Old 9th February 2011, 00:04   #1741  |  Link
8ternity
8ternity's Avatar
@MrC:
Didi i need to give you something more about the issue on the version 2.3.4? I'Ve try with "ffmpeg", "directshow" and also "A2D"... it's make this to all of my projects and any files in m2ts.
Thanks!
Old 9th February 2011, 04:33   #1742  |  Link
8ternity
8ternity's Avatar
@MrC:
I had a suggestion for the batch window. Did is possible to attached the window to the other window when we move it to the other window, and when we move the main window, the batch window move it too like IMBGURN does it for the status window.
What you think about that?
Ohh i forgot something else... please wait before release the icons has the defaut one, i need to arranged the contrast on some ones, and re-arranged someones.
Old 9th February 2011, 10:34   #1743  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
@8ternity
So, no luck with Preview Clip using FFMpegSource? That's quite strange, because FFMpegSource does not use a directshow approach. Are you sure you are having problems with all m2ts files?
About Jobs List window positioning, no problem, I will do. OK for icons as well.
Bye
MrC
AVStoDVD Homepage
AVStoDVD @ Doom9 Forum
Old 9th February 2011, 11:17   #1744  |  Link
houston
Originally Posted by houston View Post
Hey
i got a problem...
I dont get any pictures if i try to preview a track inside of a2d
But the audio is playing.
any solutions?
br
houston
Just thought about to look nto the faq myself ... then looking here and get the advice ... Shame on me
But thanks, now it works
houston is offline   Reply With Quote
Old 9th February 2011, 16:48   #1745  |  Link
8ternity
8ternity's Avatar
@MrC:
I was having this issue with 3 movies on 3, so i've not tester with more of this one. I need to finish some conversion and after that reinstall 2.3.4 version and try a different movies excluding the 3 i've already done.
I've show you the GraphEdit on the movie in question, and with 2.3.3 version it pass like a charm!
EDIT: Theme pack finished. PM sent. Thanks. Hope to see theses icon has the new defaut, i just cant wait to see comments of avstodvd users it's just my little contribution to your great work and support!
Old 10th March 2011, 18:16   #1746  |  Link
leoliver
add external sub-titles to a DVD
Can I use DirectVobSub(VSFilter.dll) to add external sub-titles , when I'm using AVStoDVD to convert a .avi to DVD ?
Or would I have to use another program to add the external sub to a .avi before using AVStoDVD to make a DVD ?
Your Friend,
Larry
leoliver is offline   Reply With Quote
Old 10th March 2011, 20:42   #1747  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
What is exactly your purpose and your input subtitle file format? AVStoDVD supports directly SRT, SUP and SST format. Just click on 'Edit Title'/'Subtitles'/'Add Subtitles' (or type CTRL-S).
Bye
MrC
AVStoDVD Homepage
Old 11th March 2011, 18:08   #1748  |  Link
leoliver
Bye
The subs are SRT. I'll try the actions you mentioned. Thanks.
Your Friend,
Larry
Old 1st April 2011, 19:09   #1749  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
AVStoDVD release 2.4.0 beta 110401 is available to download
Change log:
- Some bugs fixed
- Added multi subtitles tracks encoding and authoring capability
- Added support to VobSub subtitles (idx/sub)
- Added support to SubStation Alpha subtitles (ssa/ass)
- Added order tracking during Audio/Subs tracks selection
- Added possibility to open background image from DVD Menu Editor to default image viewer/editor
- Added possibility to use custom images for DVD Menu Thumbnails (Static Menu only)
- Added graphical support to 32bit icons using VB resource library (DLL ActiveX)
- Moved all .ico files to single .dll file for Skins
- Changed 'Default' Skin (thanks to 8ternity for new suite). Old 'Default' is now called 'Classic'.
- Changed 'Default' Splash Screen (thanks to 8ternity). Old 'Default' is now called 'Classic'.
- Changed default authored subtitles format from 'Tahoma 18pt Bold' to 'Tahoma 18pt'
- Added 'Menu Templates Path' option in 'Preferences'/'Paths'
- Removed 'Local AppData Path' option in 'Preferences'/'Paths' (discontinued)
- Improved 'Fix SRT' routine for authored subtitles
- Added MKVtoolinx 4.5.0 to AVStoDVD Installer package
- FFmpeg updated to r28671
- MediaInfo updated to 0.7.42
As usual, please provide feebacks and comments about this beta release.
