8th February 2007, 17:57 | #101 | Link | |
This is what the GPAC team says about the issue:
8th February 2007, 18:02 | #102 | Link |
retired developer
thanks! gonna be fixed in next release.
Detritus Software |
10th February 2007, 19:42 | #105 | Link |
retired developer
xvid is on the way.
If your source don't have audio, output won't have audio either. To not have audio, bot usre if it works, but set an audio track number that doesn't exist, like 42.
Detritus Software |
10th February 2007, 20:31 | #106 | Link |
Bencos also fails if there's no video in the file. RA5 works like a charm, though.
Though RA5 used Nero's AAC encoder it seems, and bencos uses enhAacPlusEnc.exe, and I think the later is better? Well, I'd like to be able to encode even if there's no video stream in the container. |
10th February 2007, 20:42 | #107 | Link |
retired developer
Bencos don't verify the source like RA5 did. It only check if there's audio while performing the video first pass encoding.
Bencos requires you to have a video stream, but audio stream is optional. Use another tool for audio-only recoding, there are plenty out there.
Detritus Software |
10th February 2007, 22:58 | #109 | Link |
retired developer
Detritus Software |
11th February 2007, 03:49 | #111 | Link |
Mr. Sandman
Bencos on the contrary of RA is a generic batch encoder )which means it has different profiles for movies, animes, etc...). MPEG-4 ASP is necessary for standalones compatibility and it is still the most used standard on the internet. MPEG-4 ASP is also lightweight and (optimal for low end computers) and it's more appetible for a wider range of users, so it's necessary for a general encoding app to have it.
MPEG-4 ASP Custom Matrices: EQM V1(old), EQM AutoGK Sharpmatrix (aka EQM V2), EQM V3HR (updated 01/10/2004), EQM V3LR, EQM V3ULR (updated 04/02/2005), EQM V3UHR (updated 17/12/2004) and EQM V3EHR (updated 05/10/2004) Info about my ASP matrices. MPEG-4 AVC Custom Matrices: EQM AVC-HR Info about my AVC matrices My x264 builds. Mooo!!! Last edited by Sharktooth; 11th February 2007 at 03:52. |
11th February 2007, 14:52 | #114 | Link |
Why would it be? Currently, it's inferior to RA because most things haven't been added yet. And what does BENCOS have that RA does not? The only thing I can think of right now is dvd input and movie profiles. And linux support, of course. Very neat features, and I do hope there's more to come.
But RA had so much more, so BENCOS isn't better just yet... |
11th February 2007, 16:15 | #115 | Link |
retired developer
Now that the biggest problem is fixed, the massive framedrops and gray frames, we can add more stuff to bencos and make it the best GUI ever
Currently bencos handle more inputs than RA5 and is more stable, it also have more profiles than RA4/5.
Detritus Software |
11th February 2007, 20:12 | #118 | Link |
I snatched the latest build on the site and, aside from the whole can't encode to any other dir than C:\, it looks like it worked. The sound quality was what I tested and there seems to be no delays and good quality @ 24 kbps. Artifacts appeared when using 16, but that's to be expected.
Good work! |
12th February 2007, 01:30 | #119 | Link |
retired developer
@Eretria-chan
Output to F: still fails? @Amnon82 I'll make the nessessary mod during the week for linux use. Then you'll need someone to compile it.
Detritus Software |
12th February 2007, 03:34 | #120 | Link |
retired developer
Detritus Software |
aac, bencos, gui, webm, x264 |
