Old 24th September 2019, 18:26   #7041  |  Link
Boulder
Pig on the wing
Boulder's Avatar
And my question that I posted to the x265 mailing list still has not been approved so I don't know if any dev saw the question regarding the motion search methods.
Old 24th September 2019, 19:27   #7042  |  Link
Selur
Selur's Avatar
did a quick test trying to reproduce this here (did no filtering, just decoded with ffmpeg and piped to x265), for me too uhm was slower than star, but the speeds were similar.
--me star:
"I:\Hybrid\64bit\x265.exe" --preset medium --input - --output-depth 10 --y4m --profile main10 --me star --limit-modes --no-early-skip --no-open-gop --opt-ref-list-length-pps --lookahead-slices 0 --crf 18.00 --opt-qp-pps --cbqpoffs -2 --crqpoffs -2  --limit-refs 0 --ssim-rd --psy-rd 2.50 --rdoq-level 2 --psy-rdoq 10.00 --aq-mode 0 --deblock=-1:-1 --limit-sao --no-repeat-headers --range limited --colormatrix bt709 --output "E:\Temp\19_56_10_6810_02.265"
-> "encoded 2868 frames in 325.41s (8.81 fps), 4606.13 kb/s, Avg QP:23.78"
--me uhm:
"I:\Hybrid\64bit\x265.exe" --preset medium --input - --output-depth 10 --y4m --profile main10 --me umh --limit-modes --no-early-skip --no-open-gop --opt-ref-list-length-pps --lookahead-slices 0 --crf 18.00 --opt-qp-pps --cbqpoffs -2 --crqpoffs -2  --limit-refs 0 --ssim-rd --psy-rd 2.50 --rdoq-level 2 --psy-rdoq 10.00 --aq-mode 0 --deblock=-1:-1 --limit-sao --no-repeat-headers --range limited --colormatrix bt709 --output "E:\Temp\20_03_51_9010_02.265"
-> "encoded 2868 frames in 326.89s (8.77 fps), 4605.07 kb/s, Avg QP:23.78"
I used:
x265 [info]: HEVC encoder version 3.1+20-913823aa15cd
x265 [info]: build info [Windows][GCC 9.2.0][64 bit] 10bit
x265 [info]: using cpu capabilities: MMX2 SSE2Fast LZCNT SSSE3 SSE4.2 AVX FMA3 BMI2 AVX2
on a Ryzen 7 1800X
Ran the calls a second time this time I got:
--me star: "encoded 2868 frames in 320.13s (8.96 fps), 4606.13 kb/s, Avg QP:23.78"
--me umh: "encoded 2868 frames in 322.27s (8.90 fps), 4605.07 kb/s, Avg QP:23.78"
-> So here too, uhm is slower, but not a lot, so this might still be source depended.
Old 25th September 2019, 05:39   #7043  |  Link
Boulder
Pig on the wing
Boulder's Avatar
There are some early exits in star which probably don't exist in umh, so that source dependency would make sense. The method is some kind of an adaptation of what's in HM encoder.
https://xevc.wordpress.com/2014/01/2...of-hm-encoder/
Old 25th September 2019, 09:06   #7044  |  Link
markiemarcus
I've seen some gains from using umh instead of star on animated sources. Admittedly slight at 1080p, but definitely visible at 720p and below. On live action I really can't spot the difference.
markiemarcus is offline   Reply With Quote
Old 25th September 2019, 15:51   #7045  |  Link
Barough
Barough's Avatar
x265 v3.2+3-fdd69a766881 (32 & 64-bit 8/10/12bit Multilib Windows Binaries) (GCC 9.2.0)
Barough is online now   Reply With Quote
Old 25th September 2019, 20:14   #7046  |  Link
Natty
Noob
release notes for v3.2
https://bitbucket.org/multicoreware/...leasenotes.rst
Natty is offline   Reply With Quote
Old 26th September 2019, 07:35   #7047  |  Link
The speed of "far" motion search algorithms depends on the average amount of motion. Some of them can terminate early if the optimum is found close to an intermediate step. Disclaimer: If I understood these algorithms correctly...
Old 26th September 2019, 21:52   #7048  |  Link
Ma
Originally Posted by Boulder View Post
The clip that causes this one can be found here:
https://drive.google.com/open?id=1AU...FwqqFfOZLgNr4M
x265-3.1+14 works fine.
Could you specify your x265 options to reproduce the problem?
