Old 12th June 2020, 01:47   #1341  |  Link
SamuriHL
SamuriHL's Avatar
Yea I hadn't updated in a while either for the obvious reasons. I suppose it's entirely possible that WU broke the driver install. It was bad though. Freaked me right out. LOL Downgraded back to my normal driver and all is well so no big deal I guess. Just apparently no one else has run into it.
SamuriHL is online now   Reply With Quote
Old 12th June 2020, 03:30   #1342  |  Link
VBB
VBB's Avatar
I haven't watched anything HDR in a while, but as you know, I've been using the latest drivers. No issues here other than the now well known one mentioned in the first post. What did you notice wrong with SDR? How did you figure HDR wasn't being output in the correct color space?
Henry | LG OLED65C7P | Denon AVR-X3500H | ELAC Uni-Fi x7 | ELAC Debut 2.0 SUB3030 x2 | NVIDIA SHIELD TV Pro 2019 | Plex
VBB is offline   Reply With Quote
Old 12th June 2020, 06:10   #1343  |  Link
RXP
Does 442.74 passthrough meta data oK? I don't notice that mentioned on the first page anymore.
RXP is offline   Reply With Quote
Old 12th June 2020, 08:33   #1344  |  Link
VBB
VBB's Avatar
Yes, meta data has been passed through properly for a long time now.
Old 12th June 2020, 14:55   #1345  |  Link
SamuriHL
SamuriHL's Avatar
Yes 442.74 is the driver I'm sticking with until they fix the stupid issues introduced in the later drivers. It works perfectly for me.
Old 13th June 2020, 08:59   #1346  |  Link
webbo
Hello SamuriHL
But which would be those issues - for example, tested 446.14 myself for a few movies / TV Shows, 4K HDR ones, no issues whatsoever
Bugs in colorspace, you mean?
Thanks for your input
HTPC Build : 8700k / 16GB DDR4 / 1080Ti GPU - Setup for FullHD / 4K MKV Playback - PotPlayer + madVR
Display #1 - 32GK850G
Display #2 - LG G3 OLED 55'' (ISF Calibrated)
webbo is offline   Reply With Quote
Old 13th June 2020, 20:04   #1347  |  Link
SamuriHL
SamuriHL's Avatar
The issues that have been reported about if you're outputting 10 bit or higher, it'll pull you out of HDR if you bring up an overlay (like your player). It's just distracting. Not that I tend to bring up the overlay very often when I'm watching a movie, but, I have no reason to upgrade that machine unless I have a driver with no compromises to go to. For others, especially those using 8 bit output, it's a non-issue.
Old 14th June 2020, 04:55   #1348  |  Link
Calvi
I am running 442.92 Studio drivers and it seems as good as 442.74
Calvi is offline   Reply With Quote
Old 14th June 2020, 14:10   #1349  |  Link
SamuriHL
SamuriHL's Avatar
Maybe I'll give those a try.
Sent from my SM-G975U using Tapatalk
Old 15th June 2020, 05:36   #1350  |  Link
nsnhd
So with the 442.74, outputting 10-bit FSW stays when bringing up overlay ? I'm using the very old 385.28 for sticking to 10-bit in all modes but when overlay (seek bar, madVR controls...)comes up it changes to 8-bit shortly.
nsnhd is offline   Reply With Quote
Old 15th June 2020, 12:33   #1351  |  Link
SamuriHL
SamuriHL's Avatar
Yup works just fine.
Old 19th June 2020, 02:58   #1352  |  Link
VBB
VBB's Avatar
Updated Windows 10 to v2004. Kept all drivers and software settings intact, but reset display resolution, gamut, and bit depth to Nvidia defaults. Haven't run into any issues, other than the ones associated with the latest Nvidia drivers (see 1st post in this thread).
Old 19th June 2020, 16:00   #1353  |  Link
SamuriHL
SamuriHL's Avatar
I've been running 2004 for a few weeks now and I'm using it with the latest studio driver with no issues.
Old 24th June 2020, 16:17   #1354  |  Link
littleD
littleD's Avatar
Originally Posted by GTPVHD View Post
https://www.nvidia.com/en-us/geforce...-ready-driver/
Nvidia GeForce 451.48 WHQL WDDM 2.7 driver, new driver branch so will need testing.
Finally new features:
Supports DirectX 12 Ultimate
Supports Vulkan 1.2
Supports hardware-accelerated GPU Scheduling.
Supports CUDA 11.0.
littleD is offline   Reply With Quote
Old 24th June 2020, 17:37   #1355  |  Link
SamuriHL
SamuriHL's Avatar
Ah damn! I'll see if I can test those out tonight if no one gets to it first. Those look fun!
Old 24th June 2020, 18:42   #1356  |  Link
littleD
littleD's Avatar
Be careful i ve lost "add run with graphic processor" to context menu. I still look for fix.
Microsoft's shit again https://nvidia.custhelp.com/app/answ...tail/a_id/5035
Old 24th June 2020, 18:52   #1357  |  Link
kostik
Nvidia GeForce 451.48 WHQL again the same issues I've seen with the last drivers... wrong colorspace when launching HDR with madVR ... to fix this, after launching the movie first time, in the same mpc-hc window , I click open file and pick the same movie file and it switches to NV HDR and to the correct colorspace.
TV :LG OLED 65CX ; PC: CPU: Ryzen 9 3950X @43.25GHz ; GPU: Gigabyte GeForceŽ RTX 3080 GAMING OC 10G ;Memory: Corsair Vengeance RGB (2X16GB) DDR4 3600MHz, ;
kostik is offline   Reply With Quote
Old 24th June 2020, 19:07   #1358  |  Link
VBB
VBB's Avatar
@kostik Could you give us a little more detail? What color space does it launch in? What does it say instead of NV HDR when it first does this? Are you using 10-bit?
Old 24th June 2020, 19:31   #1359  |  Link
kostik
I am using 12bit RGB 24Hz. . . If you disable "send hdr metadeta to the display" in madVR settings and turn on HDR in windows display settings , play an HDR movie, you will see the exact phenomenon I get launching hdr movie first time with this driver (and some of other 45X drivers) .
It uses OS HDR. While the movie plays, if you open it again (file->open) , it switches to the right mode.
WEIRD ... 446.14 works fine, also the studio drivers work good. Maybe I will try the Studio version of this 451.48 driver but I guess its an issue with this branch and will have to wait for a fix
Old 24th June 2020, 19:36   #1360  |  Link
Klaus1189
Is there difference between Studio Driver and Game Ready Driver, when the number is identical? I thought it's the same, but I was already mind blown by minor things
