15th April 2010, 00:49 | #7701 | Link |
hey folks,
sorry if that topic is already old (I guess it is) but instead of reading all 380+ pages of that topic I dare to ask right away . i've got the problem that the sound doesn't seem to be synchron to the picture; while watching the movie the picture / sound freezes for some seconds every 1-2 minutes. is that a common problem? and much more important, is there a solution? regards |
15th April 2010, 01:34 | #7702 | Link |
Snow White & The Seven Dwarfs Disc 2
Ok im confused. I was trying to do the second disc of Snow White and got the following:
[Earlier Status Text Truncated] ... - [08:18:34] Reencoding: VID_00115, Pass 1 of 1 - [08:18:48] Video Encode complete - [08:18:48] Reencoding audio tracks (if req'd) - [08:18:48] Multiplexing M2TS - [08:18:49] Extracting A/V streams [VID_00276] - [08:18:51] Reencoding: VID_00276 (189 of 256) - [08:18:51] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 803 frames - Bitrate: 6,804 Kbs - [08:18:51] Reencoding: VID_00276, Pass 1 of 1 - [08:19:44] Video Encode complete - [08:19:44] Reencoding audio tracks (if req'd) - [08:19:44] Multiplexing M2TS - [08:19:45] Extracting A/V streams [VID_00279] - [08:19:46] Reencoding: VID_00279 (190 of 256) - [08:19:46] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 1,152 frames - Bitrate: 4,597 Kbs - [08:19:47] Reencoding: VID_00279, Pass 1 of 1 - [08:20:45] Video Encode complete - [08:20:45] Reencoding audio tracks (if req'd) - [08:20:45] Multiplexing M2TS - [08:20:46] Extracting A/V streams [VID_00100] - [08:20:47] Reencoding: VID_00100 (191 of 256) - [08:20:47] Collecting video information - Source Video: MPEG-2, 720x480 - Rate/Length: 29.970fps, 2,969 frames - [08:20:47] Reencoding: VID_00100, Pass 1 of 1 - Encode failed. Retrying. - Encode failed. Retrying. - Reached retry limit. Aborting. - BD-Rebuilder v0.33.04 (beta) - Windows Version: 6.1 [7600] - AVISYNTH Version: 2.5.7.0, Ok - HAALI Splitter: Ok - FFDSHOW: 3326, Ok - WIN7 preferred AVC CODEC: Ok - WIN7 preferred VC-1 CODEC: Ok - WIN7 preferred MPEG2 CODEC: Ok - FFDSHOW VC-1 set to "wmv9", Ok - FFDSHOW MPEG2 set incorrectly: [0] - FFDSHOW AVC set to "libavcodec": Ok - X264: Ok - AFTEN: Ok - FAAC: Ok - MP4BOX: Ok - WAVI: Ok - TSMUXER: Ok [08:20:53] - Failed video encode, aborted What am I doing wrong now? And what is MPEG2 supposed to be set at? Thanks Jake |
15th April 2010, 02:36 | #7704 | Link |
Episodic Disc Problem
Everything works great on standard discs. When using a multi-episode disc it crashes after a few seconds. Message follows:
[21:31:48] BD Rebuilder v0.33.02 (beta) - Source: BSG_S1_D1 - Input BD size: 41.32 GB - Approximate total content: [04:42:53.231] - Target BD size: 22.66 GB - Windows Version: 6.1 [7600] - One Pass ABR Mode enabled - Audio Settings: AC3=1 DTS=1 HD=0 Kbs=640 [21:31:49] PHASE ONE, Encoding - [21:31:49] Extracting A/V streams [VID_00280] - [21:31:56] Reencoding: VID_00280 (1 of 18) - [21:31:56] Collecting video information - Source Video: VC-1, 1920x1080 - Rate/Length: 23.976fps, 1,128 frames - [21:31:56] Reencoding: VID_00280, Pass 1 of 1 - Encode failed. Retrying. - Encode failed. Retrying. - Reached retry limit. Aborting. - FFDSHOW Revision: (3342) [21:32:02] - Failed video encode, aborted Any ideas? Last edited by Fulgrim; 15th April 2010 at 03:39. Reason: Corrected Problem. Went to recommended versions. Works fine now. |
15th April 2010, 04:32 | #7706 | Link | |
15th April 2010, 12:41 | #7707 | Link |
Extract Audio Problem
Seems like this problem should be fixed now reading earlier posts...
