Old 13th May 2008, 19:21   #4801  |  Link
hlkc
Originally Posted by Beastie Boy View Post
TrueHD is lossless audio, DD and DTS are both lossy. If you wish to retain TrueHD quality, either convert the audio to LPCM, WAV or FLAC with eac3to, or mux the original TrueHD stream to Bluray structure using tsMuxer.
I suggest you read up on both tools, decide what it is you need to acheive, and then come and ask for assistance using the tools if you still need it. I get the impression that you don't really know what you are trying to do at the moment
Cheers, Beastie.
Thanks for the reply Beastie,
My goal is I want to get these TrueHD format BD movies I back up from my HTPC to my pre-amp. I did not finish the threads since most of the posts are talking about how to do it. I just want to see is this the right tool for me before I convert the BD audio stream. So to sum up: This is a tool to convert TrueHD audio format to LPCM, WAV or FLAC and output to our receivers. Right?
If it is the case, I guess this is not for me since I want to get the TrueHD to my pre-amp using HDMI 1.3, right? Yes, I realize as of today there is nothing can output TrueHD to pre-amp from our HTPC yet. From best of my knowledge, in the future x-tension card from Auzentech or Intel G45 MB will be the hardewares we need in order to output the TrueHD format from our HTPC to receiver.
hlkc is offline   Reply With Quote
Old 13th May 2008, 19:52   #4802  |  Link
nautilus7
nautilus7's Avatar
What is your video format? Do you plan to use the BD's as they are or have you convert them to mkv?
HDMI 1.3 is useful if you need to transfer TrueHD, DTS-HD or LPCM (and decoded FLAC) audio. Otherwise you can use spdif for AC3 and DTS or analog for all the previous.
nautilus7 is offline   Reply With Quote
Old 13th May 2008, 20:16   #4803  |  Link
OHB
hi guys I'm quite new to this burning blu-ray thing and i seem to be having way to much problems with the audio. I've followed many of the tutorials and am stuck with the audio not being liked by a eac3to. I've started with evodemux and got the audio (ddp) and video (vc1) fine. video works fine ran it with vc1conv and ran muigenerator and works fine with scenarist. the audio on the other hand gives me a problem when i try to run it with eac3to says
"eac3to v2.45
command line: eac3to d:\temp\vc1\audio1.ddp d:\temp\vc1\audio.wavs -sonic
AC3, 2.0 channels, 1:49:00, 192kbit/s, 48khz, dialnorm: -27dB
Removing dialog normalization...
The Sonic (E-)AC3 Decoder applies DRC.
Decoding with DirectShow (Sonic Audio Decoder)...
DirectShow reports 5.1 channels, 16 bits, 48khz
Writing WAVs...
Creating file "d:\temp\vc1\audio.R.wav"...
Creating file "d:\temp\vc1\audio.L.wav"...
This track is not clean. Processing aborted.
Please clean the track with delaycut and then retry eac3to.
Aborted at file position 2424832.
so i use delaycut and i get this in my logfile
"[Input info]
Bitrate=1087
Actual rate=1087.000000
Sampling Frec=48000
TotalFrames=108247
Bytesperframe=1450.0000
Filesize=156959019
FrameDuration= 10.6716
Framespersecond= 93.7069
Duration=00:19:22.659
Channels mode=2/0: L+R
LFE=LFE: Not present
[Target info]
StartFrame=0
EndFrame=108246
NotFixedDelay= 0.0000
Duration=00:19:15.165
====== PROCESSING LOG ======================
Time 00:00:00.000; Frame#= 1. Crc error SILENCED: read = DDDD; calculated=6DB0
Time 00:00:00.010; Frame#= 2. Unsynchronized frame...REWINDED 682 bytes. Found new synch word
Time 00:00:00.021; Frame#= 3. Crc error SILENCED: read = DDDD; calculated=1BDF
Time 00:00:00.032; Frame#= 4. Unsynchronized frame...REWINDED 682 bytes. Found new synch word
Time 00:00:00.042; Frame#= 5. Crc error SILENCED: read = DDDD; calculated=5FB5
Time 00:00:00.053; Frame#= 6. Unsynchronized frame...REWINDED 682 bytes. Found new synch word
Time 00:00:00.064; Frame#= 7. Some basic parameters changed between Frame #1 and this frame
Time 00:00:00.064; Frame#= 7. Crc error SILENCED: read = 6108; calculated=BC0F
Time 00:00:00.074; Frame#= 8. Unsynchronized frame...REWINDED 2556 bytes. Found new synch word
Time 00:00:00.085; Frame#= 9. Some basic parameters changed between Frame #7 and this frame
Time 00:00:00.085; Frame#= 9. Crc error SILENCED: read = 5369; calculated=F18A
Time 00:00:00.096; Frame#= 10. Unsynchronized frame...REWINDED 2594 bytes. Found new synch word
Time 00:00:00.106; Frame#= 11. Some basic parameters changed between Frame #9 and this frame
Time 00:00:00.106; Frame#= 11. Crc error SILENCED: read = F33F; calculated=2029
Time 00:00:00.117; Frame#= 12. Unsynchronized frame...REWINDED 2368 bytes. Found new synch word
Time 00:00:00.128; Frame#= 13. Some basic parameters changed between Frame #11 and this frame
Time 00:00:00.128; Frame#= 13. Crc error SILENCED: read = 4967; calculated=4827
Time 00:00:00.138; Frame#= 14. Unsynchronized frame...REWINDED 1122 bytes. Found new synch word
Time 00:00:00.149; Frame#= 15. Some basic parameters changed between Frame #13 and this frame
Time 00:00:00.149; Frame#= 15. Crc error SILENCED: read = F9F3; calculated=0748
Time 00:00:00.160; Frame#= 16. Unsynchronized frame...REWINDED 848 bytes. Found new synch word
Time 00:00:00.170; Frame#= 17. Some basic parameters changed between Frame #15 and this frame
Time 00:00:00.170; Frame#= 17. Crc error SILENCED: read = 73ED; calculated=D95D
Time 00:00:00.181; Frame#= 18. Unsynchronized frame...REWINDED 1098 bytes. Found new synch word
Time 00:00:00.192; Frame#= 19. Some basic parameters changed between Frame #17 and this frame
Time 00:00:00.192; Frame#= 19. Crc error SILENCED: read = 956B; calculated=556A
Time 00:00:00.202; Frame#= 20. Unsynchronized frame...REWINDED 2818 bytes. Found new synch word
Time 00:00:00.213; Frame#= 21. Some basic parameters changed between Frame #19 and this frame
Time 00:00:00.213; Frame#= 21. Crc error SILENCED: read = BD43; calculated=1C7C
Time 00:00:00.224; Frame#= 22. Unsynchronized frame...REWINDED 340 bytes. Found new synch word
Time 00:00:00.234; Frame#= 23. Some basic parameters changed between Frame #21 and this frame
Time 00:00:00.234; Frame#= 23. Crc error SILENCED: read = 9136; calculated=5577
Time 00:00:00.245; Frame#= 24. Unsynchronized frame...REWINDED 638 bytes. Found new synch word
Time 00:00:00.256; Frame#= 25. Some basic parameters changed between Frame #23 and this frame
Time 00:00:00.256; Frame#= 25. Crc error SILENCED: read = 1709; calculated=8263
Time 00:00:00.266; Frame#= 26. Unsynchronized frame...REWINDED 2442 bytes. Found new synch word
Time 00:00:00.277; Frame#= 27. Some basic parameters changed between Frame #25 and this frame
Time 00:00:00.277; Frame#= 27. Crc error SILENCED: read = 6734; calculated=7FA9
Time 00:00:00.288; Frame#= 28. Unsynchronized frame...REWINDED 608 bytes. Found new synch word
Time 00:00:00.298; Frame#= 29. Some basic parameters changed between Frame #27 and this frame
Time 00:00:00.298; Frame#= 29. Crc error SILENCED: read = 000A; calculated=9DC4
Time 00:00:00.309; Frame#= 30. Unsynchronized frame...REWINDED 460 bytes. Found new synch word
Time 00:00:00.320; Frame#= 31. Some basic parameters changed between Frame #29 and this frame
Time 00:00:00.320; Frame#= 31. Crc error SILENCED: read = 9F3E; calculated=DBC1
Time 00:00:00.330; Frame#= 32. Unsynchronized frame...REWINDED 1606 bytes. Found new synch word
Time 00:00:00.341; Frame#= 33. Some basic parameters changed between Frame #31 and this frame
Time 00:00:00.341; Frame#= 33. Crc error SILENCED: read = C235; calculated=BDE2
Time 00:00:00.352; Frame#= 34. Unsynchronized frame...REWINDED 742 bytes. Found new synch word
Time 00:00:00.362; Frame#= 35. Some basic parameters changed between Frame #33 and this frame
Time 00:00:00.362; Frame#= 35. Crc error SILENCED: read = ACC2; calculated=A802
Time 00:00:00.373; Frame#= 36. Unsynchronized frame...REWINDED 3028 bytes. Found new synch word
Time 00:00:00.384; Frame#= 37. Some basic parameters changed between Frame #35 and this frame
