Old 16th June 2011, 13:36   #1801  |  Link
laserfan
Aging Video Hobbyist
Good suggestion for improving chapters retaining feat.
Thanks for confirming the "retaining chapters from Sources" does not work for all sources! Apparently not many folks [tried to] use this feature or I'd have found more postings about it.
Dunno if you want to add "chapters from BD" to your list of enhancements but AFAIK that will require eac3to and ChapterGen as MediaInfo doesn't seem to do it.
Anyway now I know to separately use "Import Chapters" for each title.
Old 17th June 2011, 23:07   #1802  |  Link
8ternity
8ternity's Avatar
Hi Mrc,
here samething with another project.
2.4.0 original release:
the error:
http://i480.photobucket.com/albums/r...1718h04_46.png
After click "ok";
click to "Edit Movie Info" to set the title and delay if delay present; another error.
http://i480.photobucket.com/albums/r...1718h09_04.png
mediainfo log:
General
Complete name : E:\BLURAY\Diary Of A Wimpy Kid Rodrick Rules FRENCH AC3 1080P F.AVCHD\AVCHD\BDMV\STREAM\00000.m2ts
Format : BDAV
Format/Info : Blu-ray Video
File size : 4.36 GiB
Duration : 1h 39mn
Overall bit rate : 6 275 Kbps
Maximum Overall bit rate : 35.5 Mbps
Video
Menu ID : 1 (0x1)
Format : AVC
Format/Info : Advanced Video Codec
Format profile : High@L4.0
Format settings, CABAC : Yes
Format settings, ReFrames : 3 frames
Format settings, GOP : M=4, N=60
Codec ID : 27
Duration : 1h 39mn
Bit rate mode : Variable
Bit rate : 5 505 Kbps
Maximum bit rate : 25.0 Mbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.111
Stream size : 3.87 GiB (89%)
Writing library : x264 core 112 r1867 22bfd31
Encoding settings : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x3:0x133 / me=umh / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=6 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / constrained_intra=0 / bframes=3 / b_pyramid=0 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=240 / keyint_min=24 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=2pass / mbtree=1 / bitrate=5505 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=25000 / vbv_bufsize=25000 / nal_hrd=vbr / ip_ratio=1.40 / aq=1:1.00
Audio
Menu ID : 1 (0x1)
Format : AC-3
Format/Info : Audio Coding 3
Mode extension : CM (complete main)
Codec ID : 129
Duration : 1h 39mn
Bit rate mode : Constant
Bit rate : 448 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Compression mode : Lossy
Stream size : 319 MiB (7%)
Language : French
Text
Menu ID : 1 (0x1)
Format : PGS
Codec ID : 144
Language : French
Old 19th June 2011, 14:35   #1803  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
What happen if you try to remux the m2ts with tsRemux, leaving only the audio/subs tracks you need?
I've received another warning about division by zero, but the cause was a framerate detected as "0" by MediaInfo. That's should not be the same issue as yours.
Bye
MrC
AVStoDVD Homepage
AVStoDVD @ Doom9 Forum
Old 20th June 2011, 03:23   #1804  |  Link
8ternity
8ternity's Avatar
Hi Mrc,
That movie was encoded with Ripbot264 1.16.4 and re-expoted in AVCHD format with TsMuxerGUI. It not gonna change if i set to m2ts; AVCHD is the same format has the m2ts file?
I'Ve try another movie, samething. Version 2.3.4 is ok! Everything pass.
Let me know if i can help more than this.
**EDIT**
Tested re-muxed in m2ts with txmuser without subtitles; samething.
Also updated ffdshow clsidd rev3871 to 3881; samething.
Old 20th June 2011, 16:30   #1805  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
Ok, let me check. I will give you a 2.4.1 Alpha for testing.
Bye
MrC
AVStoDVD Homepage
Old 22nd June 2011, 14:31   #1806  |  Link
8ternity
8ternity's Avatar
LEt me know with a "PM" when your alpha is ready. I will test it.
THanks.
Old 28th June 2011, 23:23   #1807  |  Link
8ternity
8ternity's Avatar
The issue has neen resolved but i found that the image quality is not has the preview stable version 2.3.4!
The fast mouvement is a little bit saccaged sometimes. I seen some desinterlaced lines on caracters mouvements; saccaged a little bit in some action scene.
