Old 6th October 2024, 16:05   #32021  |  Link
Originally Posted by musiclover View Post
Is there a hidden option to prevent BD-RB from converting the subs to 23,976 fps?
I'll look. But I don't think so.
The real question here is why was the audio out of sync the first time you tried it? What kind of audio was it?
Old 6th October 2024, 16:19   #32022  |  Link
Originally Posted by iambryanknowles View Post
Last - could you either add a warning when FLAC audio tracks are ignored on import, or have them automatically convert to ac3?
Hmm... I don't think I've ever seen a video file that used FLAC for its audio.
Old 6th October 2024, 17:41   #32023  |  Link
musiclover
6 channel E-AC-3 JOC. BD_RB converted it to ac3.
General
Unique ID                   : 285951807814491606971365394848124601680 (0xD720509F64DCD036067E8C51CF458550)
Complete name               : E:\the.lord.of.the.rings.the.rings.of.power.s02e07.doomed.to.die.720p.amzn.web-dl.ddp5.1.atmos.h.264-flux.mkv
Format                      : Matroska
Format version              : Version 4
File size                   : 1.46 GiB
Duration                    : 1 h 12 min
Overall bit rate            : 2 900 kb/s
Frame rate                  : 24.000 FPS
Writing application         : mkvmerge v85.0 ('Shame For You') 64-bit
Writing library             : libebml v1.4.5 + libmatroska v1.7.1
Video
Format                      : AVC
Format/Info                 : Advanced Video Codec
Format profile              : High@L3.1
Format settings             : CABAC / 4 Ref Frames
Format settings, CABAC      : Yes
Format settings, Reference  : 4 frames
Codec ID                    : V_MPEG4/ISO/AVC
Bit rate mode               : Constant
Bit rate                    : 2 319 kb/s
Nominal bit rate            : 4 000 kb/s
Width                       : 1 248 pixels
Height                      : 520 pixels
Display aspect ratio        : 2.40:1
Frame rate mode             : Constant
Color space                 : YUV
Chroma subsampling          : 4:2:0
Bit depth                   : 8 bits
Scan type                   : Progressive
Bits/(Pixel*Frame)          : 0.149
Stream size                 : 1.17 GiB (80%)
Language                    : English (US)
Default                     : Yes
Forced                      : No
Color range                 : Limited
Color primaries             : BT.709
Transfer characteristics    : BT.709
Matrix coefficients         : BT.709
Audio
Format                      : E-AC-3 JOC
Format/Info                 : Enhanced AC-3 with Joint Object Coding
Commercial name             : Dolby Digital Plus with Dolby Atmos
Codec ID                    : A_EAC3
Bit rate                    : 576 kb/s
Channel(s)                  : 6 channels
Channel layout              : L R C LFE Ls Rs
Sampling rate               : 48.0 kHz
Frame rate                  : 31.250 FPS (1536 SPF)
Compression mode            : Lossy
Stream size                 : 298 MiB (20%)
Service kind                : Complete Main
Default                     : Yes
Forced                      : No
Complexity index            : 16
Number of dynamic objects   : 15
Bed channel count           : 1 channel
Bed channel configuration   : LFE
Dialog Normalization        : -22 dB
compr                       : -0.28 dB
dialnorm_Average            : -22 dB
dialnorm_Minimum            : -22 dB
dialnorm_Maximum            : -22 dB
Text #1
Format                      : UTF-8
Codec ID                    : S_TEXT/UTF8
Codec ID/Info               : UTF-8 Plain Text
Duration                    : 1 h 6 min
Bit rate                    : 1 b/s
Frame rate                  : 0.009 FPS
Count of elements           : 34
Stream size                 : 675 Bytes (0%)
Title                       : Forced
Default                     : Yes
Forced                      : Yes
Text #2
Format                      : UTF-8
Duration                    : 1 h 7 min
Bit rate                    : 29 b/s
Frame rate                  : 0.126 FPS
Count of elements           : 508
Stream size                 : 14.6 KiB (0%)
Default                     : No
Forced                      : No
Text #3
Format                      : UTF-8
Bit rate                    : 37 b/s
Frame rate                  : 0.179 FPS
Count of elements           : 724
Stream size                 : 18.5 KiB (0%)
Title                       : SDH
Default                     : No
Forced                      : No
Menu
00:00:00.000                : en:Studio Logo
00:00:06.000                : en:Previously On
00:01:53.000                : en:Scene 1
00:02:05.000                : en:Scene 2
00:03:51.000                : en:Scene 3
00:06:07.000                : en:Scene 4
00:06:28.000                : en:Scene 5
00:06:47.000                : en:Scene 6
00:07:15.000                : en:Scene 7
00:07:58.000                : en:Scene 8
