Go Back   Doom9's Forum > Announcements and Chat > General Discussion
Old 28th September 2019, 17:12   #161  |  Link
Groucho2004
Originally Posted by feisty2 View Post
vista is the best windows operating system ever!
NT4 is the best Windows OS ever!
Edit - Wait, changed my mind, W2K is the best.
Groucho's Avisynth Stuff
Old 29th September 2019, 00:18   #162  |  Link
StainlessS
StainlessS's Avatar
Now you are just being provocative, vista was garbage with state of the art artificial stupidity built in.
And yes, W2K was best ever [once you had turned off all of the fancy graphics stuff].
I sometimes post sober.
Old 29th September 2019, 03:55   #163  |  Link
feisty2
I'm Siri
feisty2's Avatar
lets not forget that the current windows kernel is still based on vista (NT6, tho it's renamed NT10 but u know tomato tomahto)
feisty2 is offline   Reply With Quote
Old 29th September 2019, 17:39   #164  |  Link
And the Vista kernel was based on NT5 (XP/Win2k), which was based on NT4 .. its just how the world works, you don't make new kernels, you improve the one you have.
Old 29th September 2019, 19:38   #165  |  Link
feisty2
I'm Siri
feisty2's Avatar
NT6 is a major update to NT5, vista, 7 and 8 are all NT6, since win10 is not really that different from win8, I assume NT10 is still just NT6 with a new name and no major update (like NT5 to NT6)
Old 16th October 2019, 15:43   #166  |  Link
StainlessS
StainlessS's Avatar
Just a heads up for those concerned,
Cinnamon Mint went to v19.2 a couple of months ago, and ReactOS went to 0.4.12 recently.
Gonna try set up ReactOS as Virtualbox guest, see if Avsynth does anything at all.
Old 17th November 2019, 16:26   #167  |  Link
Katie Boundary
Katie Boundary's Avatar
Cinnamon Mint
Cinnamon is just a desktop environment, and it's one of three that Mint can come with. Mint was updated to 19.2; the new version was published in all three DEs simultaneously.
I ask unusual questions but always give proper thanks to those who give correct and useful answers.
Katie Boundary is offline   Reply With Quote
Old 17th November 2019, 17:24   #168  |  Link
StainlessS
StainlessS's Avatar
Yip, IIRC,
I tried LMDE version (19.0 or 19.1, maybe), and although the installer ISO saw my Wifi just fine, when actually installed it did not work at all, so I gave up on it.
Old 17th November 2019, 22:02   #169  |  Link
Katie Boundary
Yip, IIRC,
You have to manually enable the proprietary drivers in the driver center or whatever Mint calls it. A lot of Linux distros are like that. Presumably it's some kind of security measure because Linux devs can't check closed-source drivers for malware.
Old 18th November 2019, 17:34   #170  |  Link
StainlessS
StainlessS's Avatar
Yeh, that was probably the first thing that I did, no joy [first thing I usually do is check for new Drivers/Updates, and it uses a standard builtin (RealTek I think) driver in Cinnamon].
I would have liked to have gotten Gentoo going, but way too much graft involved.
Old 3rd December 2019, 18:24   #171  |  Link
hello_hello
Seems like maybe the place to ask this question.....
I recently installed 64 bit Win7 on a laptop. I use the free version of xplorer2, which only comes in a 32 bit flavour. As a result, the right click menus added to the registry by most programs don't show up in xplorer2's right click menu (items that are often referred to as shell context menus). After installing 7-zip however, I realised it has an option for adding shortcuts to the context menu for both 64 bit and 32 bit programs, so the 7-zip context menus do show up in xplorer2.
My question is, to save me having to hunt through the registry and risk making a mess by guessing, does anyone know if it's possible to manually create 32 bit context menu registry entries for programs that don't do so when you install them, and/or which registry entries I'd need to copy/create in order to do it?
Cheers.
Old 3rd December 2019, 18:34   #172  |  Link
lvqcl
IIRC:
64-bit 7-zip has both 64-bit shell extension (7-zip.dll) and 32-bit shell extension (7-zip32.dll).
