28th July 2013, 16:36 | #283 | Link |
How exactly do I use the "Combine with profiles"?
For example, I want to use preset Placebo, tune Film and just change the minimum quantiser to 10. I tried this but it seems to ignore the preset and tune and uses all from the advanced options. PS: Thanks for the latest update! |
28th July 2013, 19:48 | #284 | Link |
TEncoder, TX264, TAC
You can see how profiles, presets, tune etc combine with other options from here: http://mewiki.project357.com/wiki/X264_Settings#Presets
Also you can manually enter options under "Custom Options" tab> "x264.exe". In your case "--qpmin 10" should work. |
3rd August 2013, 16:27 | #285 | Link |
Life's clearer in 4K UHD
I've lost my pre-sets...
Can somebody remind me which encoder/x264 options I have to select in order to generate 'AVC lossless' encodes? Many thanks
3rd August 2013, 17:21 | #286 | Link |
http://mewiki.project357.com/wiki/X264_Settings can give you an idea.
-Profile to "Not set" -CRF or quantizer to 0 I don't know much, these are what I could get out of wiki page. BTW did you lose presets because of TX264? |
3rd August 2013, 20:44 | #287 | Link | |
Are there any particular settings I need to select in order to generate 4:4:4 AVClossless encodes from my ProRes 4:4:4 sources? I'm not entirely sure when it happened. All I know is, all my pre-sets have disappeared from the PreDefs folder.
5th August 2013, 20:52 | #290 | Link |
Sadly, according to MediaInfo, everything is encoded at 4.2.0
5th August 2013, 22:29 | #292 | Link |
That's solved it... Many thanks...
3rd September 2013, 11:57 | #295 | Link |
Frame serever
Good job
I wonder if it would be possible implementarle the option work with Debug Frame Server. This would make the program more interesting as there are few who make and is a very interesting option for those who edit video. |
29th September 2013, 02:24 | #296 | Link |
I have problem it can't encode this certain file. It won't finish muxing
[9/29/2013 12:28:57 AM] Started deleting temp files... [9/29/2013 12:28:57 AM] Deleted 0 file(s). [9/29/2013 12:28:57 AM] Finished deleting temp files. [9/29/2013 12:29:35 AM] Started deleting temp files... [9/29/2013 12:29:35 AM] Deleted 0 file(s). [9/29/2013 12:29:35 AM] Finished deleting temp files. -------------------------------------------- [9/29/2013 12:29:38 AM] Starting encoding process [9/29/2013 12:29:38 AM] Command lines: -y -i "C:\Documents and Settings\Administrator\My Documents\Downloads\hentai2\Free.mkv" -vn -f wav -map 0:1 "C:\Documents and Settings\Administrator\Local Settings\Temp\1\TX264\\Free.wav" -cbr 96000 -hev2 -if "C:\Documents and Settings\Administrator\Local Settings\Temp\1\TX264\\Free.wav" -of "C:\Documents and Settings\Administrator\Local Settings\Temp\1\TX264\\Free.aac" --crf 20 --profile high --preset slow --tune animation --video-filter resize:width=848,height=480,method=bicubic --output "C:\Documents and Settings\Administrator\Local Settings\Temp\1\TX264\\Free.mkv" "C:\Documents and Settings\Administrator\My Documents\Downloads\hentai2\Free.mkv" chapters -s "C:\Documents and Settings\Administrator\My Documents\Downloads\hentai2\Free.mkv" tracks "C:\Documents and Settings\Administrator\My Documents\Downloads\hentai2\Free.mkv" 0:"C:\Documents and Settings\Administrator\Local Settings\Temp\1\TX264\\Free1.ass" --chapters "C:\Documents and Settings\Administrator\Local Settings\Temp\1\TX264\\chapters.txt" -o "C:\Documents and Settings\Administrator\My Documents\Downloads\TX264(0.9.7.3163)\TX264\\Free.mkv" "C:\Documents and Settings\Administrator\Local Settings\Temp\1\TX264\\Free.mkv" "C:\Documents and Settings\Administrator\Local Settings\Temp\1\TX264\\Free.aac" "C:\Documents and Settings\Administrator\Local Settings\Temp\1\TX264\\Free1.ass" --default-language jpn -------------------------------------------- [9/29/2013 12:29:38 AM] Files to be deleted are as follows: C:\Documents and Settings\Administrator\Local Settings\Temp\1\TX264\\Free1.ass ----Encoding Summary---- +Video -CRF: 20.00 -Preset: Slow -Profile: High -Tune: Animation -Level: Auto -Force const FPS: False -Encoding depth: 8-Bit -Subtitles: True -Chapter: True -Container: MKV +Resize -Size: 848x480 -Method: Bicubic +Crop -Disabled +Aspect ratio -Disabled +Audio -Encoder: Nero AAC -CBR: 96 kbps -Profile: HE2 +Effects -Disabled +Splitting -Disabled +Pause -Disabled Output Folder: C:\Documents and Settings\Administrator\My Documents\Downloads\TX264(0.9.7.3163)\TX264\ Temp Folder: C:\Documents and Settings\Administrator\Local Settings\Temp\1\TX264\ ----Encoding Summary---- [9/29/2013 12:29:38 AM] Done audio decoding ffmpeg version N-49610-gc2dd5a1 Copyright (c) 2000-2013 the FFmpeg developers built on Feb 5 2013 13:20:59 with gcc 4.7.2 (GCC) configuration: --enable-gpl --enable-version3 --disable-w32threads --enable-avisynth --enable-bzlib --enable-fontconfig --enable-frei0r --enable-gnutls --enable-libass --enable-libbluray --enable-libcaca --enable-libfreetype --enable-libgsm --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libopenjpeg --enable-libopus --enable-librtmp --enable-libschroedinger --enable-libsoxr --enable-libspeex --enable-libtheora --enable-libtwolame --enable-libvo-aacenc --enable-libvo-amrwbenc --enable-libvorbis --enable-libvpx --enable-libx264 --enable-libxavs --enable-libxvid --enable-zlib libavutil 52. 17.101 / 52. 17.101 libavcodec 54. 91.100 / 54. 91.100 libavformat 54. 61.104 / 54. 61.104 libavdevice 54. 3.103 / 54. 3.103 libavfilter 3. 35.101 / 3. 35.101 libswscale 2. 2.100 / 2. 2.100 libswresample 0. 17.102 / 0. 17.102 libpostproc 52. 2.100 / 52. 2.100 Input #0, matroska,webm, from 'C:\Documents and Settings\Administrator\My Documents\Downloads\hentai2\Free.mkv': Metadata: creation_time : 2013-09-19 23:22:39 Duration: 00:23:39.79, start: 0.000000, bitrate: 2405 kb/s Chapter #0.0: start 0.000000, end 16.934000 Metadata: title : Intro Chapter #0.1: start 16.934000, end 106.940000 Metadata: title : OP Chapter #0.2: start 106.940000, end 699.949000 Metadata: title : Part A Chapter #0.3: start 699.949000, end 1247.955000 Metadata: title : Part B Chapter #0.4: start 1247.955000, end 1337.920000 Metadata: title : ED Chapter #0.5: start 1337.920000, end 1419.794000 Metadata: title : Preview Stream #0:0(eng): Subtitle: ssa (default) Stream #0:1(jpn): Video: h264 (High 10), yuv420p10le, 