Old 27th September 2019, 04:43   #7049  |  Link
Boulder
Pig on the wing
Boulder's Avatar
This is what I've used for that one:
--input - --y4m --input-depth 16 --dither --sar 1:1 --profile main10
--rc-lookahead 120 --min-keyint 5 --keyint 480 --splitrd-skip --colorprim "bt709" --transfer "bt709" --colormatrix "bt709"
--preset slower --rd-refine --subme 4 --ctu 32 --qg-size 16 --limit-refs 1 --limit-tu 3 --bframes 16 --deblock -2:-1 --no-sao
--cbqpoffs -3 --crqpoffs -3 --hme --hme-search umh,umh,star --merange 26 --qcomp 0.7 --max-merge 2 --aq-mode 3 --aq-strength 0.6 --crf 18.5
Old 27th September 2019, 12:25   #7050  |  Link
Selur
Selur's Avatar
does anyone have a current x265 build with stv ?
Old 28th September 2019, 07:19   #7051  |  Link
Selur
Selur's Avatar
thanks!
Old 28th September 2019, 14:02   #7052  |  Link
-QfG-
QfG Group Germany
-QfG-'s Avatar
Has anyone results between AQ1 and AQ4? I've made 2 test encodes and see no difference in the movie, but have a smaller filesize with AQ4. Or i'm blind...
-QfG- is offline   Reply With Quote
Old 28th September 2019, 17:57   #7053  |  Link
pistacho
Possible bug:
Commit 21db162 (https://bitbucket.org/multicoreware/...4a59eb7326b46a) causes slowdown even is not used aq-mode 4 and output is identical.
Command line used:
"T:\TEST\x265\3108\x265_x64.exe" - --y4m --frames 1000 --crf 20.0 --preset "medium" --aq-mode 3 --keyint 240 --no-open-gop
--colorprim "bt709" --transfer "bt709" --colormatrix "bt709" --sar 1:1 --output "T:\TEST\encode.265"
dec  [info]: Intel Quick Sync: API LEVEL 1.29, HW
dec  [info]: 1920x1080, YV12, 24000/1001 fps, 1000 frames
y4m  [info]: 1920x1080 fps 24000/1001 i420p8 sar 1:1 unknown frame count
raw  [info]: output file: T:\TEST\encode.265
x265 [info]: HEVC encoder version 3.1+7-147fb92c5ed5
x265 [info]: build info [Windows][GCC 9.2.0][64 bit] 8bit
x265 [info]: Main profile, Level-4 (Main tier)
x265 [info]: Thread pool created using 8 threads
x265 [info]: Slices                              : 1
x265 [info]: frame threads / pool features       : 3 / wpp(17 rows)
x265 [info]: Coding QT: max CU size, min CU size : 64 / 8
x265 [info]: Residual QT: max TU size, max depth : 32 / 1 inter / 1 intra
x265 [info]: ME / range / subpel / merge         : hex / 57 / 2 / 3
x265 [info]: Keyframe min / max / scenecut / bias: 23 / 240 / 40 / 5.00
x265 [info]: Lookahead / bframes / badapt        : 20 / 4 / 2
x265 [info]: b-pyramid / weightp / weightb       : 1 / 1 / 0
x265 [info]: References / ref-limit  cu / depth  : 3 / off / on
x265 [info]: AQ: mode / str / qg-size / cu-tree  : 3 / 1.0 / 32 / 1
x265 [info]: Rate Control / qCompress            : CRF-20.0 / 0.60
x265 [info]: tools: rd=3 psy-rd=2.00 early-skip rskip signhide tmvp b-intra
x265 [info]: tools: strong-intra-smoothing lslices=6 deblock sao
x265 [info]: frame I:     11, Avg QP:16.20  kb/s: 6958.02
x265 [info]: frame P:    275, Avg QP:20.60  kb/s: 3482.34
x265 [info]: frame B:    714, Avg QP:25.57  kb/s: 356.63
x265 [info]: Weighted P-Frames: Y:10.9% UV:6.5%
x265 [info]: consecutive B-frames: 22.4% 4.5% 4.5% 38.1% 30.4%
encoded 1000 frames in 17.71s (56.47 fps), 1288.81 kb/s, Avg QP:24.10
x265 [info]: HEVC encoder version 3.1+8-21db162c8622
encoded 1000 frames in 19.56s (51.13 fps), 1288.81 kb/s, Avg QP:24.10
Outputs seems bit-identical since the QP's and bitrates match so no "slow for best quality" is justified.
pistacho is offline   Reply With Quote
Old 28th September 2019, 18:03   #7054  |  Link
-QfG-
QfG Group Germany
-QfG-'s Avatar
AQ4 is the new feature of version 3.2 from x265. AQ3 ist still good for BT709 output.
