30th September 2019, 18:35 | #7061 | Link | |
30th September 2019, 18:59 | #7062 | Link | |
I open the program, add my video, add my settings and AVS, press start. It does not encode the whole video I just delete the files And press start again in the same window It encodes the whole video Weird huh? Like I said it is random, not often. |
30th September 2019, 19:25 | #7063 | Link | |
30th September 2019, 19:46 | #7064 | Link | |
y4m [info]: 1920x1080 fps 24000/1001 i420p8 sar 1:1 unknown frame count raw [info]: output file: T:\TEST\encode.265 x265 [info]: HEVC encoder version 3.1+7-147fb92c5ed5 x265 [info]: build info [Windows][MSVC 1921][64 bit] 8bit x265 [info]: using cpu capabilities: MMX2 SSE2Fast LZCNT SSSE3 SSE4.2 AVX FMA3 BMI2 AVX2 x265 [info]: Main profile, Level-4 (Main tier) x265 [info]: Thread pool created using 8 threads x265 [info]: Slices : 1 x265 [info]: frame threads / pool features : 3 / wpp(17 rows) x265 [info]: Coding QT: max CU size, min CU size : 64 / 8 x265 [info]: Residual QT: max TU size, max depth : 32 / 1 inter / 1 intra x265 [info]: ME / range / subpel / merge : hex / 57 / 2 / 3 x265 [info]: Keyframe min / max / scenecut / bias: 23 / 240 / 40 / 5.00 x265 [info]: Lookahead / bframes / badapt : 20 / 4 / 2 x265 [info]: b-pyramid / weightp / weightb : 1 / 1 / 0 x265 [info]: References / ref-limit cu / depth : 3 / off / on x265 [info]: AQ: mode / str / qg-size / cu-tree : 3 / 1.0 / 32 / 1 x265 [info]: Rate Control / qCompress : CRF-20.0 / 0.60 x265 [info]: tools: rd=3 psy-rd=2.00 early-skip rskip signhide tmvp b-intra x265 [info]: tools: strong-intra-smoothing lslices=6 deblock sao x265 [info]: frame I: 11, Avg QP:16.20 kb/s: 6958.02 x265 [info]: frame P: 275, Avg QP:20.60 kb/s: 3482.34 x265 [info]: frame B: 714, Avg QP:25.57 kb/s: 356.63 x265 [info]: Weighted P-Frames: Y:10.9% UV:6.5% x265 [info]: consecutive B-frames: 22.4% 4.5% 4.5% 38.1% 30.4% encoded 1000 frames in 17.26s (57.95 fps), 1288.81 kb/s, Avg QP:24.10 Code:
y4m [info]: 1920x1080 fps 24000/1001 i420p8 sar 1:1 unknown frame count raw [info]: output file: T:\TEST\encode.265 x265 [info]: HEVC encoder version 3.1+8-21db162c8622 x265 [info]: build info [Windows][MSVC 1921][64 bit] 8bit x265 [info]: using cpu capabilities: MMX2 SSE2Fast LZCNT SSSE3 SSE4.2 AVX FMA3 BMI2 AVX2 x265 [info]: Main profile, Level-4 (Main tier) x265 [info]: Thread pool created using 8 threads x265 [info]: Slices : 1 x265 [info]: frame threads / pool features : 3 / wpp(17 rows) x265 [info]: Coding QT: max CU size, min CU size : 64 / 8 x265 [info]: Residual QT: max TU size, max depth : 32 / 1 inter / 1 intra x265 [info]: ME / range / subpel / merge : hex / 57 / 2 / 3 x265 [info]: Keyframe min / max / scenecut / bias: 23 / 240 / 40 / 5.00 x265 [info]: Lookahead / bframes / badapt : 20 / 4 / 2 x265 [info]: b-pyramid / weightp / weightb : 1 / 1 / 0 x265 [info]: References / ref-limit cu / depth : 3 / off / on x265 [info]: AQ: mode / str / qg-size / cu-tree : 3 / 1.0 / 32 / 1 x265 [info]: Rate Control / qCompress : CRF-20.0 / 0.60 x265 [info]: tools: rd=3 psy-rd=2.00 early-skip rskip signhide tmvp b-intra x265 [info]: tools: strong-intra-smoothing lslices=6 deblock sao x265 [info]: frame I: 11, Avg QP:16.20 kb/s: 6958.02 x265 [info]: frame P: 275, Avg QP:20.60 kb/s: 3482.34 x265 [info]: frame B: 714, Avg QP:25.57 kb/s: 356.63 x265 [info]: Weighted P-Frames: Y:10.9% UV:6.5% x265 [info]: consecutive B-frames: 22.4% 4.5% 4.5% 38.1% 30.4% encoded 1000 frames in 18.76s (53.31 fps), 1288.81 kb/s, Avg QP:24.10 |
