Old 24th August 2011, 16:55   #1861  |  Link
ggtop
Thank you for your quick reply. To use the labels instead is what is wanted to try next.
But I wonder what is the edit title textbox is good for?
You extract the original titlename from the filename so you can 100% sure it is valid. So it would be good it AVStoDVD would use the original title internally for temp files and so on and the edited name for the label. Or you change the behaviour of the textbox to read-only, because who would need a titlename that has to be changed a second time for the label...
ggtop
Old 24th August 2011, 20:27   #1862  |  Link
shreeit
@MrC..Sorry one more time..I am trying to understand and learn..You suggested Muxman refuse to retain audio track. I used tool with two .mkv files. Boths files had DTS 6.1. File1 is success and file2 is half the size of actual .mkv file and no audio.
file1 log__________________________
<8/23/2011 3:31:34 PM>
TITLE 1 SOURCE FILES
Video: C:\Users\xyz\Downloads\file1.mkv
Info: AVC - 3014 kbps - 1280x560 - DAR 2.286 - 23.976 fps (CFR) - Progressive - 2:17:52 hours - 198340 frames
Audio 1: C:\Users\xyz\Downloads\file1.mkv
Info: DTS - 1536 kbps - CBR - 6 ch - 48000 Hz - 24 bit - 2:17:52 hours (0 ms delay) - Internal
[MediaInfoLib - v0.7.47]
AVISYNTH SCRIPT
Import("C:\Program Files (x86)\AVStoDVD\Lib\A2DSource.avsi")
Video = A2DVideoSource("C:\Users\xyz\Downloads\file1.mkv", CacheFolder="C:\Users\xyz\AppData\Local\Temp", FrameRate=23.976, VFR=false)
# Audio is frameserved by AviSynth just for Preview and Edit purposes.
Audio = A2DAudioSource("C:\Users\xyz\Downloads\file1.mkv", CacheFolder="C:\Users\xyz\AppData\Local\Temp")
Video = Video.ConvertToYV12
#Using DGPulldown/HCenc to upsize FPS
Video = Video.AddBorders(0,80,0,80)
Video = Video.Spline64Resize(720,480)
AudioDub(Video, Audio)
Encoding Profile: HCenc VBR 2-pass
Target Video FileSize: 3883.3 MB
HCenc Parameters: -ini "C:\Users\xyz\AppData\Local\Temp\DVD_0_file1.HCenc.ini"
HCenc ini file:
*INFILE C:\Users\xyz\AppData\Local\Temp\DVD_0_file1_1.avs
*AVSRELOAD
*OUTFILE C:\Users\xyz\Videos\DVD_0_file1.m2v
*LOGFILE C:\Users\xyz\AppData\Local\Temp\DVD_0_file1.HCenc.log
*MAXBITRATE 9000
*BITRATE 3938
*PROFILE BEST
*ASPECT 16:9
*PROGRESSIVE
*TFF
*PULLDOWN
*BIAS 40
*DC_PREC 8
*MATRIX MPEG
*AQ 1
*LUMGAIN 1
*SMP
*PRIORITY IDLE
*WAIT 2
<8/23/2011 5:49:13 PM>
END VIDEO ENCODING OPERATIONS
A2DVideoSource: DirectShowSource
Created File: C:\Users\xyz\Videos\DVD_0_file1.m2v (3885 MB)
OUTPUT VIDEO INFO: MPEG-2 Video - 3965 kbps - 720x480 - DAR 1.778 - 23.976 fps (CFR) - Progressive (2:3 Pulldown) - 2:17:52 hours - 198339 frames
<8/23/2011 5:49:14 PM>
START AUDIO ENCODING OPERATIONS (Track 1)
