Go Back   Doom9's Forum > General > DVD2AVI / DGIndex
Old 11th July 2010, 13:17   #2001  |  Link
@kebulek and MOS-Marauder
With my current floating context build, I cannot duplicate your multiple instantiation issues. Please wait for a test version that I plan to release today.
Old 11th July 2010, 13:40   #2002  |  Link
Chefkoch_ico
Originally Posted by neuron2 View Post
Originally Posted by OK View Post
I can't get a string of audio path by using "__aud__".
Duplicated. Will fix for next release. Thanks for your report.
I just switched from DGAVCDec to the NV Suite and noticed the same.
DGAVCDec gave me block artefacts and the NV Suite makes the picture perfect, so I am looking forward for the new version so I can use my scripts again.
Thanks for your great software.
Best regards
Chefkoch_ico is offline   Reply With Quote
Old 11th July 2010, 14:24   #2003  |  Link
rajs
Feature requests
Originally Posted by rajs View Post
Couple of feature requests:
1. Add a debug option (like 'info=1' in DGMPGDec).
2. Have an option to auto-resize pixels based on the aspect ratio info in the video stream (if present), i.e.
aspect_ratio_information in a MPEG2 stream
apect_ratio_idc parameter in a H.264 stream
ASPECT_RATIO syntax element in VC-1.
I'd like to add another one - Show the frame number of the frame currently being displayed in the DGIndexNV viewer. (I.e. display some text like "Frame nnnn of mmmm".)
rajs is offline   Reply With Quote
Old 11th July 2010, 14:32   #2004  |  Link
rajs
Just want to point out a minor bug - when outputting a trimmed TS, the tool does not add the extension ".ts" to the name given in the save dialog box.
(v2019 running under Win7)
Old 11th July 2010, 14:51   #2005  |  Link
It's not a bug and has already been discussed.
Regarding your other requests:
1. Info overlay. It's on my to-do list.
2. Resizing. I won't do that. Do it in your script.
3. Not possible as DGIndexNV does not have an index. Only the source filters know the frame numbers, because DGIndexNV creates the index that they use.
Old 11th July 2010, 15:15   #2006  |  Link
Here is a test version for the floating context version. Please advise of your test results.
This also fixes the __aud__ bug.
http://neuron2.net/misc/DGDecNVfloating.zip
Old 11th July 2010, 15:51   #2007  |  Link
MOS-Marauder
Looks good.. first tests with "the Gui" dont result in a crash.
Chris
MOS-Marauder is offline   Reply With Quote
Old 11th July 2010, 16:07   #2008  |  Link
kebulek
kebulek's Avatar
Well first 3 re-opens were good, but at 4th VDub freezed again.
EDIT: 2nd try freezed at 6th re-open.
It's better - but not perfect.
kebulek is offline   Reply With Quote
Old 11th July 2010, 16:45   #2009  |  Link
@kebulek
I don't see any such problems. If you want support, you'll have to provide everything I need to duplicate it. Stream, scripts, detailed steps to reproduce.
Old 11th July 2010, 16:53   #2010  |  Link
You can mention GUIs by name and discuss their compatibility with DG tools. I just don't want general discussion like "GUIs suck, no they don't".
Old 11th July 2010, 17:05   #2011  |  Link
stax76
stax76's Avatar
Can someone using StaxRip 1.1.6 confirm that build 2019 is working fine with it? I'm having some problems getting it to work with it, but I'm pretty sure it's an error on my part somewhere.
I'm using NV tools regularly so yes I can confirm 1.1.6 works with 2019. Please first try to open the source file manually in DGIndexNV, if it's working then examine the command line executing it manually, GUIs write executed scripts and command lines to log files.
That should open the source:
-i "D:\aaa.h264"
That should open the source and start indexing:
-i "D:\aaa.h264" -o "D:\aaa.dgi"
Easy!