But the question is, have anyone see differences with YUV420P10 BT2020 HDR AQ1 and AQ4?
Old 28th September 2019, 18:09   #7055  |  Link
pistacho
I don't mean this. I'm talking about the new "AQ mode 4" function causing slowdown even when it's not used.
Old 29th September 2019, 15:50   #7056  |  Link
pistacho
I found the cause:
Some code related to AQ mode 4 is executed always.
This patch restores previous performance and not break anything (i think).
On file slicetype.cpp
line 481 replace
#define AQ_EDGE_BIAS 0.5
#define EDGE_INCLINATION 45
                uint32_t numCuInHeight = (maxRow + param->maxCUSize - 1) / param->maxCUSize;
                int maxHeight = numCuInHeight * param->maxCUSize;
                intptr_t stride = curFrame->m_fencPic->m_stride;
                pixel *edgePic = X265_MALLOC(pixel, stride * (maxHeight + (curFrame->m_fencPic->m_lumaMarginY * 2)));
                pixel *gaussianPic = X265_MALLOC(pixel, stride * (maxHeight + (curFrame->m_fencPic->m_lumaMarginY * 2)));
                pixel *thetaPic = X265_MALLOC(pixel, stride * (maxHeight + (curFrame->m_fencPic->m_lumaMarginY * 2)));
                memset(edgePic, 0, stride * (maxHeight + (curFrame->m_fencPic->m_lumaMarginY * 2)) * sizeof(pixel));
                memset(gaussianPic, 0, stride * (maxHeight + (curFrame->m_fencPic->m_lumaMarginY * 2)) * sizeof(pixel));
                memset(thetaPic, 0, stride * (maxHeight + (curFrame->m_fencPic->m_lumaMarginY * 2)) * sizeof(pixel));
                if (param->rc.aqMode == X265_AQ_EDGE)
                    edgeFilter(curFrame, edgePic, gaussianPic, thetaPic, stride, maxRow, maxCol);
                int blockXY = 0, inclinedEdge = 0;
with
		pixel *edgePic = NULL;
		pixel *gaussianPic = NULL;
		pixel *thetaPic = NULL;
and line 510
                     pixel *edgeImage = edgePic + curFrame->m_fencPic->m_lumaMarginY * stride + curFrame->m_fencPic->m_lumaMarginX;
                     pixel *edgeTheta = thetaPic + curFrame->m_fencPic->m_lumaMarginY * stride + curFrame->m_fencPic->m_lumaMarginX;
with
                     pixel *edgeImage = edgePic + curFrame->m_fencPic->m_lumaMarginY * curFrame->m_fencPic->m_stride + curFrame->m_fencPic->m_lumaMarginX;
                     pixel *edgeTheta = thetaPic + curFrame->m_fencPic->m_lumaMarginY * curFrame->m_fencPic->m_stride + curFrame->m_fencPic->m_lumaMarginX;
and line 545
                X265_FREE(edgePic);
                X265_FREE(gaussianPic);
                X265_FREE(thetaPic);
with
			X265_FREE(edgePic);
And binary with this patch applied: x265 v3.2 patched x64 GCC 9.2.0
Old 30th September 2019, 07:52   #7057  |  Link
You should send your patch to the x265 Developer mailing list. They prefer it in "diff" format and in the mail body.
_
x265 3.2+3-fdd69a766881 (MSYS2/MinGW, GCC 9.2.0)
Old 30th September 2019, 18:06   #7058  |  Link
pistacho
Diff patch send to mailing list.
Old 30th September 2019, 18:14   #7059  |  Link
Boulder
Pig on the wing
Boulder's Avatar
I couldn't replicate that difference between the two versions on my 3700X. I used the VS 2019 AVX2 builds from http://www.msystem.waw.pl/x265/
With 3.1+7, encoded 2000 frames in 461.37s (4.33 fps), 3467.58 kb/s, Avg QP:20.97
With 3.1+8, encoded 2000 frames in 459.33s (4.35 fps), 3467.58 kb/s, Avg QP:20.97
Old 30th September 2019, 18:18   #7060  |  Link
qtwigg
x265 not encoding the whole video
I have been having this issue; I give my x265 a movie and the x265 chooses how much it wants to encode. I give it a 45 minute show, it does 30 minutes. I give it a 1:40 hour movie, it decides not to do the last 10 minutes. I say it decides because it is not erroring. It literally finishes, mux into a container and says, Done! Why does it do this? Never had this problem before and the last 6 months maybe been having this issue randomly, off and on. Any ideas?
qtwigg is offline   Reply With Quote
