14th August 2010, 21:44 | #1441 | Link | |
Here you go..still 2 channel. I even looked at teh Edit-> Audio and it ID'd as 5.1 (greyed out) Quote:
15th August 2010, 11:50 | #1442 | Link | |
I manually created it and also PreviewerPathName under it. I entered exact the same value as for ExePath (there are no quotes). Then I execute AVStoDVD with admin rights but no luck. It still crashes when hitting the checkbox. I cannot enter the value manually into Preview Player Path unser Pref/Path because the textbox is disabled as long as the checkbox is not set ggtop |
15th August 2010, 18:08 | #1443 | Link | |
AVStoDVD Dev
@Mr. Monte
let's wait for AC3Filter uninstalled test. Before uninstalling AC3Filter, if you load the mkv into GraphEdit and press 'Render Media File', what does the audio path say? @ggtop HKEY_LOCAL_MACHINE\SOFTWARE\AVStoDVD key is created at first Preferences 'save as default' or if a DVD Menu is created. Of course I'm talking about W2k, XP or Vista. W7 is still a mystery to me Quote:
If you cannot solve the reg key issue, please wait for next release with the GUI bugfix. BTW thanks for reports. Bye |
15th August 2010, 18:41 | #1444 | Link | |
Thanks for your help..I like learning |
16th August 2010, 16:40 | #1445 | Link |
AVStoDVD Dev
No, never said that. ffdshow mixer is reset to 2/0/0 by AVStoDVD at the end of the encoding process, IF at the beginning it was at 2/0/0 AND if the 'Preferences'/'Misc'/'Adjust ffdshow at runtime' is on.
Yes, by setting AC3Filter mixer to 5+1. BTW if you use GraphEdit and render your mkv, you will get what decoder you are using (ffdshow or AC3Filter). Example: https://sites.google.com/site/avstod.../GraphEdit.png Bye |
17th August 2010, 10:36 | #1447 | Link |
I found regkeys under HKEY_CLASSES_ROOT\VirtualStore\MACHINE\SOFTWARE\Wow6432Node\AVStoDVD,
HKEY_USERS\...\Software\Classes\VirtualStore\MACHINE\SOFTWARE\Wow6432Node\AVStoDVD and HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\AVStoDVD Entering the value manually lets AVStoDVD crash as soon as I hit the preferences button. W7 is also mysterious to me... All other keys in the A2D branches seem to look fine..OutputPath, LocalAppDataPath etc. Last edited by ggtop; 17th August 2010 at 10:41. |
17th August 2010, 12:41 | #1448 | Link | |
AVStoDVD Dev
BTW I'm planning to install a virtual machine to test W7 interactions with AVStoDVD ASAP. Until that, I cannot declare that W7 is supported. Bye |
18th August 2010, 10:14 | #1449 | Link |
No need to hurry.. I have 2 machines running XP left
And I have another problem. I want to convert my avis (DV) to DVD. I'm only testing in the moment and use short clips. I made a DVD with motion menu yesterday at home (XPSP3). Worked fine Today I tried to do exactly the same on the other machine (XPSP3), but it didn't work ??? QuEnc created a 0kb .m2v for the menu and then muxman fails. I didn't find a log for QuEnc but the .avs file for the menu seems to be OK. ggtop Edit: I found that QuEnc fails if "enable multithread.." is checked. I have a P4 3.4 GHz... Edit2: But QuEnc stills fails on creating the motion menu m2v ??? Last edited by ggtop; 18th August 2010 at 11:42. |
18th August 2010, 12:21 | #1450 | Link |
AVStoDVD Dev
@ggtop
if you try to run the menu avs file with VirtualDub or MPC, does it work? Any differences in codecs on the 2 machines? QuEnc should not crash depending to the multithread on/off. Moreover multithread is activated IF option is on AND if more cores/cpus are detected. Bye |
18th August 2010, 14:02 | #1452 | Link |
This doesn't make sense to me either.
I just made a DVD with 1 clip and motion menu on W7 64bit (Intel Centrino Duo). I used HCEnc 2 pass (for the title). As AVS Source I use AviSource because I installed Cedocida DV Codec and that's a VfW Codec. AviSource uses VfW, right? Everything's fine. This configuration is exactly the same on my other machines. I tried different settings earlier on my P4 3.4GHz (Hyperthreading?) under XP SP2: - Title encoding ALWAYS works with HCEnc - Title encoding ONLY works with QuEnc if "Enable Multithreading" is disabled - MotionMenu encoding NEVER works with QuEnc (menu.avs plays fine with MPC-HC, so I assume it's not codec-related) I also uninstalled and reinstalled AVStoDVD... My third machine runs XP SP3 on an old AMD Athlon 2400+. Everything fine there (except encoding time ) ggtop |
18th August 2010, 15:40 | #1453 | Link | ||
AVStoDVD Dev
By default, I have left multithread encoding always ON during menu creation step. Next release will adapt to Advanced Option setting. Quote:
Bye |
19th August 2010, 16:49 | #1455 | Link |
Fade In/Out in Motion Menu
Hi Mrc,
I don't think it's a bug, but it is a little annoying. I just created a test DVD with 1 title and used FadeIn/Out via avisynth option. And I selected motion menu. In this case the fading also appears on the menu page. This doesn't look nice when all thumbnails come up slowly from black. Do you feel encouraged to change this behaviour? Maybe it would be an good idea to take the part of the video beyond selected fade-in time... ggtop BTW No issues with QuEnc under Win7 64bit & Centrino Duo. Last edited by ggtop; 19th August 2010 at 19:28. |
19th August 2010, 20:20 | #1456 | Link | ||
AVStoDVD Dev
Unfortunately it is not possible. But 2.3.2 is not so far... Quote:
Somebody would say that remove a fading effect is good and somebody would say it is bad. I think that leaving it is better than removing it at all. I would prefer to give the option to tweak the thumb avs script during DVD Menu editing. What do you think? Thanks for the feedback. It would be great if anybody else with a P4 HT could give us a feedback on motion menu creation as well. Bye |
20th August 2010, 09:17 | #1457 | Link | |
Thank you for your great app and for your continous work on it. When will 2.3.2 be released. I want to bore my family with weddings and birthday parties ggtop |
20th August 2010, 12:02 | #1458 | Link |
AVStoDVD Dev
@ggtop
do you mean the dialog windows to edit the cmd parameters? Ok, I will put in the ToDo list. 2.3.2 is almost ready. Just some beta testing with my set of sample clips. Probably next week it will be out. Bye |
21st August 2010, 13:09 | #1460 | Link | |
AVStoDVD Dev
Well, my usual PC, where I do most of A2D development, is a core2 duo centrino T8300. The Athlon 1800+ is used mainly as printer and files server. Anyway I'm seriously considering to upgrade it, because even latest web flash apps run slooooowly... Bye |
