Old 13th January 2015, 23:58   #121  |  Link
hubblec4
Matroska find' ich toll
This function already exists. called FPS Conversion:
For OGG, XML, TTXT and multiAVCHD editor you will find this function. Activate the checkbox and set the source and target FPS.
Old 3rd February 2015, 00:22   #122  |  Link
hubblec4
A new version with new functions and improvments are avalible.
Ordered chapters can now be calculated using the playing time for an edition in XML format.
Changelog chapterEditor
added &
fixed *
improvement #
layout change %
rev0.32
// chapterEditor
& Hot Keys: OGG, XML, TTXT, multiAVCHD
  all
  - Entf > delete chapter (edition)
  - q, 8(num) > chapter up
  - w, 2(num) > chapter down
  - n > new, all clear
  - k > add chapter
  XML
  - c > copy edition
  - v > add new edition
  - t > open Tags editor
  - h > change hidden
  - e > change enabled/default
  - o > change ordered
  TTXT
  - c > copy chapter
  multiAVCHD
  - c > copy chapter
  - t > open Thumbnail Positions Generator
// multi chapters
& palytime for XML:
  - Become multi chapters created for the XML format, then the specified
    playing time is used for the edition.
// settings
& Tools:     - (Java) BDSup2Sub.jar (5.1.2)
  Paths:     - Java
  BDSup2Sub: - Choice between the two versions
& XML - Matroska drag&drop with a selected edition
// XML Format
& playing time for an edition:
  - is an edition selected, you can assign a playing time
  - When you drag&drop Matroska files, the playing time may be used
  - the playing time of mpls and IFO (title) files will automatically be used
# Matroska parsing:
  - playing time is determined and used for all editions in XML
# End time calculation for "ordered chapters"
  - If an edition has a playing time and this is greater than the start time of the
    last chapter, it will be used.
# ChapterGrabber chapters file:
  - the playing time is used for the edition
// 3GPP TTXT Format
# chapter time can also be specified with milli seconds now
  - 1.234
  - 1,234
// Multi Editions Editor
& demux subtitles:
  - It will automatically check for forced subtitles and these are then extracted.
// DVD2mkv
* "XML to Editor" not working
Old 20th February 2015, 16:29   #123  |  Link
Jim_Pansen
Aaah, thanks! Sorry for not realizing this.
I'm just looking for a simple tool that can convert chapter lists as created by NLEs
to convert it to chapter lists of different formats to serve it to use NLEs, authoring
tools, encoders e.g. I-frame control lists such as qpfile for X264 which is sadly frame
based & which needs to be calculated by TC / frame rate.
Is that of someones interest so maybe you could add a new tab of the mentioned features?
Thanks in advance
Jim
Jim_Pansen is offline   Reply With Quote
Old 22nd February 2015, 21:14   #124  |  Link
hubblec4
Hi Jim
What are "NLEs? Have you a sample of such chapter list?
I have not much time but i will have a look.
Old 27th February 2015, 02:31   #125  |  Link
Jim_Pansen
Sorry for the delay.
A lot user may would be really thankful!
'NLE' just means 'non-linear editing system'!
http://en.wikipedia.org/wiki/Non-linear_editing_system
The usual scenario is that one does an edit or mastering of a feature film in NLE & sets
the chapter points. Most NLEs can export chapter lists so the user may like to use it in
the desired encoding tool to set I-frames on the right TC position. After encoding the
assets the chapter list is needed to set the right frame in favorite autoring tool.
I could send you some specific sample files holding chapter lists for different tools.
Please be patient, it will take some time.
Thanks in advance
Jim
Old 27th February 2015, 23:00   #126  |  Link
hubblec4
I have read a bit, but I found nothing about chapter lists. Without a syntax and semantic I can't do anything.
That would be helpful.
chapterEditor should be able to handle such chapter lists? And as output format ogg,xml,ttxt,multiavchd or you need another output format?
