Old 29th May 2022, 09:55   #1261  |  Link
staina
Why tsMuxer at addition DTS-HD MA 7.1 stream and set delay on any value to this value in resulting ISO file add 21ms? For example delay set at -40ms is in results in ISO file -19ms. Set delay AC3 stream and THD stream with not change.
staina is offline   Reply With Quote
Old 14th June 2022, 16:22   #1262  |  Link
a5180007
I can't reproduce the bug. Eg I've downloaded https://www.demolandia.net/downloads.html?id=83491561 , applied the following meta
MUXOPT --no-pcr-on-video-pid --new-audio-pes --hdmv-descriptors --blu-ray --vbr  --auto-chapters=5 --vbv-len=500
V_MPEG4/ISO/AVC, "C:\Users\XXX\Documents\Softwares\tsMuxer\dts-living-world-of-audio-v2-short-lossless-(www.demolandia.net).mkv", track=1, lang=eng
A_DTS, "C:\Users\XXX\Documents\Softwares\tsMuxer\dts-living-world-of-audio-v2-short-lossless-(www.demolandia.net).mkv", timeshift=-40ms, track=2, lang=eng
and the "Delay relative to video" reported by MediaInfo is -40ms as it should.
a5180007 is offline   Reply With Quote
Old 30th June 2022, 21:16   #1263  |  Link
gonca
The latest nightly change
As there is a single transport stream in tsMuxer muxes and in Blurays, the transport_stream_id does not really matter. However, all blurays I've seen have transport_stream_id = 0 so applying the same makes comparisons easier.
actually fixed an issue I had with software media players and hardware media players while using tsMuxeR created structures.
Thank you
EDIT
Seems it only fixes the issue sometimes
Still
Thank you
Old 1st July 2022, 06:42   #1264  |  Link
oniiz86
Thank you
EDIT
Still
Thank you
@gonca I was just curious what exactly was the specific issue you were experiencing & now seems partially fixed with the latest nightly build?
Have you identified & reported the problem over here? https://github.com/justdan96/tsMuxer/issues
oniiz86 is offline   Reply With Quote
Old 1st July 2022, 11:23   #1265  |  Link
gonca
The issue was menu playback.
Menus created by BD_RB
Old 1st July 2022, 23:58   #1266  |  Link
a5180007
@gonca the Bluray standard states "transport_stream_id: This field has no meaning in the HDMV TS and may take any value". So not sure the commit had an effect, it might as well come from the two other commits related to the countinuity counters.
Old 2nd July 2022, 01:34   #1267  |  Link
gonca
I am getting a feeling that it was just a coincidence.
It seems to be just one of those things.
With no menus the results play perfectly every time.
Old 2nd July 2022, 10:43   #1268  |  Link
a5180007
@gonca yes the sum of those small corrections sure make a difference.
Maybe you can open an issue and describe the problem with the menus in details.
Old 2nd July 2022, 15:07   #1269  |  Link
gonca
Before I make you chase a rabbit down the hole
A video, audio, sup and chapter remux work well every time
The issue is with the menus created by BD_RB
If I burn the folder to disc it plays fine on my Sony.
If I open the folder structure with PowerDVD it plays fine
If I open the folder with J River Media Center the menu is non functional
If I open the folder in Zidoo 4K pro the menu is non functional
I am not sure if the problem is in tsMuxeR, BD_RB or its just one of those things
EDIT
All 4 play fine with the menus in commercial discs
Old 22nd July 2022, 18:39   #1270  |  Link
Hellboy.
tsMuxer have a settings file saved somewhere?
Hellboy. is offline   Reply With Quote
Old 23rd July 2022, 09:32   #1271  |  Link
a5180007
@Hellboy. in the General tab, under "Default Output Folder" you have the option to either "use the latest output folder name", or "place output folder to a input folder".
Old 28th July 2022, 01:07   #1272  |  Link
outgoing
I am finding, regardless of the version I have tested many and it always causes the same bug, that tsMuxer (windows) pixelates the image for a second or two when I do a BD folder or m2ts mux (only movie) or any other combination without adding or removing any track from my original bluray. My original bluray is correct, there's no glitch, it's a 90,9 GB UHD, The Message. The film has a running time of 02:58:18 and the pixelation always occurs in the same sequence, 01:01:16.
Attached is an sample of the pixelation.
https://mega.nz/file/2T52QZ4Y#wkjxpm...gkoL0fyegLO8-0
Edited: ok, it doesn't matter which program is used, it seems that this error is exactly the same regardless of the program used to reauthorise. A buddy of mine has done a test with Scenarist and got the same error. Really odd what could be the cause of this.
outgoing is offline   Reply With Quote
Old 29th July 2022, 14:09   #1273  |  Link
ocean
Hi outgoing, the original disk has no problem at 1:01:16 minutes.
Doesn't the copy obtained, once the protections have been removed, have this defect?
I ask you because it could be a protection not completely removed.
ocean is offline   Reply With Quote
Old 29th July 2022, 22:30   #1274  |  Link
outgoing
Hi ocean, not at all, the original is correct, there is no error throughout the whole footage, so it is strange that different software always produce the same error at the same point in the film. It could be a correct possibility, but in the master there is no such error, so I think it is not due to the protection not being fully unlocked. But I don't rule it out either and it is perhaps the only possible cause in this.
Old 1st August 2022, 22:16   #1275  |  Link
a5180007
@outgoing could you post the same excerpt from the original m2ts (e.g. cut with an Hex editor).
Old 2nd August 2022, 18:30   #1276  |  Link
outgoing
Sorry, there is no way, it always produces that error in any attempt to cut that segment, I have tried doing demux, iso folder... and it always keeps popping up. If I dump the image to the pc with AnydVD there is also a moment where in certain sectors it throws an error even if I end up dumping it all. Then when I view it, the error is always there.
It has nothing to do with tsmuxer, more than likely the protection is not completely broken, I guess.
Old 2nd August 2022, 21:05   #1277  |  Link
SeeMoreDigital
Life's clearer in 4K UHD
SeeMoreDigital's Avatar
Probably a b0rked rip. Try ripping the disc again!
Old 9th August 2022, 21:54   #1278  |  Link
spotter
does txmuxer not respect mpls in/out marks when muxing an mpls to a ts file?
I have a playlist on a bluray that has "junk" data in the file (color bars) that are not played by a bluray player. I'm trying to remux it to mkv, but both mkvtoolnix, eac3to and makemkv have issues with it. I figured tsmuxer should be able to mux it to a ts cutting out the "crap" and then I could deal with it from there. Except it doesn't.
in tsmuxergui it shows the correct length (14:44 about). but the ts that is created when played with vlc is 15:03 (or 04). i.e. the color bars and the like are included when they shouldn't be. Am I doing something stupid? I figure it should be easy to get a ts file that has all the seamless branching combined into a single ts file with proper in/out points from the file, but I can't seem to figure it out. help?
Edit: in addition, in this case the mpls has 2 m2ts file, the first has no audio and the second does (lpcm). if I load the second m2ts by itself, tsmuxer sees the video and audio tracks. But if I load the mpls file, it only lists the video track. This is the same problem that mkvtoolnix had.
spotter is offline   Reply With Quote
Old 13th August 2022, 12:03   #1279  |  Link
a5180007
@spotter please open an issue on github.
Old 14th August 2022, 08:48   #1280  |  Link
spotter
ok, 2 issues added.