00:08:02.000                : en:Scene 9
00:08:11.000                : en:Scene 10
00:08:26.000                : en:Scene 11
00:08:45.000                : en:Scene 12
00:08:52.000                : en:Scene 13
00:08:56.000                : en:Scene 14
00:09:03.000                : en:Scene 15
00:09:14.000                : en:Scene 16
00:09:19.000                : en:Scene 17
00:09:42.000                : en:Scene 18
00:09:56.000                : en:Scene 19
00:10:06.000                : en:Scene 20
00:10:11.000                : en:Scene 21
00:10:13.000                : en:Scene 22
00:10:16.000                : en:Scene 23
00:10:41.000                : en:Scene 24
00:10:50.000                : en:Scene 25
00:11:31.000                : en:Scene 26
00:11:33.000                : en:Scene 27
00:12:31.000                : en:Scene 28
00:12:38.000                : en:Scene 29
00:14:13.000                : en:Scene 30
00:14:39.000                : en:Scene 31
00:14:42.000                : en:Scene 32
00:15:17.000                : en:Scene 33
00:15:29.000                : en:Scene 34
00:15:54.000                : en:Scene 35
00:18:23.000                : en:Scene 36
00:18:31.000                : en:Scene 37
00:18:38.000                : en:Scene 38
00:20:38.000                : en:Scene 39
00:21:56.000                : en:Scene 40
00:22:01.000                : en:Scene 41
00:22:17.000                : en:Scene 42
00:23:33.000                : en:Scene 43
00:24:18.000                : en:Scene 44
00:24:20.000                : en:Scene 45
00:24:27.000                : en:Scene 46
00:24:35.000                : en:Scene 47
00:24:56.000                : en:Scene 48
00:25:08.000                : en:Scene 49
00:25:24.000                : en:Scene 50
00:25:31.000                : en:Scene 51
00:25:34.000                : en:Scene 52
00:25:40.000                : en:Scene 53
00:25:58.000                : en:Scene 54
00:26:07.000                : en:Scene 55
00:26:50.000                : en:Scene 56
00:30:11.000                : en:Scene 57
00:31:08.000                : en:Scene 58
00:31:48.000                : en:Scene 59
00:32:12.000                : en:Scene 60
00:32:27.000                : en:Scene 61
00:32:33.000                : en:Scene 62
00:32:50.000                : en:Scene 63
00:32:57.000                : en:Scene 64
00:33:07.000                : en:Scene 65
00:33:12.000                : en:Scene 66
00:33:29.000                : en:Scene 67
00:34:53.000                : en:Scene 68
00:36:23.000                : en:Scene 69
00:36:47.000                : en:Scene 70
00:37:05.000                : en:Scene 71
00:37:11.000                : en:Scene 72
00:38:06.000                : en:Scene 73
00:38:36.000                : en:Scene 74
00:39:47.000                : en:Scene 75
00:40:24.000                : en:Scene 76
00:40:51.000                : en:Scene 77
00:41:55.000                : en:Scene 78
00:42:02.000                : en:Scene 79
00:42:14.000                : en:Scene 80
00:43:03.000                : en:Scene 81
00:46:10.000                : en:Scene 82
00:46:36.000                : en:Scene 83
00:47:08.000                : en:Scene 84
00:49:10.000                : en:Scene 85
00:49:40.000                : en:Scene 86
00:53:08.000                : en:Scene 87
00:53:25.000                : en:Scene 88
00:54:16.000                : en:Scene 89
00:55:10.000                : en:Scene 90
00:55:54.000                : en:Scene 91
00:56:16.000                : en:Scene 92
00:56:46.000                : en:Scene 93
00:57:06.000                : en:Scene 94
00:57:11.000                : en:Scene 95
00:57:13.000                : en:Scene 96
00:57:17.000                : en:Scene 97
00:58:58.000                : en:Scene 98
00:59:08.000                : en:Scene 99
00:59:47.000                : en:Scene 100
00:59:59.000                : en:Scene 101
01:01:15.000                : en:Scene 102
01:02:11.000                : en:Scene 103
01:02:37.000                : en:Scene 104
01:03:03.000                : en:Scene 105
01:03:11.000                : en:Scene 106
01:03:21.000                : en:Scene 107
01:03:25.000                : en:Scene 108
01:03:35.000                : en:Scene 109
01:03:40.000                : en:Scene 110
01:04:15.000                : en:Scene 111
01:04:24.000                : en:Scene 112
01:04:51.000                : en:Scene 113
01:05:05.000                : en:Scene 114
01:05:08.000                : en:Scene 115
01:05:16.000                : en:Scene 116
01:06:00.000                : en:Scene 117
01:06:27.000                : en:Scene 118
01:07:36.000                : en:End Credits
Old 7th October 2024, 01:00   #32024  |  Link
iambryanknowles
The bitrate used is relative to the original bitrate (and size) for that file.