Old 12th March 2015, 20:49   #127  |  Link
hubblec4
here is a new version, rev0.33
added &
fixed *
improvement #
layout change %
rev0.33
// chapterEditor
& support for dgi file (OGG,XML,TTXT,mAVCHD)
// settings
& Tools->DGIndexNV: dgi file
  - Selection for the keyframes at AVC material(DGAVCIndex)
* XML: English translation missing
// XML Format
# There can be only one edition of default.
  - the default is set for an edition of the default is at
    repealed other editions automatically
// 3GPP TTXT Format
* FPS conversion did not work for chapter times in seconds
  are indicated.
# the video track will get from now on English as the default
Old 13th March 2015, 20:54   #128  |  Link
FredThompson
FredThompson's Avatar
chapterEditor rev0.33 starts in German for me. How to force it to English?
Reclusive fart.
Collecting Military, Trains, Cooking, Woodworking, Fighting Illini, Auburn Tigers
FredThompson is offline   Reply With Quote
Old 13th March 2015, 23:09   #129  |  Link
hubblec4
In the first menu item "Sprache" you can change the language.
Old 12th April 2015, 18:09   #130  |  Link
hubblec4
A new rev0.34 is available.
added &
fixed *
improvement #
layout change %
rev0.34
// chapterEditor
# mmg file adjusted for MKVToolNix 7.8.0
  - reduce_to_core
// settings
& mkv: - settings for the Multi Editions and DVD2mkv Editor
  - target folder as the file name
  - automatically open mmg
& subtitles load by drag-and-drop
# Drag and drop adapted for input and output now
// DVD2mkv
& load external subtitle
  - VobSub idx/sub and SubRip Text srt files
  - subtitles load by drag-and-drop
* "XML to Editor" did not always work correctly
% insert "subtitle load" button
Old 14th April 2015, 02:27   #131  |  Link
khukhooo
English version Please
khukhooo is offline   Reply With Quote
Old 14th April 2015, 11:13   #132  |  Link
hubblec4
Old 12th May 2015, 16:45   #133  |  Link
hubblec4
a new small update to rev0.35 is avalible.
added &
fixed *
improvement #
layout change %
rev0.35
// chapterEditor
& The window position is now also stored and loaded at startup
// settings
& mkv -> Multi Editions Editor
  - playtime(in second) for the first and last m2ts adjustable
// XML Format
# The help improved somewhat
& Support for "embedded" AC3 in TrueHD audio tracks
  - mmg adjusted
& ignore first m2ts file
  - a workaround for mpls files that play first a m2ts which
    has other track parameters. (mmg breaks the mux-operation with an
    error message)
  - the chapters are automatically adjusted
* Drag & Drop for "source" did not work at BD-structures that are on
  the hard disk
Old 18th June 2015, 12:05   #134  |  Link
hubblec4
rev0.36 - Matroska Tags
A new version rev0.36 is avalible.
An important update for the Multi Editions Editor (BD2mkv). Since Mosu support in mmg DTS Express I had installed this also, otherwise mmg mux process does not work correctly.
A new editor also there.
Matroska Tags:
I have set up this editor to the Matroska specs.
However, since a number of settings can be selected freely, I have also tried to give these freedoms.
If anyone needed further adjustments as they could be reprogrammed quickly.
added &
fixed *
improvement #
layout change %
rev0.36
// chapterEditor
& Matroska Tags
% menu item "Matroska Tags" insert
// Matroska Tags
& Drag&Drop
  - Tags.xml
  - Matroska files (mka,mkv,mk3d)
& save the Tags directly in Matroska files (mka,mkv,mk3d)
& support for DTS Express
* BDSup2Sub.jar changed the FPS of forced subtitle during extracting
Old 4th July 2015, 12:32   #135  |  Link
hubblec4
This time there's a little bigger update rev0.37
The XML format editor had a couple of small mistakes, so then also still a lot of improvement.