1280x720, SAR 1:1 DAR 16:9, 23.98 fps, 23.98 tbr, 1k tbn, 47.95 tbc (default) Stream #0:2(jpn): Audio: aac, 48000 Hz, stereo, fltp (default) Codec 0x18000 is not in the full list. Stream #0:3: Attachment: unknown_codec Metadata: filename : Brianne_s_hand.ttf mimetype : application/x-truetype-font Codec 0x18000 is not in the full list. Stream #0:4: Attachment: unknown_codec Metadata: filename : Brush Strokes.ttf mimetype : application/x-truetype-font Codec 0x18000 is not in the full list. Stream #0:5: Attachment: unknown_codec Metadata: filename : Brushcut-Regular.ttf mimetype : application/x-truetype-font Codec 0x18000 is not in the full list. Stream #0:6: Attachment: unknown_codec Metadata: filename : Cartoon_Regular.ttf mimetype : application/x-truetype-font Codec 0x18000 is not in the full list. Stream #0:7: Attachment: unknown_codec Metadata: filename : DC___.TTF mimetype : application/x-truetype-font Codec 0x18000 is not in the full list. Stream #0:8: Attachment: unknown_codec Metadata: filename : laCartoonerie.TTF mimetype : application/x-truetype-font Codec 0x18000 is not in the full list. Stream #0:9: Attachment: unknown_codec Metadata: filename : playtime.ttf mimetype : application/x-truetype-font Codec 0x18000 is not in the full list. Stream #0:10: Attachment: unknown_codec Metadata: filename : QuaySansMdITCTT.TTF mimetype : application/x-truetype-font Codec 0x18000 is not in the full list. Stream #0:11: Attachment: unknown_codec Metadata: filename : SashasHand-Regular_0.ttf mimetype : application/x-truetype-font Codec 0x18000 is not in the full list. Stream #0:12: Attachment: unknown_codec Metadata: filename : TriplexSans-Bold.otf mimetype : application/x-truetype-font Codec 0x18000 is not in the full list. Stream #0:13: Attachment: unknown_codec Metadata: filename : WOODMD_.TTF mimetype : application/x-truetype-font Codec 0x18000 is not in the full list. Stream #0:14: Attachment: unknown_codec Metadata: filename : DAYROM__.ttf mimetype : application/x-truetype-font Output #0, wav, to 'C:\Documents and Settings\Administrator\Local Settings\Temp\1\TX264\\Free.wav': Chapter #0.0: start 0.000000, end 16.934000 Metadata: title : Intro Chapter #0.1: start 16.934000, end 106.940000 Metadata: title : OP Chapter #0.2: start 106.940000, end 699.949000 Metadata: title : Part A Chapter #0.3: start 699.949000, end 1247.955000 Metadata: title : Part B Chapter #0.4: start 1247.955000, end 1337.920000 Metadata: title : ED Chapter #0.5: start 1337.920000, end 1419.794000 Metadata: title : Preview Output file #0 does not contain any stream [9/29/2013 12:29:38 AM] Done audio encoding with neroaac ERROR: could not parse WAV file ************************************************************* * * * Nero AAC Encoder * * Copyright 2009 Nero AG * * All Rights Reserved Worldwide * * * * Package build date: Feb 18 2010 * * Package version: 1.5.4.0 * * * * See -help for a complete list of available parameters. * * * ************************************************************* [9/29/2013 1:07:41 AM] Done video encoding with x264 ffms [info]: 1280x720p 1:1 @ 24000/1001 fps (vfr) resize [warning]: converting from yuv420p10le