For the DVD conversion, the bitrate stayed within about 300kbps which isn't much in the grand scheme of things. But occasionally when creating quick play playlists from different sourced anime fan subs, file size can vary greatly - my last project has a 2gb HEVC 80 minute video and a 3 GB AVC 20 minute video - the second video was calculated at a much higher bitrate.
In the same vein, flac is a popular anime sub release format, since a lot of sources are Japanese with LPCM.
iambryanknowles is offline   Reply With Quote
Old 17th October 2024, 09:27   #32025  |  Link
iambryanknowles
Trying to IVTC some Pokemon DVDs and am getting combing artifacts. Tried to add FieldDeinterlace as added AVS script, but anything added is placed before the plugins being loaded and the IVTC. Is there a reason for this?
Then tried to compare the results using just the default program deinterlace. Hidden options says that default is SmoothDeinterlace, and no field blending, but the workfiles script shows deinterlacing defaults to FieldDeinterlace with blend=true.
Old 19th October 2024, 08:48   #32026  |  Link
musiclover
I kept going back to my project of making episode blu-rays of 24 FPS files. I found out that the length of the imported files in the pseudo bluray is 4 or 5 seconds longer than the original files. That never happens with PAL or NTSC 23,976 of 29,97 episodes. With the use of ''IMPORT_FORCE_FRAMERATE=24'' the length of the episodes stays the same.
Old 19th October 2024, 20:00   #32027  |  Link
Lowpro
I wasn't aware of the ''IMPORT_FORCE_FRAMERATE=24'' option. Nice! Guess it's time to download the latest build. That will come in handy. Will eliminate the extra step I'm taking now when encoding menu background videos that are in 24fps.
Lowpro is offline   Reply With Quote
Old 20th October 2024, 08:29   #32028  |  Link
MrVideo
MrVideo's Avatar
The question is are the DVDs true 29.97 fps with 3:2 pulldown? If there is 3:2 pulldown, is the cadence there or was the source material edited 29.97 such that the pulldown cadence is drastically lost. If the 3:2 pulldown cadence is drastically lost, IVTC isn't going to be able to recover the 23.976 frame rate cleanly.
There are other reasons that could be causing the issue. You need to supply us with the technical info regarding the DVD.
Old 3rd November 2024, 21:54   #32029  |  Link
musiclover
TSMUXER ERR: 0xFFFFFFFE and a too large AV frame
I tried to make a blu-ray small enough for a 25gb disc by blanking half the content. But there was a pop-up with this content:
Audio Detection Mismatch
The audio type for PID 1102 determined by reading the PAD/PMT
program information (DTS HDMA) does not match the detected audio
(AAC). In many cases, this is caused by emulation of audio headers
(false detection) and the PAT/PMT type is the correct type.
Hit Yes to use the PAT/PMT type.
Hit No to use the detected type.
Hit Cancel to disable this stream.
YES NO CANCEL
The log mentions a TSMUXER ERR: 0xFFFFFFFE and a too large AV frame.
[11.03.24] BD Rebuilder v0.62.12
[21.44.05] Source: DISC-1_-_CAMEL___MIRAGE
- Input BD size: 22,43 GB
- Approximate total content: [02:47:34.794]
- Target BD size: 22,95 GB
- Windows Version: 6.2 [9200]
- Auto Quality: Very Good (Very Fast), 1-Pass VBR
- Decoding/Frame serving: NVENCC
[21.44.07] PHASE ONE, Encoding
- [21.44.07] Processing: VID_00000 (1 of 9)
- [21.44.07] Extracting A/V streams [VID_00000]
- TSMUXER ERR: 0xFFFFFFFE
- Extracting video streams [VID_00000]
- Extracting audio/subtitle streams [VID_00000]
- AV frame too large (57600 bytes). Increase AV buffer.
- Extracting audio streams [VID_00000]
- Error in attempt to extract audio.
[21.44.56] - Failed to retrieve audio, aborted
This happens when I hit Yes, but also when I hit No. So I think the real culprit is the AV frame.
Is there anything to be done? How to increase the AV buffer?
Old 3rd November 2024, 22:40   #32030  |  Link
doobre
If all fails burn the mkv directly to the disc. As long as your BD player can play a file on a disc.
doobre is offline   Reply With Quote
Old 3rd November 2024, 22:50   #32031  |  Link
musiclover
It's no mkv but a blu-ray
Old 3rd November 2024, 22:53   #32032  |  Link
doobre
Could use makemkv” to create an mkv from the BD disc or folders
Old 4th November 2024, 06:22   #32033  |  Link
Emulgator
Big Bit Savings Now !