FFmpeg Parameters: -threads 2 -i "C:\Users\xyz\AppData\Local\Temp\DVD_0_file1_1.avs" -y -vn -acodec ac3 -ac 6 -ar 48000 -ab 448k "C:\Users\xyz\Videos\DVD_0_file1_1.ac3"
<8/23/2011 6:43:56 PM>
END AUDIO ENCODING OPERATIONS (Track 1)
Created File: C:\Users\xyz\Videos\DVD_0_file1_1.ac3 (441.8 MB)
OUTPUT AUDIO INFO: AC3 - 448 kbps - CBR - 6 ch - 48000 Hz - 16 bit - 2:17:52 hours (0 ms delay)
START DVD AUTHORING OPERATIONS
BatchMux Parameters: -arglist "C:\Users\xyz\AppData\Local\Temp\DVD_0_BatchMux.ini"
BatchMux ini file:
-d "C:\Users\xyz\Videos\DVD_0\VIDEO_TS"
-mxp "C:\Users\xyz\AppData\Local\Temp\DVD_0_MuxMan.mxp"
-l "C:\Users\xyz\AppData\Local\Temp\DVD_0_MuxMan.log"
-muxman "C:\Program Files (x86)\AVStoDVD\MuxMan"
-prio LOW
-palette "C:\Users\xyz\AppData\Local\Temp\DVD_0_Palette.txt"
-v "C:\Users\xyz\Videos\DVD_0_file1.m2v"
-vidmode LB
-a1 "C:\Users\xyz\Videos\DVD_0_file1_1.ac3"
-a1lang en
-cellfr "C:\Users\xyz\Videos\DVD_0_file1_Chapters.txt"
-progfr "C:\Users\xyz\Videos\DVD_0_file1_Chapters.txt"
-chapfr "C:\Users\xyz\Videos\DVD_0_file1_Chapters.txt"
<8/23/2011 7:00:58 PM>
CHECK DVD SIZE
DVD Folder (actual) Size: 4427 MB
vs Estimated Size: 4450 MB -> 0.5% undersize
vs Assets Size: 4326.8 MB -> OK
END DVD AUTHORING OPERATIONS
Created Folder: C:\Users\xyz\Videos\DVD_0 (4427 MB)
Log file created by AVStoDVD Release 2.4.1
file2 log (failure)_________________________________________________________
<8/23/2011 7:48:02 PM>
START PROCESS
PROJECT SETTINGS
DVD Video Standard: NTSC
DVD Titles number: 1
DVD Size: 4450/4450 MB (100%)
DVD Output Setup: DVD Folder
DVD Label: DVD
DVD Menu: No Menu
Output Folder: C:\Users\xyz\Videos
Delete Temp Process Files: Yes
Delete Working Files: Yes
Edit Command Parameters: No
Post Process Task: Show Progress Status window
PREFERENCES
MultiThread: 1
AVS Source Filter: A2DSource
AVS UpSize/DownSize Filter: Lanczos4Resize/Spline64Resize
Video Resolution: 0
Video BitRate Min: 2500
Video BitRate Level 1: 6500
Video Profile Level 2: 4500
Video BitRate Max: 8500
Keep DVD Compliant Video: 1
AC3 Audio Encoder: 0
PAL SpeedUp: 0
Force FFmpeg for Long Audio: 1
DVD Audio Format: 0
DVD Audio BitRate: 192
Keep DVD Compliant Audio: 1
Normalize Audio: 0
Auto Delay Audio: 1
DVD Audio Language (Primary): EN - English
DVD Audio Language (Secondary): EN - English
DVD Subs Language (Primary): EN - English
DVD Subs Language (Secondary): EN - English
DVD Subs Font: Tahoma 18pt (255,255,255)
Chapters Interval: 5
Use Source Chapters: 1
DVD Burning Drive: E: hp DVDRAM GT30L mP06
DVD Burning Speed: 4x
Auto Erase DVD RW: 1
Save Log file: 1
Display errors messages: 1
Unload ActiveMovie library: 0
Adjust ffdshow mixer: 1
Save General Settings: 0
Video: C:\Users\xyz\Downloads\file2.mkv
