Old 10th December 2009, 16:47   #241  |  Link
VFR maniac
Spinner of yarns
VFR maniac's Avatar
I may have found a new bug.
DiAVC's YV12 output is not bit-identical with other AVC decoders' except for DivX's.(DivX's AVC decoder still has deblocking issue.)
Here is a sample I encoded with x264.nl's rev1369.
http://www.megaupload.com/?d=Y69QJD0I
pass: bugreport@vfrmaniac
僕と契約して、L-SMASH developerになってよ!
L-SMASH | L-SMASH Works | Opus-in-ISOBMFF specification and reference software
VFR maniac is offline   Reply With Quote
Old 10th December 2009, 17:34   #242  |  Link
schweinsz
A new alpha version is available at http://di-avc.com/DiAVC_alpha.zip.
Changes:
fix the crash bug for some ts/m2ts contents.
Enhanced video/audio synchronization.
add queues for video renderers that are "RecieveCanBlock()==S_OK".
schweinsz is offline   Reply With Quote
Old 10th December 2009, 17:35   #243  |  Link
schweinsz
There do remain some deblock-related bugs for P frames, I will fix it recently.
Old 10th December 2009, 19:30   #244  |  Link
Stephen R. Savage
Stephen R. Savage's Avatar
Good work. Latest alpha version greatly reduces the seeking problem, though it can still fail occasionally (less than 5% here). There seems to be an audio glitch when seeking until the video catches up, but that is tolerable and within expectation. Choppy playback has also been greatly reduced. Tested on 480p60 and 1080p24 samples, and smoothness is now comparable to other decoders.
Still some initialization delay though.
However, there is one question I'd like to ask. Is implementing fully compliant deblocking a difficult or tricky task? I know that in the past, CoreAVC had many deblocking problems for several versions before they were fixed in v1.5.
Edit: It seems that the timestamp can drift by up to 1 frame, causing synchronization issues with subtitles.
Edit2: This seems to relate to seeking, and seeking again can make it drift back into place.
Stephen R. Savage is offline   Reply With Quote
Old 11th December 2009, 08:52   #245  |  Link
schweinsz
It is not difficult. It is just a history problem when I design the DiAVC in scratch. As VFR Maniac reported it, I will fix it today. As it only influence in some very special cases, so I delay to fix it.
I will loop into it.
Old 11th December 2009, 09:42   #246  |  Link
chungkid1
i got some probs with the h264 flv from youtube
chungkid1 is offline   Reply With Quote
Old 11th December 2009, 10:01   #247  |  Link
schweinsz
Could you provide the sample to me?
Old 11th December 2009, 16:55   #248  |  Link
Stephen R. Savage
Report of possible problem: When using DiAVC as default decoder (set with DiAVCsettings.exe), VirtualDub hangs and stops responding when opening H.264 using the DirectShow input driver.
Old 11th December 2009, 19:14   #249  |  Link
Lam3rD
DiAVC can't work with Winamp, either. It only shows black screen, while with the same decoder configurations it works with MPC-HC, I've only managed to simulate the problem in MPC-HC by changing the renderer to either of the 2 Null options. Switching back to ffdshow and both players work correctly, so I assume it might be a renderer problem.
OS is XP SP3 btw
Lam3rD is offline   Reply With Quote
Old 12th December 2009, 22:07   #250  |  Link
schweinsz
I have fixed the all deblocking bugs today and the next alpha version will be correct.
OS is XP SP3 btw
The two problems are incured by unsupporting of the "FormatVideoInfo" perhaps, I will add it in the next alpha version.
Old 13th December 2009, 05:04   #251  |  Link
chungkid1
@schweinsz: Here's the sample
http://www.mediafire.com/myfiles.php
Old 13th December 2009, 05:56   #252  |  Link
chungkid1
Ah,sr about that.Here's the link
http://www.mediafire.com/?mznynonmmyl
Old 13th December 2009, 06:24   #253  |  Link
Keiyakusha
契約者
Keiyakusha's Avatar
Reuploaded chungkid1's sample so debugging can go faster. Since not everyone can access mediafire for some reason...
http://www.multiupload.com/1KFX3QIGLU
Also, this stream works for me. So far this problem appears only when DiAVC connected to MPC-HC's flv splitter.
Keiyakusha is offline   Reply With Quote
Old 13th December 2009, 09:41   #254  |  Link
Stephen R. Savage
@Keiyakusha: What other FLV splitters are there? The only one I know of is the Gabest version in MPC and FLVSplitter.ax.
Old 13th December 2009, 13:42   #255  |  Link
Selur
Selur's Avatar
Small question: Has anyone DiAVC running inside MPC-HC 64bit?
Old 13th December 2009, 13:52   #256  |  Link
namaiki
afaik It's not built for 64-bit, so it shouldn't appear there.
namaiki is offline   Reply With Quote
Old 13th December 2009, 15:03   #257  |  Link
Avira Premium Security Suite reports the installer to be the backdoor "BDS/MonoBot.K".
According to VirusTotal (where Avira is reported as "AntiVir"), this happens for several more scanner engines (12/41), like Ikarus, Kaspersky, McAfee-GW, Symantec...
LigH is online now   Reply With Quote
Old 13th December 2009, 15:10   #258  |  Link
Keiyakusha
契約者
Keiyakusha's Avatar
Have no idea. But this doesn't mean there is no ways to extract the stream from the container
Old 13th December 2009, 15:30   #259  |  Link
LoRd_MuldeR
Software Developer
LoRd_MuldeR's Avatar
The problem (probably a FALSE POSITIVE) is in the "DiAVCSetting.exe" file (see Details). The actual AX file definitely is clean:
http://www.virustotal.com/de/analisi...248-1260713992
Old 13th December 2009, 16:04   #260  |  Link
yesgrey
I'm getting the same. Can we use only the AX file and simply delete the "DiAVCSetting.exe" file?
yesgrey is offline   Reply With Quote
avc, diavc, fastest decoder, h.264, software