I use same settings then before. DirecShow; 2-pass; Sline36Resize; etc.
Old 29th June 2011, 12:52   #1808  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
Fine with the issue.
About the output quality: could you please send me the log files from 2.3.4 and 2.4.1 Alpha projects that show different quality?
Bye
MrC
AVStoDVD Homepage
Old 29th June 2011, 13:25   #1809  |  Link
laserfan
Sorry if this has been asked before... The couple times I've used this software it has worked brilliantly, though I was surprised that it defaults to 1-pass and still manages to hit the bitrate target effectively (necessary as my BD-to-DVD conversions were for discs with 6 TV episodes thereon). Can I assume 2-pass will be even better re-encoding to MPEG2, and more accurate still with fitting-episodes-to-DVD, and at what speed penalty? Twice as slow? Ten times?
Old 29th June 2011, 20:32   #1810  |  Link
8ternity
8ternity's Avatar
I will post you the first log; i second will follow when i will finished all conversions.
AVStoDVD 2.4.1 Alpha;
<2011-06-28 10:12:03>
START PROCESS
PROJECT SETTINGS
DVD Video Standard: NTSC
DVD Titles number: 1
DVD Size: 4450/4450 MB (100%)
DVD Output Setup: DVD Folder
DVD Label: THE_REBOUND
DVD Menu: No Menu
Output Folder: E:\DVD-TEMP
Delete Temp Process Files: Yes
Delete Working Files: Yes
Edit Command Parameters: No
Post Process Task: Show Progress Status window
PREFERENCES
MultiThread: 1
AVS Source Filter: DirectShowSource
AVS UpSize/DownSize Filter: Spline36Resize/Spline36Resize
Video Resolution: 0
Video BitRate Min: 2500
Video BitRate Level 1: 8500
Video Profile Level 2: 8500
Video BitRate Max: 8500
Keep DVD Compliant Video: 1
AC3 Audio Encoder: 0
PAL SpeedUp: 0
Force FFmpeg for Long Audio: 1
DVD Audio Format: 0
DVD Audio BitRate: 448
Keep DVD Compliant Audio: 0
Normalize Audio: 0
Auto Delay Audio: 0
DVD Audio Language (Primary): FR - French
DVD Audio Language (Secondary): EN - English
DVD Subs Language (Primary): FR - French
DVD Subs Language (Secondary): EN - English
DVD Subs Font: Tahoma 18pt Bold (255,255,255)
Chapters Interval: 5
Use Source Chapters: 1
DVD Burning Drive: F: Optiarc DVD RW AD-7241S 1.03
DVD Burning Speed: 4x
Auto Erase DVD RW: 1
Save Log file: 1
Display errors messages: 1
Unload ActiveMovie library: 0
Adjust ffdshow mixer: 1
Save General Settings: 0
TITLE 1 SOURCE FILES
Video: E:\BLURAY\The Rebound FRENCH AC3 720P AFF DVD5.AVCHD\BDMV\STREAM\00000.m2ts
Info: AVC - 5765 kbps - 1280x720 - DAR 1,778 - 0 fps (CFR) - Progressive - 1:34:38 hours - 136150 frames
Audio 1: E:\BLURAY\The Rebound FRENCH AC3 720P AFF DVD5.AVCHD\BDMV\STREAM\00000.m2ts
Info: AC3 - 448 kbps - CBR - 6 ch - 48000 Hz - 16 bit - 1:34:38 hours (0 ms delay) - Internal
AVISYNTH SCRIPT
Video = DirectShowSource("E:\BLURAY\The Rebound FRENCH AC3 720P AFF DVD5.AVCHD\BDMV\STREAM\00000.m2ts", audio=false)
Audio = DirectShowSource("E:\BLURAY\The Rebound FRENCH AC3 720P AFF DVD5.AVCHD\BDMV\STREAM\00000.m2ts", video=false)
Video = Video.ConvertToYV12
