Old 28th April 2012, 16:34   #15041  |  Link
Originally Posted by varekai View Post
I did think of that but never actually tested because BD-RB System Inspection gives " -X264: Wrong version found"
Regards
Yeah, just ignore it.
Old 28th April 2012, 16:45   #15042  |  Link
varekai
varekai's Avatar
Yeah, the real job (the one that actually pays my bills) has been pulling me in several directions lately. I'm on the road a lot and don't have much free time. It should quite down a bit by summer.
I know what you mean, done a lot of touring myself working as a stage crew, eat-work-sleep-travel-eat-work-sleep...
I'm retired now, and summer is just around the corner, thank goodness!
Will make a donation to your much appreciated BD-RB project!
Regards
Old 28th April 2012, 17:13   #15043  |  Link
That pretty much sums it up. I'm sitting here right now, half-asleep, thinking about that 4:00am wakeup tomorrow.
Old 28th April 2012, 20:18   #15044  |  Link
wolverine3n8
Yeah, other work (the kind that actually pays my bills) has been pulling me in several directions lately. I'm on the road a lot and don't have much free time. Hopefully it will quiet down by summer.
It's none of my business but what do you do in real life? Feel free to ignore this btw.
wolverine3n8 is offline   Reply With Quote
Old 28th April 2012, 20:33   #15045  |  Link
omegaman7
omegaman7's Avatar
Given his expertise (Jealous), I'm sure it's some kind of computer consultant work. Networking, or what not. One day!
Old 29th April 2012, 00:11   #15046  |  Link
busch42
setarip_old, No I haven't tried to do a full movie backup, But i read on another site's forum where someone said they did just the main movie with BDrebuilder and had no problems.
busch42 is offline   Reply With Quote
Old 29th April 2012, 00:38   #15047  |  Link
busch42
jdobbs, I'm going to try the new version of x264, Do I just copy and paste the new one over the old one? If so I noticed in the Bdrebuilder program that the x264 application has no .exe after it.
Old 29th April 2012, 01:03   #15048  |  Link
omegaman7
omegaman7's Avatar
Either it's been renamed, or windows doesn't allow you to see the file extensions. You can change that
Old 29th April 2012, 01:52   #15049  |  Link
@busch42
You must have "Hide extensions to known file types" enabled in Windows Explorer's folder options. BD-RB uses the .EXE extension.
Old 29th April 2012, 02:46   #15050  |  Link
busch42
Thanks jdobbs, I tried the new version of x264 and this time I got to 17.40%, that's futher then before, I'm doing the bluray movie of Contraband, I don't think it's BDrebuilder's fault because if it was it wouldn't work from the beginning at least you would think that, At least the program starts then just comes up x264 has stopped working.
Old 29th April 2012, 06:05   #15051  |  Link
setarip_old
setarip_old's Avatar
Once again:
If I remember correctly, if you want to do a "Movie-only" of this disc, you have to first remove what appears to be a secondary video from 00023.m2ts. Try it.
Try doing a "FULL DISC" copy using the same rip
Old 29th April 2012, 11:45   #15052  |  Link
busch42
Thanks setarip_old, I'm getting to that, I just tried to do a full movie and got to 44.60%, That's as far as I ever got, I'm getting closer LOL. What program or how do you remove the secondary video from the first?
Old 29th April 2012, 20:12   #15053  |  Link
setarip_old
(For "movie-only) you can use tsMuxeR.
1) Create a folder named "Movie_Only_Test" (or anything else you may prefer)
2) Load 00023.m2ts into tsMuxeR.
3)UNcheck the 720x480 video (tsMuxeR will have already eliminated the related DTSExpress audio)
4) Select "Blu-ray disc" from the tabs at the BOTTOM of the tsMuxeR window
5) Browse to "Movie_Only_Test"
6) Click on "Start muxing"
7) If successful, load the "Movie_Only_Test" into BD Rebuilder and process as a "movie only".
Old 30th April 2012, 01:14   #15054  |  Link
busch42
Thanks alot setarip_old, tsMuxeR worked great, I'm now running BDrebuilder and will let you know how I make out, There is just one question, There is a site I go to for a guide to show you how to use BDrebuilder and in the settings under Audio Encoding Options he doesn't the box checked that says Keep HD Audio for BD25/ Alternate Intact, But there is some people that say you should have that checked, What is your's and jdobbs opinion? Thanks.
Old 30th April 2012, 03:02   #15055  |  Link
setarip_old
@busch42
I don't mean to sound harsh, but this thread is supposed to be exclusively for the reporting and analysis of bugs discovered in BD-RB.
(I personally NEVER keep HD audio)
I'd suggest that for postings that are NOT SPECIFICALLY related to BD-RB bugs, you simply create new threads (with meaningful titles for the threads) - and that way we can all be happy rule-abiding campers ;>}
Old 1st May 2012, 01:00   #15056  |  Link
busch42
Sorry setarip_old, Your right I should know better, But just to let you know BDrebuilder still didn't work for me, time to give up.
Old 1st May 2012, 19:07   #15057  |  Link
SquallMX
Special SeeD
@jdobbs, I found a bug when using x264's internal LAVF for decoding that causes undersized output and (potentially) out of specs streams, basically the demuxed original video is identify by LAVF as 25 fps regardless of the original framerate (23.976), so the bitrate of the output stream (after muxing at the original framerate) is lower than expected by a ~4% (25/23.976 = 1.0427):
- [12:20:18] Reencoding video [VID_00050]
- Rate/Length: 23.976fps, 823 frames
- Bitrate: 13,124 Kbs
- [12:20:18] Reencoding: VID_00050, Pass 1 of 2
- [12:20:42] Reencoding: VID_00050, Pass 2 of 2
Bitrate as reported by BDInfo.
Length:                 0:00:34.284 (h:m:s.ms)
Total Bitrate:          13.89 Mbps
VIDEO:
Codec                   Bitrate             Description
MPEG-4 AVC Video        12657 kbps          1080p / 23.976 fps / 16:9 / High Profile 4.1
Is not really that much of a difference, but I wonder if that does not cause compatibility problems since the buffer and the max bitrate of the stream where calculated using a different fps value. I don't have a 29.97 Blu-ray, but if that kind of discs are affected too the file-size differences could be huge (20%).
SquallMX is offline   Reply With Quote
Old 2nd May 2012, 02:04   #15058  |  Link
techno1
I've done about 40 backups using the new version... no issues.
There was a new version of X264 included in the release of BD-RB v0.40.09, so there's always a chance that could be an issue. Since then there is another new version of X264 (revision 2197) out, in case someone thinks they are crashing due to the last release. I just started testing it today. Just remember to only use the 8-bit depth versions. You also have to remember to rename the 64 bit version to x264-64.EXE for BD-RB to see it.
I noticed in Windows Task Manager I'm running the x264.exe *32 version and not the 64bit version. I already have a x264-64.exe in the Tool folder. How can I make BD-RB use the 64bit version? It used to use the 64bit version in the past.
techno1 is offline   Reply With Quote
Old 2nd May 2012, 02:15   #15059  |  Link
Ch3vr0n
do you have the option "use LAVF encoding" enabled ?
Old 2nd May 2012, 06:34   #15060  |  Link
NightHawkGuy
Thats completely normal - since only the 32bit version can use avisynth filters since its 32bit.
The 64bit version of x264 is only used if external filters are not used, in LAVF mode.
NightHawkGuy is offline   Reply With Quote
