Old 27th October 2013, 13:59   #1001  |  Link
Mystery Keeper
Beyond Kawaii
Mystery Keeper's Avatar
Thank you. Installed R21 RC, and it has become fast.
This plugin interpolates between frames within (radius) using linear approximation/regression.
update: Compared unfiltered and filtered single planes. Filtered look like they have something like valid output, but much brighter (twice as bright?). That shouldn't be happening though, since all I'm doing is finding the linear approximation between the same pixels of several frames. Then, of course, I'm doing the bit depth conversion. But it shouldn't be different between planes, right?
update2: Checked the Y plane, and it is actually getting brighter too. So, there's a general mistake somewhere in my calculations.
update3: Silly silly me. I forgot to calculate xsum. Fixed. Now need to test with different bit depths and maybe optimize a little.
...desu!
Mystery Keeper is offline   Reply With Quote
Old 27th October 2013, 15:25   #1002  |  Link
Myrsloik
Professional Code Monkey
Myrsloik's Avatar
Here's R21 RC2.
It will probably be released with no further changes. This final RC is just to see so I didn't break anything when moving some code around. It also has a fix for an issue no one ever noticed.
Old 27th October 2013, 15:26   #1003  |  Link
Mystery Keeper
Beyond Kawaii
Ok. Now something unrelated seems to have popped up.
ret = core.fmtc.bitdepth(ret, bits=16)
ret = core.tla.TempLinearApproximate(ret, radius=10, outBits=8)
Gives me an error in AvsPmod: AVISource: couldn't locate a decompressor for fourcc P016.
Both RC1 and RC2.
...desu!
Old 27th October 2013, 15:49   #1004  |  Link
Myrsloik
Myrsloik's Avatar
I noticed some things in your code:
1. VS doesn't allow less than 8 bits per sample to keep things simple so
if((outBitsPerSample < 1) || (outBitsPerSample > 16))
is wrong.
2. You are NEVER supposed to created your own VSFormat struct copies.
WRONG!
    internalData.format = *internalData.videoInfo.format;
    internalData.videoInfo.format = &internalData.format;
You have to keep the pointer around. If you need to get a VSFormat describing a certain format either use getFormatPreset or registerFormat.
Your format error is because the output is 16 bit and you have nothing that can play it. Convert it to 8 bit to preview.
Old 27th October 2013, 15:54   #1005  |  Link
Mystery Keeper
Beyond Kawaii
It does convert to 8bit.
Well, I'll try to register format properly. Haven't found an example of how to do that properly so far.
...desu!
Old 27th October 2013, 15:56   #1006  |  Link
Myrsloik
Myrsloik's Avatar
Python get crashed when using the argument prop_src?
I found the typo. Will put up RC3 soon.
Old 27th October 2013, 15:59   #1007  |  Link
Myrsloik
Myrsloik's Avatar
The relevant lines from ShufflePlanes. It's very simple. You enter all the parameters for the format you want and then you get a VSFormat * back you can use in VSVideoInfo (or anywhere else, really).
Old 27th October 2013, 16:56   #1008  |  Link
Mystery Keeper
Beyond Kawaii
Fixed the format. Works well so far. Still there are things to do, but hopefully shall release soon.
http://paste.org.ru/?vaevta
...desu!
Old 27th October 2013, 17:23   #1009  |  Link
Myrsloik
Myrsloik's Avatar
Another problem, I am unable to get result from both assvapour.AssRender and assvapour.Subtitle. In the shell, it just stays there. No any error message. No crash.
It's not stuck. AssVapour uses fontconfig which needs to create a font index the first run. It's very slow. Give it up to 5 minutes. (or possibly more)
Old 27th October 2013, 17:42   #1010  |  Link
Myrsloik
Myrsloik's Avatar
Here's R21 RC3. Fixes the prop_src crash and checks so a proper VSFormat is passed to setVideoInfo().
1. I've decided that all argument names should be lowercase and with underscores. So outBits => out_bits.
2. I also specify the planes to process as an int array in all internal filters. See Lut which is called like this: Lut(clip, planes=[1,2], long_lut_array).
