16th August 2012, 22:17 | #741 | Link |
Of course your reply is not really satisfactory for me, so I did a little research...
Apple Application Support can be extracted from QuickTime or iTunes and can be installed separately, but it is still bloated. It uses more than 60 MB on the HDD, it installs an autorun entry for APSDaemon.exe, and it adds a Windows Firewall exception for WebKit. A little much for my taste. Since oreons succeeded in making MkvToMp4 use qaac without installing Apple Application Support, my first attempt was to make LameXP use the CoreAudio files from MkvToMp4. But this did not work so far. The second best approach was to install Apple Application Support, but strip it down to only the essential files. And this did work... This is the procedure: 1. Download QuickTime or iTunes, open the file with 7-Zip and extract AppleApplicationSupport.msi. Install it by doubleclicking it. 2. Open RegEdit, go to HKLM/Software/Microsoft/Windows/CurrentVersion/Run and delete the entry for APSDaemon. 3. Open your Firewall settings and remove the exception for WebKit. 4. Run Explorer, navigate to Program Files/Common Files/Apple/Apple Application Support. Delete all subfolders. Delete all files in the root folder except: ASL.dll CoreAudioToolbox.dll CoreFoundation.dll icudt46.dll libdispatch.dll libicuin.dll libicuuc.dll obj.dll pthreadVC2.dll 5. Reboot The size of your Apple folder will now be only 23 MB, and the software will not make home calls any more... Cheers manolito |
16th August 2012, 22:42 | #742 | Link |
Software Developer
You really worry about 60 MB in times where the OS alone easily takes 10-15 GB of HDD space?
Anyway, if you want to be really paranoid and avoid installing Apple Application Support by all means, you can extract the CoreAudioToolbox DLL files from the "AppleApplicationSupport.msi" file via 7-Zip. Put them into a sub-folder called "QTfiles" which you create inside the directory where the "qaac.exe" resides and you are done. There is no MkvToMp4 "magic" needed for that...
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 16th August 2012 at 22:49. |
16th August 2012, 23:31 | #743 | Link | ||||
Cheers manolito //Edit// Alright, I think I figured it out... The subfolder QTfiles needs another subfolder called "Microsoft.VC80.CRT" which must contain the files msvcr80.dll msvcp80.dll Microsoft.VC80.CRT.manifest It looks like the easiest way to make this work under LameXP is to pull the whole QTFiles folder from MkvToMp4 and copy it into the LameXP folder. Last edited by manolito; 16th August 2012 at 23:50. |
16th August 2012, 23:51 | #744 | Link |
Software Developer
It does work for me. Tested on a "clean" VM.
Make sure "qaac.exe" as well as "libsoxrate.dll" are located in your LameXP directory. All the CoreAudioToolbox DLL's go into a sub-folder "QTfiles". You may verify that QAAC is working properly by running "qaac.exe --check" from the LameXP directory... [EDIT] Indeed, the Apple Application Support DLL's depend on the Visual C++ 2005 Runtime libraries. Thus you will need the Microsoft Visual C++ 2005 Redistributable Package, if you happen to not have that installed yet. Also you don't need a "special" QAAC binary from MkvToMp4, the build included in the LameXP Add-in should work fine. The CoreAudioToolbox DLL's need to be obtained from Apple web-site for legal reasons...
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 17th August 2012 at 00:29. |
17th August 2012, 01:06 | #745 | Link | |
Still qaac refused to work without the "Microsoft.VC80.CRT" subfolder under the Qtfiles folder. Oh well... I've got another request, though. When more than one AAC encoder is installed, FHG takes precedence over Nero, and qaac takes precedence over FHG. For people like me who always love to have choices, would it be possible to add a selection box to LameXP so if more than one AAC encoder is installed we could easily pick the one we want from within the GUI? Cheers manolito |
17th August 2012, 12:17 | #746 | Link |
Software Developer
The VS2005 and VS2008 runtime libraries are handled by WinSxS (Windows Side-by-Side) and thus they actually need to be installed. Just putting the runtime DLL's into the application directory won't work with these VS versions. Once the VS2005/VS2008 redistributable package has been installed, WinSxS will take care of providing each applications with the proper DLL (version). Also Windows Update will take care of keeping the DLL's managed by WinSxS up-to-date. It is also possible to provide assemblies (DLL files) as "private assemblies" by putting them into a specific sub-folder along with a suitable Manifest file. This is intended for assemblies that, unlike the C++ Runtime libs, are not supposed to be used by multiple applications. Starting with VS2010, the C++ Runtime libs are no longer maintained by WinSxS though.
About adding an option to choose the AAC encoder at runtime: This certainly would be possible, but it would be yet another complication. I see that such an option would be nice for switching between the different encoders quickly, in case you are doing some encoder comparison. But most users will probably install their preferred AAC encoder once and then stick with it. If, for example, somebody installs the Add-in for FHG-AAC or for QAAC, we can be pretty sure the user actually wants to use that encoder...