Trying Terminator Salvation and the process breaks down in Phase 1 with break error "ExtractAudioSubs()" - [02:39:54] BD Rebuilder v0.33.04 (beta) - Source: TERMINATOR_SALVATION - Input BD size: 24.86 GB - Approximate total content: [01:54:46.712] - Target BD size: 7.72 GB - Windows Version: 6.0 [6000] - MOVIE-ONLY mode enabled - One Pass ABR Mode enabled - Audio Settings: AC3=1 DTS=1 HD=1 Kbs=640 [02:39:57] PHASE ONE, Encoding - [02:39:57] Extracting A/V streams [VID_00100] - Extracting A/V to M2TS [VID_00100] - [02:52:58] ExtractAudioSubs() 00053 1605 - Error in attempt to extract audio/subs. - Muxing time: 13 min 0 sec [12:40:27] - Failed to retrieve audio, aborted |
15th April 2010, 14:17 | #7708 | Link |
I had the same problem with Terminator Salvation many versions back and gave up on it until DVDfab started to convert Bluray's and then I used it and it had no problem. So far this was the only movie to give me this problem. Also on a side note since version 33.04 and using Automatic Quality Settings all that have been done in 1 pass work and look as good as two pass but cut about 3 to 4 hours off a coversion. So now a 1 pass on a 1.5 to 2 hour conversion to DVD-DL takes about 2 hours and what a savings in time.
15th April 2010, 17:11 | #7710 | Link | |
Because 33.02 included those MPLS files from the extras as part of the movie only recode. I did it the old-school way by using tssplitter and then using the one MPLS file to do the movie only rebuild. It worked. |
15th April 2010, 17:22 | #7711 | Link | |
16th April 2010, 03:40 | #7712 | Link |
Hello,
I have converted over 5 bluray's with your softwares with theses settings: - avisynth 2.5.8 - ffdshow clsid rev3342 - BD Rebuilder 33.02 I try to convert an new movie; it crashed on first file encode. I download new version 33.04; samething. I've read the log, Inspector found "Avisynth not good version" and ffdshow "not good version" I download ffdshow clsid 3326 and install it. Same for avisynth 2.5.7. Because previously i was using for ripbot264. I reboot, reset vc1 to wm9 and samething. Here the log: Code:
----------------------- [22:24:32] BD Rebuilder v0.33.04 (beta) - Source: ***MASKED*** - Input BD size: 36,52 GB - Approximate total content: [03:19:12.023] - Target BD size: 22,66 GB - Windows Version: 6.1 [7600] - One Pass ABR Mode enabled - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=640 [22:24:32] PHASE ONE, Encoding - [22:24:32] Extracting A/V streams [VID_00074] - [22:24:34] Reencoding: VID_00074 (1 of 20) - [22:24:34] Collecting video information - Source Video: VC-1, 1920x1080 - Rate/Length: 23,976fps, 577 frames - [22:24:34] Reencoding: VID_00074, Pass 1 of 1 - Encode failed. Retrying. - Encode failed. Retrying. - Reached retry limit. Aborting. - BD-Rebuilder v0.33.04 (beta) - Windows Version: 6.1 [7600] - AVISYNTH Version: 2.5.8.0, not recommended version - HAALI Splitter: Ok - FFDSHOW: 3342, not recommended version - WIN7 preferred AVC CODEC: Ok - WIN7 preferred VC-1 CODEC: Ok - WIN7 preferred MPEG2 CODEC: Ok - FFDSHOW VC-1 set to "wmv9", Ok - FFDSHOW MPEG2 set to "libavcodec": Ok - FFDSHOW AVC set to "ffmpeg-mt": Ok - X264: Ok - AFTEN: Ok - FAAC: Ok - MP4BOX: Ok - WAVI: Ok - TSMUXER: Ok [22:27:38] - Failed video encode, aborted ----------------------- [22:31:49] BD Rebuilder v0.33.04 (beta) - Source: ***MASKED*** - Input BD size: 36,52 GB - Approximate total content: [03:19:12.023] - Target BD size: 22,66 GB - Windows Version: 6.1 [7600] - One Pass ABR Mode enabled - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=640 [22:31:56] PHASE ONE, Encoding - [22:31:56] Extracting A/V streams [VID_00074] - [22:31:57] Reencoding: VID_00074 (1 of 20) - [22:31:57] Collecting video information - Source Video: VC-1, 1920x1080 - Rate/Length: 23,976fps, 577 frames - [22:31:57] Reencoding: VID_00074, Pass 1 of 1 - [22:32:11] Video Encode complete - [22:32:11] Reencoding audio tracks (if req'd) - [22:32:11] Multiplexing M2TS - [22:32:12] Extracting A/V streams [VID_00077] - [22:32:14] Reencoding: VID_00077 (2 of 20) - [22:32:14] Collecting video information - Source Video: VC-1, 1920x1080 - Rate/Length: 23,976fps, 2*257 frames - [22:32:15] Reencoding: VID_00077, Pass 1 of 1 - Encode failed. Retrying. - Encode failed. Retrying. - Reached retry limit. Aborting. - BD-Rebuilder v0.33.04 (beta) - Windows Version: 6.1 [7600] - AVISYNTH Version: 2.5.7.0, Ok - HAALI Splitter: Ok - FFDSHOW: 3326, Ok - WIN7 preferred AVC CODEC: Ok - WIN7 preferred VC-1 CODEC: Ok - WIN7 preferred MPEG2 CODEC: Ok - FFDSHOW VC-1 set to "wmv9", Ok - FFDSHOW MPEG2 set to "libavcodec": Ok - FFDSHOW AVC set to "ffmpeg-mt": Ok - X264: Ok - AFTEN: Ok - FAAC: Ok - MP4BOX: Ok - WAVI: Ok - TSMUXER: Ok [22:36:39] - Failed video encode, aborted Code:
[Status] LABEL=***MASKED*** VERSION=v0.33.04 (beta) SOURCE_SIZE=39215686561 SOURCE_VIDEO_SIZE=38768240640 TARGET_SIZE=24326963200 REDUCTION=.615955660736427 RESIZE_1080=0 AUDIO_TO_KEEP=all SUBS_TO_KEEP=all BACKUP_MODE=0 MOVIEONLY_TYPE=0 QUICK=1 ENCODE_STEP=1 COMPLETED=1 [00074] AUDIO=1111 PGS=111111 M2TS_TARGET=16942900 NSIZE=23795712 FLINK=0 MLINK=0 [00077] AUDIO=1111 PGS=111111 M2TS_TARGET=64032582 Note: it was decrypt and copy over my hard drive and worked from my hdd, not from the bd movie. EDIT: the last video file AVS file source code Code:
#Created by BD Rebuilder - v0.33.04 (beta) DirectshowSource("E:\BDR\THE_BLIND_SIDE\FULLDISC\THE_BLIND_SIDE\BDMV\STREAM\00077.m2ts", fps=23.976, framecount=2257, audio=false) ConvertToYV12().AssumeFPS(24000,1001)
PC; 7.5 on 7.9 (Windows Experience Rating) on the lower rating. Last edited by 8ternity; 16th April 2010 at 03:54. |
16th April 2010, 04:22 | #7713 | Link |
@8ternity;
You could try to put "MIN_M2TS_SIZE=500" ( or just larger than the .m2ts file BD-RB doesn't like ) under options in the BD-RB ini, and it should leave it alone and move on to the next file. Try it, then load BD-RB again and see if that vid# is listed in the to reencode list. |
16th April 2010, 06:38 | #7714 | Link | |
anyhow i just uninstalled cccp (codec pack) and reinstalled it and everything works normally again, and bd-rebuilder still works so everythings ok anyhow ^^ |
16th April 2010, 07:08 | #7715 | Link |
I am stll getting slight motion blur on my backups, enough to tell the difference between the original, even though I'm backing up to a Bd25. It is more noticable in concerts where there is a camera pan or maybe the drummer is drumming. You get blurring during the pan or blurring of the drumsticks moving which weren't present in the original. I know I shouldn't expect it to be perfect as I am still reencoding, but most people on here say they can't tell the difference between their backup and the original.
I've tried doing movie only encodes with the same result. During slow moving scenes the picture is indistinguishable, just during motion. Are there any tweaks or setting for BDRB or for x264? Although the backup is great and certainly watchable, I find myself getting annoyed as I am always noticing it now as I'm always looking for it. Hope someone can help me out |
16th April 2010, 13:13 | #7718 | Link | |
DEINTERLACE=0 You can also use field delinteracing without blending rather than the default by setting DEINTERLACE=2. As for the 23.976 source... check and see if the original used pulldown. If BD-RB shows a "*" in the stream listing, that is an indicator that the source was actually 29.97 as a result of pulldown. I can think of no reason why you'd ever get motion blur on a 23.97 progressive source -- I've never seen it. Last edited by jdobbs; 16th April 2010 at 13:17. |
16th April 2010, 13:49 | #7719 | Link |
audio out of sync
Hey jdobbs,
I have made a BD25 Region A full backup of Monsters Vs Aliens. The audio on the PIP Secondary video is terribly out of sync. Is there anyway to fix this? Otherwise the rest of the disc plays perfectly. I ran Inspect.exe and I have all the right versions of the encoding software and I am using BD Rebuilder .33.04. Is this a bug in the program? Any help is greatly appreciated. Thanks! Moviewatcher666 |