3rd October 2019, 12:06 | #7066 | Link |
Did you als sign the Contributor License Agreement? See
https://bitbucket.org/multicoreware/...iki/Contribute They rejected all my patches until I sended them back the signed Contributor License Agreement. It is also important to format it correctly. One of my former patches couldn't be applied, because the formatting was wrong. And don't be surprised if it takes some time. For my patches it normally takes several weeks until they get applied. |
3rd October 2019, 17:13 | #7068 | Link |
Looks like
https://bitbucket.org/multicoreware/...e3ca9a1b6e1d39 and https://bitbucket.org/multicoreware/...f10c31238d6bf1 commit are meant to fix the "slowdown even is not used AQ mode 4." Cu Selur |
4th October 2019, 14:29 | #7069 | Link |
SuperVirus
x265.exe 3.2+5-354901970679
--- Fix: AQ mode 4 commit (21db162) introduces slowdown even when AQ mode 4 is not used; --- Adaptive Frame duplication This patch does the following: 1. Replaces 2-3 near-identical frames with one frame and sets pic_struct based on frame doubling / tripling; 2. Add option "--frame-dup" and "--dup-threshold' to enable frame duplication and to set threshold for frame similarity (optional); http://www.mediafire.com/file/ado1h8...70679.rar/file |
4th October 2019, 18:26 | #7070 | Link | |
I could see this helping efficiency and encoding speed for stuff like a title card displayed for a couple of seconds. |
4th October 2019, 19:08 | #7071 | Link |
--frame-dup makes output duration smaller than input. Is it a decoder problem of not duplicating/triplicating frame duration when needed? Or is it a muxing problem when using matroska as a container?
4th October 2019, 19:34 | #7072 | Link |
I wonder if that mode is really that beneficial. If it detects dupes, it could just code them as all-skip P or B frames with minimal bitstream overhead. Sure, that single frame is being saved, but in the grand scheme of things for a small scene of a static shot that seems insignficant. Nevermind that repeat flags are likely to trip up decoders and/or muxers, as you basically generate a VFR bitstream.
4th October 2019, 20:07 | #7073 | Link | |
The reason for doing such a weird VFR is that the same mechanism used for 3:2 pulldown and 24->60p conversion is used here. |
4th October 2019, 20:26 | #7074 | Link | |
4th October 2019, 22:25 | #7075 | Link | |
A mechanism thats already rarely used in HEVC, and likely not well supported, or intentionally ignored, because original 24p content is just better then stuttery 30p.
5th October 2019, 03:51 | #7076 | Link | |
Still, one of Multicoreware's corporate clients probably asked for it (anime OTT?), so there it is. |
5th October 2019, 17:02 | #7078 | Link |
Actually it's not really a good idea for anime. The duplicate removal filters like this can mishandle a very common scenario where the whole picture doesn't move at all, but there is just mouth movement in a tiny part. It can be just few pixels, but killing that and replacing with wrong duplicate is a terrible sort of artifact.
6th October 2019, 15:33 | #7079 | Link | |
6th October 2019, 23:52 | #7080 | Link |
Hey Guys,
Are there any new switches that would speed up multi pass encoding?