Time 00:00:00.384; Frame#= 37. Crc error SILENCED: read = E02F; calculated=8C7F
Time 00:00:00.394; Frame#= 38. Unsynchronized frame...REWINDED 428 bytes. Found new synch word
Time 00:00:00.405; Frame#= 39. Some basic parameters changed between Frame #37 and this frame
Time 00:00:00.405; Frame#= 39. Crc error SILENCED: read = 7D0B; calculated=7D78
Time 00:00:00.416; Frame#= 40. Unsynchronized frame...SKIPPED 716 bytes. Found new synch word
Time 00:00:00.426; Frame#= 41. Some basic parameters changed between Frame #39 and this frame
Time 00:00:00.426; Frame#= 41. Crc error SILENCED: read = 9F3E; calculated=5FC6
Time 00:00:00.437; Frame#= 42. Unsynchronized frame...REWINDED 98 bytes. Found new synch word
Time 00:00:00.448; Frame#= 43. Some basic parameters changed between Frame #41 and this frame
Time 00:00:00.448; Frame#= 43. Crc error SILENCED: read = F9F3; calculated=4D21
Time 00:00:00.458; Frame#= 44. Unsynchronized frame...REWINDED 2426 bytes. Found new synch word
Time 00:00:00.469; Frame#= 45. Some basic parameters changed between Frame #43 and this frame
Time 00:00:00.469; Frame#= 45. Crc error SILENCED: read = 256D; calculated=0F85
Time 00:00:00.480; Frame#= 46. Unsynchronized frame...REWINDED 1738 bytes. Found new synch word
Time 00:00:00.490; Frame#= 47. Some basic parameters changed between Frame #45 and this frame
Time 00:00:00.490; Frame#= 47. Crc error SILENCED: read = C1B0; calculated=1DD6
Time 00:00:00.501; Frame#= 48. Unsynchronized frame...REWINDED 2842 bytes. Found new synch word
Time 00:00:00.512; Frame#= 49. Some basic parameters changed between Frame #47 and this frame
Time 00:00:00.512; Frame#= 49. Crc error SILENCED: read = 7CF9; calculated=5FB1
Time 00:00:00.522; Frame#= 50. Unsynchronized frame...SKIPPED 654 bytes. Found new synch word
Time 00:00:00.533; Frame#= 51. Some basic parameters changed between Frame #49 and this frame
Time 00:00:00.533; Frame#= 51. Crc error SILENCED: read = 51DB; calculated=D9A1
Time 00:00:00.544; Frame#= 52. Unsynchronized frame...SKIPPED 154 bytes. Found new synch word
Time 00:00:00.554; Frame#= 53. Some basic parameters changed between Frame #51 and this frame
Time 00:00:00.554; Frame#= 53. Crc error SILENCED: read = 9671; calculated=4954
Time 00:00:00.565; Frame#= 54. Unsynchronized frame...SKIPPED 102 bytes. Found new synch word
Time 00:00:00.576; Frame#= 55. Some basic parameters changed between Frame #53 and this frame
Time 00:00:00.576; Frame#= 55. Crc error SILENCED: read = F099; calculated=6DFE
Time 00:00:00.586; Frame#= 56. Unsynchronized frame...REWINDED 1178 bytes. Found new synch word
Time 00:00:00.597; Frame#= 57. Some basic parameters changed between Frame #55 and this frame
Time 00:00:00.597; Frame#= 57. Crc error SILENCED: read = 4FFB; calculated=1418
Time 00:00:00.608; Frame#= 58. Unsynchronized frame...SKIPPED 90 bytes. Found new synch word
Time 00:00:00.618; Frame#= 59. Some basic parameters changed between Frame #57 and this frame
Time 00:00:00.618; Frame#= 59. Crc error SILENCED: read = 7E92; calculated=759D
Time 00:00:00.629; Frame#= 60. Unsynchronized frame...REWINDED 2686 bytes. Found new synch word
Time 00:00:00.640; Frame#= 61. Some basic parameters changed between Frame #59 and this frame
Time 00:00:00.640; Frame#= 61. Crc error SILENCED: read = 986F; calculated=02B0
Time 00:00:00.650; Frame#= 62. Unsynchronized frame...REWINDED 1060 bytes. Found new synch word
Time 00:00:00.661; Frame#= 63. Some basic parameters changed between Frame #61 and this frame
Time 00:00:00.661; Frame#= 63. Crc error SILENCED: read = 007B; calculated=50A2
Time 00:00:00.672; Frame#= 64. Unsynchronized frame...REWINDED 1932 bytes. Found new synch word
Time 00:00:00.682; Frame#= 65. Some basic parameters changed between Frame #63 and this frame
Time 00:00:00.682; Frame#= 65. Crc error SILENCED: read = E069; calculated=53D2
Time 00:00:00.693; Frame#= 66. Unsynchronized frame...REWINDED 1268 bytes. Found new synch word
Time 00:00:00.704; Frame#= 67. Some basic parameters changed between Frame #65 and this frame
