17th February 2012, 05:15 | #14501 | Link |
NightHawkGuy, I never saw mkvmerge.exe in TaskManager either. Not even an ~Instant~..haha. I even tried the rebuild after using MSConfig and changing settings to Diagnostic Startup, even that produced the same effect. I've installed AutoGK as I've noticed Windows 7 64-bit have challenges with it when trying to encode and split (a "year" ago)...but everything is functional there. I've even noticed challenges with DVD Rebuilder, and haven't reinstalled it yet.. I have some projects to have done for Saturday so I cannot focus too much towards BD-RB at the moment since everything else is operating correctly (that I can see). I've copy/pasted, after making a backup, 40.07 and am now trying with The Da Vinci Code (again). I know it completed with 40.06 with the same settings. So.. :-D Shall See.
17th February 2012, 06:23 | #14503 | Link | |
17th February 2012, 06:37 | #14504 | Link |
Yes, the case of the one that failed was from selecting a multi-part 41min extra, 720x480 MPEG-2 title as the main movie. It was a deleted scenes title(playlist) that appears to made up of 27 chapters/segments.
A separate build from a single part source selecting the 1080p AVC main movie worked OK to MKV output. I ran the tests for the quickest speed using CRF 1-pass MKV mode, very fast encoding with directshow/ffdshow and no multiprocess. Last edited by NightHawkGuy; 17th February 2012 at 06:42. |
17th February 2012, 07:13 | #14505 | Link | |
Doing the BD Rebuild as we speak , but confident the copy will come out beautiful (as usual) . Sorry for the possible "false alarm" on the new 4007 build . Thanks jdobbs for all your hardwork on BDR! Last edited by stereo55; 17th February 2012 at 07:21. |
17th February 2012, 10:25 | #14507 | Link |
I'll check for replies in the morning. However, Ahhh...Haaa... An Encode DID complete...
---------------------- [02/16/12] BD Rebuilder v0.40.07 (beta) [19:57:18] Source: DA_VINCI_CODE - Input BD size: 40.59 GB - Approximate total content: [02:54:37.467] - Windows Version: 6.1 [7601] - MOVIE-ONLY/ALTERNATE OUTPUT mode enabled - Mode: MKV Container, 1920x1080, Intact Audio - Decoding/Frame serving: DirectShow [2-way] - Audio Settings: AC3=0 DTS=1 HD=0 Kbs=448 [19:57:23] PHASE ONE, Encoding - [19:57:23] Processing: VID_00011 (1 of 1) - [19:57:23] Extracting A/V streams [VID_00011] - [20:06:03] Reencoding video [VID_00011] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 251,208 frames - Bitrate: 5,703 Kbs - [20:06:03] Reencoding: VID_00011, Pass 1 of 2 - [21:34:44] Reencoding: VID_00011, Pass 2 of 2 - [01:01:29] Video Encode complete - [01:01:29] Processing audio tracks [01:01:29]PHASE ONE complete [01:01:29]PHASE TWO - Rebuild Started - [01:01:29] Building ALTERNATE OUTPUT Structure [01:11:55] - Encode and Rebuild complete [01:11:55] JOB: DA_VINCI_CODE finished.
17th February 2012, 20:26 | #14509 | Link |
Tom Hanks is in it. :-)
18th February 2012, 01:33 | #14510 | Link |
So if you use MULTIPROCESS=1 does bdrebuilder then not use DGDecNV? The reason I ask is because if I set MULTIPROCESS=0 then DGDecNV crashes and it has to be closed, however if I set MULTIPROCESS=1 the encode finishes no problem.
Also I'm in 64-bit win7, but the program gives the error that the 64-bit version of DGDecNV is not supported, I know 32-bit programs run fine in a 64-bit environment, wondering though if this might be the cause of DGDecNV crashing? |
18th February 2012, 02:14 | #14511 | Link | |
I believe that BD Rebuilder uses only 32bit Avisynth even with Windows 7 64bit, so you need to use only 32bit filters including with DGDecNV. I'm using Windows 7 64 bit with the recommended 32bit Avisynth and 32bit DGDecNV with no crashing either with Multiprocess on or off. |
18th February 2012, 12:36 | #14512 | Link | |
And b.t.w. thanks a lot for supporting DG...NV tools |
18th February 2012, 14:41 | #14513 | Link | |
19th February 2012, 04:22 | #14514 | Link |
For the past three days I have been trying to batch encode episodes from blurays for Farscape using DGDecNV for decoding. In the morning I find a dialogue box saying "Error: cuInit failed (100)". A google search found that this error is most likely attributed to DGDecNV. After some trial and error I found that this error occurs when the monitor has turned off to comply with Windows Power Option settings. After changing my Power Options so that the monitor never turns off, the cuInit error no longer occurs when batch encoding with DGDecNV enabled.
This is not an bug with BD-Rebuilder per se, but I figured it was worth pointing out in case other people are experiencing the same issue when using DGDecNV. |
19th February 2012, 04:30 | #14515 | Link |
Question re: DGDecNV and MULTIPROCESS=1
Using MULTIPROCESS=1 has really sped up conversions to "movie only/alternate output MKV" (example: UNDERWORLD-UNRATED-EXTENDED took 2hrs 1min to convert with 0.40.06)
Since I have an EVGA GeForce GTX 275 896-P3-1170-AR, which supports CUDA. Being that its a slightly older card, I was wondering how much, if any, also using DGDecNV would help? Thoughts? or should I just leave it alone since the current setup is working fine? If it matters, rest of system's main parts are i7-860 (2.8GHz 8MB L3 Cache), ASUS P7P55D Deluxe motherboard, 8gig Corsair XMS3 CMX4GX3M2A1600C8 (4 x 2Gig sticks). Hard drives are Western Digital Caviar GP SATA (which I know are "slower") |
19th February 2012, 05:15 | #14516 | Link | |
19th February 2012, 05:17 | #14517 | Link | |
19th February 2012, 06:15 | #14518 | Link | |
My monitor can go into standby mode and come out fine during a build and I like that feature, so would like to keep that ability. For those who have a problem in their particular setup, perhaps an optional ini entry can be used to disable it, but allow it to be enabled otherwise. Might depend on the particular Nvidia chip and driver and other system specific stuff? Should probably report it at the DGDecNV support forum with details of your particular system and video card + drivers. I noticed he has a support thread over there for that particular error which could happen if the video card's memory is used a lot at the same time as DGDecNV by some other graphics intensive apps. Last edited by NightHawkGuy; 19th February 2012 at 06:17. |
19th February 2012, 06:59 | #14519 | Link |
Good to know. I'm using a Asus Nvidia GTX580 card with the most recent beta drivers (295.51). DGDecNV hasn't really given me any performance boost over the multi-processor option so I was going to stop using it. But I'll post over at the official forums in case it helps anyone.
19th February 2012, 07:46 | #14520 | Link | |
I plan to run some comparisons using the faster setting, and compare to X264/LAVF, and see what I come up with.