3. You probably don't want to have this condition
                        uint32_t outValue;
                        if(inBytesPS == 2)
                            outValue = ((uint16_t *)srcp)[w];
                        else
                            outValue = srcp[w];
in the inner loop. Accept that you may need to write the outer loop several times instead. Again see how MaskedMerge works.
There's also the obivious question of why this filter is doing bitdepth conversion at all. Especially downconversion by truncation probably isn't what most people really want. Maybe you should leave that to fmtconv?
Upconversion from 8 to 16 bit is also extremely cheap to do in a separate filter placed in front of TLA so maybe drop that complexity?
Old 27th October 2013, 19:06   #1011  |  Link
Mystery Keeper
Beyond Kawaii
Yup, you're right. I did normalization of the source values, and I shouldn't. Double precision should be enough for 16-bit calculations on any reasonable radius. If it isn't - normalization wouldn't help anyway. So I'll drop normalization, bit depth conversion and format change altogether.
...desu!
Old 27th October 2013, 20:33   #1012  |  Link
Mystery Keeper
Beyond Kawaii
Here you go. As fast as it gets. Still a draft, but usable.
http://paste.org.ru/?h6sf34
...desu!
Old 27th October 2013, 21:12   #1013  |  Link
Myrsloik
Myrsloik's Avatar
1. You can drop the (internalData.videoInfo->numFrames != 0) check. Requesting frames beyond the end is allowed (you'll get the last actual frame back)
2. You're calling vsapi->getReadPtr() in the inner loop, you probably want to store the pointers in a local array before the loop
3. You can automatically copy planes using newVideoFrame2() (which is free since it uses some reference counting behind the scenes). See ShufflePlanes as an example of how it's used. Basically you pass an array of 3 frame and another of the planes that should be copied from them. If you pass 0 as the frame pointer you get a normal blank plane.
Old 28th October 2013, 19:02   #1014  |  Link
Mystery Keeper
Beyond Kawaii
I'm afraid I can't. This plugin needs to know the exact number of frames so it would take the proper range near the end.
...desu!
Old 28th October 2013, 21:51   #1015  |  Link
IanB
Avisynth Developer
I assume zero length clips are valid in VapourSynth as they are in Avisynth.
Zero length clips need to be handled gracefully.
IanB is offline   Reply With Quote
Old 28th October 2013, 21:56   #1016  |  Link
Tima
Another corner case could be nonzero-length clips with both (or just one!) dimensions being zero
Tima is offline   Reply With Quote
Old 28th October 2013, 22:00   #1017  |  Link
Myrsloik
Myrsloik's Avatar
If the length is zero it means that it is unknown. The actual number has to be determined some other way. Call it an esoteric feature. It can be useful for streaming and such. If you request a frame beyond the end all filters should return the last valid frame.
Clips that actually have 0 frames aren't allowed and can't be created for obvious reasons.
As for clips either both or no dimensions are known. You will trigger a fatal error if you try to set only one of width and height to zero.
I have plenty of extra argument checks going on to stop some common mistakes from happening. If VapourSynth ever "just quits" run it from the commandline to see the stderr output. It usually prints the reason and offending filter (if any).
Old 29th October 2013, 22:15   #1018  |  Link
Myrsloik
Myrsloik's Avatar
I finally released R21. Changelog in the first post. Download link on the website.
Blog post here.
Same procedure as every time... Now for some plugin writing.
Download link now fixed.
Old 30th October 2013, 04:14   #1019  |  Link
Mystery Keeper
Beyond Kawaii
Great work, Myrsloik! Is there MVTools among the priority plugins?
...desu!
Old 30th October 2013, 09:35   #1020  |  Link
Myrsloik
Myrsloik's Avatar
Of course it is. I actually do write these things down on the bug tracker and blog...
I don't know if there is any other really popular plugin left to port. I think I got all the extremely useful ones but correct me if I'm wrong.
speed, vaporware, vapoursynth