added &
fixed *
improvement #
layout change %
rev0.37
// multi chapters
& for chapter in XML format, the default settings "automatic chapter name" can be used
// Matroska Tags
& change language for all the following and selected Simple Tag
& supports Tags contain no Targets Node (Haali's TRACKSETEX)
% a button inserted, with which one directly enters settings for the Matroska Tags
// settings
& Matroska Tags
& XML:
  - Tags Editor choice
    - Matroska Tags
    - simple Editor
  - automatic chapter name
    - numbered or indexed
    - without level (nested chapter); only the simple chapter number is used
    - name first / as last (chapter 1 or 1. chapter)
    - Language and Country
// XML Format
* internal drag&drop: creates wrong chapter number when you move (left mouse button)
   a chapter (except nested chapters) on their own edition
# when adding a new edition a first chapter is automatically inserted
# create a new chapter file now always adds a 1st edition and a 1st chapter
# add chapter name
  - automatic chapter name can be used
# Chapter naming
  - without level(nested chapters)
  - indexed did not work correctly for nested chapters
  - adjusted hidden / disabled chapter of the display pattern for LAV Splitter
# UID check now allows the full 64bit size (18446744073709551615)
# UID generation:
  - full 64bit size
  - happen to be a 19- or 20-digit UID
# the Help extends
// OGG, 3GPP TTXT, multiAVCHD - Format
# create a new chapter file now always inserts a 1st chapter
Old 20th August 2015, 10:56   #136  |  Link
von Suppé
von Suppé's Avatar
Hi hubblec4
Edit: question removed, wrong thread. Mayor case of brain damage from my side...
Old 20th August 2015, 12:40   #137  |  Link
hubblec4
Originally Posted by von Suppé View Post
Hi hubblec4
Is there a possibility to color the break-line tag <br/> and italic tags <i> and </i> in the list view?
Cheers
von Suppé
Soory, i don't understand.
You mean the AVCHD-editor?
Where exactly?
Old 22nd August 2015, 14:24   #138  |  Link
von Suppé
von Suppé's Avatar
Sorry hubblec4
post edited, my bad
cheers
Old 17th September 2015, 22:59   #139  |  Link
hubblec4
It's a little while ago, but I'm still trying, when time is to work on the chapterEditor (rev0.38).
Mosu has, his new great GUI brought has been a while among the people, therefore an update for the Multi Editions Editor.
(for the time DVD2mkv has unfortunately not enough.)
added &
fixed *
improvement #
layout change %
rev0.38
// settings
& mkv:
  - mmg create (mmg is deprecated and will no longer creates normal)
  - chapter and tag files:
    - new or overwrite
    - use files in mtxcfg/mkv
& mtxcfg file: instead of the old mmg will be the new mtxcfg file created
  - Audio conversion is monitored and analyzed at the end with mkvmerge
  - create mtxcfg file only works if all the audio conversions were quit
  - for the separate mux is a CMD file created instead of mtxcfg
& check whether chapters and tags xml files exist
  - if so, predefined options can be used in settings
& Track name edit box HotKeys
  - Arrow keys (up, down) to select the tracks in the ListView
  - "ENTER" - opens the personal favorites
& but do not use converted audio files
  - if one had converted a wrong track, had to reverse to some
    and start from scratch
* "mmg / mtxcfg automatically open" has not been properly deactivated (mmg / mtxcfg launched always)
# mmg file for MKVToolnix 8.3.0 adapted - last adjustment!
# The help extended and adapted
Old 22nd September 2015, 21:04   #140  |  Link
hubblec4
A small update.
Adapting mtxcfg file to the new MKVToolnix 8.4.0 version.
added &
fixed *
improvement #
layout change %
rev0.39
& HotKeys for the ListView(available titles)
  - arrow keys (up, down) to select the title in the ListView
  - "ENTER" adds the title to the "title used" added
& Start button: ENTER key is as "standard" defined
  - is the Start button enabled, can be started from anywhere with the ENTER key
* mtxcfg: more than one converted audio track and / or an external subtitle
  generated a corrupt file
# mtxcfg: adapted to MKVToolnix 8.4.0
bluray backup, chapter editor, dvd2mkv, matroska menu, metadata, multi-edition-mkv, xml tag
