Old 13th January 2006, 02:11   #221  |  Link
Scoty
Scoty's Avatar
this Codec is very great. with MPC i can run it but how can i use with WMP 9 or 10 ?
Scoty is offline   Reply With Quote
Old 13th January 2006, 02:41   #222  |  Link
loni_blues
And for lossless support?
loni_blues is offline   Reply With Quote
Old 13th January 2006, 05:01   #223  |  Link
ChronoReverse
Originally Posted by [Toff]
New build up :
http://coreavc.corecodec.org/CoreAVC20060113.7z
Version 0.0.0.4 Alpha (20060113) :
Support for VSSH FOURCC
Support for YUY2 output
Force anamorphic flag on renderer
You can thank Haali for this release ;-)
Haali gets a cookie. VMR9 Renderless mode is working perfectly in Media Player Classic now. I'm getting my automatic aspect ratio and my softsubs.
ChronoReverse is offline   Reply With Quote
Old 13th January 2006, 09:08   #224  |  Link
Pookie
You CoreAVC guys deserve medals for this big leap in playback functionality, and I mean BIG !
Thank you very, very much
Pookie is offline   Reply With Quote
Old 13th January 2006, 10:56   #225  |  Link
Yes - thank you [Toff], thank you Haali. YUY2 output will help my old and crappy GeForce2 a little.
Old 13th January 2006, 11:25   #226  |  Link
hippoth
playboi
hippoth's Avatar
@BetaBoy
A new TCMP-version (NOT TCPMP) is coming soon (I hope so). What can we expect in relation to AVC support? Is it similar to TCPMP?
hippoth is offline   Reply With Quote
Old 13th January 2006, 11:26   #227  |  Link
SeeMoreDigital
SeeMoreDigital's Avatar
Hmmm.
I'm still unable to get anamorphiclly signalled MPEG-4 AVC streams within AVI to auto AR in Media Player Classic or WMP10. And it's no-go with MPEG-4 AVC streams within MP4 in Media Player Classic too!
When tested on my other WinXP boot, the same encodes work fine with Haali's splitter!
Cheers
Old 13th January 2006, 11:31   #228  |  Link
sillKotscha
what's this for?
sillKotscha's Avatar
Originally Posted by SeeMoreDigital
Hmmm.
at first I've experienced the same beahviour with your posteted clip - but than I've reinstalled latest Haali Media Splitter and wOOt
what about http://tcpmp.corecodec.org/tcpmpx/index.htm ?
I can't see anything 'cause FireFox does need a plugin and I'm to dumb to install the required one...
sillKotscha is offline   Reply With Quote
Old 13th January 2006, 12:23   #229  |  Link
bond
Originally Posted by bond
basically the nero mp4 parser was the one which introduced the way how avc mp4 parsing is done now in as good as all mp4 parsers (haali, gabest, elecard...), so its in a way the benchmark
coreavc shows the same behaviour with the nero parser as with gabest here, which tells me coreavc doesnt read out the anamorphic resize correctly it gets from the parsers (they attach the SPS/PPS storing the ar info)
propably haali does something additional/different which makes coreavc work
but still, this means coreavc has incomplete anamorphic resize support with mp4
still the case with 0.0.0.4
anamorphic resize works with haali's mp4 parser, but not with nero's (and all the other mp4 parsers acting the same way as nero, like gabest, elecard...)
therefore i think haali does something different than all the others making coreavc not resize and therefore the support in coreavc is, unfortunately, still incomplete
Between the weak and the strong one it is the freedom which oppresses and the law that liberates (Jean Jacques Rousseau)
I know, that I know nothing (Socrates)
MPEG-4 ASP FAQ | AVC/H.264 FAQ | AAC FAQ | MP4 FAQ | MP4Menu stores DVD Menus in MP4 (guide)
Ogg Theora | Ogg Vorbis
use WM9 today and get Micro$oft controlling the A/V market tomorrow for free
bond is offline   Reply With Quote
Old 13th January 2006, 12:42   #230  |  Link
SeeMoreDigital
....therefore i think haali does something different than all the others making coreavc not resize and therefore the support in coreavc is, unfortunately, still incomplete
Agreed....
