4th January 2019, 08:27 | #181 | Link | |
Helenium(Easter)
From vapoursynth.com/doc/pythonreference.html#get_core
Just use vs.core instead of vs.get_core() (also simpler). Alternatively, you can use "from vapoursynth import core".
Monochrome Anomaly Last edited by Wolfberry; 4th January 2019 at 08:30. |
4th January 2019, 10:21 | #182 | Link |
Thx, I updated it in my post. One line less now :-)
4th January 2019, 10:27 | #183 | Link | |
Pig on the wing
This one is something that could provide a nice enhancement for VS-based optimization compared to SSIM: http://forum.doom9.org/showthread.php?t=175862.
4th January 2019, 16:14 | #184 | Link |
Based on some tests I guess prefiltering is a gimmick lol, aside so many filtering conventions sticked to our brains for so long (like blocksize 16 for 1080p). Thanks for the tool it takes some of the voodoo-guessing out of the equation. I think implementing VMAF is worth here, after reading the Netflix VMAF article a few weeks ago it seemed that SSIM did some bad assumptions, in my case contrasharpening was defaulting to 0 or false which in my opinion wasn't making justice to what I observed. That or if your port it I might start using VapourSynth occasionally for VMAF and BM3D, I just don't like how it requires you to write more, and script readability. Also something for x264 like SSIM Plus would be cool if someone knows about a free open source alternative.
5th January 2019, 01:09 | #185 | Link |
Thanks @ChaosKing and @StainlessS, I have now read the Python tutorial, the official VapourSynth site and ChaosKing's FATPACK thread. I found a SSIM plugin for VapourSynth as well.
Is there a plugin for measuring runtime (preferably per frame)? I suppose Python's standard I/O routines can be used to write stuff to a file during the script evaluation? |
5th January 2019, 03:48 | #186 | Link | ||
Maybe Groucho has better code for timing stuff.
But some stuff from RT_Stats below. [EDIT: Use as you will] Code:
AVSValue __cdecl RT_LocalTimeString(AVSValue args, void* user_data, IScriptEnvironment* env) { const bool file = args[0].AsBool(true); SYSTEMTIME st = { 0 }; if(file) { DWORD tick=GetTickCount(); while(GetTickCount()==tick) // Wait until system clock goes TICK (prevent two separate calls returning same time) Sleep(0); } GetLocalTime(&st); char bf[64]; if(file) { sprintf(bf,"%4d%02d%02d_%02d%02d%02d_%03d",st.wYear,st.wMonth,st.wDay,st.wHour,st.wMinute,st.wSecond,st.wMilliseconds); } else { sprintf(bf,"%4d-%02d-%02d %02d:%02d:%02d.%03d",st.wYear,st.wMonth,st.wDay,st.wHour,st.wMinute,st.wSecond,st.wMilliseconds); } return env->SaveString(bf); } Quote:
AVSValue __cdecl RT_Timer(AVSValue args, void* user_data, IScriptEnvironment* env) { return double(clock()) / double(CLOCKS_PER_SEC); } double __cdecl RT_TimerHP_Lo(void) { LARGE_INTEGER liPerfCounter = {0,0}; LARGE_INTEGER liPerfFreq = {0,0}; bool bStat = true; DWORD_PTR dwpOldMask = SetThreadAffinityMask(GetCurrentThread(), 0x01); Sleep(0); if ((QueryPerformanceFrequency(&liPerfFreq) == 0) || (QueryPerformanceCounter(&liPerfCounter) == 0)) bStat = false; double tim; if(!bStat) { // High precision NOT available. static clock_t first_time32=0; static bool done32=false; const clock_t t = clock(); if(!done32) { first_time32 = t; done32=true; } tim = double(t-first_time32) / double(CLOCKS_PER_SEC); // Fallback, low rez timer } else { // High precision IS available. static __int64 first_time64=0; static bool done64 = false; if(!done64) { first_time64 = liPerfCounter.QuadPart; done64=true; } tim = (double)(liPerfCounter.QuadPart-first_time64) / (double)liPerfFreq.QuadPart; } SetThreadAffinityMask(GetCurrentThread(), dwpOldMask); Sleep(0); return tim; // return double for C client } AVSValue __cdecl RT_TimerHP(AVSValue args, void* user_data, IScriptEnvironment* env) { return RT_TimerHP_Lo(); // Implicit type conversion to AVSValue float } Quote:
EDIT: Code:
env->AddFunction("RT_LocalTimeString", "[file]b",RT_LocalTimeString, 0); env->AddFunction("RT_Timer", "",RT_Timer, 0); env->AddFunction("RT_TimerHP", "",RT_TimerHP, 0);
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 5th January 2019 at 04:01. |
5th January 2019, 05:06 | #187 | Link |
Your 'RT_TimerHP_Lo' function looks pretty good in terms of precision and resolution (and somewhat familiar ).