Video = Video.ConvertFPS("ntsc_video")
Video = Video.Spline36Resize(720,480)
AudioDub(Video, Audio)
Encoding Profile: HCenc VBR 2-pass
Target Video FileSize: 4053,8 MB
HCenc Parameters: -ini "E:\Temp\THE_REBOUND_0_THE_REBOUND.HCenc.ini"
HCenc ini file:
*INFILE E:\Temp\THE_REBOUND_0_THE_REBOUND_1.avs
*AVSRELOAD
*OUTFILE C:\Users\ST3PH4NE\Videos\THE_REBOUND_0_THE_REBOUND.m2v
*LOGFILE E:\Temp\THE_REBOUND_0_THE_REBOUND.HCenc.log
*MAXBITRATE 9000
*BITRATE 5988
*PROFILE BEST
*ASPECT 16:9
*PROGRESSIVE
*TFF
*BIAS 60
*DC_PREC 9
*MATRIX MPEG
*AQ 1
*LUMGAIN 1
*SMP
*PRIORITY IDLE
*WAIT 2
<2011-06-28 12:06:35>
END VIDEO ENCODING OPERATIONS
Created File: C:\Users\ST3PH4NE\Videos\THE_REBOUND_0_THE_REBOUND.m2v (4053,4 MB)
OUTPUT VIDEO INFO: MPEG-2 Video - 6037 kbps - 720x480 - DAR 1,778 - 0 fps (CFR) - Progressive (TFF) - 1:34:32 hours - 170017 frames
START AUDIO ENCODING OPERATIONS (Track 1)
Wavi+Aften Parameters: "E:\Temp\THE_REBOUND_0_THE_REBOUND_1.avs" - | "C:\Program Files (x86)\AVStoDVD\Aften\aften.exe" -b 448 -pad 0 -dynrng 5 -bwfilter 0 - "C:\Users\ST3PH4NE\Videos\THE_REBOUND_0_THE_REBOUND_1.ac3"
<2011-06-28 12:08:43>
END AUDIO ENCODING OPERATIONS (Track 1)
Created File: C:\Users\ST3PH4NE\Videos\THE_REBOUND_0_THE_REBOUND_1.ac3 (303,3 MB)
OUTPUT AUDIO INFO: AC3 - 448 kbps - CBR - 6 ch - 48000 Hz - 16 bit - 1:34:38 hours (0 ms delay)
START DVD AUTHORING OPERATIONS
BatchMux Parameters: -arglist "E:\Temp\THE_REBOUND_0_BatchMux.ini"
BatchMux ini file:
-d "E:\DVD-TEMP\THE_REBOUND_0\VIDEO_TS"
-mxp "E:\Temp\THE_REBOUND_0_MuxMan.mxp"
-l "E:\Temp\THE_REBOUND_0_MuxMan.log"
-muxman "C:\Program Files (x86)\AVStoDVD\MuxMan"
-prio LOW
-palette "E:\Temp\THE_REBOUND_0_Palette.txt"
-v "C:\Users\ST3PH4NE\Videos\THE_REBOUND_0_THE_REBOUND.m2v"
-vidmode LB
-a1 "C:\Users\ST3PH4NE\Videos\THE_REBOUND_0_THE_REBOUND_1.ac3"
-a1lang fr
-cellfr "C:\Users\ST3PH4NE\Videos\THE_REBOUND_0_THE_REBOUND_Chapters.txt"
-progfr "C:\Users\ST3PH4NE\Videos\THE_REBOUND_0_THE_REBOUND_Chapters.txt"
-chapfr "C:\Users\ST3PH4NE\Videos\THE_REBOUND_0_THE_REBOUND_Chapters.txt"
<2011-06-28 12:11:37>
CHECK DVD SIZE
DVD Folder (actual) Size: 4441,4 MB
vs Estimated Size: 4450 MB -> 0,2% undersize
vs Assets Size: 4356,7 MB -> OK
END DVD AUTHORING OPERATIONS
Created Folder: E:\DVD-TEMP\THE_REBOUND_0 (4441,4 MB)
Log file created by AVStoDVD Release 2.4.1 Alpha build 110624
Old 30th June 2011, 08:03   #1811  |  Link
ynamojn
5.1 DTS to 5.1 AC3 encoding problem
It seems that encoding 5.1 DTS to 5.1 AC3 using wavi+aften will give 2.0 AC3 audio. Is this not possible or am I making mistake in preference? I have choose AC3 with 448 kbps bit rate. I assume with 448 kbps you will get 5.1 AC3 if the input is 6 channels.
ynamojn is offline   Reply With Quote
Old 30th June 2011, 13:03   #1812  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
@laserfan
yes, theoretically 2-pass VBR encoding will give you a better result than 1-pass VBR, mainly using low bitrates (i.e. <3000 kbps). Encoding time should increase about 70-80% than 1-pass VBR.
@8ternity
if you have some frames screenshots that show quality difference, that would be great. Otherwise, log files are enough
@ynamojn
take a look at Help/FAQ/Audio/Q4.1
Bye
MrC
AVStoDVD Homepage
Old 30th June 2011, 13:19   #1813  |  Link
laserfan
@laserfan
Many thanks for your careful reply, and thanks again for this excellent software, which somehow has flown under my radar for a long time now.
Next time I need to use it I am gonna send you a contribution. I promise.
Old 30th June 2011, 16:26   #1814  |  Link
broxburn
Windows 7 64bit.
XviD1.2.1 or 1.32.
Selecting QuEnc (no problem with HcEnc) the conversion freezes as soon as the QuEnc window pops up (Not Responding in Task Manager).
Single or multi-thread.
If I choose multithread I get four instances of QuEnc not responding.
I found that if I changed the fourCC code of the AVI to DX50 there is no problem.
If I was to simply run QuEnc from the subfolder it creates the mpeg file OK.
( I found that FAVC displays the same behaviour, but put it down to being older and not supported recently).
broxburn is offline   Reply With Quote
Old 30th June 2011, 19:22   #1815  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
@laserfan
thank you very much in advance
@broxburn
have you installed Windows 7 Preferred Filter Tweaker and selected XviD as default decoder?
Bye
MrC
MrC
AVStoDVD Homepage
Old 30th June 2011, 19:39   #1816  |  Link
broxburn
It worked - many thanks.
Old 1st July 2011, 01:30   #1817  |  Link
8ternity
8ternity's Avatar
Here the second log (2.3.4 version):
<2011-06-30 18:19:35>
START PROCESS
PROJECT SETTINGS
DVD Menu: No Menu
PREFERENCES
MultiThread: 1
Video Resolution: 0
PAL SpeedUp: 0
DVD Audio Format: 0
Normalize Audio: 0
Auto Delay Audio: 0
DVD Audio Language: FR - French
DVD Subs Language: FR - French
Save Log file: 1
Info: AVC - 5765 kbps - 1280x720 - DAR 1,778 - 23,976 fps (CFR) - Progressive - 1:34:38 hours - 136150 frames
Info: AC3 - 448 kbps - CBR - 6ch - 48000Hz - 16bit - 1:34:38 hours - Internal
Subs:
[MediaInfoLib - v0.7.41]
AVISYNTH SCRIPT
#Using DGPulldown/HCenc to upsize FPS
HCenc Parameters: -ini "E:\Temp\THE_REBOUND_1_THE_REBOUND.HCenc.ini"
HCenc ini file:
*INFILE E:\Temp\THE_REBOUND_1_THE_REBOUND_1.avs
*AVSRELOAD
*OUTFILE E:\DVD-TEMP\THE_REBOUND_1_THE_REBOUND.m2v
*LOGFILE E:\Temp\THE_REBOUND_1_THE_REBOUND.HCenc.log
*MAXBITRATE 9000
*BITRATE 5988
*PROFILE BEST
*ASPECT 16:9
*PROGRESSIVE
*TFF
*PULLDOWN
*BIAS 60
*DC_PREC 9
*MATRIX MPEG
*AQ 1
*LUMGAIN 1
*SMP
*PRIORITY IDLE
*WAIT 2
<2011-06-30 19:06:29>
Created File: E:\DVD-TEMP\THE_REBOUND_1_THE_REBOUND.m2v (4034,9 MB)
OUTPUT VIDEO INFO: MPEG-2 Video - 6003 kbps - 720x480 - DAR 1,778 - 23,976 fps (CFR) - Progressive (2:3 Pulldown) - 1:34:38 hours - 136148 frames
Wavi+Aften Parameters: "E:\Temp\THE_REBOUND_1_THE_REBOUND_1.avs" - | "C:\Program Files (x86)\AVStoDVD\Aften\aften.exe" -b 448 -pad 0 -dynrng 5 -bwfilter 0 - "E:\DVD-TEMP\THE_REBOUND_1_THE_REBOUND_1.ac3"
<2011-06-30 19:08:37>
Created File: E:\DVD-TEMP\THE_REBOUND_1_THE_REBOUND_1.ac3 (303,3 MB)
