Old 22nd November 2020, 10:07   #21  |  Link
ghostshadow
Originally Posted by quietvoid View Post
It might be related to the memory, buffer allocations..
My stack size on linux was limited to 8MB, and I was using 4MB in the code.
I have lowered it way down, please try again.
Hello quietvoid, it's good it works, that was it.
Now I'm going to try encoded in x265 and give it this rpu as a parameter. I will let you know
ghostshadow is offline   Reply With Quote
Old 24th November 2020, 01:52   #22  |  Link
imhh11
@quietvoid thanks a lot for your tool. Just for fun, I tried to encode p7 dual-layer bluray to p5 single layer full range. Seems to work well on my bluray player and Nvidia Shield but I don't know if I used proper x265.exe settings.
But I probably should use profile 8 and keep the BL HDR10 compatible.
P5 encoded sample:
https://drive.google.com/file/d/12Cm...ew?usp=sharing
P8 encoded sample:
https://drive.google.com/file/d/1HSe...ew?usp=sharing
Video
Format                                   : HEVC
Format/Info                              : High Efficiency Video Coding
Format profile                           : Main 10@L5.1@High
HDR format                               : Dolby Vision, Version 1.0, dvhe.05.06, BL+RPU
Codec ID                                 : dvhe
Codec ID/Info                            : High Efficiency Video Coding with Dolby Vision
Duration                                 : 1 min 0 s
Bit rate                                 : 8 440 kb/s
Width                                    : 3 840 pixels
Height                                   : 2 160 pixels
Frame rate                               : 23.976 (24000/1001) FPS
Chroma subsampling                       : 4:2:0 (Type 0)
Bit depth                                : 10 bits
Bits/(Pixel*Frame)                       : 0.042
Stream size                              : 61.2 MiB (100%)
Writing library                          : x265 3.4+26-ga82c6c7a7:[Windows][GCC 10.2.1][64 bit] 10bit
Encoding settings                        : cpuid=1111039 / frame-threads=4 / numa-pools=28 / wpp / no-pmode / no-pme / no-psnr / no-ssim / log-level=2 / input-csp=1 / input-res=3840x2160 / interlace=0 / total-frames=1459 / level-idc=51 / high-tier=1 / uhd-bd=0 / ref=3 / no-allow-non-conformance / repeat-headers / annexb / aud / hrd / info / hash=0 / no-temporal-layers / no-open-gop / min-keyint=23 / keyint=250 / gop-lookahead=0 / bframes=4 / b-adapt=2 / b-pyramid / bframe-bias=0 / rc-lookahead=20 / lookahead-slices=8 / scenecut=40 / hist-scenecut=0 / radl=0 / no-splice / no-intra-refresh / ctu=64 / min-cu-size=8 / no-rect / no-amp / max-tu-size=32 / tu-inter-depth=1 / tu-intra-depth=1 / limit-tu=0 / rdoq-level=0 / dynamic-rd=0.00 / no-ssim-rd / signhide / no-tskip / nr-intra=0 / nr-inter=0 / no-constrained-intra / no-strong-intra-smoothing / max-merge=3 / limit-refs=1 / no-limit-modes / me=1 / subme=2 / merange=57 / temporal-mvp / no-frame-dup / no-hme / weightp / no-weightb / no-analyze-src-pics / deblock=-2:-2 / no-sao / no-sao-non-deblock / rd=3 / selective-sao=0 / early-skip / rskip / no-fast-intra / no-tskip-fast / no-cu-lossless / b-intra / no-splitrd-skip / rdpenalty=0 / psy-rd=2.00 / psy-rdoq=0.00 / no-rd-refine / no-lossless / cbqpoffs=0 / crqpoffs=3 / rc=crf / crf=14.0 / qcomp=0.60 / qpstep=4 / stats-write=0 / stats-read=0 / vbv-maxrate=160000 / vbv-bufsize=160000 / vbv-init=0.9 / min-vbv-fullness=50.0 / max-vbv-fullness=80.0 / crf-max=0.0 / crf-min=0.0 / ipratio=1.40 / pbratio=1.30 / aq-mode=2 / aq-strength=1.00 / cutree / zone-count=0 / no-strict-cbr / qg-size=32 / no-rc-grain / qpmax=69 / qpmin=0 / no-const-vbv / sar=0 / overscan=0 / videoformat=5 / range=1 / colorprim=2 / transfer=2 / colormatrix=2 / chromaloc=1 / chromaloc-top=0 / chromaloc-bottom=0 / display-window=0 / cll=0,0 / min-luma=0 / max-luma=1023 / log2-max-poc-lsb=8 / vui-timing-info / vui-hrd-info / slices=1 / no-opt-qp-pps / no-opt-ref-list-length-pps / no-multi-pass-opt-rps / scenecut-bias=0.05 / hist-threshold=0.03 / no-opt-cu-delta-qp / no-aq-motion / no-hdr10 / no-hdr10-opt / no-dhdr10-opt / no-idr-recovery-sei / analysis-reuse-level=0 / analysis-save-reuse-level=0 / analysis-load-reuse-level=0 / scale-factor=0 / refine-intra=0 / refine-inter=0 / refine-mv=1 / refine-ctu-distortion=0 / no-limit-sao / ctu-info=0 / no-lowpass-dct / refine-analysis-type=0 / copy-pic=1 / max-ausize-factor=1.0 / no-dynamic-refine / no-single-sei / no-hevc-aq / no-svt / no-field / qp-adaptation-range=1.00 / no-scenecut-aware-qpconformance-window-offsets / right=0 / bottom=0 / decoder-max-rate=0 / no-vbv-live-multi-pass
Default                                  : No
Encoded date                             : UTC 2020-11-24 00:29:30
Tagged date                              : UTC 2020-11-24 00:29:30
Color range                              : Full
Codec configuration box                  : hvcC+dvcC
Video
Format                                   : HEVC
HDR format                               : Dolby Vision, Version 1.0, dvhe.08.06, BL+RPU / SMPTE ST 2086, HDR10 compatible
Codec ID                                 : dvhe
Bit rate                                 : 6 795 kb/s
Chroma subsampling                       : 4:2:0 (Type 2)
Bit depth                                : 10 bits
Bits/(Pixel*Frame)                       : 0.034
Stream size                              : 49.3 MiB (100%)
Encoding settings                        : cpuid=1111039 / frame-threads=4 / numa-pools=28 / wpp / no-pmode / no-pme / no-psnr / no-ssim / log-level=2 / input-csp=1 / input-res=3840x2160 / interlace=0 / total-frames=1459 / level-idc=51 / high-tier=1 / uhd-bd=0 / ref=4 / no-allow-non-conformance / repeat-headers / annexb / aud / hrd / info / hash=0 / no-temporal-layers / no-open-gop / min-keyint=23 / keyint=250 / gop-lookahead=0 / bframes=4 / b-adapt=2 / b-pyramid / bframe-bias=0 / rc-lookahead=25 / lookahead-slices=4 / scenecut=40 / hist-scenecut=0 / radl=0 / no-splice / no-intra-refresh / ctu=64 / min-cu-size=8 / rect / no-amp / max-tu-size=32 / tu-inter-depth=1 / tu-intra-depth=1 / limit-tu=0 / rdoq-level=2 / dynamic-rd=0.00 / no-ssim-rd / signhide / no-tskip / nr-intra=0 / nr-inter=0 / no-constrained-intra / no-strong-intra-smoothing / max-merge=3 / limit-refs=3 / limit-modes / me=3 / subme=3 / merange=57 / temporal-mvp / no-frame-dup / no-hme / weightp / no-weightb / no-analyze-src-pics / deblock=-2:-2 / no-sao / no-sao-non-deblock / rd=4 / selective-sao=0 / no-early-skip / rskip / no-fast-intra / no-tskip-fast / no-cu-lossless / no-b-intra / no-splitrd-skip / rdpenalty=0 / psy-rd=2.00 / psy-rdoq=1.00 / no-rd-refine / no-lossless / cbqpoffs=0 / crqpoffs=0 / rc=crf / crf=14.0 / qcomp=0.60 / qpstep=4 / stats-write=0 / stats-read=0 / vbv-maxrate=160000 / vbv-bufsize=160000 / vbv-init=0.9 / min-vbv-fullness=50.0 / max-vbv-fullness=80.0 / crf-max=0.0 / crf-min=0.0 / ipratio=1.40 / pbratio=1.30 / aq-mode=2 / aq-strength=1.00 / cutree / zone-count=0 / no-strict-cbr / qg-size=32 / no-rc-grain / qpmax=69 / qpmin=0 / no-const-vbv / sar=0 / overscan=0 / videoformat=5 / range=0 / colorprim=9 / transfer=16 / colormatrix=9 / chromaloc=1 / chromaloc-top=2 / chromaloc-bottom=2 / display-window=0 / master-display=G(13250,34500)B(7500,3000)R(34000,16000)WP(15635,16450)L(10000000,1) / cll=233,63 / min-luma=0 / max-luma=1023 / log2-max-poc-lsb=8 / vui-timing-info / vui-hrd-info / slices=1 / no-opt-qp-pps / no-opt-ref-list-length-pps / no-multi-pass-opt-rps / scenecut-bias=0.05 / hist-threshold=0.03 / no-opt-cu-delta-qp / no-aq-motion / hdr10 / hdr10-opt / no-dhdr10-opt / no-idr-recovery-sei / analysis-reuse-level=0 / analysis-save-reuse-level=0 / analysis-load-reuse-level=0 / scale-factor=0 / refine-intra=0 / refine-inter=0 / refine-mv=1 / refine-ctu-distortion=0 / no-limit-sao / ctu-info=0 / no-lowpass-dct / refine-analysis-type=0 / copy-pic=1 / max-ausize-factor=1.0 / no-dynamic-refine / no-single-sei / no-hevc-aq / no-svt / no-field / qp-adaptation-range=1.00 / no-scenecut-aware-qpconformance-window-offsets / right=0 / bottom=0 / decoder-max-rate=0 / no-vbv-live-multi-pass
Default                                  : No
Encoded date                             : UTC 2020-11-24 01:57:43
Tagged date                              : UTC 2020-11-24 01:57:43
Color range                              : Limited
Color primaries                          : BT.2020
Transfer characteristics                 : PQ
Matrix coefficients                      : BT.2020 non-constant
Mastering display color primaries        : Display P3
Mastering display luminance              : min: 0.0001 cd/m2, max: 1000 cd/m2
Maximum Content Light Level              : 233 cd/m2
Maximum Frame-Average Light Level        : 63 cd/m2
Old 24th November 2020, 03:43   #23  |  Link
quietvoid
I'm not sure BT2020 primaries is meant to be played as profile 5 :P
They both play just fine on my device, otherwise.
But yes, the profile 5 only plays in Dolby Vision.
Old 24th November 2020, 03:58   #24  |  Link
imhh11
yes you're right, it's probably not possible yet to encode p7 bt2020 to true p5 which uses a different colorspace. or maybe you know how ?
profile 8 file with HDR10 BL should be standard though
thank's again for your great work.
Old 24th November 2020, 04:04   #25  |  Link
quietvoid
There still seem to be unknowns in Dolby's IPTQc2 colorspace, if you're interested this mpv issue has good info: https://github.com/mpv-player/mpv/issues/7326
Old 24th November 2020, 10:38   #26  |  Link
SeeMoreDigital
Life's clearer in 4K UHD
SeeMoreDigital's Avatar
Both files display the Dolby Vision logo on my 2016 LG television...
Old 24th November 2020, 12:42   #27  |  Link
ghostshadow
Hello SeeMoreDigital, your encodings are in mp4, have you tried in mkv?
thank you again to quietvoid after the hdr10 + it finds the solution of the dolby vision
Old 24th November 2020, 16:15   #28  |  Link
imhh11
x265.exe produces raw HEVC stream. not an mp4 nor an mkv.
To create those samples, I encoded with x265.exe and then I used the mp4muxer to create a DV MP4. You could also use the nightly tsMuxer and make a TS file with Atmos and maybe you can try the yusesope tool (mkv patcher ?) but I have minimal experience with his tool.
Old 24th November 2020, 16:25   #29  |  Link
ghostshadow
no I encode in x265 and then with mkvtoolnix
Old 24th November 2020, 17:30   #30  |  Link
imhh11
someone correct me if I'm wrong but mkvtoolnix has been updated to support dual-layer profile 7 Dolby Vision remixing(only the file created by makemkv) and does not support single layer DV remuxing.