Edit: Déjà vu...
Groucho's Avisynth Stuff Last edited by Groucho2004; 5th January 2019 at 05:11. |
5th January 2019, 06:00 | #188 | Link |
Yep, If's I recalls correctly, me robbed some of that from your PM (I was wantin' to keep that a secret )
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 5th January 2019 at 06:56. |
5th January 2019, 12:28 | #189 | Link |
Ah, yes. Alzheimer slowly kicking in.
Groucho's Avisynth Stuff |
6th January 2019, 01:05 | #190 | Link |
Thanks, I forgot to mention I need it in a VapourSynth script. I guess this VapourSynth discussion is a bit off topic here so I made a new thread in the VapourSynth section.
17th January 2019, 17:43 | #192 | Link | ||
So my assumptions during MFlow testing were correct, the metricts favor blur, hence the sharp=0 (and possibly pel=4) bias. Maybe you could try downscaling before calculation as well.
zorr, is there a length limit for the combination of filters and limits for a single parameter? Whenever I add more params to dependencies than I have here Quote:
Same here, add CRscaleCSAD2 to Quote:
17th January 2019, 21:56 | #193 | Link | |
Also the SSIM index for the pixel is calculated using a 8x8 neighbourhood (fast method) or using a gaussian weighting function (high quality method). That explains why it's not able to "see" fine details. I'm running some Vapoursynth tests now and there we also have GMSD which gave much better results than SSIM in my denoising test (best SSIM result had ringing artifacts). I haven't tried VMAF yet. It would be great to have these quality metrics as Avisynth plugins too. |
17th January 2019, 22:04 | #194 | Link | ||
[EDIT] I tried the Clevel = ... line and it worked. But there are some small fixes in the parser code which are not released yet, so maybe only my development version accepts it. You should check that there are no line breaks anywhere, the optimizer doesn't support continuing lines with \ like Avisynth does. Oh and if I'm interpreting it correctly you're trying to take the maximum of many numbers. That's not going to work with only one max function since it only takes the top two numbers from the stack. Last edited by zorr; 17th January 2019 at 22:30. |
18th January 2019, 10:49 | #195 | Link |
It's just a part of my ever-increasing MFlow script that now does the initial upsample, follows by the MCompensate trick and then tries to add recalculation to it (over 40 params now). However it always chooses not to do the latter part.