Bye
MrC
AVStoDVD Homepage
Old 2nd April 2011, 02:43   #1750  |  Link
8ternity
8ternity's Avatar
Hi Mrc!
I just saw the beta release on Videohelp.com! I just download it and take a look of new exciting theme and give you some news about it ASP.
I can't wait 2min to finished to download it!
Thanks!
Old 2nd April 2011, 03:15   #1751  |  Link
8ternity
8ternity's Avatar
Hey Mrc,
Did you had the dimensions for the image on the installer for you program? I can design one for the new release when it's will coming out from beta?
I Will design it from the splash screen i've design.
Also, i need to update the shadow of the icon in the splash screen, i doesnt like it, i need to look more natural. I know how to correct it.
And that splash screen is the official one on the next release?
Just an update; in the splash screen, put the text in black for the release version and beta build text.
**Edit**: new splash attached to this post.
- Fixed the shadow with a real shadow (perspective effect, guassian blur effect, 85% oppacity.
- Updated the titles AVStoDVD font tunned to fine/precised effect.
- Ice/Polar background
- Lightings storm effect in both side of the icon/movie image
***end***
Old 2nd April 2011, 08:58   #1752  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
Vertical image: 164x314 px
Horizontal image: 150x57 px
Yes, it is
It should be already black, isn't it?
***end***
Thanks for your great support! Very appreciated
Bye
MrC
AVStoDVD Homepage
Old 2nd April 2011, 23:00   #1753  |  Link
8ternity
8ternity's Avatar
Great, i will design it for you as soon as possible.
No it was in white. But when i unstall the older version, i say yes to keep registry setting in the registry of windows. Did to keep that registry keys keep that white title? I don't think so it must be in the programmation itself of avstodvd?
It's a pleasure! I like your software and use it every week. If i can help in a way, i help for small things like that. Also i like to photoshop somes things, design publicity, business card, etc.
I let you know when your image in the setup is ready.
8ternity
Old 2nd April 2011, 23:22   #1754  |  Link
8ternity
8ternity's Avatar
Hi Mrc!
Here all the images for installer!
Old 3rd April 2011, 23:14   #1755  |  Link
John_J
John_J's Avatar
Hi there!
I'm glad to see another new release of AVStoDVD. I haven't tested it so far, but changelog looks promising
Hope to see AVS script support for DVD menu backgrounds one day...
Change log:
I've began to update icon packs back to 32bit color depth, but I always get default icons for all buttons. Am I missing some dlls or do you only support a icon dll now?
Cheerio,
JohnJ
PS: I also collected some new ideas for menu backgrounds. If I got enough input, I'll create a new template pack.
John_J is offline   Reply With Quote
Old 4th April 2011, 13:10   #1756  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
It is coming... keep the hope.
If Icons.dll file (.ico container, ActiveX DLL resource library) is found, it is used, otherwise .ico files (if present) are loaded.
Great! Eager to see them!
Bye
MrC
AVStoDVD Homepage
Old 4th April 2011, 21:35   #1757  |  Link
John_J
John_J's Avatar
Awesome...I already got a script from an earlier project ready to provide an example/tutorial.
..., otherwise .ico files (if present) are loaded.
And those single icon files (still) have to be 8bit?
-JohnJ
Old 5th April 2011, 12:56   #1758  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
Yep, 32bit support is only thru resource dll.
Bye
MrC
AVStoDVD Homepage
Old 5th April 2011, 13:13   #1759  |  Link
John_J
John_J's Avatar
Aaahh...I got it. Is there a simple way to create such ressource dlls without Visual-Studio/-Basic/... for testing purposes?
EDIT: I used Resource Hacker, but icons doesn't really look like 32bit (missing alpha channel). Should I send you a sample?
-JohnJ
Old 5th April 2011, 17:46   #1760  |  Link
Manji
Hi - great app but having an issue now with bottom green screen. Please see image:
http://i.imgur.com/VuJoD.jpg
Source is PAL mp4 converting to NTSC. Using latest beta. Any ideas? thanks
Manji is offline   Reply With Quote
[IMG] code is Off
