22nd August 2020, 22:00 | #29902 | Link | |
Not sure which is worse, the viruses or the software that is designed to deal with them. |
23rd August 2020, 14:53 | #29906 | Link | |
I want to do more tests, but I will be away from my PC for several weeks. Did you have a chance to check SEI information? |
23rd August 2020, 17:39 | #29907 | Link |
Suggestion
Hi jdobbs,
thank you for the new version. Just downloaded it and wanted to perform a first encode when I immediately received an error: Code:
ExtractAudioSubs() 00053 1604 Maybe you could implement a basic "FILE EXISTS" check for entries under [Paths] in BDREBUILDER.INI? ggtop |
24th August 2020, 03:13 | #29908 | Link | |
24th August 2020, 03:17 | #29909 | Link | |
What I'm doing now since I'm not re-encoding a lot of Blu-rays at the moment, I just defeat about 3/4 of the 'cores/threads' so that I am only using 3 out of 12 and at that 25% I can BARELY keep the heat just below redlining. Doesn't seem like it should be that way. I guess down the road I will hafta get one of the water coolers you guys are talking about. Appreciate the input! |
24th August 2020, 03:20 | #29910 | Link |
Yeah, the guy honestly SEEMS like he is pretty sharp about this, but he could always take a look at it to see if he can narrow down exactly why it is getting so hot when more fully utilized. I guess I can wait until I get the water cooler so that he can install it at the same time I suppose...
24th August 2020, 03:21 | #29911 | Link | |
24th August 2020, 03:22 | #29912 | Link | |
24th August 2020, 04:39 | #29914 | Link |
Um, the latest version on page one seems to direct to a site in Germany with really slow speeds. Is that where it usually goes...?
https://jammernhilftnichts.de/jdobbs/BD-RBV06113.zip |
24th August 2020, 13:23 | #29915 | Link | |
24th August 2020, 16:42 | #29916 | Link | |
Can't do much about it but reboot the Server. Usually I get at least 100mbit/s |
24th August 2020, 19:21 | #29917 | Link | |
25th August 2020, 18:06 | #29918 | Link |
Watchmen Dir Cut
Running this BD as a .mp4 container fails, Input & Output files are in a previous post. Running this as a .mkv completes successfully, but it still has the wrong length. Notice that the Audio & Video sections report the Time Duration as 3h 6min, that is the correct length of the movie. The subtitles are an incorrect Duration causing the General->Duration time to be incorrect.
I have the mediainfo on the BD source, but its too long to add as CODE. How can I get the data in here? Code:
$ mediainfo WATCHMEN_DC.mkv General Unique ID : 190735447712007644297711488837758782096 (0x8F7E4F9F098A76D0BCE8F305B0C88A90) Complete name : WATCHMEN_DC.mkv Format : Matroska Format version : Version 2 File size : 5.25 GiB Duration : 6 h 12 min Overall bit rate : 2 015 kb/s Encoded date : UTC 2020-08-25 03:48:42 Writing application : mkvmerge v9.7.1 ('Pandemonium') 32bit Writing library : libebml v1.3.4 + libmatroska v1.4.5 Video ID : 1 Format : HEVC Format/Info : High Efficiency Video Coding Format profile : Main 10@L4@Main Codec ID : V_MPEGH/ISO/HEVC Duration : 3 h 6 min Bit rate : 3 731 kb/s Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 23.976 (23976/1000) FPS Original frame rate : 23.976 (24000/1001) FPS Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 10 bits Bits/(Pixel*Frame) : 0.075 Stream size : 4.86 GiB (93%) Writing library : x265 3.2.1+3-b4b2ecac21f6:[Windows][GCC 9.2.0][64 bit] 10bit Encoding settings : cpuid=1111039 / frame-threads=3 / numa-pools=8 / wpp / no-pmode / no-pme / no-psnr / no-ssim / log-level=2 / input-csp=1 / input-res=1920x1080 / interlace=0 / total-frames=0 / level-idc=0 / high-tier=1 / uhd-bd=0 / ref=3 / no-allow-non-conformance / no-repeat-headers / annexb / no-aud / no-hrd / info / hash=0 / no-temporal-layers / open-gop / min-keyint=23 / keyint=240 / gop-lookahead=0 / bframes=4 / b-adapt=2 / b-pyramid / bframe-bias=0 / rc-lookahead=20 / lookahead-slices=6 / scenecut=40 / radl=0 / no-splice / no-intra-refresh / ctu=64 / min-cu-size=8 / no-rect / no-amp / max-tu-size=32 / tu-inter-depth=1 / tu-intra-depth=1 / limit-tu=0 / rdoq-level=0 / dynamic-rd=0.00 / no-ssim-rd / signhide / no-tskip / nr-intra=0 / nr-inter=0 / no-constrained-intra / strong-intra-smoothing / max-merge=3 / limit-refs=1 / no-limit-modes / me=1 / subme=2 / merange=57 / temporal-mvp / no-hme / weightp / no-weightb / no-analyze-src-pics / deblock=0:0 / sao / no-sao-non-deblock / rd=3 / selective-sao=4 / early-skip / rskip / no-fast-intra / no-tskip-fast / no-cu-lossless / b-intra / no-splitrd-skip / rdpenalty=0 / psy-rd=2.00 / psy-rdoq=0.00 / no-rd-refine / no-lossless / cbqpoffs=0 / crqpoffs=0 / rc=crf / crf=1.0 / qcomp=0.60 / qpstep=4 / stats-write=0 / stats-read=0 / ipratio=1.40 / pbratio=1.30 / aq-mode=2 / aq-strength=1.00 / cutree / zone-count=0 / no-strict-cbr / qg-size=32 / no-rc-grain / qpmax=69 / qpmin=0 / no-const-vbv / sar=0 / overscan=0 / videoformat=5 / range=0 / colorprim=2 / transfer=2 / colormatrix=2 / chromaloc=0 / display-window=0 / cll=0,0 / min-luma=0 / max-luma=1023 / log2-max-poc-lsb=8 / vui-timing-info / vui-hrd-info / slices=1 / no-opt-qp-pps / no-opt-ref-list-length-pps / no-multi-pass-opt-rps / scenecut-bias=0.05 / no-opt-cu-delta-qp / no-aq-motion / no-hdr / no-hdr-opt / no-dhdr10-opt / no-idr-recovery-sei / analysis-reuse-level=5 / scale-factor=0 / refine-intra=0 / refine-inter=0 / refine-mv=1 / refine-ctu-distortion=0 / no-limit-sao / ctu-info=0 / no-lowpass-dct / refine-analysis-type=0 / copy-pic=1 / max-ausize-factor=1.0 / no-dynamic-refine / no-single-sei / no-hevc-aq / no-svt / no-field / qp-adaptation-range=1.00 Default : Yes Forced : No Audio ID : 2 Format : AAC LC Format/Info : Advanced Audio Codec Low Complexity Codec ID : A_AAC-2 Duration : 3 h 6 min Bit rate : 265 kb/s Channel(s) : 6 channels Channel layout : C L R Ls Rs LFE Sampling rate : 48.0 kHz Frame rate : 46.875 FPS (1024 SPF) Compression mode : Lossy Stream size : 351 MiB (7%) Language : English Default : Yes Forced : No Text #1 ID : 3 Format : PGS Muxing mode : zlib Codec ID : S_HDMV/PGS Codec ID/Info : Picture based subtitle format used on BDs/HD-DVDs Duration : 6 h 12 min Bit rate : 6 485 b/s Count of elements : 4072 Stream size : 17.3 MiB (0%) Language : English Default : No Forced : No Text #2 ID : 4 Format : PGS Muxing mode : zlib Codec ID : S_HDMV/PGS Codec ID/Info : Picture based subtitle format used on BDs/HD-DVDs Duration : 6 h 12 min Bit rate : 8 679 b/s Count of elements : 4758 Stream size : 23.1 MiB (0%) Language : English Default : No Forced : No Menu 00:00:00.000 : en:00:00:00.000 00:05:41.674 : en:00:05:41.674 00:11:16.133 : en:00:11:16.133 00:16:05.339 : en:00:16:05.339 00:19:05.561 : en:00:19:05.561 00:23:48.802 : en:00:23:48.802 00:26:39.514 : en:00:26:39.514 00:31:37.979 : en:00:31:37.979 00:36:26.892 : en:00:36:26.892 00:41:01.417 : en:00:41:01.417 00:44:58.654 : en:00:44:58.654 00:47:27.344 : en:00:47:27.344 00:51:40.597 : en:00:51:40.597 00:56:10.241 : en:00:56:10.241 00:58:17.910 : en:00:58:17.910 01:00:58.946 : en:01:00:58.946 01:04:13.265 : en:01:04:13.265 01:11:22.778 : en:01:11:22.778 01:13:14.264 : en:01:13:14.264 01:16:45.892 : en:01:16:45.892 01:18:47.264 : en:01:18:47.264 01:21:47.527 : en:01:21:47.527 01:26:52.081 : en:01:26:52.081 01:31:17.972 : en:01:31:17.972 01:37:09.490 : en:01:37:09.490 01:41:10.355 : en:01:41:10.355 01:46:57.410 : en:01:46:57.410 01:53:50.698 : en:01:53:50.698 01:57:18.739 : en:01:57:18.739 02:03:03.167 : en:02:03:03.167 02:06:07.309 : en:02:06:07.309 02:10:23.774 : en:02:10:23.774 02:15:18.777 : en:02:15:18.777 02:19:31.988 : en:02:19:31.988 02:22:13.524 : en:02:22:13.524 02:27:11.030 : en:02:27:11.030 02:33:54.933 : en:02:33:54.933 02:36:37.679 : en:02:36:37.679 02:41:03.069 : en:02:41:03.069 02:44:25.897 : en:02:44:25.897 02:47:31.833 : en:02:47:31.833 02:51:02.293 : en:02:51:02.293 02:55:06.996 : en:02:55:06.996 02:59:45.983 : en:02:59:45.983 03:06:27.843 : en:03:06:27.843 Code:
[Status] LABEL=WATCHMEN VERSION=v0.61.12 SOURCE_SIZE=35145842688 SOURCE_VIDEO_SIZE=35145842688 TARGET_SIZE=4686086144 REDUCTION=.133332587458487 RESIZE_1080=0 RESIZE_1440=0 AUDIO_TO_KEEP=eng; KEEP_HD_AUDIO=0 SUBS_TO_KEEP=eng; BACKUP_MODE=1 MOVIEONLY_TYPE=33 USE_LAVF=0 INSTANCES=1 DGDECNV=0 DGDECIM=0 FRIMSOURCE=0 FFMS2=0 SSIF_MODE=0 UHD_V3_MODE=0 QUICK=0 ENCODE_STEP=0 COMPLETED=25 REBUILD_COMPLETE=1 [00500] AUDIO=100 PGS=100010 S1440=0 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=268696 NSIZE=0 FLINK=-1 MLINK=0 [00501] S1440=0 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=15032236 AUDIO=100 NSIZE=0 FLINK=-1 MLINK=0 [00502] S1440=0 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=57589438 AUDIO=100 NSIZE=0 FLINK=-1 MLINK=0 [00503] S1440=0 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=78818887 AUDIO=100 NSIZE=0 FLINK=-1 MLINK=0 [00504] S1440=0 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=378957342 AUDIO=100 NSIZE=0 FLINK=-1 MLINK=0 [00505] S1440=0 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=69512008 AUDIO=100 NSIZE=0 FLINK=-1 MLINK=0 [00506] S1440=0 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=574395251 AUDIO=100 NSIZE=0 FLINK=-1 MLINK=0 [00507] S1440=0 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=65900995 AUDIO=100 NSIZE=0 FLINK=-1 MLINK=0 [00508] S1440=0 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=134614287 AUDIO=100 NSIZE=0 FLINK=-1 MLINK=0 [00509] S1440=0 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=45525147 AUDIO=100 NSIZE=0 FLINK=-1 MLINK=0 [00510] S1440=0 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=94264817 AUDIO=100 NSIZE=0 FLINK=-1 MLINK=0 [00511] S1440=0 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=65805968 AUDIO=100 