2nd April 2009, 02:56 | #781 | Link | |
My solution was to rename AVISource in my file names to AVIS. Everything seems to work now. |
2nd April 2009, 09:43 | #782 | Link |
AVStoDVD Dev
AVISource cannot read AC3 audio, so AVStoDVD forces DirectShowSource if AC3 audio (to be encoded) is found. It adds a comment to the script:
#'AVISource' replaced with 'DirectShowSource' for AC3 audio support Bye |
3rd April 2009, 02:31 | #783 | Link | |
<4/2/2009 9:22:53 PM> START PROCESS <> <4/2/2009 9:22:53 PM> DVD SETTINGS DVD Titles number: 1 DVD Video Standard: PAL DVD Chapters Interval: 5 min DVD Menu: Static DVD Menu DVD Size: 8/4435 MB (0%) DVD Output Setup: DVD Folder Delete Temp Process Files: Yes Delete Working Files: Yes Edit Command Parameters: No Save Log file: Yes Output Folder: D:\Dave's Documents <> <4/2/2009 9:22:53 PM> TITLE 1 SOURCE FILES Video: D:\Dave's Documents\TEST AVISource.avi Info: M-JPEG - 14400 kbps - 640x480 - DAR 1.333 - 30 fps - PPF - 6 seconds - 202 frames Audio: D:\Dave's Documents\TEST AVISource.avi ***AUDIO FILE NAME IS CORRECT HERE*** Info: PCM - 705 kbps - CBR - 44100Hz - 1ch - 6 seconds Subs: [MediaInfoLib - v0.7.10] <> <4/2/2009 9:22:53 PM> AVISYNTH SCRIPT Video = AVISource("D:\Dave's Documents\TEST AVISource.avi", audio=false) Video = Video.ConvertToYV12 Video = Video.ChangeFPS(25) Video = Video.Lanczos4Resize(720,576) Audio = DirectShowSource("D:\Dave's Documents\TEST DirectShowSource.avi") ***AUDIO FILE NAME HAS BEEN CHANGED BY PROGRAM*** #'AVISource' replaced with 'DirectShowSource' for AC3 audio support Audio = Audio.SSRC(48000) Audio = Audio.ConvertToMono AudioDub(Video, Audio) <> <4/2/2009 9:22:53 PM> START VIDEO ENCODING OPERATIONS Encoding Profile: QuEnc CBR 1-pass Target Video FileSize: 7.1 MB QuEnc Parameters: -i "C:\DOCUME~1\Dave\LOCALS~1\Temp\TEST_0_Title_01.avs" -o "D:\Dave's Documents\TEST_0_Title_01.m2v" -b 8500 -1 -hq -novbr -scene -trell -aspectratio 4:3 -nointerlaced -mpeg2mux noaudio -dc 10 -priority 5 -auto -close <> <4/2/2009 9:23:04 PM> PROCESS ABORTED DURING TITLE 1 VIDEO ENCODING OPERATIONS. CHECK LOG FILE <D:\DAVE'S DOCUMENTS\TEST_0.LOG> FOR MORE INFO. <> <4/2/2009 9:23:04 PM> Log file created by AVStoDVD Release 2.1.4 <> |
10th April 2009, 21:44 | #789 | Link |
I think I've asked a similar question before, but is there anyway to edit the avg video bitrate for all the added files in one go? I've added 17 videos and it would be handy to be able to globally set them to the value I need.
11th April 2009, 15:02 | #791 | Link |
AVStoDVD Dev
@calmart
What kind of audio/video streams are contained in the file that gives you the error? @rendez2k No way right now to set one bitrate for all (17! wow!) titles. Actual best approach is to play with 'Custom DVD Size' to find the filesize that fit the wanted bitrate. Bye |
12th April 2009, 16:10 | #793 | Link |
audio delay problem
I have a little problem here with audio sync. I have aAVI file with XVID video and AC3 audio, and when I try to create a DVD, the audio is out of sync. I can't preview and use delay because no audio in the preview. Is this a limitation of AVS2DVD, or is there some other workaround? I guess I could make a pass and then use FFDshow to figure the delay, and then make a second pass, but that seems a little involved.
12th April 2009, 16:24 | #794 | Link | |
http://www.alexander-noe.com/video/amg/ |
12th April 2009, 22:37 | #795 | Link |
AVStoDVD Dev
@calmart
And the audio stream? Is it an AC3? I would try to reset AVStoDVD settings by pressing 'Option'/'Restore default settings'. @Richardw322 wg' suggestion is good. BTW another path (that will lead to audio re-encoding) could be: go to 'Settings'/'AudioVideo' and toggle off 'Keep DVD compliant audio'. Audio preview will be activated and you can play with 'DelayAudio'. Bye |
12th April 2009, 23:51 | #796 | Link | |
Carlos Martinez
Pressing "Option'/'Restore default settings" just deletes my input. |
13th April 2009, 17:03 | #797 | Link |
AVStoDVD Dev
You are saying that you are loading a single m2v file without audio? It should be an easy scenario...
Could you please take a shot of the main AVStoDVD form with the error message box and post it here? Bye |
13th April 2009, 23:13 | #798 | Link |
wg, That worked a charm. Made a great DVD.
MrC: Another good suggustion, that would have worked. Another question. I like to make DVD's with a single title, but a menu. That leaves me with a play all button, and the thumbnail button. Seems redundent to me. Any way to get rid of one or the other? I tried shrinking the thumbnail to 4x2, but then I get "Can't resize image" on the menu. (Made that damn thing 4 times yesterday before I was happy with it, between the audio and the menu). Thanks guys! |
13th April 2009, 23:58 | #799 | Link | |
Carlos Martinez
http://forum.doom9.org/attachment.ph...1&d=1239663373 What can you make of it? |
15th April 2009, 11:43 | #800 | Link |
Carlos Martinez
Sometimes when I press the Preview Title Output button, what I get is an upside down image.
This usually turns out right when conversion is finished. But I had some (rare) cases when this doesn't happen. Why's that and what (script line?) puts things back as they should? |
