Old 25th September 2012, 21:21   #15861  |  Link
wakko709
i ran it in administarator
still i get
- Windows Version: 6.1 [7600]
- FFDSHOW: [3882], Ok
- WIN7 preferred MPEG2 CODEC: Not Set correctly
- FFDSHOW MPEG2 set to "libmpeg2": Ok
- AnyDVD settings check: Ok.
- BD Rebuilder v0.42.0.3, Ok
- X264: Ok
- AFTEN: Ok
- FAAC: Ok
- MP4BOX: Ok
- WAVI: Ok
- TSMUXER: Ok
[09/25/12] BD Rebuilder v0.42.03 (beta)
[13:18:49] Source: JOHN_CARTER
- Input BD size: 43.91 GB
- Approximate total content: [03:32:33.240]
- Target BD size: 22.95 GB
[13:18:51] PHASE ONE, Encoding
- [13:18:51] Processing: VID_00252 (1 of 31)
- [13:18:51] Extracting A/V streams [VID_00252]
- Error in attempt to extract audio/subs.
[13:23:04] - Failed to retrieve audio, aborted
wakko709 is offline   Reply With Quote
Old 25th September 2012, 21:28   #15862  |  Link
RobertM
still i get
<snip>
<snip>
But did you run the FFDSHOW video configuration program? Several people have advised you to do so.
Old 26th September 2012, 00:39   #15863  |  Link
wakko709
yes i did!
Old 26th September 2012, 04:09   #15864  |  Link
Paddy97
From changelog
- Changed MKV output so no PGS subtitle is selected
by default at playback.
Is there any hidden option that I can use to revert this behaviour? It's troublesome for my kids to select subtitle since my mediaplayer does not select automatically.
Today I have to remux the MKV to set the default PGS.
Paddy97 is offline   Reply With Quote
Old 26th September 2012, 19:26   #15865  |  Link
RiotRay
Hi!
I'm trying to recode "Sarah Connor Chronicles Season 2" to BD25. BDRebuilder has a very strange behaviour here. It doesn't give back any error messages, but recoding the VC1 Videos takes place at approximately 1 FPS. This way it takes forever! I already tried DVDfab, which gives me an error message with these discs at 50% recoding.
I think it should be much faster, since my system does with h264 material (AMD Phenom II X6 1090t).
What's the problem here?
thx
RiotRay is offline   Reply With Quote
Old 26th September 2012, 22:11   #15866  |  Link
gonca
Are you encoding from hard drive or optical disc?
Old 27th September 2012, 12:48   #15867  |  Link
RiotRay
I'm encoding from harddrive.
Old 27th September 2012, 16:12   #15868  |  Link
omegaman7
omegaman7's Avatar
A faulty cable, or faulty hard drive COULD behave like that. I must admit though, that has to be highly rare...
Though faulty Sata cables can cause drop outs, and bandwidth issues. A bad southbridge could probably cause that too. Also rare. I'd be for testing the crap out of the hard drive, via other applications.
Old 27th September 2012, 17:20   #15869  |  Link
RiotRay
I'm a USB3.0 dock for target and an external USB2.0 for the source material. It all goes over the same USB3.0 root hub. I never experienced this before with other discs. I guess, I just have to keep trying until I find the reason..
thx
Old 27th September 2012, 22:26   #15870  |  Link
gonca
Post your log and .ini files. There might be a clue there. Also try hdtune to test your hard drives. Ist it possible your hub is the issue?
Old 28th September 2012, 00:24   #15871  |  Link
AmigaFuture
AmigaFuture's Avatar
Hi!
Today's computers won't process something forever..the fact you're noticing movents indicating that.
If you're noticing movement, even the smallest amount, then make sure your cables and hardware are functioning fine. Also, if another Blu-ray rips fine and encode fine, check your hard drives file system (Windows XP and 7 have good built in checking), check the surface of the HDD. If there's a "read error" or a sector failing that can be part of "very slow data movement" as the drive tries to read "through" the corruption. These are possibilities without being there examining it.
Old 28th September 2012, 06:15   #15872  |  Link
omegaman7
omegaman7's Avatar
RiotRay. Try a linear Read of the hard drive in question. That should eliminate a read/sector issue. Everest can do the job. Never used Hdtune.
Old 29th September 2012, 17:36   #15873  |  Link
AmigaFuture
Toy Story: I have 3 machines here. 1 I use as storage and Firefox, and my Son uses for Homework and games. No extra codecs are installed. Very stock Windows 7. Toy Story has the same "glitches" using that machine when I have BD-RB reencode Full Backup and no editing. Everything shows as rendered fine, except for playback in Standalone unit. I've tried BD-RE-DL and BD-R, same results for both. I had it output to Alternative movie only MKV, mkvmerge fails to finish. 2) I've checked my main system, which I'm using now, checked all connections...verified the HDDs are fine, RAM is good...everything is cooled so no overheating. I've removed all software, including AnyDVD, reset, made sure all lingering bits were removed. Reset. Then reinstalled.
I'm now wondering if it has to do with AnyDVD? Now I'm checking with some other movies. I may check with older versions of AnyDVD to see if a bug for introduced somewhere. 7.0.8.0 in use.
Anyone else have the movie and noticing these things at the times I've stated in recent previous posts? Thanks.
Old 29th September 2012, 18:04   #15874  |  Link
omegaman7
omegaman7's Avatar
The first toy story, or the third one? I've been meaning to do all of them come to think of it :S
Old 29th September 2012, 23:30   #15875  |  Link
AmigaFuture
Something about me.. If I'd meant Toy Story 2 or 3 I'd gave typed that. Or edited my post upon noticing unclear info.