Old 24th November 2020, 21:31   #31  |  Link
ghostshadow
After you have to go back to Makemkv that's all
Old 24th November 2020, 21:59   #32  |  Link
SeeMoreDigital
Playing Dolby Vision HEVC encoded video streams placed within the .mkv container on an LG television is currently not possible because an entirely new .mkv file parser and splitter will have to be created first.
The same goes for any other SoC hardware playback device...
Old 24th November 2020, 23:33   #33  |  Link
imhh11
I'm curious, how do you do that? I know it works with dual layers files but I never heard of MakeMkv working with single-layer file
I just tried and the DV metadata are gone once the new MKV is created.
Old 5th December 2020, 01:09   #34  |  Link
theweasley
Posting in this thread as it's the oldest.
I made a first release of my tool: https://github.com/quietvoid/dovi_to.../tag/0.1.0-fix
It can be used to create an RPU file from a profile 5, 7 or 8 HEVC encoded file.
Commands:
demux: Demuxes single track dual layer Dolby Vision into Base layer and Enhancement layer files.
extract-rpu: Extracts Dolby Vision RPU from an HEVC encoded file.
More info in the README.
Enjoy.
Thank you this is a Great tool! Works really well. I've managed to successfully create a profile 8.1 x265 uncropped encode with it.
I have a quick question on cropping.
I'd like to crop the encode as well. Looking at these specific lines in vdr_dm_data.rs (https://github.com/quietvoid/dovi_to...a.rs#L309-L310)
Am I right to assume that the active area for DV can be altered here by hard coding it into the RPU / EL to get a properly cropped encode with DV? Been experimenting with it a bit and I'm having trouble figuring out how the values can be altered. Can I simply hardcode a custom offset here and if so what would be the correct way to input them?
Once again, thank you very much for the script. Works amazingly. And your insight would be most appreciated!
theweasley is offline   Reply With Quote
Old 5th December 2020, 01:12   #35  |  Link
quietvoid
From what I understand, they are only necessary to tell the decoder how large the black bars are.
If you crop them off, it would probably be 0.
Old 5th December 2020, 07:25   #36  |  Link
theweasley
Oh I see that makes more sense. Thanks! I'll test and report back.
One more quick thing: I've noticed that if I build your script from the source (without changing anything in the code), the dovi parsing runs super slow with a simple ffmpeg stream copy to EL.hevc, like at 0.5x even. But when I use your prebuilt tool that you release on github, it's 10 times faster. I am probably building it wrong. I use cargo build on the src directory. Should I be doing something else?
Old 5th December 2020, 17:14   #37  |  Link
quietvoid
You need to build with optimizations, usually "cargo build --release".
Old 6th December 2020, 14:52   #38  |  Link
theweasley
Amazing! Both your suggestions worked. Setting it to 0 allowed me to create a cropped encode that works without issues and the optimized build fixed the slow EL extraction. Without your tool this wouldn't be possible! Thanks again
Old 30th March 2021, 11:10   #39  |  Link
telemO
Yes, quietvoid is the man !
He's developped this excellent and useful tool for the community, as well as the one to parse the HDR10+ metadata : so much for that.
@theweasley: I am very interesting to know how to transcode cropped version with the DoVi tool : are you changing the code of this DV tool? Or just inputing some extra parameters when parsing?
@quietvoid : Is it possible to transcode cropped video as well with your HDR10+ tool?
Thank you very much in advance for answering
telemO is offline   Reply With Quote
Old 30th March 2021, 14:38   #40  |  Link
quietvoid
There's no simple way to use the tool for cropped video, you have to edit the code.
Also, using the RPU with x265 to transcode might end up with some desyncs due to the way x265 is inserting the metadata back.
Unfortunately I don't think there is a solution for that, other than inserting the metadata after transcoding.
See https://github.com/quietvoid/dovi_to...ment-803652617
Now those desyncs are not always visible in playback, but they're still there.
For HDR10+ the same desync issue is present. For cropped video, the metadata is supposedly resolution agnostic and hopefully the analysis is done on the active image area only.
So it should work in theory,
I'm curious to know how streaming services make use of x265's RPU insertion. There has to be some predicting the transcode's decoding order somehow, to make sure the RPU is synced throughout.
Though I've had artifacts with Dolby Vision on Netflix as well, so maybe they don't bother syncing either.
LG C2 OLED | GitHub Projects
dolby vision, dovi, hdr, rpu, x265