Time 00:00:00.704; Frame#= 67. Crc error SILENCED: read = E7CF; calculated=2E1C
Time 00:00:00.714; Frame#= 68. Unsynchronized frame...REWINDED 1618 bytes. Found new synch word
Time 00:00:00.725; Frame#= 69. Some basic parameters changed between Frame #67 and this frame
Time 00:00:00.725; Frame#= 69. Crc error SILENCED: read = C328; calculated=441F
Too Many Errors. Stop Logging.
Number of written frames = 202844
Number of Errors= 607898
then when i run it into eac3to again i get this
"eac3to v2.45
command line: eac3to d:\temp\vc1\audio1_fixed.ddp d:\temp\vc1\audio.wavs -sonic
The format of the source file could not be detected.
I have searched for days now for answers and I am stumped if anyone can help me out i would really appreciate it.
i also have my main audio file available from rapidshare
http://rapidshare.com/files/114658575/audio1.part1.rar
http://rapidshare.com/files/114652825/audio1.part2.rar
OHB is offline   Reply With Quote
Old 13th May 2008, 20:31   #4804  |  Link
Beastie Boy
Beastie Boy's Avatar
You have more chance of success if you use eac3to for the whole process. Load you m2ts or EVO files into eac3to and take it from there. See the first post for some example command lines, or check out the thread for eac3to_and_more_gui
Cheers, Beastie.
Beastie Boy is offline   Reply With Quote
Old 13th May 2008, 20:48   #4805  |  Link
madshi
@OHB, your audio file is AC3 and not E-AC3. You can trust in what eac3to tells you about it. But you named the file "*.ddp". Now ddp stands for Dolby Digital Plus which is another term for E-AC3. That means you've named the file incorrectly. That doesn't matter for eac3to cause eac3to (mostly) ignores the file extension of source files. However, delaycut depends on the file having the correct file extension. So take the original audio file (*not* the one delaycut produced!), rename it to something.ac3 and then run it through delaycut again.
P.S: Furthermore you shouldn't really use Sonic for AC3 and E-AC3 decoding. Sonic is a bad decoder to use for that format (see first post of this thread). Use Nero or libav instead. Or just leave the decision to eac3to instead of forcing a specific decoder.
Old 13th May 2008, 21:02   #4806  |  Link
wildchild22
Is there a way you can leave the last end of sequence code in the file at the very end of the movie? I am asking because I like to let my istar hd 1.3 play a file right through then repeat and now where the end of sequence code is removed when encoding to mkv it just plays a black screen without audio or video after the movie finishes. ( I do this to make sure the movie plays all the way though before I watch anything with my wife. Too many bad movie nights with the 169time mod for directv for her to ever trust any high definition playback)
wildchild22 is offline   Reply With Quote
Old 13th May 2008, 22:16   #4807  |  Link
hlkc
Hi nautilus,
Thanks for your reply. Yes, I intended just for the BD movies. But I still don't get the idea behind and I believed I must miss something here...
So with this tool, I will able to convert the TrueHD audio to the format I mentioned before via SPDIF out to our receiver, right? So this is probably a solution for interim means before we are fully able to send TrueHD via HDMI 1.3 to receiver or someone just prefer without TrueHD receiver, right? Also, after the conversion completed, do we need to do another conversion to convert it back in order to send the TrueHD out?
Thank you.
Old 13th May 2008, 22:48   #4808  |  Link
nautilus7
nautilus7's Avatar
Audio conversion is needed for pc playback for 2 reasons:
1. No available directshow decoders for e-ac3, truehd, dts-hd
2. It's impossible to transmit these formats through spdif for decoding by the receiver.
If you want to play your Blu-ray movies (either backed up on your hard disc as they are or directly from the discs) you don't need any conversions. Simply use powerdvd or another player and set audio output to hdmi.