Info: AVC - 2802 kbps - 1280x544 - DAR 2.353 - 24 fps (CFR) - Progressive - 2:25:07 hours - 208983 frames
Audio 1: C:\Users\xyz\Downloads\file2.mkv
Info: DTS - 1536 kbps - CBR - 6 ch - 48000 Hz - 16 bit - 2:25:07 hours (0 ms delay) - Internal
AVISYNTH SCRIPT
Video = A2DVideoSource("C:\Users\xyz\Downloads\file2.mkv", CacheFolder="C:\Users\xyz\AppData\Local\Temp", FrameRate=24, VFR=false)
Audio = A2DAudioSource("C:\Users\xyz\Downloads\file2.mkv", CacheFolder="C:\Users\xyz\AppData\Local\Temp")
Video = Video.AddBorders(0,88,0,88)
Target Video FileSize: 2726 MB
HCenc Parameters: -ini "C:\Users\xyz\AppData\Local\Temp\DVD_1_file2.HCenc.ini"
HCenc ini file:
*INFILE C:\Users\xyz\AppData\Local\Temp\DVD_1_file2_1.avs
*AVSRELOAD
*OUTFILE C:\Users\xyz\Videos\DVD_1_file2.m2v
*LOGFILE C:\Users\xyz\AppData\Local\Temp\DVD_1_file2.HCenc.log
*MAXBITRATE 7964
*BITRATE 2626
*PROFILE BEST
*ASPECT 16:9
*PROGRESSIVE
*TFF
*BIAS 30
*DC_PREC 8
*MATRIX MPEG
*AQ 1
*LUMGAIN 1
*SMP
*PRIORITY IDLE
*WAIT 2
<8/23/2011 10:31:13 PM>
Created File: C:\Users\xyz\Videos\DVD_1_file2.m2v (2727.4 MB)
OUTPUT VIDEO INFO: MPEG-2 Video - 2642 kbps - 720x480 - DAR 1.778 - 24 fps (CFR) - Progressive (TFF) - 2:25:07 hours - 208983 frames
START PULLDOWN OPERATIONS
DGPulldown Parameters: "C:\Users\xyz\Videos\DVD_1_file2.m2v" -srcfps 24.000 -destfps 29.97 -inplace -tff
<8/23/2011 10:36:59 PM>
END PULLDOWN OPERATIONS
DGPulldown executed on File: C:\Users\xyz\Videos\DVD_1_file2.m2v (2727.4 MB)
OUTPUT VIDEO INFO: MPEG-2 Video - 2642 kbps - 720x480 - DAR 1.778 - 23.976 fps (CFR) - Progressive (2:3 Pulldown) - 2:25:07 hours - 208772 frames
<8/23/2011 10:37:00 PM>
START AUDIO DEMUXING OPERATIONS (Track 1)
FFmpeg Parameters: -i "C:\Users\xyz\Downloads\file2.mkv" -acodec copy "C:\Users\xyz\Videos\DVD_1_file2_1.ToFix.dts"
<8/23/2011 10:45:46 PM>
Created File: C:\Users\xyz\Videos\DVD_1_file2_1.dts (1566.4 MB)
OUTPUT AUDIO INFO: DTS - 1536 kbps - CBR - 6 ch - 48000 Hz - 16 bit - 2:25:03 hours (0 ms delay)
<8/23/2011 10:45:47 PM>
BatchMux Parameters: -arglist "C:\Users\xyz\AppData\Local\Temp\DVD_1_BatchMux.ini"
BatchMux ini file:
-d "C:\Users\xyz\Videos\DVD_1\VIDEO_TS"
-mxp "C:\Users\xyz\AppData\Local\Temp\DVD_1_MuxMan.mxp"
-l "C:\Users\xyz\AppData\Local\Temp\DVD_1_MuxMan.log"
-prio LOW
-palette "C:\Users\xyz\AppData\Local\Temp\DVD_1_Palette.txt"
-v "C:\Users\xyz\Videos\DVD_1_file2.m2v"
-vidmode LB
-a1 "C:\Users\xyz\Videos\DVD_1_file2_1.dts"
-a1lang en
-cellfr "C:\Users\xyz\Videos\DVD_1_file2_Chapters.txt"
-progfr "C:\Users\xyz\Videos\DVD_1_file2_Chapters.txt"
-chapfr "C:\Users\xyz\Videos\DVD_1_file2_Chapters.txt"
<8/23/2011 11:02:19 PM>
CHECK DVD SIZE
DVD Folder (actual) Size: 2802 MB
vs Estimated Size: 4450 MB -> 37.0% undersize
vs Assets Size: 4293.8 MB -> Warning!
