18th February 2013, 20:50 | #803 | Link |
MPC-BE DEV
... (started a new and separated development) starting from an old version of MPC-HC
Win11 x64, i7 8700K 5Ghz, ASUS MAXIMUS X HERO, G.Skill (2x8GB) Trident Z F4-3600C16D-16GTZ, RX 5700,TV Philips 43PUS6703/12, Zappiti 4K HDR Media Player Classic - BE x86/x64. Team of developers. |
18th February 2013, 21:15 | #804 | Link | |
Windows 11 Pro, CPU: Ryzen 9 5900X, GPU: GeForce RTX 3090 /w 512.95, Audio: HDMI to Yamaha RX-A3060 (5.1) |
19th February 2013, 06:54 | #805 | Link |
Can't reproduce. If you can - record movie and upload.
19th February 2013, 07:21 | #806 | Link |
http://pan.baidu.com/share/link?shar...&uk=3558042035
Would be add the mp3 lyrics support like this? |
19th February 2013, 08:06 | #807 | Link |
Thanks previews work again on primary display but broken on extended displays with madvr. I don't think they ever worked with madvr but work with other renderers. This is also probably the same as what I meant by not working over network. Can't test right now.
19th February 2013, 08:15 | #808 | Link | |
19th February 2013, 14:20 | #809 | Link |
MPC-BE DEV
MPC-BE v1.1.0.1 -dev build 2117 (Nightly Builds) (sourceforge)
MPC-BE v1.1.0.1 -dev build 2117 (Nightly Builds) (Dev. MPC-BE)
19th February 2013, 14:20 | #810 | Link |
Will see what I can do to make a video, the above is related to using LAV for MPEG and thus for BD/mpls/bdmv.
19th February 2013, 15:04 | #811 | Link | |
http://i.imgur.com/VVKBd4p.jpg default "dark" theme, could see the chapter mark, its fine. http://i.imgur.com/yGX4c46.jpg uncheck the "dark" theme, then cant see the chapter mark. Last edited by wanezhiling; 19th February 2013 at 16:36. |
19th February 2013, 17:09 | #812 | Link | |
I noticed in the newest build that the behavior of the player changed when trying to reproduce this issue I reported in my last post:
a) jumps to a different position, often partly off screen. (this happens if the player is positioned in the top left part of the screen when you double click it) or b) stays in place, but after dragging your mouse to the top left part of the screen, the player jumps off screen. (logically, this happens if the player is positioned anywhere else, not top left part of the screen) in both cases the player is being dragged along with the mouse after it jumped, and after releasing it, it switches to fullscreen properly. expectedly, after exiting fullscreen, the player is positioned wherever you dropped it after you dragged it. this is an improvement over the previous behavior for me as I no longer accidentally misalign the fullscreen video by accident, but i imagine this strange glitch should not be occuring. edit: by position of the player I mean the top left corner of the player, since I deduced that is how your player defines its position. Last edited by ^w^ing; 19th February 2013 at 17:19. |
20th February 2013, 01:00 | #813 | Link | |
20th February 2013, 06:24 | #814 | Link |
MPC-BE+MadVR not showing previews on extended monitors is the real problem for my report about them not working over network.
With frame only, no borders, the flybar maximize button is basically fullscreen while still being able to resize, is that intended? I thought it would work like every other maximize button, fill screen except taskbar (unless its hidden) and not allow resize. Also some things concerning context menu: - could view > hide menu -> frame only -> no borders > show menu&caption be changed to a submenu that has the different modes? This would allow people to set the view they want with 1 button instead of maximum 4 buttons. - context menu changes a lot when menu is enabled, could it be consistent with no menu? - can an option or something be added to show audio\sub languages again in context menu? Some of us don't enable control bar. ^w^ing: I can't reproduce the problem, but I had some similar window sizing/moving issues that was resolved by resetting defaults (blank ini) |
20th February 2013, 07:03 | #815 | Link |
Add display Album. And also start work for display lyrics info for MP3
20th February 2013, 10:40 | #818 | Link | |
I noticed that in scenario a) i described, the distance the player jumps is longer depending on how far away the player is from the very top left pixel on my screen. unless of course, the player is not in the top left "quarter" of my screen. also the direction of where it jumps is consistent depending on where the player originally is, if it is close to the top middle of my screen, it jumps to the right, if its close to left middle, it jumps down. in scenario b) it also similarly follows this after i drag it into top left quarter of my screen - if its on the right middle and i drag it top left, it jumps to the right, and if its on the bottom middle and i drag it top left, it jumps down. but it jumps almost completely off screen. I successfully reproduced it on two other PCs with this build (2117). |
20th February 2013, 15:09 | #819 | Link |
MPC-BE DEV
MPC-BE v1.1.0.1 -dev build 2125 (Nightly Builds) (sourceforge)
MPC-BE v1.1.0.1 -dev build 2125 (Nightly Builds) (Dev. MPC-BE)
20th February 2013, 16:07 | #820 | Link | |
Any chance for this:
