BD3D do you use for your tests ?
19th January 2020, 23:05 | #284 | Link | |
Lots of code to write. Maybe there will be some good wills to do it, but it is above my c++ and Qt5 abilities. Last edited by a5180007; 19th January 2020 at 23:07. |
20th January 2020, 06:02 | #285 | Link | |
20th January 2020, 09:30 | #286 | Link | |
LOG from BD3D2MK3D Streams of 00100.mpls, 1:36:05, 24 chapters, 00049.ssif : Video : Und AVC, 1080p, 23.976 fps, right-eye Video : Und MVC, 1080p, 23.976 fps, left-eye (32 3D-Planes) Audio : Eng DTS-HD-Master, Multi-channel, 48 Khz Audio : Ces AC3, Multi-channel, 48 Khz Audio : Hun AC3, Multi-channel, 48 Khz Audio : Pol AC3, Multi-channel, 48 Khz Audio : Rus AC3, Multi-channel, 48 Khz Subtitle: Eng PGS, 3D-plane: 1 Subtitle: Ara PGS, 3D-plane: 2 Subtitle: Ces PGS, 3D-plane: 3 Subtitle: Dan PGS, 3D-plane: 4 Subtitle: Est PGS, 3D-plane: 5 Subtitle: Fin PGS, 3D-plane: 6 Subtitle: Heb PGS, 3D-plane: 7 Subtitle: Hun PGS, 3D-plane: 8 Subtitle: Isl PGS, 3D-plane: 9 Subtitle: Nor PGS, 3D-plane: 10 Subtitle: Pol PGS, 3D-plane: 11 Subtitle: Por PGS, 3D-plane: 12 Subtitle: Ron PGS, 3D-plane: 12 Subtitle: Rus PGS, 3D-plane: 13 Subtitle: Swe PGS, 3D-plane: 14 Subtitle: Ces PGS, 3D-plane: 3 Subtitle: Hun PGS, 3D-plane: 8 Subtitle: Pol PGS, 3D-plane: 11 Subtitle: Rus PGS, 3D-plane: 13 LOG from tsMuxeR V_MPEG4/ISO/MVC, "H:\BDMV\PLAYLIST\00100.mpls", insertSEI, contSPS, track=4114 V_MPEG4/ISO/AVC, "H:\BDMV\PLAYLIST\00100.mpls", insertSEI, contSPS, track=4113 A_DTS, "H:\BDMV\PLAYLIST\00100.mpls", track=4352, lang=eng A_AC3, "H:\BDMV\PLAYLIST\00100.mpls", track=4353, lang=ces A_AC3, "H:\BDMV\PLAYLIST\00100.mpls", track=4354, lang=hun A_AC3, "H:\BDMV\PLAYLIST\00100.mpls", track=4355, lang=pol A_AC3, "H:\BDMV\PLAYLIST\00100.mpls", track=4356, lang=rus S_HDMV/PGS, "H:\BDMV\PLAYLIST\00100.mpls", fps=23.976, 3d-plane=1, track=4608, lang=eng S_HDMV/PGS, "H:\BDMV\PLAYLIST\00100.mpls", fps=23.976, 3d-plane=2, track=4609, lang=ces S_HDMV/PGS, "H:\BDMV\PLAYLIST\00100.mpls", fps=23.976, 3d-plane=3, track=4610, lang=ara S_HDMV/PGS, "H:\BDMV\PLAYLIST\00100.mpls", fps=23.976, 3d-plane=4, track=4611, lang=dan S_HDMV/PGS, "H:\BDMV\PLAYLIST\00100.mpls", fps=23.976, 3d-plane=5, track=4612, lang=est S_HDMV/PGS, "H:\BDMV\PLAYLIST\00100.mpls", fps=23.976, 3d-plane=6, track=4613, lang=fin S_HDMV/PGS, "H:\BDMV\PLAYLIST\00100.mpls", fps=23.976, 3d-plane=7, track=4614, lang=heb S_HDMV/PGS, "H:\BDMV\PLAYLIST\00100.mpls", fps=23.976, 3d-plane=8, track=4615, lang=hun S_HDMV/PGS, "H:\BDMV\PLAYLIST\00100.mpls", fps=23.976, 3d-plane=9, track=4616, lang=isl S_HDMV/PGS, "H:\BDMV\PLAYLIST\00100.mpls", fps=23.976, 3d-plane=10, track=4617, lang=nor S_HDMV/PGS, "H:\BDMV\PLAYLIST\00100.mpls", fps=23.976, 3d-plane=11, track=4618, lang=pol S_HDMV/PGS, "H:\BDMV\PLAYLIST\00100.mpls", fps=23.976, 3d-plane=12, track=4619, lang=por S_HDMV/PGS, "H:\BDMV\PLAYLIST\00100.mpls", fps=23.976, 3d-plane=12, track=4620, lang=ron S_HDMV/PGS, "H:\BDMV\PLAYLIST\00100.mpls", fps=23.976, 3d-plane=13, track=4621, lang=rus S_HDMV/PGS, "H:\BDMV\PLAYLIST\00100.mpls", fps=23.976, 3d-plane=14, track=4622, lang=swe S_HDMV/PGS, "H:\BDMV\PLAYLIST\00100.mpls", fps=23.976, 3d-plane=3, track=4623, lang=ces S_HDMV/PGS, "H:\BDMV\PLAYLIST\00100.mpls", fps=23.976, 3d-plane=8, track=4624, lang=hun S_HDMV/PGS, "H:\BDMV\PLAYLIST\00100.mpls", fps=23.976, 3d-plane=11, track=4625, lang=pol S_HDMV/PGS, "H:\BDMV\PLAYLIST\00100.mpls", fps=23.976, 3d-plane=13, track=4626, lang=rus |
20th January 2020, 22:27 | #287 | Link |
@staina thanks for the details, I have reproduced the bug with Hobbit Smaug and this patch should definitely correct it.