Since I have all the params of MCompensate tied to the weight at which I overlay the MCompensated version over the original one (so as not to try combination when the weight is under 0.2) I tried to follow the no-bias rule and tie the weight itself back to them. Same with the doRecalc switch later. But the fact that max doesn't work with more than 2 arguments is a disappointing discovery, that means I won't be able to do the many-to-one parameter tying. Is the situation the same for the OR operator which I'm using to combine multiple boolean values? |
18th January 2019, 15:11 | #196 | Link | |
Using MSU_Blurring can improve SSIM: (SSIM+SSIM*BLUR)/(SSIM+1) BLUR - if encode_blur < source_blur then (encode_blur / source_blur) BLUR - if encode_blur > source_blur then (source_blur / encode_blur) UPD: Fix calculation of the value, relative to SSIM. The lower the SSIM, the lower the effect of the blur on the final value. Example: SSIM=0.9 BLUR=0.5 - Result=0.7105 SSIM=0.5 BLUR=0.9 - Result=0.6333 Previously, in both situations it was 0.7 p.s. There is also a B-SSIM metric that fixes SSIM problems for blurry images. Fig.b SSIM = 0.8241, B-SSIM = 0.6434 Fig.c SSIM = 0.7276, B-SSIM = 0.4526 Last edited by zub35; 20th January 2019 at 12:33. |
18th January 2019, 21:43 | #197 | Link | |||
I tried doing MFlow + MRecalculate at the same time and there MRecalculate brought some extra quality. I haven't tried all three at the same time (and my method of combining MCompensate is different than yours). I also tried MFlow + MCompensate in phases, I first optimized MFlow only and once I had optimal values I "freezed" them. I then added the MCompensate and only optimized its parameters. That way the number parameters stays lower and the search is easier. It might however result in little less optimal result than what could be possible doing them both at the same time. Quote:
So if you need the max of say, three values, you can do it this way: max(a,b,c) == max(a, max(b,c)) In rpn it's even simpler: a b c max max. So you just add (n-1) max functions to max n numbers. The same works with OR as well. |
18th January 2019, 23:36 | #198 | Link | ||
You could also calculate the blurriness and optimize for both SSIM and blurriness. The pareto front will then have results with increasing SSIM and blurriness and you can choose which one looks best. Of course we'd need a blurriness detection in Avisynth to do that. I found a promising method which is simple to implement and should give good results: variance of the laplacian. The laplacian filter is easy to calculate with MaskTools and StainlessS's RT_YPlaneStdev can be used to calculate the variance. Quote:
[EDIT] Just remembered that SSIM value can be negative, the valid range is -1 .. 1. So by multiplying a really bad SSIM with < 1 you can actually make the metric better. Last edited by zorr; 18th January 2019 at 23:44. |
19th January 2019, 22:58 | #199 | Link |
B-SSIM seemed too intriguing to pass so I went ahead and implemented it. Or at least a variation of it. The original uses the Sobel filter for edge detection, I'm using the Scharr operator instead because it's more accurate. And by the way the "sobel" in MaskTools is not actually sobel, it detects edges but the mask is incorrect and gives sub-par results.
Other difference is that I'm not taking the maximum of standard deviations from the whole clip sample, I just take one from each frame. Taking the maximum would need a two pass algorithm and I wanted to avoid that. The difference to the original shouldn't be that large. In my tests this seems to work as it should giving lower scores to blurrier frames. Anyway, here's a sample code to compare a blurred clip to the original, showing both SSIM and B-SSIM(mod). Code:
# source clip AVISource("d:\process2\1 deinterlaced.avi") ConvertToYV16() # for MaskTools orig = last blurred = orig.GaussianBlur(1.5) scharr_orig = scharr(orig) scharr_blurred = scharr(blurred) final = ScriptClip(last, """ global ssim = SSIM_FRAME(orig, blurred) bssim = BSSIM_MOD(scharr_orig, scharr_blurred, ssim) return orig.SubTitle("SSIM "+String(ssim)+" BSSIM "+String(bssim)) """) return final function scharr(clip c) { scharr_x = c.mt_edge("3 0 -3 10 0 -10 3 0 -3", thY1 = 0, thY2 = 255, y=3, u=1, v=1) scharr_y = c.mt_edge("3 10 3 0 0 0 -3 -10 -3", thY1 = 0, thY2 = 255, y=3, u=1, v=1) scharr = mt_lutxy(scharr_x, scharr_y, yexpr=mt_polish("((x*x)+(y*y))^0.5"), u=1, v=1) return scharr } function BSSIM_MOD(clip scharr_orig, clip scharr_alt, float ssim) { stddev_orig = RT_YPlaneStdev(scharr_orig) stddev_alt = RT_YPlaneStdev(scharr_alt) mul = (2*stddev_orig*stddev_alt) / (stddev_orig*stddev_orig + stddev_alt*stddev_alt) return mul*ssim } Seedmanc and Dogway, can you try the B-SSIM variation and see if it fixes the blurring issue? Last edited by zorr; 19th January 2019 at 23:03. |
29th January 2019, 01:39 | #200 | Link |
An additional "toy" for comparing video qualitiy: https://github.com/fdar0536/vapoursynth-butteraugli