NSIZE=0 FLINK=-1 MLINK=0 [00512] S1440=0 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=597088602 AUDIO=100 NSIZE=0 FLINK=-1 MLINK=0 [00513] S1440=0 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=56924251 AUDIO=100 NSIZE=0 FLINK=-1 MLINK=0 [00514] S1440=0 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=802112735 AUDIO=100 NSIZE=0 FLINK=-1 MLINK=0 [00515] S1440=0 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=93446440 AUDIO=100 NSIZE=0 FLINK=-1 MLINK=0 [00516] S1440=0 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=473949605 AUDIO=100 NSIZE=0 FLINK=-1 MLINK=0 [00517] S1440=0 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=69221194 AUDIO=100 NSIZE=0 FLINK=-1 MLINK=0 [00518] S1440=0 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=334745366 AUDIO=100 NSIZE=0 FLINK=-1 MLINK=0 [00519] S1440=0 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=69143370 AUDIO=100 NSIZE=0 FLINK=-1 MLINK=0 [00520] S1440=0 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=87712073 AUDIO=100 NSIZE=0 FLINK=-1 MLINK=0 [00521] S1440=0 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=64320767 AUDIO=100 NSIZE=0 FLINK=-1 MLINK=0 [00522] S1440=0 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=366298316 AUDIO=100 NSIZE=0 FLINK=-1 MLINK=0 [00523] S1440=0 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=90352339 AUDIO=100 NSIZE=0 FLINK=-1 MLINK=0 [00524] S1440=0 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=86016 AUDIO=100 NSIZE=0 FLINK=0 MLINK=0 Code:
[08/24/20] BD Rebuilder v0.61.12 [13:54:12] Source: WATCHMEN_00100 - Input BD size: 32.73 GB - Approximate total content: [03:06:28.385] - Windows Version: 6.2 [9200] - MOVIE-ONLY/ALTERNATE OUTPUT mode enabled - Mode: MKV Container, HEVC 1920x1080, Auto-AAC - Quality: High Quality (Default) - Decoding/Frame serving: DirectShow - Audio Settings: AC3=0 DTS=0 HD=0 Kbs=640 [13:54:12] PHASE ONE, Encoding - [13:54:12] Processing: VID_00500 (1 of 25) - [13:54:12] Extracting A/V streams [VID_00500] - [13:59:32] Reencoding video [VID_00500] - Source Video: VC-1, 1920x1080 - Rate/Length: 23.976fps, 96 frames - [13:59:32] Reencoding: VID_00500, Pass 1 of 1 - Analyzing 43.45 23.75 1.00 [1.00] - [13:59:44] Video Encode complete - [13:59:44] Processing audio tracks - Track 4352 (eng): Reencoding audio to AAC... <snip> - [20:39:34] Processing: VID_00523 (24 of 25) - [20:39:34] Extracting A/V streams [VID_00523] - [20:39:47] Reencoding video [VID_00523] - Source Video: VC-1, 1920x1080 - Rate/Length: 23.976fps, 10,006 frames - [20:39:47] Reencoding: VID_00523, Pass 1 of 1 - Analyzing 26.35 21.85 22.20 [22.20] - [20:45:59] Video Encode complete - [20:45:59] Processing: VID_00524 (25 of 25) - [20:45:59] Extracting A/V streams [VID_00524] - [20:46:03] Reencoding video [VID_00524] - Source Video: VC-1, 1920x1080 - Rate/Length: 23.976fps, 29 frames - [20:46:03] Reencoding: VID_00524, Pass 1 of 1 - Analyzing 42.15 24.35 11.45 1.00 [1.00] - [20:46:10] Video Encode complete [20:46:10]PHASE ONE complete [20:46:10]PHASE TWO - Rebuild Started - [20:46:11] Building ALTERNATE OUTPUT Structure [20:51:32] - Encode and Rebuild complete [20:51:32] JOB: WATCHMEN finished. Last edited by meadrocks; 26th August 2020 at 00:11. |