Created Folder: C:\Users\xyz\Videos\DVD_1 (2802 MB)
<8/23/2011 11:02:20 PM>
shreeit is offline   Reply With Quote
Old 25th August 2011, 00:20   #1863  |  Link
8ternity
8ternity's Avatar
Hi Mrc,
Related to last issue, i take out the subtitles and everything is okay for the conversion. I was only had that subtitle, no srt. I can even convert it, look like they are corrupted.
Old 25th August 2011, 13:10   #1864  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
@ggtop
I will think about that
@shreeit
in project #2, force DTS track encoding to AC3: go to 'Edit Title'/'Audio', toggle off 'Auto Audio Setup' and 'Keep DVD-compliant audio'.
@8ternity
you are welcome
Bye
MrC
AVStoDVD Homepage
AVStoDVD @ Doom9 Forum
Old 25th August 2011, 21:48   #1865  |  Link
shreeit
@MrC. I uncheck 'Keep DVD-compliant audio' from preference/audio menu. Can't find go to 'Edit Title'/'Audio', toggle off 'Auto Audio Setup'
I noticed I got warning/error by ffmeg.exe
Stream #0.1: Audio: pcm_s161e, 48000 Hz, 6 channels, s16 4608 kb/s
Incompatible sample format 's16' for codec 'ac3', autoselecting format 'flt' [ac3 @07c097e0] No channel layout specified. The encoder will guess the layout, but might be incorrect
Old 25th August 2011, 22:11   #1866  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
Right click on the source title, click on 'Edit Title', select 'Audio' tab, toggle off 'Auto Audio Setup', toggle off 'Keep DVD compliant audio'. C'mon just be a little more intrepid when you wander within AVStoDVD GUI
Do not worry, leave ffmpeg follow its path.
Bye
MrC
AVStoDVD Homepage
Old 26th August 2011, 02:48   #1867  |  Link
shreeit
Thanks. Everything came out perfact. Thanks again...
Old 3rd September 2011, 15:04   #1868  |  Link
Sjakko
Hi, small remark:
I was trying to get a DVB recording to DVD. I pulled it through ProjectX to remove any errors first. It gave me a m2v and a mp2 file which I threw at AVStoDVD. But on authoring I kept getting the following error:
"Warning! Errors found during Title 1 Audio Track 1 encoding. Do you want to start Backup Audio encoding routine (FFmpeg based)? [YES/NO]"
To be clear this happened when AVStoDVD tried to do an audio stream copy (ffmpeg "-acodec copy" parameter). I went to investigate and it turns out that the error is caused by the fact that my source audio file has the word "error" in its path.
I assume this behavior is intentional, but it can have side-effects, like in my case where I wanted to keep original audio quality but the audio stream was encoded. Maybe this behavior can be smartened a bit so there's no unnecessary encoding when a stream copy can be done. Maybe the warning could be clearer too; I didn't know that by pressing YES I was choosing for an encode instead of a stream copy.
Sjakko is offline   Reply With Quote
Old 4th September 2011, 15:19   #1869  |  Link
Sjakko
@whiskey
1. Open the srt file with Notepad
2. Save it with ANSI format
3. Open the new srt with SubtitleCreator (it comes with AVStoDVD package)
4. Report here the error message from SubtitleCreator (if any)
Bye
Hi MrC,
I have the same problem as Whiskey. I think the problem is a typing error in the SubtitleCreator parameters AVStoDVD provides. See, there's no space between the "-i" and the IFO path parameter!
