24th February 2014, 14:46 | #321 | Link |
Broadband Junkie
I looked back and figured out what I was thinking of:
XySubFilter fixed this for DVB subtitles and only when there was a single line, not PGS/HDMV. madVR optimized performance for this by "only uploading every bitmap ID once" to the GPU instead of "uploading every subtitle frame". @madshi for reference, we discussed exactly this problem with PGS by email around 6/24/2013 |
25th February 2014, 20:22 | #322 | Link | |
I haven't read through this entire thread, but I have used search, which came up with nothing, so excuse me if this has been asked before.
My hobby website |
25th February 2014, 20:56 | #323 | Link |
Broadband Junkie
We only support AYUV (packed 4:4:4 YUV) at this time, not YV24 (planar 4:4:4 YUV), and VSFilter in general only supports the Avisynth 2.5 plugin interface, not 2.6.
Supporting DirectShow YV24 input/output is something on our to-do list for a future release, but I don't see there being any Avisynth 2.6 support (which added support for additional color formats like YV24) for TextSub unless MPC-HC/MPC-BE add such support themselves, or someone provides us a patch. Same goes for something like VapourSynth support, patches welcome. Last edited by cyberbeing; 25th February 2014 at 21:07. |
5th March 2014, 19:49 | #324 | Link |
Broadband Junkie
XySubFilter Beta2 has been released
GoogleCode no longer allows adding downloads, so all future releases will be made on GitHub XySubFilter Beta2 .zip Archive (32-bit) | XySubFilter Beta2 .zip Archive (64-bit) Debug Symbols for XySubFilter 3.1.0.682 Note: XySubFilter requires a compatible subtitle consumer. We recommend madVR 0.87.5+. MPC-HC 1.7.2+ 64-bit (EVR-CP) or other 64-bit Subtitle Consumer is required to use the 64-bit build. Features & Changes
Bug Fix
Complete Changelog __________ Primarily a bug-fix release, to sync with the bug-fixes and changes made in madVR 0.87.5. Installer will be added at a later date. madVR no longer loads XySubFilter itself. You must ensure to run the 'Install' bat (not only replace) or else XySubFilter's autoload helper required for entering the DirectShow graph with external subtitles will not be installed. Last edited by cyberbeing; 30th April 2014 at 19:17. |
5th March 2014, 20:01 | #326 | Link |
Broadband Junkie
xy_sub_filter_rc3 branch
GitHub requires tagging to make releases, so the exact 3.1.0.682 tree can be found here, or from links on the GitHub release page. Most of the interesting (unstable) stuff we've been working recently has been backed out and delayed till a Beta3 release. |
5th March 2014, 21:19 | #329 | Link |
The position override isn't working properly in the XYSubFilter beta 2 build for me.
Is there a way to get the subtitles rendered with respect to the window size and its aspect rather than the video's size/aspect? This might also solve the bitmap subtitles from bluray discs from getting truncated when the position is overided beyond the border of the video's resolution. Last edited by dansrfe; 5th March 2014 at 21:30. |
5th March 2014, 21:34 | #331 | Link | |
Also, I'm curious, why was positioning removed for text subtitles? Also, when I drag another file into MPC-HC (nightly) using madVR (latest), the player crashes. When XYSubFilter is not loaded, the player doesn't crash. Last edited by dansrfe; 5th March 2014 at 21:40. |
5th March 2014, 21:45 | #332 | Link | ||||
Broadband Junkie
When you say 'drag another file' did you mean something else? Last edited by cyberbeing; 5th March 2014 at 21:59. |
6th March 2014, 05:11 | #334 | Link |
Broadband Junkie
No idea. Can anyone else reproduce this? If you have a crash dump, please upload it somewhere. If madVR is generating crash reports, download the PDB debug symbols for MPC-HC and XySubFilter and upload the next crash report.
Do you have any external subtitles in the directories you drag and drop files from? If so, which formats? Is there anything special about your playback setup? Installed Video Decoders & Splitters? Any post-processing filters or MPC-HC shaders active? Any subtitle filters other than XySubFilter.dll installed or active? VSFilter.dll? FFDShow? MPC-HC ISR? Any filters you've added to MPC-HC External Filters? Does it occur with both madVR and EVR-CP using XySubFilter in MPC-HC? Does it occur with madVR using XySubFilter in MPC-BE? Which OS? |
6th March 2014, 11:32 | #335 | Link |
After updating xySubFilter to latest 3.1.0.682 Beta2 and madVR to 0.87.5 subtitles no longer loads in Zoom Player 8.6.1 (Smart Play enabled). MadVR 0.87.4 and 3.1.0.682 works fine. Is any way to force loading subtitle filter without rolling back to 0.87.4?
VSFilter and ffdshow not installed, only registered new XySubFilter.dll. Using latest LavFilters for decoding and splitting. I think it happens because latest change in madVR: * removed XySubFilter auto-loading functionality, it's now XySubFilter's job
Windows 10 Pro 64bit, Core i5-2500K@4GHz, Asus P8Z77-V Pro, Kingston HyperX XMP 16Gb RAM (4x4 kit), MSI GeForce GTX 1060 Gaming X 6G, Iiyama ProLite X2483HSU and LCD TV LG LW4500 |
6th March 2014, 13:48 | #338 | Link |
Broadband Junkie
Blight only needs to support XySubFilter with SmartPlay, the way he currently supports xy-VSFilter. They share the same API, so that part should be simple enough. The only time consuming part is likely rewriting the GUI, settings dialog, and subtitle filter loading logic, since XySubFilter could only be used with madVR. ZoomPlayer's SmartPlay is already fully manual graph building which manages detection/loading of external subtitles into xy-VSFilter itself. In that regard, the only other change is XySubFilter supports external Blu-ray PGS files (.sup). He likely just hasn't gotten around to adding XySubFilter SmartPlay support yet, probably since we haven't released a stable version. Not to mention that he usually likes to distribute all filters himself through the ZoomPlayer Download Center.
6th March 2014, 23:39 | #339 | Link |
Otaku
@cyberbeing
I'm having some issues with the new build (XySubFilter 3.1.0.682). Basicaly MPC-HC (v1.7.3) crashes after opening a video using either EVR CP or madvr (v0.87.6). Such issues don't occur with the previous release (XySubFilter v3.1.0.546). Not all videos generate this issue but also happens if reopening some videos during playback. I've downloaded the pdb files for mpc and xy-subfilter, set them in place and triggered the issue to generate dump files. Dumps are here (for both evr cp and madvr) Video that triggers the crash here. System specs here. If you require additional information or more testing let me know! Thanks! Kado
In the school, the three guys met. Their relation had been changed in the season, and turned into three love stories.