to yuv420p16le resize [info]: resizing to 848x480 x264 [info]: using SAR=160/159 x264 [info]: using cpu capabilities: MMX2 SSE2 SSE3 Cache64 BMI1 x264 [info]: profile High, level 3.1 x264 [info]: frame I:403 Avg QP:16.19 size: 41855 x264 [info]: frame P:8529 Avg QP:18.39 size: 6012 x264 [info]: frame B:25109 Avg QP:23.75 size: 1151 x264 [info]: consecutive B-frames: 3.2% 5.1% 8.4% 38.5% 18.3% 26.6% x264 [info]: mb I I16..4: 26.8% 40.9% 32.3% x264 [info]: mb P I16..4: 3.5% 5.5% 1.5% P16..4: 25.1% 7.0% 5.0% 0.0% 0.0% skip:52.4% x264 [info]: mb B I16..4: 0.3% 0.7% 0.2% B16..8: 12.5% 1.6% 0.5% direct: 0.6% skip:83.6% L0:40.5% L1:55.7% BI: 3.7% x264 [info]: 8x8 transform intra:50.6% inter:72.0% x264 [info]: direct mvs spatial:100.0% temporal:0.0% x264 [info]: coded y,uvDC,uvAC intra: 52.9% 72.8% 44.2% inter: 5.1% 7.1% 1.0% x264 [info]: i16 v,h,dc,p: 22% 21% 8% 49% x264 [info]: i8 v,h,dc,ddl,ddr,vr,hd,vl,hu: 13% 14% 15% 7% 10% 9% 11% 9% 12% x264 [info]: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 18% 13% 12% 8% 11% 10% 9% 9% 10% x264 [info]: i8c dc,h,v,p: 32% 30% 20% 18% x264 [info]: Weighted P-Frames: Y:2.8% UV:2.1% x264 [info]: ref P L0: 57.8% 6.4% 13.8% 6.2% 4.1% 3.7% 2.8% 1.8% 1.3% 1.7% 0.3% 0.0% x264 [info]: ref B L0: 78.4% 7.6% 5.0% 2.5% 2.2% 1.4% 1.4% 0.9% 0.5% x264 [info]: ref B L1: 95.3% 4.7% x264 [info]: kb/s:546.79 encoded 34041 frames, 14.96 fps, 546.80 kb/s [9/29/2013 1:07:42 AM] Done extracting chapters from mkv CHAPTER01=00:00:00.000 CHAPTER01NAME=Intro CHAPTER02=00:00:16.934 CHAPTER02NAME=OP CHAPTER03=00:01:46.940 CHAPTER03NAME=Part A CHAPTER04=00:11:39.949 CHAPTER04NAME=Part B CHAPTER05=00:20:47.955 CHAPTER05NAME=ED CHAPTER06=00:22:17.920 CHAPTER06NAME=Preview [9/29/2013 1:07:46 AM] Done extracting subtitle from mkv Extracting track 0 with the CodecID 'S_TEXT/ASS' to the file 'C:\Documents and Settings\Administrator\Local Settings\Temp\1\TX264\\Free1.ass'. Container format: SSA/ASS text subtitles Progress: 100% [9/29/2013 1:07:47 AM] Done muxing to mkv mkvmerge v6.3.0 ('You can't stop me!') built on Jun 28 2013 20:09:41 Error: The file 'C:\Documents and Settings\Administrator\Local Settings\Temp\1\TX264\\Free.aac' could not be opened for reading: open file error. [9/29/2013 1:07:47 AM] Started deleting temp files... [9/29/2013 1:07:47 AM] Deleted 4 file(s). [9/29/2013 1:07:47 AM] Finished deleting temp files. [9/29/2013 1:07:47 AM] Finished encoding in: 00:36:51 [9/29/2013 1:07:47 AM] Cannot find output file C:\Documents and Settings\Administrator\My Documents\Downloads\TX264(0.9.7.3163)\TX264\\Free.mkv |
7th October 2013, 21:06 | #300 | Link |
@Ruriko, I think I solved your problem. Download tx264.exe from here. Make sure you have a backup of older one to be safe. With this build I can encode the sample you sent me.
Edit: I forgot, you should also download this and copy "wavi.exe" to "Tools" folder.
TEncoder-Multithreaded GUI for FFMpeg and MEncoder TX264-x264 GUI with audio encoding, subtitle and chapter TAudioConverter-Multithreaded Audio Converter/Extractor THandBrake-HandBrake GUI Last edited by ozok; 7th October 2013 at 21:09. Reason: Added wavi.exe |
faac, mkv, mp4, neroaacenc, x264 |