SubtitleCreator Parameters: "C:\DVD\DVD_0_Clash.Of.Empires.Battle.For.Asia.srt" -p4 -i"C:\Program Files (x86)\AVStoDVD\SubtitleCreator\Examples\VTS_01_1.IFO"
Old 5th September 2011, 13:08   #1870  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
Originally Posted by Sjakko View Post
Hi, small remark:
To better understand, could you please post the complete project log file?
Bye
MrC
AVStoDVD Homepage
Old 5th September 2011, 13:09   #1871  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
Hi MrC,
That's exactly how SubtitleCreator works
Bye
MrC
AVStoDVD Homepage
Old 5th September 2011, 14:25   #1872  |  Link
Sjakko
Bye
Absolutely:
<5-9-2011 15:01:49>
START PROCESS
<5-9-2011 15:01:49>
PROJECT SETTINGS
DVD Video Standard: PAL
DVD Size: 1217/4450 MB (27%)
DVD Label: DVD
DVD Menu: No Menu
Output Folder: F:\Werkmap\AVStoDVD
Delete Temp Process Files: No
Delete Working Files: No
PREFERENCES
MultiThread: 1
Video Resolution: 0
PAL SpeedUp: 0
DVD Audio Format: 1
Normalize Audio: 0
Auto Delay Audio: 1
DVD Subs Font: Tahoma 18pt Bold (255,255,255)
DVD Burning Drive: I: TSSTcorp CDDVDW SH-S223F SB03
Save Log file: 1
<5-9-2011 15:01:49>
Video: H:\Caps\The BBC One Sessions - Amy Winehouse_NO_DVB_ERRORS\The BBC One Sessions - Amy Winehouse.m2v
Info: MPEG-2 Video - 2987 kbps - 720x576 - DAR 1,778 - 25 fps (CFR) - Interlaced (TFF) - 51:31 minutes - 77275 frames
Audio 1: H:\Caps\The BBC One Sessions - Amy Winehouse_NO_DVB_ERRORS\The BBC One Sessions - Amy Winehouse.mp2
Info: MPEG-1 Audio layer 2 - 256 kbps - CBR - 2 ch - 48000 Hz - 51:31 minutes (0 ms delay) - External
Subs 1: H:\Caps\The BBC One Sessions - Amy Winehouse_NO_DVB_ERRORS\The BBC One Sessions - Amy Winehouse.srt
<5-9-2011 15:01:49>
AVISYNTH SCRIPT
Import("C:\Program Files\AVStoDVD\Lib\A2DSource.avsi")
# Video is frameserved by AviSynth just for Preview and Edit purposes.
Video = A2DVideoSource("H:\Caps\The BBC One Sessions - Amy Winehouse_NO_DVB_ERRORS\The BBC One Sessions - Amy Winehouse.m2v", CacheFolder="F:\Werkmap\AVStoDVD\_TEMP", FrameRate=25, VFR=false)
Audio = A2DAudioSource("H:\Caps\The BBC One Sessions - Amy Winehouse_NO_DVB_ERRORS\The BBC One Sessions - Amy Winehouse.mp2", CacheFolder="F:\Werkmap\AVStoDVD\_TEMP")
Video = Video.ConvertToYV12(interlaced=true)
<5-9-2011 15:01:49>
START VIDEO DEMUXING OPERATIONS
Target Video FileSize: 1100,6 MB
FFmpeg Parameters: -i "H:\Caps\The BBC One Sessions - Amy Winehouse_NO_DVB_ERRORS\The BBC One Sessions - Amy Winehouse.m2v" -vcodec copy "F:\Werkmap\AVStoDVD\_TEMP\DVD_0_The BBC One Sessions - Amy Winehouse.m2v"
<5-9-2011 15:02:28>
Created File: F:\Werkmap\AVStoDVD\_TEMP\DVD_0_The BBC One Sessions - Amy Winehouse.m2v (1094,2 MB)
OUTPUT VIDEO INFO: MPEG-2 Video - 2987 kbps - 720x576 - DAR 1,778 - 25 fps (CFR) - Interlaced (TFF) - 51:31 minutes - 77275 frames
<5-9-2011 15:02:28>
FFmpeg Parameters: -i "H:\Caps\The BBC One Sessions - Amy Winehouse_NO_DVB_ERRORS\The BBC One Sessions - Amy Winehouse.mp2" -acodec copy "F:\Werkmap\AVStoDVD\_TEMP\DVD_0_The BBC One Sessions - Amy Winehouse_1.ToFix.mp2"
<5-9-2011 15:02:51>
