19th July 2019, 16:28 | #401 | Link |
MKVToolNix author
Sounds like… well… something, maybe bad compiler optimizations? I don't know… Please give the latest continuous build a try. They're built with newer compiler versions.
Not that I think that'll really do anything, mind you… As I don't have access to a single Ryzen system, I don't think there's really anything I can do at the moment, especially given that older Ryzen seems to have run the binaries just fine according to you.
Latest MKVToolNix is v83.0 If I ever ask you to upload something, please use my file server. |
19th July 2019, 16:30 | #402 | Link |
MKVToolNix author
No. "codec" wasn't changed at all. The property "codec_name" was added containing the value of the "CodecName" track header attribute if present.
29th July 2019, 17:53 | #403 | Link | |
29th July 2019, 19:33 | #404 | Link | |
The only workaround I've found is to import files, choose my settings, then do "Show command line" and run it manually in the command line.
TV Setup: LG OLED55B7V; Onkyo TX-NR515; ODroid N2+; CoreElec 9.2.7 |
31st July 2019, 03:34 | #405 | Link |
Yep, just noticed the same thing, Ryzen 5 3600. Start multiplexing crashed the program and it won't start again. It was working fine up until I chose the destination file using the button instead of typing the name in manually.
1st August 2019, 08:20 | #406 | Link |
MKVToolNix author
The new Ryzens are known to contain several bugs, e.g. with their RDRAND instruction. This is not a bug in MKVToolNix, and AMD has released new BIOSes that're supposed to fix some of those bugs to for the motherboard manufacturers. Another user who reported the issue over on Gitlab also reported that their motherboard manufacturer's just released a BIOS update. After having applied the update MKVToolNix started to work fine for them.
1st August 2019, 10:03 | #407 | Link |
That's interesting, thanks. Did AMD become the new Intel?!
3rd August 2019, 15:19 | #408 | Link | |
Either way, I tried the latest dev release and it seems to work now. Not sure if it's because of the new version or a new BIOS but at least it works now.
3rd August 2019, 19:07 | #409 | Link |
there are quit some issues they even pulled bios versions thanks to bugs in the AGESA. boards are shipped with alpha version bios this is as rushed as possible...
if you want a stable system zen 2 shouldn't be an option for now. |
8th August 2019, 10:58 | #411 | Link | ||
There is also an old thread: http://forum.doom9.org/showthread.php?t=155732
At least, version 11 was the first that dropped support for WinXP. PS: http://forum.doom9.org/showthread.ph...81#post1806381 Last edited by lvqcl; 8th August 2019 at 11:06. |
8th August 2019, 12:44 | #412 | Link | |
Yeah, officially. The sounds made the GUI not work on XP for good. CLI may still work. As should Vista.
8th August 2019, 13:33 | #413 | Link | ||
I had to rebuild another XP system that I was using for compiling and loaded XP-64 on it. I ran either 31 or 33 on it. Hardware issues required a new mobo so I upgraded it to Win7 as well. I had already built another Win7 box for compiling and have basically turned off the other Win7 box. At least I haven't turned it back on after AC power issues. Personally I do not like the "ding"ing that goes on when programs finish, or if there are errors. I find it annoying. The error dialog popups are good enough for me. Thanks for the responses. It has been helpful. |
9th August 2019, 04:37 | #414 | Link |
The last CLI version which works under WinXP is v.29. If you need the GUI you have to replace some components of the package with older versions.
FWIW here is a package which does this... https://files.videohelp.com/u/172211/ToolNix_XP.zip /EDIT/ The archive was updated to also include the last Win7 compatible version (32-bit only) Last edited by manolito; 20th April 2022 at 02:32. |
9th August 2019, 09:06 | #415 | Link | |
Thanks for the info. That'll save me a lot of trial and error.
10th August 2019, 15:58 | #416 | Link |
MKVToolNix author
MKVToolNix v36.0.0 released
Here's another small summery bug fix release for MKVToolNix, v36.0.0. Nothing major's changed; just a couple of fixes here & there.
There've been no changes regarding packaging since the previous release. Here are the usual links: the MKVToolNix home page, the Windows installer/portable version & macOS DMG & Linux AppImage and the source code. The Windows and macOS binaries as well as the Linux AppImage are available already. The other Linux binaries are still being built and will be available over the course of the next couple of hours. Here are the NEWS since the previous release: Version 36.0.0 "Is That Jazz?" 2019-08-10 New features and enhancements
Bug fixes
Have fun
10th August 2019, 16:07 | #417 | Link | |
MKVToolNix author
I don't know specifics about buggy instructions other than RDRAND, but there are tons of reports out there of bugs such as software crashing (see e.g. Destiny 2 crashing), Windows blue-screening during boots and several board vendors releasing BIOS updates several times a week. All of that paints a picture of a rather immature hardware platform. Not really surprising, really, as AMD's hardware seems to include much more radical changes & new features than the glacial enhancements Intel seems to produce these days. I'd simply give the hardware platform some more time to mature, or be aware of the usual risks for early adopters.
10th August 2019, 16:13 | #418 | Link | |
MKVToolNix author
This doesn't mean that MKVToolNix will stop running on Windows 7 on that day, nor does it mean that I'll go out of my way to make MKVToolNix require newer Windows versions to run. In fact, it's quite possible MKVToolNix will continue running on Windows 7 for much longer than it used to run on XP after its end of support. But I do reserve the right to refuse to debug issues occurring on Windows 7 unless the user can show the problem happens on other supported platforms, too. Queue the outrage in 3… 2… 1…
10th August 2019, 16:15 | #419 | Link |
MKVToolNix author
That's because I don't implement intentionally that cause MKVToolNix not to run on older versions anymore. "Not supported" doesn't necessarily mean "doesn't run anymore". I just don't pay attention to unsupported OS anymore regarding my choice of things such as library versions, features used, compiler flags used etc. I often don't even realize there's a problem running on older OS until users complain.
matroska |