OUTPUT AUDIO INFO: AC3 - 448 kbps - CBR - 6ch - 48000Hz - 16bit - 1:34:38 hours
BatchMux Parameters: -arglist "E:\Temp\THE_REBOUND_1_BatchMux.ini"
BatchMux ini file:
-d "E:\DVD-TEMP\THE_REBOUND_1\VIDEO_TS"
-mxp "E:\Temp\THE_REBOUND_1_MuxMan.mxp"
-l "E:\Temp\THE_REBOUND_1_MuxMan.log"
-prio LOW
-v "E:\DVD-TEMP\THE_REBOUND_1_THE_REBOUND.m2v"
-vidmode LB
-a1 "E:\DVD-TEMP\THE_REBOUND_1_THE_REBOUND_1.ac3"
-a1lang fr
-cellfr "E:\DVD-TEMP\THE_REBOUND_1_THE_REBOUND_Chapters.txt"
-progfr "E:\DVD-TEMP\THE_REBOUND_1_THE_REBOUND_Chapters.txt"
-chapfr "E:\DVD-TEMP\THE_REBOUND_1_THE_REBOUND_Chapters.txt"
<2011-06-30 19:11:53>
CHECK DVD SIZE
DVD Folder (actual) Size: 4422,3 MB
vs Estimated Size: 4450 MB -> 0,6% undersize
vs Assets Size: 4338,1 MB -> OK
Created Folder: E:\DVD-TEMP\THE_REBOUND_1 (4422,3 MB)
Log file created by AVStoDVD Release 2.3.4
Old 1st July 2011, 10:10   #1818  |  Link
ynamojn
@ynamojn
Bye
Thanks. I got it now. Another question, this is just confirmation. Suppose the source is 24 bit DTS, then it will not be retained?
Old 1st July 2011, 14:55   #1819  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
@8ternity
see source title info readings:
AVStoDVD 2.3.4 (MediaInfo 0.7.41)
AVStoDVD 2.4.1 Alpha (MediaInfo 0.7.44)
Thus AVStoDVD 2.4.1 Alpha does not apply 2:3 pulldown command when encoding with HCenc.
Do you have the possibility to copy&paste here the full MediaInfo 0.7.44 (advanced mode) report?
@ynamojn
No, it will not (FAQ/Audio/Q4.4)
Bye
MrC
AVStoDVD Homepage
Old 2nd July 2011, 04:57   #1820  |  Link
8ternity
8ternity's Avatar
Here the advanced log took with 0.7.44.
General
Count : 277
Count of stream of this kind : 1
Kind of stream : General
Stream identifier : 0
Count of video streams : 1
Count of audio streams : 1
Video_Format_List : AVC
Video_Format_WithHint_List : AVC
Codecs Video : AVC
Audio_Format_List : AC-3
Audio_Format_WithHint_List : AC-3
Audio codecs : AC3
Audio_Language_List : French
Complete name : E:\BLURAY\The Rebound FRENCH AC3 720P AFF DVD5.AVCHD\BDMV\STREAM\00000.m2ts
Folder name : E:\BLURAY\The Rebound FRENCH AC3 720P AFF DVD5.AVCHD\BDMV\STREAM
File name : 00000
File extension : m2ts
Format : BDAV
Format : BDAV
Format/Extensions usually used : m2ts
Commercial name : BDAV
Codec : BDAV
Codec : BDAV
Codec/Info : Blu-ray Video
Codec/Extensions usually used : m2ts
File size : 4688658432
File size : 4.37 GiB
File size : 4 GiB
File size : 4.4 GiB
File size : 4.367 GiB
Duration : 5678601.711111
Duration : 1h 34mn
Duration : 1h 34mn 38s 602ms
Duration : 1h 34mn
Duration : 01:34:38.602
Overall bit rate : 6605362
Overall bit rate : 6 605 Kbps
Maximum Overall bit rate : 35500000
Stream size : 191972997
Stream size : 183 MiB (4%)
Stream size : 183.1 MiB
Proportion of this stream : 0.04094
File creation date : UTC 2011-06-26 21:18:40.871
File creation date (local) : 2011-06-26 17:18:40.871
File last modification date : UTC 2011-06-26 21:19:32.437
File last modification date (local) : 2011-06-26 17:19:32.437
Video
Count : 193
Kind of stream : Video
Menu ID : 1
Menu ID : 1 (0x1)
