9th September 2015, 21:33 | #32841 | Link | |||
Yey me! I made NVidia listen, I think...
Here's my "Bug Report": Quote:
9th September 2015, 21:44 | #32842 | Link | |
i'm pretty sure this will change again when the UBD is out. and if you see a stream that's not correctly flag bring it up to the maker of the stream |
10th September 2015, 08:48 | #32843 | Link |
I've updated to a new Windows 10 Beta driver and it didn't make a difference. Still getting inordinately long wait times when any type of image doubling is used. It actually skips 500-700 frames before I actually get an image on screen including using NNEDI3. With NNEDI3 I am still getting an embossed effect with the image. Also, I didn't notice until someone posted about it but, madVR isn't using FSE mode in FS only FS windowed. I tried switching to from using D3D11 to using D3D9 and that didn't make a difference either.
I also tried using a very, very old build of MPC-HC (actually JanWillem32's) and I am getting the exact same behavior as with the latest stable main branch build of MPC-HC. Also thank you for not leaving Windows 10 users till later and addressing our issues now.
Intel i5 3470, EVGA GTX 1050Ti SC ACX 2.0, Windows 10 Pro 64 bit, 16 GB 1600 mhz DDR3 RAM |
10th September 2015, 12:34 | #32844 | Link |
madshi, I have been doing several tests and finally I was able to identify what was causing the crashes with JRiver MC 20. It was NNEDI. The instant I choose it as Luma Doubling, then stop the movie, then click play and it crashes instantly. Also I find another problem, DX11 windowed mode is very slow (at the point i can't even use Super-XBR) in comparison with DX9 windowed, there is no such difference in FSE.
OS: Windows 7 x64 My hardware is: CPU: Intel i5 3570k @ 4.5 GHz RAM: 16 GB DDR3 @ 1600 MHz GPU: Sapphire HD 7870 OC @ 1100/1375 MHz If you need more info, or want me to test more things just tell me. Thanks |
10th September 2015, 14:22 | #32845 | Link |
@ madshi
I updated madvr from 0.88.21 to 0.89.2 today. Now madvr crashes everytime I start a movie. Send you the crashlog via madvr. when I reset to defaults, movie starts but I got a big red "out of memory" message on screen. When I set up my prefered options in madvr it crashes again. reverting back to 0.88.21 does not cure the problem even if I reset to default settings... Edit: problem solved. Wrong bios setting (PCI-E Lanes "16/0" instead of "Auto"; changed it to Auto solved the problem) Now everything works great with 0.89.2
Intel i5 6600, 16 GB DDR4, AMD Vega RX56 8 GB, Windows 10 x64, Kodi DS Player 17.6, MadVR (x64), LAV Filters (x64), XySubfilter .746 (x64) LG 4K OLED (65C8D), Denon X-4200 AVR, Dali Zensor 5.1 Set Last edited by Sunset1982; 11th September 2015 at 13:21. |
10th September 2015, 14:40 | #32848 | Link |
someone has a link to the registry hack or the thread page to force madvr to use nvidia gpu instead of onboard gpu?
10th September 2015, 20:05 | #32851 | Link |
cosmic entity
i have a strange problem with the new MADVR version...
ussually i double klick the media player, (mpchc) to go into fullscreen. anyway, sometimes, mostly, when i go into fullscreen i only see 1/4 of teh picture. its like zooomes way in, and i cant seem to change it at all.. i have to restart the player like 8 times, till it goes correctly into fullscreen.. dunno what is doing this, but 0.88.21 works as it should... if you need more infos i would be glad to post em.. greetz |
10th September 2015, 20:32 | #32852 | Link |
Not a big deal, but I noticed that the screenshot function in JRiver MC seems to grab the full frame rather than the crop.
As I understand it, the screenshot function is supposed to grab an unscaled image, so this is probably intentional, but I think I've only ever used the feature to grab thumbnails for videos so it would actually be preferable to grab a cropped & scaled image. (e.g. aspect ratio correction for anamorphic videos) |
11th September 2015, 03:56 | #32855 | Link | |
What makes you believe madVR is no longer doing chroma upscaling?
madVR options explained |
11th September 2015, 04:54 | #32856 | Link |
madshi,
Thanks for your continued development of madVR. I'm having trouble with a couple of videos using the new detect black bars function. Using MPC-HC, keep aspect ratio is disabled and stretch to window enabled (video frame options). This Pillarboxed Blu-ray Disc doesn't want to scale to the screen resolution (1920*1080). https://www.dropbox.com/s/e4qayrnseh...test1.zip?dl=0 I'm not sure if you can improve things with this DVD, fast scene / AR changes, detection is a bit slow. The subtitles also get cut off. https://www.dropbox.com/s/5z81qo74ht...test2.zip?dl=0 |
11th September 2015, 09:57 | #32860 | Link |
Hi everyone.
I wonder if someone could elaborate on why this happens: I use my laptop to play media on my FullHD tv through HDMI, with MPC-HC and MadVR. The laptop being 1366x768, I don't clone or extend desktops, I rather make the TV the only screen when HDMI is connected. Usually I do one of these two things: Start up the laptop with the HDMI already connected, having to log in to Windows through my tv, or having the laptop on, connect the HDMI cable so the desktop moves to the tv. Yesterday I watched smoothly several tv shows and today they played horrible, unwatchable, with heavy frame skipping. I didn't use the laptop for anything else, I didn't change anything... so I soon realized the what happened: Yesterday, I booted up the computer with the HDMI already connected, and today I hooked it up after the computer started up. So, I shut it down, started up again with HDMI already connected and it played all files as smoothly as yesterday. Is this a driver related thing? MadVR showed the same info on both scenearios, apart from the frame skipping. I could make some screenshots. Thank you. Last edited by panetesan2k6; 11th September 2015 at 09:58. Reason: Thanking |
