27th January 2020, 12:46 | #18281 | Link | |
Grumpy Old Man.
Just how much benefit would a GT 1030 give..(compute units) Is passive cooling going to be sufficient if being used for heavy use.. I have an MSI GTX 1080, and an MSI RX 480, both have 2 big fan's, but don't spin until they get hot, and then they are very quiet. What CPU are you running ??
27th January 2020, 13:19 | #18283 | Link | |
GT710 can decode AVC blu-ray (~26Mbps) at ~120fps Code:
AVSMeter 2.5.3 (x64) - Copyright (c) 2012-2017, Groucho2004 AviSynth+ 3.4 (r2925, master, x86_64) (3.4.0.0) Number of frames: 14405 Length (hh:mm:ss.ms): 00:10:00.809 Frame width: 1920 Frame height: 1080 Framerate: 23.976 (24000/1001) Colorspace: i420 Frames processed: 14405 (0 - 14404) FPS (min | max | average): 38.51 | 195.9 | 121.7 Memory usage (phys | virt): 95 | 259 MiB Thread count: 20 CPU usage (average): 2% Time (elapsed): 00:01:58.320
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 27th January 2020 at 13:27. |
27th January 2020, 13:27 | #18284 | Link | |
Grumpy Old Man.
Surely it's only a small % of "help", and there's only some filters that use GPU's for filtering, not encoding. MDegrain is CPU, KnlMeansCL is GPU.
27th January 2020, 13:33 | #18285 | Link | |
27th January 2020, 13:47 | #18286 | Link |
Grumpy Old Man.
Hmmm, better spending that money on CPU's, not necessarily on powerful GPU's.
27th January 2020, 13:53 | #18287 | Link | |
Grumpy Old Man.
And then with 8K "just around the corner", that will really throw a "cat among the pigeons"....
27th January 2020, 14:21 | #18288 | Link | ||
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 27th January 2020 at 14:23. |
27th January 2020, 15:06 | #18289 | Link | |
Grumpy Old Man.
I doubt that I will test GPU decoding.... I don't use GPU for anything but 4k playback and display for my 4K LG monitor...
27th January 2020, 15:15 | #18290 | Link | |
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 27th January 2020 at 15:17. |
28th January 2020, 07:02 | #18291 | Link |
Grumpy Old Man.
A small feature request
Atak,
You know it would be VERY handy to be able to shutdown the Client PC, at any chosen chunk, instead of having to sit there, until the chunk(s) is completed, then manually stop the process. If this:- = SHUTDOWN SERVER AT IDLE STATE (Finish encoding current chunk and then shutdown), could be added to the Clients options, instead of just the Servers. Or better still (just on the Client), if the encoding process could be gracefully closed, and not start the next chunk, then you could abort out, without the job having been completed, ready to resume, whenever...
29th January 2020, 10:11 | #18293 | Link |
Grumpy Old Man.
Joining a 2 part movie
I know this question is a little off topic for this forum, but it is along the lines of a question jojo54000 asked, several days ago.
I am trying to join 2 parts of a movie, and I can get each part to playback well, after running them thru either tsMuxer, or MKVToolnix, but when I "merge / append" the parts together, either using tsMuxer of MKVToolnix, the 2nd part is out of sync. I have several movies that are like this, meaning it 2 parts, and I'm not having much luck. Anybody with a hint, would be welcome.
29th January 2020, 12:07 | #18295 | Link | |
Grumpy Old Man.
But a more powerful CPU would be a lot better...what are running ??
Not poorly done, just doin' it my way !!! Live every day like it's your last, because one day, it will be !! (M$B) Last edited by Pauly Dunne; 30th January 2020 at 01:09. |
29th January 2020, 13:20 | #18296 | Link | |
1- copy / b (first demux the videos .h265 / .h264) 2- mp4box 3- ffmpeg 4- mkvtoolnix the safest is with 'copy / b' and the least secure with mkvtoolnix according to my tests. with 'copy / b', never had synchronization concerns, but the 2 parts must be encoded exactly with the same options, resolution ... and avoid videos with OpenGOPs. |
29th January 2020, 13:29 | #18297 | Link | |
Grumpy Old Man.
found these examples... Method 1 type "C:\folder1\file1.txt" "C:\folder2\file2.txt" > output.txt Method 2 copy "C:\folder1\file1.txt"+"C:\folder2\file2.txt" output.txt
29th January 2020, 15:16 | #18299 | Link | |
29th January 2020, 16:45 | #18300 | Link | |
ByteShare
As for GPU decoding, I ran some long tests a while back and it is slightly faster on longer encodes but only when I'm not using my usual GPU filters, when using heavier GPU filters it is slower to decode with GPU. |