Edit: you can test the build on my fork https://github.com/jcdr428/tsMuxer/actions Last edited by a5180007; 21st January 2020 at 07:26. |
21st January 2020, 14:42 | #288 | Link | |
22nd January 2020, 11:01 | #290 | Link | |
PgcEdit daemon
And the "phantom streams" (present in the M2TS but unreferenced in the MPLS) are now clearly identified as such with "(PID not in MPLS)" instead of the confusing "3D-Plane: zero". Great work ! Thanks !
22nd January 2020, 20:53 | #291 | Link | |
I will push the patch when it is confirmed it is working well. |
22nd January 2020, 21:09 | #292 | Link | |
Awesome work, thank you ! |
23rd January 2020, 18:21 | #294 | Link |
Thanks very much a5180007 for this latest nightly...
On my ancient computer (P3 without SSE2, WinXP) the last working tsMuxeR version used to be 2.6.12 from 2014. Your builds are different. The GUI does not work (as expected), but the CLI executable works like a charm. And it runs beautifully under the old GUI, I have not found any issues so far. Thanks again manolito |
23rd January 2020, 18:30 | #295 | Link | |
https://www.videohelp.com/software/tsMuxeR Last edited by FilipeAmadeuO; 23rd January 2020 at 19:07. |
23rd January 2020, 20:32 | #296 | Link | |
23rd January 2020, 20:40 | #297 | Link | |
Unfortunately, I'm afraid I don't have good news for you regarding the GUI : Qt has required SSE2 support in all builds since version 5.3.0. As for the CLI, it's a consequence of building the Windows versions with MinGW, which uses legacy x87 instructions by default. MSVC, on the other hand, has enabled SSE2 by default since Visual Studio 2012 or so. Roman's own tsMuxeR builds were most possibly made with MSVC. |
24th January 2020, 08:22 | #298 | Link |
Could someone check please?, TSMuxer hide subtitles when I try to replace the spa (latin) with spa (spain). For instance:
Source: Code:
PLAYLIST REPORT: Name: 00700.MPLS Length: 2:13:04.976 (h:m:s.ms) Size: 55,198,617,600 bytes Total Bitrate: 55.30 Mbps VIDEO: Codec Bitrate Description ----- ------- ----------- MPEG-H HEVC Video 46163 kbps 2160p / 23.976 fps / 16:9 / Main 10 @ Level 5.1 @ High / 10 bits / HDR10 / BT.2020 AUDIO: Codec Language Bitrate Description ----- -------- ------- ----------- DTS-HD Master Audio English 4545 kbps 7.1 / 48 kHz / 4545 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit) Dolby Digital Audio English 448 kbps 5.1 / 48 kHz / 448 kbps / DN -31dB Dolby Digital Audio Spanish 448 kbps 5.1 / 48 kHz / 448 kbps / DN -31dB Dolby Digital Audio French 448 kbps 5.1 / 48 kHz / 448 kbps / DN -31dB Dolby Digital Audio English 224 kbps 2.0 / 48 kHz / 224 kbps / DN -31dB SUBTITLES: Codec Language Bitrate Description ----- -------- ------- ----------- Presentation Graphics English 53.456 kbps Presentation Graphics Spanish 38.371 kbps Presentation Graphics French 41.440 kbps Presentation Graphics English 81.546 kbps Presentation Graphics Spanish 71.088 kbps Presentation Graphics French 76.848 kbps Code:
Disc Title: XXXXXXXX Disc Label:XXXXXXXXXXXX Disc Size: 57,680,873,663 bytes Protection: AACS2 Playlist: 00800.MPLS Size: 0 bytes Length: 2:13:04.976 Total Bitrate: 0.00 Mbps Video: MPEG-H HEVC Video / 0 kbps / 2160p / 23.976 fps / 16:9 / Main 10 @ Level 5.1 @ High / 10 bits / HDR10 / BT.2020 Audio: English / DTS-HD Master Audio / 7.1 / 48 kHz / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit) Audio: English / Dolby Digital Audio / 5.1 / 48 kHz / 448 kbps / DN -31dB Audio: Spanish / DTS Audio / 5.1 / 48 kHz / 768 kbps / 24-bit Audio: French / Dolby Digital Audio / 5.1 / 48 kHz / 448 kbps / DN -31dB Audio: English / Dolby Digital Audio / 2.0 / 48 kHz / 224 kbps / DN -31dB * Subtitle: English / 0.000 kbps * Subtitle: Spanish / 0.000 kbps * Subtitle: French / 0.000 kbps * Subtitle: English / 0.000 kbps * Subtitle: French / 0.000 kbps * Subtitle: Spanish / 0.000 kbps Am I doing something wrong? Regards |
24th January 2020, 16:14 | #299 | Link |
Quick status that is now old news but I’ve ripped and remuxed 4 movie only from UHD disks with Dolby Vision. They all play with audio video and subtitles in sync for at least 10-30 minutes that I watched.
Don’t have a DV player or TV so can’t comment on that but it’s is in the stream. Fantastic! |
24th January 2020, 18:05 | #300 | Link | |
SuperVirus
Yes, you can be sure they were made with MSVC, not with MinGW-w64&&MSYS. The original source-code was messy as Hell, but at least it didn't require a posix-threaded compiler without a very-good reason. Last edited by filler56789; 24th January 2020 at 18:11. Reason: wrong link removed |
