Old 17th January 2020, 00:59   #7361  |  Link
benwaggoner
Originally Posted by jlpsvk View Post
Is there any way to fully utitlise x265 with single process (without distrubuted encoding) on Ryzen 9 3950X (16c/32t) without quality loss?
What resolution are you encoding to?
--preset slower --pmode --pme should saturate most systems. Although it's often faster to leave out --pmode and --pme if the cores/pixels ratio isn't that high. The goal is to maximize fps, not CPU load. PMode is typically a lot more useful than PME, which I've only seen to be helpful at SD resolutions and below.
PMode and PME don't have any negative quality impact, and pmode can actually help a trifle, potentially.
Doing 2160p on an 18/36 system encoding is ~30% faster without pmode than with it, even though CPU load is about 50% versus ~90%.
Ben Waggoner
My Compression Book
Old 17th January 2020, 05:54   #7362  |  Link
Boulder
Pig on the wing
Boulder's Avatar
--pmode can have a negative impact in CRF mode, so be warned. I just experienced that.. it produced a lower bitrate than without --pmode at the same settings at CRF 18, and I happened to check a scene with a heavily noisy picture. The dancing of the noise was much uglier than in a test encode without --pmode.
Boulder is online now   Reply With Quote
Old 17th January 2020, 12:21   #7363  |  Link
--ctu 32
Old 17th January 2020, 19:48   #7364  |  Link
benwaggoner
--ctu 32
Right! There are other ways to increase parallelism, at the risk of some hits to compression efficiency. However, with a whole lot of cores, quality @ perf might have a different optimal configuration, like using more frame thread and a higher RD level. Other parameters in the same bucket:
-F >4 (this had quality hits in older versions; not sure of the impact in 3.x)
--lookahead slices >8 (It seems like this shouldn't have a quality hit, but it is 1 in the slowest presets)
Another thing that might help (haven't tested) without impacting quality is --selective-sao 2. SAO itself limits parallelism somewhat per https://x265.readthedocs.io/en/default/threading.html. So turning it off for B-frames could help. Although it's also possible that the latency hit is fixed whenever SAO is on at all, so --no-sao might help, although with efficiency hits, particularly at lower bitrates. Worth testing.
Ben Waggoner
My Compression Book
Old 17th January 2020, 19:49   #7365  |  Link
benwaggoner
Oh, good tip! That isn't supposed to happen in theory. You should provide a bug report and repro to MultiCoreWare so they can look at this deeper.
Ben Waggoner
My Compression Book
Old 17th January 2020, 20:51   #7366  |  Link
jlpsvk
I am encoding 2160p, with CRF16.
AMD Ryzen 9 3950X, 32GB DDR4-3200 CL16, RTX 2070, 1TB NVMe SSD, 56TB NAS
jlpsvk is offline   Reply With Quote
Old 17th January 2020, 21:07   #7367  |  Link
Boulder
Pig on the wing
Boulder's Avatar
This probably affects frame type decision, at least that's what I observed when using four lookahead slices compared to just one.
It's probably due to the encoder doing deeper analysis as some performance related early skips are avoided. Nevertheless, I got a clip of the scene for my testing toolkit and I can definitely create a ticket for the issue. Maybe there is something there to fix.
Old 18th January 2020, 09:07   #7368  |  Link
jlpsvk
i tested, and without pme and pmode, it's faster.
Old 18th January 2020, 09:35   #7369  |  Link
froggy1
ffx264/ffhevc author
froggy1's Avatar
I have tested a few samples with SAO and selective-sao set to 2. I find the result looking too soft. Without it, there's more detail present. But if others like it, who am I to stop them?
ffx264--ffhevc--ffxvid
AMD Ryzen 7 3700X
froggy1 is offline   Reply With Quote
Old 19th January 2020, 19:56   #7370  |  Link
jlpsvk
exactly... my 2160p HDR10 preset currently...any suggestions?
--preset slow --profile main10 --level-idc 5.1 --output-depth 10 --crf 16 --ctu 64 --aq-mode 4 --merange 57 --amp --no-rskip --qg-size 8 --vbv-bufsize 160000 --vbv-maxrate 160000 --bframes 8
--rc-lookahead 48 --gop-lookahead 30 --hdr10 --hdr10-opt --repeat-headers --no-info --no-deblock --no-sao --selective-sao 0 --allow-non-conformance --no-strong-intra-smoothing --high-tier --chromaloc 2
--fades --hme --hme-search umh,umh,star
Old 20th January 2020, 01:10   #7371  |  Link
froggy1
froggy1's Avatar
I'd set deblock to -1,-1 instead of completely disabling it - deblock has seen a major revision compared to x264.
Also strong-intra-smoothing seems to have a positive effect at keeping noise. Many people are scared by the name but I find it does improve things a bit. It will help reduce banding on very clean scenes too, like skies or other clean textures, by blending a bit instead of keeping the banding
merange has no effect when using HME since the latter has its own range parameters you can adjust with --hme-range
AMD Ryzen 7 3700X
Old 20th January 2020, 12:19   #7372  |  Link
Boulder
Pig on the wing
Boulder's Avatar
Ben Waggoner was doing some tests with --aq-mode 4, I don't think he got them finished though. He's probably the only one (apart from the devs) who has some kind of an insight to how it looks with real life examples.