Old 11th July 2010, 17:19   #2012  |  Link
MOS-Marauder
Ok. It would make no sense to Discuss about something not related to the DGToolsNV
Chris
Old 11th July 2010, 17:19   #2013  |  Link
kebulek
kebulek's Avatar
@kebulek
Try that with my old sample:
http://www.mediafire.com/file/fomnzzyykmw/sample.ts
And with this .AVS:
LoadPlugin("C:\Program Files\DGTools\DGMultiDecodeNV.dll")
DGMultiSource("E:\video.dgi", deinterlace=1, resize_w=624, resize_h=352)
At home, I've got currently 6GB .ts with this script:
DGMultiSource("E:\video.dgi", deinterlace=1, resize_w=640, resize_h=480)
Action: VDub -> open .avs, seek somewhere, close .avs -> open .avs, seek somewhere, close .avs etc...
Sometimes VDub freezes after 2nd-4th try and sometimes after 10th or more - I don't understand it.
When I close freezed VD and open new one, everything is alright again until Xth try...
Old 11th July 2010, 17:27   #2014  |  Link
I cannot duplicate it.
Have you monitored the GPU memory use using GPU-Z?
My driver version is 257.21. What is yours?
Old 11th July 2010, 17:32   #2015  |  Link
OK
about "__aud__"
Hi,neuron2
I verified the bug was fixed.
Thanks a lot.
I honor you every time.
OK is offline   Reply With Quote
Old 11th July 2010, 18:50   #2016  |  Link
Alf Bundy
Alf Bundy's Avatar
My result with the test build :
- Sample file used : 50Mb (30sec) .mts from my Lumix FZ35/38
http://dl.dropbox.com/u/2137721/00001.MTS
- Script used :
DGmultiSource("C:\Users\Alf\Downloads\DGNV testbuild\test 00001.dgi",deinterlace=1)
AssumeFPS(25)
ConvertToYV12()
- Here's my GPU specs : Driver is WHQL 257.21, Memory = 512Mb
After a reboot, video memory is 91Mb.
And here's what happen when I load my script in VD :
Initial load = 189Mb
1st reload (F2) = 262Mb
2nd reload = 334Mb
3rd reload = 406Mb
4th reload = 478Mb
5th reload -> code (100) error in VD -> crash
After VD's crash, video memory goes back to 91Mb
Hope it helps.
Don't hesitate to ask if you need other tests/precisions.
Alf Bundy is offline   Reply With Quote
Old 11th July 2010, 19:13   #2017  |  Link
kebulek
kebulek's Avatar
Still the same: WinXP SP3, GF 9600GT 512MB with 191.07.
Weird is, that when I do the same with F2, I can reload the whole movie X times and everything works fine.
GPU-Z: 47MB before load, 187MB after load, when I hit F2, it goes to 205MB shortly and then again 187MB. After close it's again 47MB. And when it freeze, it goes to 92MB.
I can send you a Dr. Watson report after VDub crash, if you want. "ErrorText=The program is not responding. etc..."
Old 11th July 2010, 19:14   #2018  |  Link
@Alf Bundy
I cannot duplicate it with your stream and script.
Are you ABSOLUTELY sure you load the correct DLL? You have no loadplugin in your script so...
What versions of Avisynth and VirtualDub?
@kebulek
A VirtualDub crash is not a memory leak issue. Yes, give me the dump and tell me the Avisynth and VirtualDub versions.
Also, if possible, upgrade your driver to 257.21 and try again.
Old 11th July 2010, 19:18   #2019  |  Link
tormento
Acid fr0g
tormento's Avatar
@neuron2
Do you mind compiling a x64 version? Would like to test even in "my" environment.
@turment on Telegram
Old 11th July 2010, 19:19   #2020  |  Link
Alf Bundy
Alf Bundy's Avatar
Well, all files were within the same folder.
The sample video, DGNV testbuild (with it's dll), the dgi created and the avs script generated from my template.avs.
I test it again with the loadplugin() .....