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 17th August 2012 at 13:41. |
17th August 2012, 20:29 | #748 | Link | |
Software Developer
LameXP v4.05 Beta-4
If you used any of the previous LameXP v4.05 Alpha/Beta versions, then it is highly recommended that you check your %TEMP% directory and clean it up manually, if required...
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 21st August 2012 at 23:13. |
17th August 2012, 21:21 | #749 | Link | |
Re: qaac support
Just a quick note for users of the stable version 4.04:
And it is not necessary to copy All the CoreAudioToolbox DLL's. Only these 9 files need to be copied: ASL.dll CoreAudioToolbox.dll CoreFoundation.dll icudt46.dll libdispatch.dll libicuin.dll libicuuc.dll obj.dll pthreadVC2.dll Cheers manolito |
21st August 2012, 23:16 | #750 | Link | |
Software Developer
LameXP v4.05 RC-1
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 22nd August 2012 at 22:56. |
22nd August 2012, 11:32 | #751 | Link |
Opus encoding does not work in ABR mode
LameXP v4.05 (Build #1094), compiled on 2012-08-21 at 21:38:19 ------------------------------- C:/Users/Mama/AppData/Local/Temp/fb867800d75349b5bf17ed998fe27c63/lxp_flac.exe -d -F -f -o C:\Users\Mama\AppData\Local\Temp\fb867800d75349b5bf17ed998fe27c63\332ef1f30da44ea89ed1890f46a613a8.wav "C:\Users\Mama\Desktop\CryptidaliaFLAC\Rom Di Prisco\Cryptidalia\01 - Troposphere.flac" flac 1.2.1, Copyright (C) 2000,2001,2002,2003,2004,2005,2006,2007 Josh Coalson flac comes with ABSOLUTELY NO WARRANTY. This is free software, and you are welcome to redistribute it under certain conditions. Type `flac' for details. Exited with code: 0x0000 ------------------------------- C:/Users/Mama/AppData/Local/Temp/fb867800d75349b5bf17ed998fe27c63/lxp_sox.exe --i C:/Users/Mama/AppData/Local/Temp/fb867800d75349b5bf17ed998fe27c63/332ef1f30da44ea89ed1890f46a613a8.wav Input File : 'C:/Users/Mama/AppData/Local/Temp/fb867800d75349b5bf17ed998fe27c63/332ef1f30da44ea89ed1890f46a613a8.wav' Channels : 2 Sample Rate : 44100 Precision : 16-bit Duration : 00:05:39.26 = 14961152 samples = 25444.1 CDDA sectors File Size : 59.8M Bit Rate : 1.41M Sample Encoding: 16-bit Signed Integer PCM Exited with code: 0x0000 ------------------------------- C:/Users/Mama/AppData/Local/Temp/fb867800d75349b5bf17ed998fe27c63/lxp_opusenc_ea7.exe -cvbr --music --comp 10 --framesize 20 --bitrate 64 --title Troposphere --artist "Rom Di Prisco" --comment album=Cryptidalia --comment genre=Electronic --comment "comment=Encoded with LameXP" --comment date=2010 --comment track=1 C:\Users\Mama\AppData\Local\Temp\fb867800d75349b5bf17ed998fe27c63\332ef1f30da44ea89ed1890f46a613a8.wav "C:\Users\Mama\Desktop\CryptidaliaFLAC\01 - Troposphere (3).opus" Usage: opusenc [options] input_file output_file.opus Encodes input_file using Opus. It can read the WAV, AIFF, or raw files. General options: -h, --help This help -v, --version Version information --quiet Quiet mode input_file can be: filename.wav file - stdin output_file can be: filename.opus compressed file - stdout Encoding options: --speech Optimize for speech --music Optimize for music --bitrate n.nnn Encoding bitrate in kbit/sec (6-256 per channel) --vbr Use variable bitrate encoding (default) --cvbr Use constrained variable bitrate encoding --hard-cbr Use hard constant bitrate encoding --comp n Encoding complexity (0-10, default: 10) --framesize n Maximum frame size in milliseconds (2.5, 5, 10, 20, 40, 60, default: 20) --expect-loss Percentage packet loss to expect (default: 0) --downmix-mono Downmix to mono --downmix-stereo Downmix to stereo (if >2 channels) --max-delay n Maximum container delay in milliseconds (0-1000, default: 1000) Diagnostic options: --save-range file Saves check values for every frame to a file --set-ctl-int x=y Pass the encoder control x with value y (advanced) Preface with s: to direct the ctl to multistream s This may be used multiple times --uncoupled Use one mono stream per channel Metadata options: --comment Add the given string as an extra comment This may be used multiple times --artist Author of this track --title Title for this track Input options: --raw Raw input --raw-bits n Set bits/sample for raw input (default: 16) --raw-rate n Set sampling rate for raw input (default: 48000) --raw-chan n Set number of channels for raw input (default: 2) --raw-endianness n 1 for bigendian, 0 for little (defaults to 0) --ignorelength Always ignore the datalength in Wave headers C:\Users\Mama\AppData\Local\Temp\fb867800d75349b5bf17ed998fe27c63\lxp_opusenc_ea7.exe: invalid option -- c Exited with code: 0x0001 Regarding opus advanced settings --music and --speech switch will be removed in official final version according to devs
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 22nd August 2012 at 11:38. |
22nd August 2012, 12:07 | #752 | Link |
Software Developer
Thank you for the report. LameXP is passing "-cvbr", while it should be passing "--cvbr". I will fix this typo in the next build
Also I probably won't update the Opus binaries again before the 4.05 release, so "--music" and "--speech" will stay for now (although they don't do much, they don't hurt either).