Format : AVC
Format/Url : http://developers.videolan.org/x264.html
Commercial name : AVC
Format settings : CABAC / 3 Ref Frames
Internet media type : video/H264
Codec ID : 27
Codec : AVC
Codec : AVC
Codec/Family : AVC
Codec/Info : Advanced Video Codec
Codec/Url : http://developers.videolan.org/x264.html
Codec profile : High@L4.0
Codec settings : CABAC / 3 Ref Frames
Codec settings, CABAC : Yes
Codec_Settings_RefFrames : 3
Duration : 5678590
Duration : 1h 34mn
Duration : 1h 34mn 38s 590ms
Duration : 1h 34mn
Duration : 01:34:38.590
Bit rate mode : VBR
Bit rate : 5765000
Bit rate : 5 765 Kbps
Maximum bit rate : 25000000
Width : 1280
Width : 1 280 pixels
Height : 720
Height : 720 pixels
Pixel aspect ratio : 1.000
Display aspect ratio : 1.778
Frame rate : 23.976
Frame count : 136150
Resolution : 8
Resolution : 8 bits
Colorimetry : 4:2:0
Color space : YUV
Bit depth : 8
Bit depth : 8 bits
Interlacement : PPF
Interlacement : Progressive
Bits/(Pixel*Frame) : 0.261
Delay : 600000.000
Delay : 10mn 0s
Delay : 10mn 0s 0ms
Delay : 10mn 0s
Delay : 00:10:00.000
Delay, origin : Container
Stream size : 4178682491
Stream size : 3.89 GiB (89%)
Stream size : 4 GiB
Stream size : 3.9 GiB
Stream size : 3.892 GiB
Proportion of this stream : 0.89123
Writing library : x264 - core 114 r1924 08d04a4
Writing library : x264 core 114 r1924 08d04a4
Writing library/Name : x264
Writing library/Version : core 114 r1924 08d04a4
Encoding settings : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x3:0x133 / me=umh / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=6 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / constrained_intra=0 / bframes=3 / b_pyramid=0 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=240 / keyint_min=24 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=2pass / mbtree=1 / bitrate=5765 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=25000 / vbv_bufsize=25000 / nal_hrd=vbr / ip_ratio=1.40 / aq=1:1.00
Buffer size : 3125000
Audio
Count : 167
Kind of stream : Audio
Menu ID : 1
Menu ID : 1 (0x1)
Format : AC-3
Commercial name : AC-3
Codec ID : 129
Codec : AC3
Codec : AC3
Duration : 5678624
Duration : 1h 34mn
Duration : 1h 34mn 38s 624ms
Duration : 1h 34mn
Duration : 01:34:38.624
Bit rate mode : CBR
Bit rate : 448000
Bit rate : 448 Kbps
Channel(s) : 6
Channel positions : 3/2/0.1
Sampling rate : 48000
Samples count : 272573952
Frame count : 177457
Resolution : 16
Resolution : 16 bits
Bit depth : 16
Bit depth : 16 bits
Delay : 600000.000
Delay : 10mn 0s
Delay : 10mn 0s 0ms
Delay : 10mn 0s
Delay relative to video : 0
Video0 delay : 0
Stream size : 318002944
Stream size : 303 MiB (7%)
Stream size : 303.3 MiB
Proportion of this stream : 0.06782
Language : fr
Language : French
Language : French
Language : fr
Language : fra
Language : fr
dialnorm : -31
dialnorm/String : -31 dB
bsid : 8
dialnorm_Average : -31
dialnorm_Average/String : -31 dB
dialnorm_Minimum : -31
dialnorm_Minimum/String : -31 dB
dialnorm_Maximum : -31
dialnorm_Maximum/String : -31 dB
dialnorm_Count : 2
[IMG] code is Off
