7th October 2009, 20:57 | #5501 | Link | |
All bluray burners are much of a muchness and all discs are much of a muchness. We haven't reached the point where companies are at rock bottom margins and most of the cheap discs are utter pants... |
7th October 2009, 21:12 | #5502 | Link | |
8th October 2009, 00:12 | #5503 | Link | |
Hej
Discovered two zip files in the root of the disc, these zip files contains files in a folder named sync: 083824576\sync\083824576-dts_5_1-eng.iid 083824576\sync\083824576-dts_5_1-eng.syn If you need more info, please let me know. //Jesper Quote:
8th October 2009, 04:22 | #5504 | Link |
Hmm BD Rebuilder produced over 4.9GB of files even though I specified DVD-5, so ImgBurn refused to writes the files to disc. Is anyone else running into this problem? I'm re-running the whole thing now with the custom size set to 4.2GB. v0.30.02
8th October 2009, 04:32 | #5505 | Link |
@marius1
Hi! I'm guessing you have a BluRay disc with multiple "heavy duty" audiostreams - and have not deleted enough of them to leave sufficient room for the video, making burning to DVD-5 infeasible... Last edited by setarip_old; 8th October 2009 at 04:41. |
8th October 2009, 16:48 | #5507 | Link | |
Reverting to ffdshow 2857 seems to have restored things back to normal. I have a conversion program that automatically updates ffdshow. I should have known this was the problem. I backed up the dark knight and the file structure now looks correct. thanks....cwh |
9th October 2009, 02:10 | #5509 | Link |
Former Kanenite
I got a new disc to rip and yet I still get the same result. I have done almost two dozen discs without problems, I have no idea why this one is causing problems. :/
Edit: I just noticed the first Pirates movie failed as well, although it failed at a different spot. Code:
========================== [15:02:08] BD Rebuilder v0.30.02 (beta) [15:02:08] BEGIN - BATCH SEQUENCE ========================== ----------------------- [15:02:08] PROCESSING BATCH FILE [1] ----------------------- [15:02:09] BD Rebuilder v0.30.02 (beta) - Source: PIRATES1 - Input BD size: 42.44 GB - Approximate total content: [03:29:56.241] - Target BD size: 22.46 GB - Windows Version: 6.1 [7600] - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=640 [15:02:09] PHASE ONE, Encoding - [15:02:09] Extracting A/V streams [VID_00002] - [15:02:09] Reencoding: VID_00002 (1 of 10) - [15:02:09] Collecting video information - Video: 1920x1080, 23.976fps, 24 frames - [15:02:09] Reencoding: VID_00002, Pass 1 of 1 - Encode failed. Retrying. - Encode failed. Retrying. - Reached retry limit. Aborting. [15:05:11] - Failed video encode, aborted Last edited by DGenerateKane; 9th October 2009 at 02:12. |
9th October 2009, 02:28 | #5510 | Link | |
EDIT: I see you already tried that... oops! Just keep lowering it until you get to a number that either works or chokes immediately. |
9th October 2009, 04:29 | #5511 | Link | |
I bought the disc used from the local video store so it shouldn't be a Region B disc, but my experience with ripping it seems to suggest it is. Region A discs don't seem to have the issue of being split into so many parts. Very strange! Regardless, I read the post above which lead me to try a few things. I tried it with MakeMKV on the image I had already ripped via AnyDVD, but I couldn't get TsMuxer to recognise any of the subtitles afterwards. Instead I just used TsMuxer to open the 0081 playlist and unselected the unnecessary video, audio, and subtitles. This generated a Blu Ray folder structure that seemed to play fine with TotalMedia Theatre and it included the subtitles. I'm now feeding this into BD Rebuilder as I write this to see what comes out the other end. I realise that use of a modified source is unsupported though. So is it TsMuxer that generates the really long filename shown in my previous post when going at it directly with BD-Rebuilder? I don't really know enough about this stuff just yet to know if I should be puzzled why it worked through the TsMuxer GUI?! |
9th October 2009, 05:53 | #5512 | Link | |
Good luck on the venture and I look forward to seeing resize work with subs on virtually everything. |
9th October 2009, 08:04 | #5513 | Link |
I have to come back on the black area encoding problem, as it drives me crazy. The latest BD RB compresses fine now, but whenever I have large areas of black I get compression artifacts of the worst kind. For example compressing a fully black screen results in an encoded mid grey screen (sometimes with very lively artifacts) that only changes to black when enough other picture content comes into the game. I am sure that this is a problem with the avisynth re-encoding. Most likely any of the prameters used generate the problem? What can I do about this? (Right now I am trying some parameters in the ffdshow output settings, like turning off the automatic BT601/709 setting and swithing it to ITU-R BT709 and setting the output level to TV/projector instead of computer monitor). By the way - is there any GUI type interface that I could use only for the video resizing with Avisynth (like FitCD) that can generate the required Avisynth script? Last edited by astraub; 9th October 2009 at 08:29. |
9th October 2009, 13:54 | #5515 | Link | |
9th October 2009, 15:23 | #5516 | Link | |
[Options] MODE=1 QUICK_EXTRAS=0 PRIORITY_CLASS=1 RESIZE=0 ENCODE_QUALITY=0 AUDIO_TO_KEEP=eng; SUBS_TO_KEEP=eng; TRELLIS=0 COLOR_BOOST=0 RESIZE_1080=0 DTS_REENCODE=1 AC3_REENCODE=0 AC3_640=0 KEEP_HD_AUDIO=0 AVCHD=1 AUDIO_TRACK_LIMIT=1 SUBTITLE_TRACK_LIMIT=1 CUSTOM_TARGET_SIZE=23450 [Paths] SOURCE_PATH=D:\BD\THE_READER\ WORKING_PATH=C:\FAB\REBUILDER\ Keep in mind that this is the first time i've run into this problem. I've rebuilt about a dozen blu-ray discs with success so far. |
9th October 2009, 18:50 | #5518 | Link | |
x264 developer
9th October 2009, 20:22 | #5519 | Link |
BD_Rebuilder 0.30.02_beta "expired"
Hi!
I unzipped BD_Rebuilder 0.30.02_beta to a folder on my PC and ran it. But it only showed "Beta version expired. Please upgrade to newer version." Could somebody please tell me what I could do about this? Cheers Last edited by elrond81; 9th October 2009 at 20:25. |