22nd August 2012, 12:14 | #753 | Link | |
Another thing. I wonder why user would like to lower Encoding Complexity and Frame Size?
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 22nd August 2012 at 12:16. |
22nd August 2012, 12:20 | #754 | Link | |
Software Developer
They do something. Though not what one may expect.
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 22nd August 2012 at 12:24. |
22nd August 2012, 12:24 | #755 | Link | |
http://www.hydrogenaudio.org/forums/...dpost&p=805845
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 22nd August 2012 at 12:28. |
22nd August 2012, 12:41 | #756 | Link |
Another question. Why LameXP always dumps everything first to .wav instead of just using pipes? My HDD is old and slow and this is really a noticeable bottleneck when running 4 instances on my Q8200@2.8Ghz
22nd August 2012, 12:54 | #757 | Link |
Software Developer
Because using pipes would require all encoders and all decoders to support reading input from STDIN and writing output to STDOUT.
Also: Even if we assume all tools could to this, what do you send over the pipe? Just the "raw" PCM samples? If so, how do you indicate the sample format? Does the GUI need to know the sample format the previous tool outputs (how?) and pass that info to the next tool in the chain via CLI arguments? Or does the previous tool have to prepend a "fake" Wave header (or whatever header) to the data, which the next tools is required to parse? Who defines all this and enforces the individual tool authors to make use of it? In reality, every audio CLI tools does things slightly differently. And I cannot fix or re-write them all! After all, using Wave files seems to be the "least common denominator" for exchanging audio data between various CLI tools. Using pipes might be more elegant, but suffers from a lot of practical problems...
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 22nd August 2012 at 13:01. |
22nd August 2012, 13:03 | #758 | Link | ||
22nd August 2012, 13:07 | #759 | Link | |||
Software Developer
Also: In case of LAME, the default/recommended "algorithm complexity" is not the slowest one, but the third slowest one. We certainly can't force all people to use the slowest settings, because benefit over the default settings will be minimal while encoding-speed will be a lot slower. Still some people don't care about speed and might want to user even slower settings than the default. Quote:
You can send some kind of "fake" Wave header (with "blank" size fields), indeed. But this requires the next tool in the chain to (a) expect a Wave header over the pipe and (b) know about your hack... Quote:
Supporting both methods, passing the data by Wave files and via Pipe, would add even more complexity plus more things to test - for every single CLI tool. No, thanks Also: If the data is passed via pipe, how does the GUI determine the sample format that comes out of the decoder? The GUI has to know this, because sometimes the output format (e.g. sample-rate or bit-depth) the decoder spits out is not acceptable for the encoder and we need to convert via SoX!
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 22nd August 2012 at 13:19. |
22nd August 2012, 13:24 | #760 | Link |
here is how i convert .FLAC to lossy formats without intermediate .wavs
.FLAC to .OPUS Code:
ffmpeg.exe -i "01 - Troposphere.flac" -f wav - | "opusenc.exe" --bitrate 64 - "01 - Troposphere.opus" Code:
ffmpeg.exe -i "01 - Troposphere.flac" -f wav - | "oggenc.exe" -Q -q 0 - -o "01 - Troposphere.ogg" Code:
ffmpeg.exe -i "01 - Troposphere.flac" -f wav - | "fhgaacenc.exe" --profile he --cbr 64 --adts --ignorelength - "01 - Troposphere.aac" Code:
ffmpeg.exe -i "01 - Troposphere.flac" -f wav - | "aften.exe" -readtoeof 1 -b 192 - "01 - Troposphere.ac3"
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 22nd August 2012 at 13:49. |
aac, aotuv, flac, lame, lamexp, mp3, mp4, ogg, oggenc, opus, vorbis |
