29th June 2015, 20:57 | #1602 | Link |
Myrsloik
I'm feeling very stupid to ask such a dumb question - but do you have a Windows build of mpv, compiled with VapourSynth support? In other words - where can I find .lib/.dll files suitable for linking with gcc?
SVPflow motion interpolation |
30th June 2015, 04:58 | #1603 | Link | |
unsigned int
x86_64-w64-mingw32-g++ -o app.exe app.o -L/path/to/vsscriptdll -lvsscript
Buy me a "coffee" and/or hire me to write code! |
30th June 2015, 09:54 | #1604 | Link |
C:/msys32/mingw32/lib/vapoursynth.lib: error adding symbols: File in wrong format Code:
const VSAPI *vs = getVapourSynthAPI(VAPOURSYNTH_API_VERSION); qDebug()<<"VS: "<<(vs!=0); return 0; Code:
g++ .... -L"C:\Program Files (x86)\VapourSynth\core32" -lvapoursynth undefined reference to `_imp__getVapourSynthAPI@4'
SVPflow motion interpolation Last edited by chainik_svp; 30th June 2015 at 12:31. |
30th June 2015, 21:18 | #1605 | Link | |
unsigned int
For vsscript.dll this worked: Code:
LIBRARY vsscript EXPORTS vsscript_clearEnvironment@4 vsscript_clearOutput@8 vsscript_clearVariable@8 vsscript_createScript@4 vsscript_evaluateFile@12 vsscript_evaluateScript@16 vsscript_finalize@0 vsscript_freeScript@4 vsscript_getCore@4 vsscript_getError@4 vsscript_getOutput@8 vsscript_getVSApi@0 vsscript_getVariable@12 vsscript_init@0 vsscript_setVariable@8 Code:
dlltool -d vsscript.def -l vsscript.lib For vapoursynth.dll, this .def file should work: Code:
LIBRARY vapoursynth EXPORTS getVapourSynthAPI@4
30th June 2015, 22:23 | #1606 | Link |
jackoneill
Have you actually tried to execute compiled binary? Yeah, it links w/o errors, but gives "procedure entry point "getVapourSynthAPI@4" couldn't be located" at runtime depends.exe shows that .exe asks for "getVapourSynthAPI@4" while the library contains "_getVapourSynthAPI@4" You may think that adding "_" to the .def file could help? no it that case linking fails again =============== The correct answer is: Code:
dlltool --add-stdcall-underscore -d vsscript.def -l vsscript.lib I wonder why it isn't included into "SDK"?
SVPflow motion interpolation Last edited by chainik_svp; 30th June 2015 at 22:38. |
1st July 2015, 06:57 | #1607 | Link |
unsigned int
I tried to run it in Wine, but VapourSynth isn't installed there, so it only got as far as reporting that Python34.dll was missing. I'm glad you got it to work.
20th July 2015, 15:02 | #1608 | Link | |
Do you need to link in both the vapoursynth.lib and the vsscript.lib ? Can you show me how you do this linking ? Thanks again, man ! |
21st July 2015, 20:38 | #1609 | Link | |
unsigned int
I think a command similar to this works: Code:
g++ -o asdf.exe asdf.cpp -L. -lvsscript
30th July 2015, 14:18 | #1612 | Link |
Well, when using ffsm2 to open clips with variable framerate, it gives me a constant framerate in the end (only in the metadata, since the doc says that there's the same number of frame), so, how would I do to get the same framerate in the output file?
30th July 2015, 14:24 | #1613 | Link |
Raw video, Y4M etc. don't know about variable framerate. You have to save timecodes into external file using vspipe and load into encoder/muxer.
vspipe script.vpy - --y4m --timecodes timecodes.txt | x264 - --demuxer y4m --tcfile-in timecodes.txt -o output.mkv (btw.: vspipe help is missing "--tcfile-in" part of x264) I have not tested this: 1.) I don't know if ffms2 creates frame duration metadata 2.) I don't know if timecodes.txt is created immediately for use At least in AviSynth ffms2 also has a parameter to create timecode file directly. I don't know if that parameter is available in the VapourSynth version. (And of course it would be useless in case you actually want to work with the frame duration metadata within VapourSynth) Last edited by sneaker_ger; 30th July 2015 at 14:27. |
30th July 2015, 15:20 | #1614 | Link | |
30th July 2015, 16:20 | #1615 | Link |
unsigned int
1) ffms2 does attach the frame duration to each frame.
2) The timecodes file is only complete after vspipe writes all the frames. If sneaker_ger's command doesn't work, you'll have to pass the timecodes file to the muxer after x264 is done.
30th July 2015, 18:03 | #1616 | Link | |
vspipe script.vpy --y4m --timecodes tc.dat out.y4m x264 out.y4m --demuxer y4m --tcfile-in tc.dat -o out.mkv did the trick. |
30th July 2015, 18:19 | #1617 | Link |
Yes, like jackoneill said timecode file is not ready at start of conversion (when x264 needs it), so my example does not work.
You could do like he suggested without having to save huge y4m file: vspipe script.vpy --y4m --timecodes tc.dat - | x264 - --demuxer y4m -o es.264 mkvmerge -o out.mkv --timecodes "0:tc.dat" es.264 (but since x264 does not have timecodes it cannot do things like framerate aware CRF if you care about that) |
30th July 2015, 19:07 | #1618 | Link |
Actually, this doesn't work well. I have two problems:
- The output video is offset by -0.217s - I have random passages where I get garbled frame order and/or frame repetition. Original segment, garbled segment. (I hope it's okay with the rules; it's only a less than 2s segment ). I insist on the fact that this problem appears randomly. I also tried with the mkvmerge method, still fucked. Last edited by Q3CPMA; 30th July 2015 at 19:14. |
30th July 2015, 19:22 | #1619 | Link |
Can you test latest RC?
http://forum.doom9.org/showpost.php?...postcount=2088 |
30th July 2015, 19:45 | #1620 | Link | |