If a program doesn't have 32-bit shell extensoin then it's not possible to add it to a shell context menu.
Old 3rd December 2019, 18:49   #173  |  Link
BetA13
cosmic entity
BetA13's Avatar
whoops, nothing important to see here...
Delete me..^^
i did missunderstod the Question...
BetA13 is offline   Reply With Quote
Old 3rd December 2019, 19:02   #174  |  Link
clsid
The things that you can add to the menu with just a registry key already apply to both 32/64-bit.
What you are missing are shell extensions, as lvqcl already mentioned.
Old 4th December 2019, 03:57   #175  |  Link
StainlessS
StainlessS's Avatar
Seems to work, what are you missing ?
Lite (free) 32 bit(only) version download(v4.2.0.1, version about April 2019):- https://www.zabkat.com/x2lite.htm
Features Comparison:- https://www.zabkat.com/comparison.htm
Setup
7zip(x64, v19.0, 21st Feb 2019) Options [Untick "Cascade Context Menu", puts options directly in context menu rather than contained in 7Zip sub menu]
Standard Windows Explorer context Menu
xPlorer Lite(x86) context Menu
EDIT: The missng context menu shortcuts in xPlorer lite, are from Comodo Anti-virus and "Create Checksum file" maybe from Nirsoft "HashMyFiles".
All 7zip shortcuts are present.
Old 6th December 2019, 21:05   #176  |  Link
feisty2
I'm Siri
feisty2's Avatar
since ur british Im gonna hijack this thread.
is it common that phd students in the uk don't receive funding and other financial support from the universities instead they gotta find some external scholarships? Im considering going to oxford
Old 6th December 2019, 21:57   #177  |  Link
StainlessS
StainlessS's Avatar
No idea !
Old 8th December 2019, 21:30   #178  |  Link
StainlessS
StainlessS's Avatar
For those of you on Win7 that are a bit frustrated with Windows Explorer thing switching views all of the time,
eg you want it always on General Items/Details Vew, but the damn thing keeps switching to icons (or some other view) when an image
or video clip or audio file is in a directory, then here is a fix for you.
I usually end up having to go to Folder Properties for each drive and select Customise/General Items, but have to repeat at each boot,
unfortunately does not work as easily on C drive where individual folders have to be configged, and back to square one again on next reboot.
FIX:
https://answers.microsoft.com/en-us/...2-ac4a4b8bea06
final post by ViaMala
Fix scatty Win Explorer view behaviour to FileType Unspecified
LockFiletypesUnSpecified.reg
Windows Registry Editor Version 5.00
[HKEY_CURRENT_USER\Software\Classes\Local Settings\Software\Microsoft\Windows\Shell\Bags\AllFolders\Shell]
"FolderType"="NotSpecified"
Unfix
LockFiletypesUnSpecified_REMOVE.reg
"FolderType"=-
I've rebooted and still set at unspecified filetypes
EDIT: If you manually set folder to a different view, it will survive a reboot for that folder [I would maybe like all reset to details on reboot, but I can live with that].
EDIT: Above all "Filetypes" should probably read "FolderTypes".
Old 10th December 2019, 18:44   #179  |  Link
laserfan
Aging Video Hobbyist
For those of you on Win7 that are a bit frustrated with Windows Explorer thing switching views all of the time...
Awesome thanks; that's as deep/obscure a regentry I have seen I think! Wonder how it was ever found!
Old 10th December 2019, 20:14   #180  |  Link
StainlessS
StainlessS's Avatar
Yep, shame that both my Android and Windows phones refuse to comply (both insist on icons on each folder until change to details),
I really dont understand how/why people put up with the icons things, not like you dont have to read the text/name anyways, go figure.
(I can partly understand children that have not yet mastered reading english, or even non tech savvy peeps using icons, but what the hell
use are they after those issues are no longer a problem ???)
EDIT: Only place that I'm aware where icons are maybe of use is in the likes of Control Panel, where ALL icons are different, a folder of 200
Word docs, icons play no part at all in being user friendly. [EDIT: I always switch to icons in control panel, go figure ?]
EDIT: "Android and Windows phones", when attached via USB to Win7.