If you want to back up your blu-rays as a different format (matroska .mkv) and play them from your htpc, you need to use eac3to.
If you just want to back up your blu-rays and also strip the extras from them (or unwanted audio streams) use tsmuxer (no audio conversions needed).
If you want to create movie back ups with blu-ray structure from whatever source also use tsmuxer (perhaps you need to do some audio conversions).
Old 13th May 2008, 23:54   #4809  |  Link
hlkc
Got it. On the other words, in the mean time since software, PDVD8 is down streaming 24/48 and hardware, no HDMI 1.3 audio card available yet, I can use this conversion and make the BD TrueHD audio to different audio format and output it to our pre-amp via SPDIF.
Old 14th May 2008, 02:05   #4810  |  Link
OHB
thanks for the help guys i got audio to ac3 using the main evo file. Thanks beastie boy. now im facing another little problem with getting audio to sync up with video in scenarist. im following the steps thoroughly changing the audio to 23.976 for vc1 but the output m2ts file has syncing issue
Old 14th May 2008, 06:42   #4811  |  Link
gregt
Madshi,
I know Nero 8 has been discussed here previously, but I was wondering why eac3to is not able to use it's codecs. I am able to use them in GraphEdit to render most hidef files (like vc1, h264 - some times I have to change the extension to mpeg2). I just use 'File Source (Async)' -> 'Nero Video Decoder HD' -> 'Video Renderer'. The filter is located at 'Nero\DSFilter\NeVideoHD.ax". So why can't eac3to utilize Nero 8 filter's?
Also, this may not be of interest to anyone, but a feature that I would like is an option to convert to wmv utilizing the Windows Media Video 9 Avanced Profile instead of mkv. I can find no use for mkv, whereas, wmv allows me to use Zune or WMP11 to play hi-def movies over my 802.11n wireless network with no degradation from my computer to my Xbox 360s. Right now converting mkv to wmv using Windows Media Encoder takes 12-16 hours for a single hi-def movie. I found another tool that can do it in 3-4 hours, but it costs $40 plus it is an additional step plus they will not allow me to move my license to another computer without paying for it again (). The WM SDK is free so it is just the time for coding it into eac3to. Any thoughts on this?
Finally, the new changes for vob seem to be working well, but I am having a lot of issues with gaps and the audio being out of sync on various movies and TV shows. I have tried with and without gaps for the following DVD movies to no avail:
Blade Runner, Escape from New York, RoboCop, Terminator and also TV show Stargate SG1 Season 6.
Oddly, I had no problems with Stargate SG1 Season 5,8,9 (DVD structure looks the same as season 6) where gaps were detected and I reran eac3to to add them in. Just as a note Nero Recode was able to read and recode Season 6 with no problem, but it is 15x slower than eac3to.
Thanks for all your work on a great and useful tool!
zap
gregt is offline   Reply With Quote
Old 14th May 2008, 16:23   #4812  |  Link
dorati
By default, eac3to removes dialog normalization.
I convert my Audio-Files to AC3 5.1. The Source Files have dialnorm: -27db.
For what is the remove?
In my created AC3 the Dialog has other Volume? Why not take the default?
dorati is offline   Reply With Quote
Old 14th May 2008, 17:00   #4813  |  Link
OHB
and another thing i just realized is that my video length is 214:43:04 and audio length is 147:48:10 any ideas how to fix this?
Old 14th May 2008, 22:26   #4814  |  Link
Yraen
Originally Posted by gregt View Post
Madshi,
That's the video filters. Those aren't used by eac3to. Can you use the audio filters in graphedit also?
When you use WMV 9 you're converting the video, using mkv you're just placing the video, in it's original form, inside a container. Eac3to doesn't convert the video, it just demuxes/muxes it.
Main evo file or files? Usually there are two files you'll need to get the entire video and audio.
See above, most likely the problem. Try this route:
eac3to "path to movie folder"
Find the titleset you want to demux from.
eac3to "path to movie folder" #)
Replace # with the number of the titleset you want. Now find the tracks listed you want to demux.
eac3to "path to movie folder" #) #: movie.mkv -options #audio.ac3 -options #: chapters.txt
Replace the new # with the number beside the tracks you want.
Those should get you the tracks you want without having to type out the path and file names for the individual evo files.
