Old 8th August 2017, 09:27   #2601  |  Link
lansing
Originally Posted by blaze077 View Post
It's all there in the documentation:
FrameNum | FrameProps | SetFrameProp
A frame's properties can be accessed by using the get_frame function along with the props attribute. Like so:
src.get_frame(num).props.someFrameProperty = someValue
Reference.
That still doesn't tell me the list of properties of a frame. The problem I have is that I didn't even know the name. In my example, how do I know the name to call frame number? Is it ".props.frame_number" or ".props.frame_num", or is it "props.framenum"? The reference sure doesn't have them.
Old 8th August 2017, 09:34   #2602  |  Link
TheFluff
Excessively jovial fellow
http://www.vapoursynth.com/doc/apire...ame-properties
I'm not sure if there's a standard for anything else. The props are just a key-value map that can contain anything though so just iterate over the keys and all secrets will be revealed to you. Maybe.
TheFluff is offline   Reply With Quote
Old 8th August 2017, 22:35   #2603  |  Link
lansing
Thanks, I didn't know that they were listed on that page, I was looking all over the python reference and function reference page.
Old 11th August 2017, 17:24   #2604  |  Link
lansing
Hi I have another question, is there a function that can delete a series of ranges of frames? For example, I wanted to delete frame 1-10, 100-200 and 500-600 of a clip.
Old 11th August 2017, 17:26   #2605  |  Link
Myrsloik
Professional Code Monkey
Myrsloik's Avatar
Sure is. Trim and splice.
Myrsloik is online now   Reply With Quote
Old 12th August 2017, 09:39   #2606  |  Link
lansing
DeleteFrames should be easier to use.
Can you give an example?
Old 12th August 2017, 15:28   #2607  |  Link
tuanden0
I'm new to vapoursynth, Can someone help me?
I need to change this line in Aviysnth with aWarpSharp filter to Vapoursynth with aWarpSharp2.
I haven't used aWarpSharp2 filter with Avisynth yet
aWarpSharp(depth=12, thresh=0.2, cm=1)
tuanden0 is offline   Reply With Quote
Old 12th August 2017, 18:52   #2608  |  Link
WolframRhodium
According to pinterf's code
in Avisynth is (almost) equivalent to
aWarpSharp2(depth=12, thresh=51, chroma=4)
So in VapourSynth, I think it should be
last = core.warp.AWarpSharp2(last, depth=12, thresh=51, chroma=0)
WolframRhodium is offline   Reply With Quote
Old 12th August 2017, 18:55   #2609  |  Link
ChaosKing
From aWarpSharp2 readme (avisynth)
Original aWarpSharp compatibility:
Mapping from original aWarpSharp parameters:
thresh = thresh*256
blur = blurlevel
depth = depth*blurlevel/2
chroma = 0->2, 1->4, 2->3
You should change thresh to 51 or 52 in awarpsharp2
ChaosKing is online now   Reply With Quote
Old 12th August 2017, 19:00   #2610  |  Link
WolframRhodium
I'll use following code in this case:
frame_list = list(range(1, 10+1)) + list(range(100, 200+1)) + list(range(500, 600+1))
last = core.std.DeleteFrames(last, frame_list)
Old 12th August 2017, 21:05   #2611  |  Link
lansing
Thanks, this is what I'm looking for.
Old 13th August 2017, 03:15   #2612  |  Link
tuanden0
@WolframRhodium, @ChaosKing
Thank You very much
Old 13th August 2017, 04:25   #2613  |  Link
hydra3333
Originally Posted by Myrsloik View Post
R38 is released.
The usual post
Thank you for your great work !
I also appreciate your enabling people to compile their own bits (in my case avisynth_compat.cpp). Beaut !
hydra3333 is offline   Reply With Quote
Old 13th August 2017, 09:45   #2614  |  Link
lansing
How do I overlay text on the frame, like showing frame number of every frame? I can only think of this, but it's certainly a wrong way to do it because it ate up all my ram until the program crashed on longer videos.
for i in range (len(clip)):
	if (i==0):
		sub_clip = core.sub.Subtitle(clip[i], text=str(i))
	else:
		sub_clip += core.sub.Subtitle(clip[i], text=str(i))
Old 13th August 2017, 10:19   #2615  |  Link
AzraelNewtype
AzraelNewtype's Avatar
clip = core.text.FrameNum(clip)
You really might want to actually read the docs.
AzraelNewtype is offline   Reply With Quote
Old 13th August 2017, 13:41   #2616  |  Link
lansing
Thanks. I did read the documents many many times, I thought this function is to print the frame number out to the console, like "print(x)". And there's no sample codes showing what it does.
Old 13th August 2017, 13:59   #2617  |  Link
TheFluff
The use of the word "print" in the docs is a bit confusing, yes. It should probably clarify that it refers to printing on the video frame.
Either way though, requesting all frames in the input clip in Python and splicing one frame at a time is an extremely awkward way of doing things in VS. If you ever find yourself writing a loop that requests frames in Python, you're probably doing things wrong. Yes, iterating over a sequence is intuitive for most programmers, but in the VS world, you need to stop thinking imperative programming and start thinking functional. What you want to write is a composition of functions that does what you want, handling one or at most a few frames at a time, and leave invoking that function chain up to the client application (usually vspipe). Or in other words, start attaching callbacks to things. One more idiomatic way of reimplementing the equivalent of what core.text.FrameNum does yourself is by using FrameEval (example stolen from the docs and slightly modified):
import vapoursynth as vs
import functools
core = vs.get_core()
base_clip = core.std.BlankClip(format=vs.YUV420P8, length=1000, color=[255, 128, 128])
def PrintFrameNumber(n, clip):
  return core.sub.Subtitle(clip, text=str(n))
number_clip = core.std.FrameEval(base_clip, functools.partial(PrintFrameNumber, clip=base_clip))
You might be thinking that this is just doing the same thing that you did. The difference is that here, the subtitling is done when a frame is actually requested, not when the Python script is compiled, and it can be parallelized by the VS thread pool to subtitle many frames at once.
Old 14th August 2017, 01:25   #2618  |  Link
lansing
Thanks for the explanation, that's really clear. I practiced with a few simple function, [s]but I got the error "BuildSCClip() missing 1 required positional argument: 'f'", what does it mean?[/s]
update: I figured out the last problem. And for this one, why didn't it return a delete even clip back to me?
import functools
core = vs.get_core(accept_lowercase=True)
source = abc.avi
def DeleteEven(n, clip):
	if n % 2 ==0:
		return core.std.DeleteFrames(clip, n)
	return clip
odd = core.std.FrameEval(source, functools.partial(DeleteEven, clip=source))
odd.set_output()
Old 14th August 2017, 06:17   #2619  |  Link
tuanden0
Can someone give me an example of using TCanny to create a mask and apply it to keep detail in dark area?
I tried it myself but the output turn on black and mask
Here's my output:
http://i.imgur.com/yBgilc4.png
Old 14th August 2017, 22:25   #2620  |  Link
TheFluff
import functools
source = abc.avi
	if n % 2 ==0:
	return clip
odd.set_output()
Well, I dunno. Aside from DeleteFrames taking a list of ints, not a single int (I think) that kinda looks like it should work (maybe; I'm a bit unsure of what'll happen on the last frame of the clip). I don't think "source = abc.avi" is what's actually in your script though. What does happen when you try to run it?
speed, vaporware, vapoursynth