START (BACKUP) AUDIO ENCODING OPERATIONS (Track 1)
FFmpeg Parameters: -threads 2 -i "H:\Caps\The BBC One Sessions - Amy Winehouse_NO_DVB_ERRORS\The BBC One Sessions - Amy Winehouse.mp2" -y -vn -acodec mp2 -ar 48000 -ab 256k "F:\Werkmap\AVStoDVD\_TEMP\DVD_0_The BBC One Sessions - Amy Winehouse_1.mp2"
<5-9-2011 15:03:24>
Created File: F:\Werkmap\AVStoDVD\_TEMP\DVD_0_The BBC One Sessions - Amy Winehouse_1.mp2 (94,3 MB)
OUTPUT AUDIO INFO: MPEG-1 Audio layer 2 - 256 kbps - CBR - 2 ch - 48000 Hz - 51:31 minutes (0 ms delay)
<5-9-2011 15:03:24>
START SUBS ENCODING OPERATIONS (Track 1)
SRT fixing routine applied (0 lines fixed)
SubtitleCreator Parameters: "F:\Werkmap\AVStoDVD\_TEMP\DVD_0_The BBC One Sessions - Amy Winehouse.srt" -p2 -i"C:\Program Files\AVStoDVD\SubtitleCreator\Examples\VTS_01_1.IFO"
<5-9-2011 15:03:34>
PROCESS ABORTED DURING TITLE 1 SUBS (TRACK 1) ENCODING OPERATIONS.
CHECK LOG FILE <F:\WERKMAP\AVSTODVD\DVD_0.LOG> FOR MORE INFO.
<5-9-2011 15:03:34>
As you can see, it uses the BACKUP audio encoding routine after a stream copy fails. I suspect the cause is the word "ERROR" in the mp2's path (I know, it's weird, please read on).
Now below the exact same project, only now I renamed 1 character in the source folder:
The BBC One Sessions - Amy Winehouse_NO_DVB_ERRXRS
instead of
And now the audio stream copy succeeds! The log:
<5-9-2011 15:04:13>
START PROCESS
<5-9-2011 15:04:13>
PROJECT SETTINGS
DVD Label: DVD
DVD Menu: No Menu
PREFERENCES
MultiThread: 1
Video Resolution: 0
PAL SpeedUp: 0
DVD Audio Format: 1
Normalize Audio: 0
Auto Delay Audio: 1
Save Log file: 1
<5-9-2011 15:04:13>
Video: H:\Caps\The BBC One Sessions - Amy Winehouse_NO_DVB_ERRXRS\The BBC One Sessions - Amy Winehouse.m2v
Audio 1: H:\Caps\The BBC One Sessions - Amy Winehouse_NO_DVB_ERRXRS\The BBC One Sessions - Amy Winehouse.mp2
Subs 1: H:\Caps\The BBC One Sessions - Amy Winehouse_NO_DVB_ERRXRS\The BBC One Sessions - Amy Winehouse.srt
<5-9-2011 15:04:13>
AVISYNTH SCRIPT
Video = A2DVideoSource("H:\Caps\The BBC One Sessions - Amy Winehouse_NO_DVB_ERRXRS\The BBC One Sessions - Amy Winehouse.m2v", CacheFolder="F:\Werkmap\AVStoDVD\_TEMP", FrameRate=25, VFR=false)
Audio = A2DAudioSource("H:\Caps\The BBC One Sessions - Amy Winehouse_NO_DVB_ERRXRS\The BBC One Sessions - Amy Winehouse.mp2", CacheFolder="F:\Werkmap\AVStoDVD\_TEMP")
<5-9-2011 15:04:13>
FFmpeg Parameters: -i "H:\Caps\The BBC One Sessions - Amy Winehouse_NO_DVB_ERRXRS\The BBC One Sessions - Amy Winehouse.m2v" -vcodec copy "F:\Werkmap\AVStoDVD\_TEMP\DVD_0_The BBC One Sessions - Amy Winehouse.m2v"
<5-9-2011 15:04:56>
<5-9-2011 15:04:56>
FFmpeg Parameters: -i "H:\Caps\The BBC One Sessions - Amy Winehouse_NO_DVB_ERRXRS\The BBC One Sessions - Amy Winehouse.mp2" -acodec copy "F:\Werkmap\AVStoDVD\_TEMP\DVD_0_The BBC One Sessions - Amy Winehouse_1.ToFix.mp2"
<5-9-2011 15:05:04>
<5-9-2011 15:05:04>
<5-9-2011 15:05:15>
<5-9-2011 15:05:15>
Bye
Could you take a look at one of the above logs which also demonstrates the srt problem? It seems to create the .sup files in both cases just fine though. I checked them with SubtitleCreator.
