18th February 2009, 23:42 | #41 | Link | |
How can I do this? Get the original code and then build x264? |
18th February 2009, 23:43 | #42 | Link | |
x264 developer
A proper description of this modification would be "disable row-based VBV handling". |
18th February 2009, 23:43 | #43 | Link |
Software Developer
Exactly.
18th February 2009, 23:45 | #45 | Link | |
Software Developer
Also you can use a GUI like MeGUI, which uses Avisynth input too, offers job control (batch processing) and offers all options you'll need.
18th February 2009, 23:50 | #47 | Link | |
Software Developer
However Avisynth allows you to use the pre-processing filters of your choice, including your preferred deinterlacer
18th February 2009, 23:51 | #48 | Link | |
With this patch the vbv-maxrate / bufzie will still work? I will be able to set the x264 to use VBV at 250Kbps with maximum 500Kbps? Thanks |
18th February 2009, 23:53 | #50 | Link |
If you don't have a build environment already setup, here is a build with Dark Shikari's change: http://users.telenet.be/darnley/x264...thiagoprado.7z
x264 log explained || x264 deblocking how-to preset -> tune -> user set options -> fast first pass -> profile -> level Doom10 - Of course it's better, it's one more. |
19th February 2009, 00:25 | #54 | Link |
I thought bufsize is the time in seconds maxrate can be used.
Ex: maxrate 500 / bufzise 500 - One second of 500Kbps peak maxrate 500 / bufsize 1000 - Two seconds of 500Kbps peak I'm using JW Player with Flash Media Streaming 3.5 Last edited by thiagoprado; 19th February 2009 at 00:28. |
19th February 2009, 00:44 | #56 | Link | |
x264 developer
If you're using progressive download, you don't need VBV. |
19th February 2009, 00:51 | #59 | Link |
x264 developer
If you're encoding beforehand and not in real-time, why do you need to stream instead of progressive download?
IMO progressive download avoids most of these annoyances and is much easier for both the user and server. |
bug, mediacoder, vbv-maxrate, x264 |
