Old 17th September 2008, 00:15   #1101  |  Link
Ranguvar
Ranguvar's Avatar
ahhh....
Ranguvar is offline   Reply With Quote
Old 17th September 2008, 00:57   #1102  |  Link
Soichiro
Originally Posted by skystrife View Post
Excited about the b-adapt 2 speedboost!
Still would like some working multithreading up in there.
Soichiro is offline   Reply With Quote
Old 17th September 2008, 01:01   #1103  |  Link
Dark Shikari
x264 developer
Dark Shikari's Avatar
What's the problem? Works fine here...
Old 17th September 2008, 01:07   #1104  |  Link
kemuri-_9
Compiling Encoder
kemuri-_9's Avatar
maybe whining that it's not as fast as b-adapt 1?
custom x264 builds & patches | F@H | My Specs
kemuri-_9 is offline   Reply With Quote
Old 17th September 2008, 01:27   #1105  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
just use a sane number of b-frames.
Sharktooth is offline   Reply With Quote
Old 17th September 2008, 02:13   #1106  |  Link
Soichiro
Of course it's all my fault if it's being slow. Of course I'm just whining and being stupid. -_-;
I am using a sane number of b-frames. It's set to 6. And while it's better than before, it still doesn't use all of both cores with --b-adapt 2, which is something ideally I would like to see fixed. It's not too crippling on a dual core (though 70% CPU usage isn't something to be happy about either), but I imagine the new method would cause much more of a slowdown on a 4+ core system.
Old 17th September 2008, 02:15   #1107  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
6 is not sane... 3 (or 4 maybe) is...
and as Dark_Shikari said, even 2 with b-adapt 2 will look better then 16 with b-adapt 1.
Old 17th September 2008, 02:18   #1108  |  Link
Soichiro
Well my tests show that 6 is a good balance between speed and quality for animated material. Almost all my anime encodes have shown large (10%+) b-frame usage in up to 6-frame sequences, while beyond 6 frames is below 1%. I would call that "sane".
Old 17th September 2008, 02:21   #1109  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
not with b-adapt 2... using 6 b-frames will kill the encoding speed, so it's not a good balance.
use 3 b-frames with b-adapt 2. also for animes, maybe you better stick with b-adapt 1 and 6 or more b-frames.
Old 17th September 2008, 02:23   #1110  |  Link
Soichiro
Has b-adapt 2 shown bad results on anime? o.O
Old 17th September 2008, 02:27   #1111  |  Link
Dark Shikari
x264 developer
No, I haven't done much testing on anime.
The question is whether you lose more from the lower --bframes than you gain from b-adapt 2, and I highly doubt that is the case.
Old 17th September 2008, 02:27   #1112  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
no, but since anime encodings will be happy with more b-frames, b-adapt 1 is faster and probably will be not much different than b-adapt 2 with less b-frames.
Old 17th September 2008, 02:33   #1113  |  Link
Dark Shikari
x264 developer
We don't know this for sure Some testing will have to be done.
I have some anime clips that benefit tremendously from b-adapt 2. Though it might be because they're full of fades.
Old 17th September 2008, 02:33   #1114  |  Link
Soichiro
Ah, that makes sense, then. So I should keep using the old method until the new method is more optimized/properly multithreaded, then (unless I have extra time to kill ).
Thank you. ;D
Old 17th September 2008, 12:37   #1115  |  Link
Quark.Fusion
Quark.Fusion's Avatar
AFAIK --b-adapt 2 can't be multithreaded as it relies on it's previous result (correct me if I'm wrong). Get process explorer and see how much cpu b-adapt thread uses, if it's greatly lesser that 100%/(num of cores) — try thread-pool patch.
Quark.Fusion is offline   Reply With Quote
Old 17th September 2008, 13:05   #1116  |  Link
kemuri-_9
Compiling Encoder
kemuri-_9's Avatar
working on some b-adapt comparisons
http://forum.doom9.org/showthread.ph...14#post1184814
Old 17th September 2008, 14:04   #1117  |  Link
skystrife
skystrife's Avatar
x264.979.modified.exe - Alternate Download
Patches used:
x264_hrd_pulldown.09_interlace.diff
gcc 3.4.5 fprofiled build with -march=pentium2.
skystrife is offline   Reply With Quote
Old 17th September 2008, 14:07   #1118  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
tnx skystrife
Old 17th September 2008, 14:32   #1119  |  Link
gav1577
gav1577's Avatar
Patches used:
gav1577 is offline   Reply With Quote
Old 17th September 2008, 14:34   #1120  |  Link
fields_g
x264... Brilliant!
If the next 21 builds come as quickly as the last 21, we will be at r1000 in 2 weeks...... wow....
It's not the quantity changes, but the QUALITY of the changes that impress me though! Thanks Devs!!
fields_g is offline   Reply With Quote
h.264, x264, x264 builds, x264 patches, x264 unofficial builds