I can provide you with temporary files for both cases above if you want. Thank you!
Old 6th September 2011, 11:41   #1873  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
instead of
Yep, there's a bug in the ffmpeg log parsing routine: currently if there is the word "error" in the log file, whatever position, then the audio demuxing step is considered failed. Just have to fix it. Thanks for the bug report.
What does SubtitleCreator say when you load your srt with it? Any errors messages? If not, please send me the srt file (avstodvd@gmail.com).
Bye
MrC
AVStoDVD Homepage
Old 6th September 2011, 12:19   #1874  |  Link
Sjakko
Thank you!
No errors. I don't know what exactly goes wrong, because a perfectly good .sup file seems to be created during the AVStoDVD process. I can take the sup file AVStoDVD just generated (but gave me an error on), put it in the same AVStoDVD project instead of the srt and the whole authoring process goes without a hitch. So the sup generating in itself doesn't seem to be faulty.
You've got mail.
Old 7th September 2011, 12:57   #1875  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
You've got mail.
The (fake) error is probably due to the 'DVD Asset Path' and 'Temp Files Path' having the same value in your Preferences. It is obviously a bug to be fixed but, as workaround, you can give different paths to these 2 variables.
Bye
MrC
AVStoDVD Homepage
Old 7th September 2011, 13:06   #1876  |  Link
Sjakko
Great! That fixed it. Thanks.
Old 8th September 2011, 13:43   #1877  |  Link
8ternity
8ternity's Avatar
Hi mrc,
Did you had instruction regarding custom dvd menu templates (background, button, etc.) to customisez a dvd menu in default? I want to check for creating a theme menu, starting to play with that to create one menu for testing.
Old 9th September 2011, 16:12   #1878  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
@8ternity
you can start having a look at the 'Templates - Readme.txt' file under '\AVStoDVD\Menu\Templates' folder. Then you can download some custom templates from here and get some hints.
I hope you will share your creations with us.
Thanks in advance
Bye
MrC
AVStoDVD Homepage
Old 10th September 2011, 11:12   #1879  |  Link
ggtop
Just an info
Hi all,
right now I'm converting some dozens DV tapes to DVD and always wondered why the preview doesn't work although the final DVD / encoded file works fine.
My setup is Windows 7 64bit, Cedocida DV codec installed, AVS Source Filter: AviSource().
I did some research and found that I have to use all involved components in the same "environment". Because I have 32bit Avisynth installed it loads the 32bit cedocida VfW codec with AviSource() enabled, I also have to use 32bit MPC-HC for preview. And that was the culprit, because my default preview player path pointed to the 64bit version. After installing the 32bit version in parallel and changing the path everything works fine.
ggtop
Old 12th September 2011, 21:53   #1880  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
@ggtop
thanks for sharing your experience
Bye
MrC
AVStoDVD Homepage
[IMG] code is Off