For what it's worth, lately I've found --aq-mode 3 being troublesome. With normal sources originating from film, like the older seasons of X-Files which contain quite a lot of grain and noise, it works well at around ~0.6 for strength. Then there's something like Suits, or The Killing, which look terrible. The sources are terrible in quality -- lots of macroblocking which appears when the encoder starts removing the grain hiding some of that -- and aq-mode 3 produces a substantially lower average bitrate at the same CRF than aq-mode 1. I don't know why the rate control works this way, The Killing does contain quite a lot of dark scenes but I was unable to get a good result without switching to --aq-mode 1 at the default strength. I also raised psy-rd to 3.0 and deblock to 0:0 to try to keep the higher frequencies and avoid banding where the encoder removes too much from the original image.
I really scratched my head at the issue the whole weekend. Yes, I did test x264 at --preset veryslow, but it wasn't any better
Sometimes I have used a dirty trick and added a light amount of fake grain with GrainFactory3 before feeding the video to the encoder. I may need to test that too
Old 20th January 2020, 16:37   #7373  |  Link
froggy1
froggy1's Avatar
I did my own testing, both with AQ mode 2 and 3. It did not make things beter here and I was hoping AQ mode 3 would work well on dark scenes, but it didn't. All I saw is increased bitrate for 2 and 3 with no meaningful improvements... so I went back and stick to my good ol' AQ mode 1
As for psy-rd/psy-rdoq, they are meant to keep the original energy of the source as much as possible at higher strength. So if you have a (very) noisy sample, the bitrate will shoot up in order to preserve the noise/grain. These two settings are set to high values when using --tune grain (psy-rd is set to 4 and psy-rdoq is set to 10). I personally now use psy-rd of 3.2 and psy-rdoq of 15. I do not mind the increase of bitrate as I aim to preserver the input as much as possible. These two especially have an effect on dark scenes and look better than using AQ mode 2 or 3. I haven't tested AQ mode 4, though
AMD Ryzen 7 3700X
Old 20th January 2020, 16:45   #7374  |  Link
benwaggoner
I finished making the content but not my comparisons. Thanks for the reminder to take a look again.
Maybe throw in some --nr-inter? That tends to reduce grain swirling and lower QPs a bit at the same bitrate.
Ben Waggoner
My Compression Book
Old 20th January 2020, 16:47   #7375  |  Link
benwaggoner
The AQ comparisons really need to be made with 2-pass VBR to compare bitrates. Different AQ modes can require different CRF values in practice.
Ben Waggoner
My Compression Book
Old 20th January 2020, 17:01   #7376  |  Link
froggy1
froggy1's Avatar
I have no need for 2-pass VBR. I only do CRF encoding and that's what matters to me but also tested in 2-pass as you recommended previously in a post a week or so ago. Not much improvement. I find psy-rd/rdoq delivering better results than these AQ modes
AMD Ryzen 7 3700X
Old 20th January 2020, 19:25   #7377  |  Link
Boulder
Pig on the wing
Boulder's Avatar
If you want to try things, I uploaded the sample clip I used to test: https://drive.google.com/open?id=1Ar...5cr6UNO1WjfV7- . Take a look at the flat background in the shots with the cop, it's ugly in the source and gets much worse after encoding.
Old 20th January 2020, 19:47   #7378  |  Link
benwaggoner
Right. But if you want to figure out the optimum efficiency for a CRF encode, comparing the features in 2-pass VBR shows you how features compare at the same file size. Once you nail down the optimum parameters, then you figure out what CRF is optimal for you with those other parameters.
Ben Waggoner
My Compression Book
Old 20th January 2020, 19:51   #7379  |  Link
froggy1
froggy1's Avatar
I won't be bothered doing this. At the moment I'm quite happy with my own setting for CRF @ 21. I increased some of them by a small amount to give it a bit more headroom. If I can compress a source of say 22-25 GiB down to 5-6 or 7 GiB (with decent quality according to my eyes), I'm a happy camper
AMD Ryzen 7 3700X
Old 26th January 2020, 22:41   #7380  |  Link
zerowalker
Annoying question but might as well ask it.
It was a long time ago since i checked out x265, probably like 2 years ago, and back then x264 was better except for edge cases which was very low bitrate and very high resolutions mostly.
And then it looked crap anyway so even if x265 won it didn't really matter (for me).
How is it nowadays (know it's a vague question)?
If you have like a 1080p video and use crf=16 (which i would say results in high quality for x264 at least) would x265 achieve the "same quality" for less space?
Or is it only in very high resolutions like 4k and beyond that x265 can outdo it cause of how it works?
I know it sounds like i am saying x265 is crap compared to x264, but that's not what i am trying to say, but it's hard to ask the comparison question without making it sound that way.
I am not denying x265 nor the standard h265, it's obviously made for a good reason and the encoder is surely aiming to be as great as possible compared to what currently exists (either for all or some cases),
i just don't know that much about it except that the standard was made with very high resolutions in mind as h264 breaks down quickly there except with very high bitrates (which is the "throw money at the problem" solution usually;P).
zerowalker is offline   Reply With Quote