BD-RB was able to reencode my Toy Story to BD-9 before, but I now recall from there I made an MKV myself AND I didn't watch it completely after it was done. I meant to.
Since you have them, try the first one...erm, hehe...Toy Story (Original) and check those times I posted, please. Very interesting that my 3 machines render fine, and yet the exact same "jerky" flaw at the same times each time. The Burner is good, the disks are good.. A bug?
I checked the directory and notice the large files that make the movie. It's broken into a few chunks. Which explains why I can hear the BD player's optics moving to access them. Seems in the rebuild process that...they're not being connected "?cleanly?".. Hmm..
Old 29th September 2012, 23:35   #15876  |  Link
omegaman7
omegaman7's Avatar
I saw you mention both the third and first one in past posts. THat's why I was uncertain I'll let you know as soon as I can. Busy weekend, and busy next week. Work work work... But... $$$
-Edit-
Found your post.
http://forum.doom9.org/showpost.php?p=1592504&postcount=15836
Jdobbs apparently didn't have a problem with that one. Perhaps a bad rip. I've had rips that play on the pc fine, other players fine, but when re-processed, $h!t hits the fan. Copy of a copy of a copy I guess...
Old 30th September 2012, 03:10   #15877  |  Link
-Edit-
Found your post.
I did Toy Story with no issues, but that was a long time ago. It's possible something could have been introduced that causes problems -- but not probable. I'll go back an reencode to see how it comes out just to be sure.
Old 30th September 2012, 04:50   #15878  |  Link
AmigaFuture
omegaman7: When you take the "work" out of a job it goes much better in many ways.
I noticed something interesting. I ripped Toy Story again with AnyDVD 7.0.8.0 as an ISO instead of files in a directory. I then burned it to a BD DL...the the movie played smooth in the times I noted before. I checked it a few times; ejecting the disk and reinserting it...rewinding and playing.. I'm going to mount the image and have BD-RB 42.03 rebuilt the image and check that. Looks like AnyDVD Is the cause..
I always check both ways, program and standalone.
Update: Using Movie and Menus, I set FORCE_NOENCODE=1 and the output at the "jerky" video and audio. Now doing using the High Speed option with Movie and Menus. Next, if same output, I'll use Full Backup.
Old 30th September 2012, 07:30   #15879  |  Link
AmigaFuture
Toy Story Movie and Menus
No blanking was used.
[09/29/12] BD Rebuilder v0.42.03 (beta)
[20:39:00] Source:  TOY_STORY
  - Input BD size: 24.80 GB
  - Approximate total content: [05:48:14.789]
  - Windows Version: 6.1 [7601]
  - MOVIE and MENUS mode enabled
  - Quality: High-Speed Option (BD-25), Two Pass
  - Decoding/Frame serving: DirectShow [4-way]
  - Audio Settings: AC3=0 DTS=1 HD=0 Kbs=448
[20:39:00] PHASE ONE, Encoding
[Edited to fit to post..Processed fine]
 - [22:54:42] Multiplexing M2TS
 - [22:54:59] Blanking: VID_00514 (134 of 147)
 - [22:54:59] Blanking: VID_00515 (135 of 147)
 - [22:54:59] Blanking: VID_00516 (136 of 147)
 - [22:54:59] Blanking: VID_00517 (137 of 147)
 - [22:54:59] Blanking: VID_00518 (138 of 147)
 - [22:54:59] Blanking: VID_00520 (139 of 147)
 - [22:54:59] Blanking: VID_00522 (140 of 147)
 - [22:54:59] Blanking: VID_00535 (141 of 147)
 - [22:54:59] Blanking: VID_00536 (142 of 147)
 - [22:54:59] Blanking: VID_00537 (143 of 147)
 - [22:54:59] Processing: VID_00538 (144 of 147)
 - [22:54:59] Extracting A/V streams [VID_00538]
 - [22:55:05] Reencoding video [VID_00538]
   - Rate/Length: 23.976fps, 566 frames
   - Bitrate: 34,898 Kbs
 - [22:55:05] Reencoding: VID_00538, Pass 1 of 2
 - [22:55:05] Reencoding: VID_00538, Pass 2 of 2
 - [22:55:14] Video Encode complete
 - [22:55:14] Processing audio tracks
   - Track 4353 (eng): Reencoding audio to AC3...
   - Track 4354 (eng): Keeping original audio
   - Track 4357 (eng): Keeping original audio
 - [22:55:18] Multiplexing M2TS
 - Error in attempt to multiplex: MUX_00538.meta
[22:55:24] - Failed to build structure, aborted
Now BD-RB is attempting Full Backup.. No blanking.
Old 30th September 2012, 11:22   #15880  |  Link
Scorpio1
Small glitch
OS Windows 7 x64 Pro.
I have discovered that if the font size is set to 125% in personalization/make text easier to read (acsessed by right clicking the desktop and selecting personalization), that when BD Rebuilder completes a job the progress bars are stuck at about 80%, the progress does state 100% however. This gets worse if 150% is selected and the progress bars seem stuck at about 60%.
Just a minor cosmetic bug really.
Any idea when the full version will be released, the program is excellent and must be very near a stable version by now, I have used BDR for over 2 years and never had a serious problem, apart from 1 weird error message many versions ago.
Scorpio1 is offline   Reply With Quote