Yraen is offline   Reply With Quote
Old 15th May 2008, 01:44   #4815  |  Link
OHB
its all one big huge evo file sitting at about 12GB. eac3to demuxes the 2 tracks that are in the file no problem. i then try to run the vc1 file into muigenerator and it gives me an error when i run in scenarist. so i clean the track with vc1conv and then run it through muigenerator and then load it up in scenarist and it takes it fine. I do the same for the ac3 file and that loads up fine. the problem that i'm having is that when i mux everything through scenarist again the m2ts file has audio and video off sync. i've tried even runing eac3togui and getting the same results
Old 15th May 2008, 02:21   #4816  |  Link
Yraen
What movie is it? If I've got it I'll take a look at it. Every HD-DVD I've got is split up into 2 files, most close to or over 20GB total.
If you go from eac3to to mkv, is the audio and video in sync? Are the times then reported correctly?
Old 15th May 2008, 02:54   #4817  |  Link
bigdog660
I've ran into a few movies where there is just one EVO file. Not common, but I've seen it in about 5 movies out of 30 or so.
bigdog660 is offline   Reply With Quote
Old 15th May 2008, 04:43   #4818  |  Link
OHB
It's an adult movie
haven't tried to go to mkv yet, i will try it now once i figure out the command string
Old 15th May 2008, 07:46   #4819  |  Link
Chouonsoku
I just demuxed Nine Inch Nails: Ghosts I-IV and noticed that eac3to downsampled the audio from 96kHz to 48kHz when it was encoded to FLAC.
eac3to v2.46
command line: eac3to "F:\Video\NINE INCH NAILS _ GHOSTS I_IV" 1) 1: chapters.txt 2: video.h264 3: english.flac
M2TS, 1 video track, 1 audio track, 1:50:17
1: Chapters, 36 chapters
2: h264/AVC, 1080p24 /1.001 (16:9)
3: RAW/PCM, English, 2.0 channels, 24 bits, 96khz
Creating file "chapters.txt"...
[v02] Extracting video track number 2...
[a03] Extracting audio track number 3...
[a03] Reading RAW/PCM...
[a03] Swapping endian...
[a03] Encoding FLAC...
[v02] Creating file "video.h264"...
[a03] Creating file "english.flac"...
Video track 2 contains 158662 frames.
eac3to processing took 25 minutes, 40 seconds.
Done.
Is that something that's done automatically? If so, shouldn't that be something that would be done at a users discretion? When I encode my audio track to FLAC, I want to maintain the exact quality of the source audio. Not degrade it to save space.
Chouonsoku is offline   Reply With Quote
Old 15th May 2008, 08:35   #4820  |  Link
madshi
That should be possible.
What does all this have to do with eac3to? Please don't ask in this thread about how to use Scenarist or muigenerator. Please post here about strictly eac3to related questions/problems/suggestions, only. I've never used Scenarist or muigenerator myself yet, so I can't help with that. What you might want to test is to let eac3to mux your movie into an MKV. If that works fine then eac3to probably does everything correctly. If you still have problems with Scenarist or other tools then the problem probably lies outside of eac3to.
When I last tried Nero 8, the audio decoder was not accessible outside of Nero ShowTime. Not in eac3to and also not in GraphEdit. If things changed then that is nice! But I'd like to have confirmation from at least 2 different persons about that before I take the time to install Nero 8 again...
You mean reencoding? That's outside of the scope of what eac3to is about. I'm not considering adding such features at this point in time.
I don't have any of these DVDs (I only buy Blu-Rays these days). So the list of titles doesn't help me much. If you want me to fix this problem I need more detailed information. The first thing to do would be to compare all the DVDs which show these problems. Do they all behave similar in some way? E.g. do you always get only audio gaps and no video gaps? Or always only video gaps and no audio gaps? Also do the gaps always occur directly on the join points of the VOB files? What happens if you ignore the gaps, is audio sync wrong/correct then? What happens if you let eac3to fix the gaps, is audio sync wrong/correct then? Finally, if you found a pattern in where things go wrong exactly, I'd probably need a little sample...
Some of this is explained in the first post of this thread. For general information about dialog normalization please do a google search. Thanks.
The log you posted does not indicate that downsampling was done. Why do you think that eac3to downsampled the audio? eac3to normally doesn't downsample unless you ask it to. Is the final FLAC file signaled as being 48kHz? If so, that's most probably a bug. And in that case probably the FLAC doesn't play correctly?
eac3to
