#802 | Link |
Matroska find' ich toll
You mean for the normal mkv creation.
Ahh, I guess I have forgotten to ignore the chapters from the mpls input for the options.json file. With the .mtxcfg file (create the MKV manually) the mpls-chapters are ignored(not used). |
#803 | Link |
chapterEditor(cE) rev1.43 is available.
Windows Linux There is a new cE version with several improvements and a few bugs have been fixed. DGDemux version 1.0.0.73 must now be used for BD2mkv because Rocky has made important improvements. Code:
Change chapterEditor added & fixed * improved # changed % rev1.43 2024-02-12 // chapterEditor & Support for the FFmpeg MetaData format // Chapter Converter & FFmpeg MetaData as output format - Time base adjustable - empty time base corresponds to nanoseconds * FPS calculation now works again for the formats: Celltimes, MeGUI and x264QP // Disc2mkv & Multiple track selection by right-clicking to activate and deactivate the tracks - Click on the checkbox -> all tracks - Click on the track type -> all tracks of the same type - Click on the language -> all tracks of the same language // BD2mkv & Support for specially structured mpls files - removing duplicate m2ts files is not allowed - for a Multi-Edition MKV this mpls must not be the first * Multi-Edition MKV mode: external tracks are now correctly included in the .mtxcfg file again # Multi-Edition MKV mode: better detection of whether mpls files can be merged into a Multi-Edition MKV % Support for DGDemux 1.0.0.73 (settings) - the switch "-sp" was replaced by "-ignorepl" - the "-ch" switch has been removed // Matroska Menu (Medium-Linking) * Source is a folder: all previously loaded files are now correctly removed |
#806 | Link | |
Acid fr0g
I used it many times, it's giving me a bad headache now. EDIT: I downloaded a fresh clean version, deleted everything. It works now. ![]()
@turment on Telegram Last edited by tormento; 16th March 2024 at 20:00. |
#808 | Link |
Hi marooned2
Welcome to Doom9 forum. With a middle click on the Save button, all tabs will be saved. You will find this info in the status bar of cE when the mouse is over the Save button. Last edited by hubblec4; 11th April 2024 at 01:52. |
#818 | Link |
Uploading here in this forum is not good. it takes toooooo much time for the approval.
OK, but I guess I see the issue. You said you load .txt files: You can only do a direct save when the files already in this format like the editor handles. .txt files can not be saved as .xml files without an explicit new filename. |
#820 | Link |
A new file name is always re-entered through a save dialog.
Every program works in this way if the original format was not in the loaded file in the editor. That's understandable because if cE simply overwrites this loaded file, the original content will be lost. In addition, the file extension is also incorrect. Once you have loaded your file into the Matroska Chapter Editor and press the "Save" button, a save dialog will appear. The next time you click on the “Save” button, it will be saved immediately. The question I have is where do the chapter files come from? Which program creates it and couldn't cE do it right away? I also thought about it a long time ago whether it would make sense to allow/incorporate direct saving for "foreign" chapter formats. The thing looks like this: A new file name is needed. We could now simply say: just swap the file extension. For your chapter files it would then be w21_02.xml. The problem is, it can't be used that generally. There are also chapter formats that are already stored in an XML structure, and therefore exchanging the file extension would no longer make sense. |
bluray backup, chapter editor, dvd2mkv, matroska menu, metadata, multi-edition-mkv, xml tag |
