Old 4th November 2016, 10:07   #2561  |  Link
pinterf
Originally Posted by Stephen R. Savage View Post
Wouldn't that conflict with a function named test_array? AVS does not prevent creating variables with the same name as functions.
Yes, there would be conflict.
Final solution should be something like that
black = [0,128,128]
test_array = [ ["ciao", black], ["hello",[1,1,2.718281]], ["null", []] ]
test_array = test_array + ["dummy"]
item = test_array[0]
item2 = test_array["hello"]
e = item2[2]
Provided the [ and ] symbols are not reserved.
Or { and }. Language experts will decide.
pinterf is offline
Old 4th November 2016, 12:16   #2562  |  Link
Gavino
Avisynth language lover
[ and ] are currently used only for nestable block comments [* ... *].
Although technically possible, I recommend not using { and } as these are already well established as code block delimiters, whereas [] is familiar from other languages as indicating array indexing.
You could argue for using a different symbol, like { ... }, for array creation (as in C/C++ and Java), but I would prefer [] for both indexing and creation. There is no problem in distinguishing the two contexts in the parser even if the same symbol is used for both.
On a wider note...
You have so far shown examples of how the array features would be used in the script language.
From the plugin writer's point of view, I would also like to see a list of proposed API changes.
I imagine there will be changes to the public interface of AVSValue and possibly new ScriptEnvironment functions.
GScript and GRunT - complex Avisynth scripting made easier
Gavino is offline
Old 4th November 2016, 12:47   #2563  |  Link
pinterf
Originally Posted by Gavino View Post
On a wider note...
I agree with [ and ].
I also wonder how can I do that with keeping backward compatibility. Anyway, I will return to the problem later, this will definitely need more time than that day I spent on it so far.
pinterf is offline
Old 4th November 2016, 13:23   #2564  |  Link
Gavino
Since [ and ] are currently illegal in scripts (except for [* and *]), what problem do you see with backward compatibility?
Gavino is offline
Old 4th November 2016, 13:38   #2565  |  Link
pinterf
Sorry, I was thinking forward on AVSValue things and the possible interface additions.
pinterf is offline
Old 4th November 2016, 13:58   #2566  |  Link
Gavino
Yes, that's certainly an area where careful thought will be required (although at the moment I can't see any specific problems).
Gavino is offline
Old 4th November 2016, 14:00   #2567  |  Link
stranno
I'm getting a "display error" with r2294 using ProRes 422LT source. Pre-2000 releases work fine. I have seen r2003+ releases support high bit depth colorspace so i'm not sure whats the problem.
Edit: I'm using FFMS2 2.23.
stranno is offline
Old 4th November 2016, 14:13   #2568  |  Link
pinterf
Pre r2294 versions did not support 10,12 and 14 bit depths. Could you please try with the latest version?
pinterf is offline
Old 4th November 2016, 14:27   #2569  |  Link
tuanden0
I have a problem with Avisynth Plus r2294, can someone help me
I coppied the Avisynth.dll to System32 but i still error
tuanden0 is offline
Old 4th November 2016, 14:36   #2570  |  Link
pinterf
If you have installed 32 bit avisynth+ and have a 64 bit windows, the avisynth.dll must be placed to the SysWOW64 folder.
On 32 bit windows, system32 is O.K. for 32 bit avisynth.
But the installer should do this instead of you.
I suppose, there is another avisynth.dll somewhere, can it be set in avspmod?
pinterf is offline
Old 4th November 2016, 14:42   #2571  |  Link
tuanden0
Yah, my fault, i forgot that
Thank you very much
tuanden0 is offline
Old 4th November 2016, 14:52   #2572  |  Link
ajp_anton
ajp_anton's Avatar
But as mentioned, you can already create those conflicts with variable names. What makes array-name conflicts any different? Either you ignore the problem (allow conflicts), or you do something about it (throw error when conflicts happen, or require ()-brackets for functions), but you do the same thing with variable names and array names (aren't arrays also some kind of "variables"?).
Though I agree that []-brackets are better for arrays.
ajp_anton is offline
Old 5th November 2016, 01:22   #2573  |  Link
Aktan
I have an interesting problem. I have a Lagarith source AVI in RGB32 colorspace with the resolution of 350x240. If I open this AVI with AVS+, I get distorted video. From Info(), I noticed the video pitch is wrong. Then I realized 350 is not mod 4. Is this a known problem?
Aktan is offline
Old 5th November 2016, 01:25   #2574  |  Link
Reel.Deel
What AVS+ version are you using?
Reel.Deel is offline
Old 5th November 2016, 01:27   #2575  |  Link
Aktan
r1576, x64
Edit: Well I guess it's an old version? lol.
Aktan is offline
Old 5th November 2016, 01:31   #2576  |  Link
Reel.Deel
r1576, x64
IIRC someone reported a similar problem way back. I believe it was fixed, try updating to the latest version. Report your findings .
Edit: maybe this? https://github.com/AviSynth/AviSynthPlus/issues/36
Old 5th November 2016, 01:34   #2577  |  Link
Aktan
Thanks, will do!
Edit: r2294 works fine =)
Aktan is offline
Old 5th November 2016, 17:09   #2578  |  Link
Stephen R. Savage
Stephen R. Savage's Avatar
There are no function pointers, so I believe AVS will use the presence of the parentheses token to identify a function name instead of a variable.
Stephen R. Savage is offline
Old 5th November 2016, 19:17   #2579  |  Link
Gavino
It does indeed, but in principle it could be extended to try x(1) as an array indexing if it finds that there is no function named x - just as now, when it finds plain 'x' and there is no variable called x, it tries to treat it as a parameterless function call x().
However, I don't think that would be a good idea and the availability of [] makes it unnecessary.
Gavino is offline
Old 7th November 2016, 12:54   #2580  |  Link
jpsdr
A little question.
If i am with an YUVA 4:4:4 mode (for exemple), will IsYV24() still be true ?
jpsdr is offline