I cross-checked to see if Media Player Classic's own internal MP4 parser was working okay by playing some anamorphic MPEG-1 and MPEG-2 in MP4 streams (muxed using YAMB/MP4box) and they work perfectly
Cheers
Old 13th January 2006, 12:48   #231  |  Link
bond
thx to this i can now connect to vmr9 without the need for the avi decompressor doing the colorspace conversion
some random speed comparison between yv12 and yuy2 output:
yv12: 72.32fps
yuy2: 67.47fps (-7%)
edit:
is the colorspace conversion done in coreavc lossless?
Old 13th January 2006, 13:29   #232  |  Link
3ngel
New build up :
It works absolutely great on my side! Great!
One question, how can i know what colorspace is used during the decoding? I use MPC. Is there a way to force the output colorspace to RGB? You can add the option in the control panel of DirectShow filter to decide the output color space?
3ngel is offline   Reply With Quote
Old 13th January 2006, 13:39   #233  |  Link
videomixer9
ffdshow fan
Isn't there a way to make GPU do all the colorspace conversions via directx or something? I still wonder why this things cannot be easily done via simple interfaces to the graphics adapter. Imo VMR9 should've been made that way though, connect with anything and convert via hardware to anything else ... but now I'd think filters could fix this up at least maybe ...
videomixer9 is offline   Reply With Quote
Old 13th January 2006, 16:14   #234  |  Link
Koti
Always trying
Koti's Avatar
New build up :
Thx Haali , Toff , Picard , CoreCodec
Koti is offline   Reply With Quote
Old 13th January 2006, 17:05   #235  |  Link
SeeMoreDigital
Agreed....
I wonder, would it be possible to place some "user settings" that can be accessed and adjusted via the filters "Properties" widow: -
Cheers
Old 13th January 2006, 17:33   #236  |  Link
[)370|\|470!2
dentist-experimenter
[)370|\|470!2's Avatar
New build up :
Just great! With an YUY2 it's now possible to mess around with
saturation/brightness/contrast. Thx Core team. Keep up teh
good work.
20 years and ubuntu has just restored my faith in humanity ...lol
[)370|\|470!2 is offline   Reply With Quote
Old 13th January 2006, 17:43   #237  |  Link
foxyshadis
ангел смерти
foxyshadis's Avatar
GPUs doing colorspace conversions is what causes so many problems with YUV levels being incorrectly converted to RGB for output, and why the big flamewar over ffdshow and/or vmr9 sucking erupted. Still, it's worth investigating if you need the speed and can find a colorspace it doesn't trash.
Old 13th January 2006, 18:08   #238  |  Link
Revgen
I personally have trouble with VMR9/VMR7 whever I use FFDShow or CoreAVC. I pretty much stick to Ol' Fashioned Hardware Overlay.
Pirate: Now how would you like to die? Would you like to have your head chopped off or be burned at the stake?
Curly: Burned at the stake!
Moe: Why?
Curly: A hot steak is always better than a cold chop.
Revgen is offline   Reply With Quote
Old 14th January 2006, 03:37   #239  |  Link
Isochroma
RGB24 for CoreAVC
Thank you CoreCodec team for your awesome work! Unfortuantely, my GeForce FX5200 (and MX400) don't do either YUY2 or YV12 colorspace conversions right - the result looks really ugly - faded, washed out colors.
When you get time, it would be really great to add RGB24 output to your decode filter, thanks!
Isochroma is offline   Reply With Quote
Old 14th January 2006, 09:49   #240  |  Link
molinacabaleiro
mpc 6481 + ffdshow = 40% cpu
tcpmp + ffmpeg = 20% cpu
not bad, but ogg vorbis volume goes down quite a bit compared to radlight decoder
what do i do with CoreAVC.ax so mpc will recognize it?
when i uninstall ffdshow it resorts to nero for x264 playback
molinacabaleiro is offline   Reply With Quote
codec, coreavc, corecodec, coremvc, cuda, decoder, dxva, h.264, mvc, scam