Emulgator's Avatar
Maybe you hit a tsMuxeR demux limitation, or BD-R misinterprets a stream as being AAC.
(as blu-ray cannot have AAC audio)
You may want to demux the assets using DGDemux and work from there.
Old 4th November 2024, 10:39   #32034  |  Link
musiclover
Thank you all for contributing. But after a re-rip all is well.
What a nuisance a faulty rip can be.
By the way.... Can the AV buffer in TSMUXER be increased?
Old 8th November 2024, 09:47   #32035  |  Link
musiclover
Just reporting a minor bug.
After BD Rebuilder reports an audio/PGS sizing issue and choosing to continue the log window stops reporting the progress of the remainder of the job. The log itself keeps filling up but it is not visible in the log window.
Old 9th November 2024, 06:36   #32036  |  Link
iambryanknowles
Not sure if it's the same for other sources, but when importing PAL MKVs with Pal to Film set, chapters aren't adjusted to fit the new timing. Not sure how else to do it, but MKVToolnix GUI allows you to set a stretch parameter in the options setting of chapter files - assuming it works in the CLI too - just in case you're not sure of a way to do it.
Also, it would be nice if when both Convert SD to 1080 and Convert 1920x1080 to 1440x1080 were selected, that the output was 1440x1080 - right now it only upconverts to 1920x1080 and ignores the other option.
Old 10th November 2024, 07:20   #32037  |  Link
MrVideo
MrVideo's Avatar
What new timing? 25 fps film speed is legal for Blu-rays. If BDRB is trying to change to 23.976 (or 24) fps, IMHO, that would be wrong. By keeping it at 25 fps, there shouldn't be a timing issue. What did you end up with for the frame rate?
I'm curious as to what you would convert from 1920 to 1440. Normally, taking a 1920 video to 1440 would end up squeezing it. If the video within the 1920 was 4:3, then you would have to crop the black vertical bars to get to 1440.
Old 10th November 2024, 09:12   #32038  |  Link
iambryanknowles
PAL to FILM is in BDRB hidden options.It's just to slow down 25fps to 23.976 so that it plays back smoothly on a 120hz screen. I've never tried to play 25fps on my Blu-ray player before- I'm assuming it would have to add frames to pad the video to play back at a standard 29.97 which would disrupt smooth camera panning.
I was given 500 single layer DVD+Rs so I've been playing around a lot - squeezing to 1440x1080 with sar 4:3 reduces number of encoded pixels by 1/4 - on a DVD-5 that gives better overall quality than encoding the same thing at full 1920x1080.
I mentioned SD to 1080, but I more often use the 720 to 1080 option for 29.97fps videos since encoding to 720p requires doubling the frames encoding at 59.94fps to be compliant.
Old 11th November 2024, 04:09   #32039  |  Link
MrVideo
MrVideo's Avatar
All of this depends on your equipment, both the player and the TV. Thinking back, not all U.S. sold players support 25 fps material.Stupid really, but that is the U.S. product. IMHO, 120 Hz video playback is a gimmick. I prefer 23.976/24/25 fps material get displayed at that rate. What is interesting in that my setup, with a projector, results in 1080p/25 material being converted to 1080p/60. But, if I upconvert to 2160p/25, then the system will play it at 25 fps. AFAICT, 1080p/25 is not natural for my projector. It is the projector that doesn't like 1080p/25. The player is 4k and so is the projector. You'd have to look at the specs for your devices.
Keep in mind you really don't gain much. Why? Because black compresses to a lot less bits. So, taking away the "few" bits doesn't really gain you anything. But yes, a lot of people do crop the black, which is why a lot of videos have letterbox bars removed as well. When it comes to 4K videos, I have to restore the black because the projector will vertically expand the video to fill 2160p. But 1080p material it leaves alone. Go figure.
I'm not sure that applies to MKV files. Yes, Blu-ray authored 720p does have that framerate restriction. But, for simple MKV playback, it depends on what your hardware will allow. When it comes to Old Doctor Who episodes at 576/25, I have to redo them as 2160p/25 in order to play them at 25 fps.Keep in mind that my projector upscales everything (other than 3D) to 4K. So, by doing it myself, I can keep the frame rate.
I store all these videos on HDDs, not DVDs or BDs.
Fine print: YMMV
Old 15th November 2024, 17:20   #32040  |  Link
Hmm... I'll have to look at that. I know I adjusted audio and subtitles when that hidden option is set -- but it's been a while, and I can't remember how/if I adjusted chapter points.
