7th March 2014, 00:37 | #341 | Link |
Broadband Junkie
Cannot seem to reproduce this, so I may need to provide you a few builds with changes rolled back based on your dump & crash report to track down the cause. If luck has it, this will be the same issue dansrfe reported. Before I do that, could you use this logging build and upload the log it generates up until the crash occurs. The shorter the log the better, so try to delete it between attempts. If you could upload logs for a couple variations of triggering the crash, that could also be useful. You can edit the target in the .properties file, but currently I have it set to write to C:\
Edit: I've sent you a PM with some builds to test. Some of those may actually be less stable, but see if any resolve this particular crash. Last edited by cyberbeing; 7th March 2014 at 01:36. |
7th March 2014, 06:51 | #342 | Link |
The AutoLoader doesn't seem to work for me. The only way to load external subtitles with XySubFilter is to name them exactly the same as the videofile. Subtitles muxed with the video load fine.
I use MPC-HC 1.7.3 + LAV Filters 0.61.0 + madVR 0.87.6 + XySubFilter 3.1.0.682 BETA2. XySubFilterAutoLoader & XySubFilter are set to Prefer in the External Filters settings (set merit doesn't work either). |
7th March 2014, 09:15 | #343 | Link |
Otaku
@cyberbeing
Thanks, will do when I get back from work! Sent from my SGS3 with Temasek 's CM11 & Tapatalk Pro!
In the school, the three guys met. Their relation had been changed in the season, and turned into three love stories.
7th March 2014, 19:49 | #344 | Link | |
Broadband Junkie
VideoTitle.mkv VideoTitle.en.srt VideoTitle.jp.srt VideoTitle.fr.srt VideoTitle.styled.ass VideoTitle.bluray.sup Last edited by cyberbeing; 7th March 2014 at 20:40. |
7th March 2014, 20:58 | #345 | Link | |
I already thought that it was ment to be like that... Isn't there a way to work around this? So XySubFilter gets always loaded, like it was before? I would have to rename 200+ files to get all my subtitles working. Switching back to an older version of madVR fixes this, but I don't want to loose the new features of madVR. |
7th March 2014, 21:07 | #346 | Link |
Broadband Junkie
I'm not sure what you mean exactly, since even if XySubFilter is present in the graph in prior versions of madVR, those external subtitles still wouldn't be auto-loaded? Were you manually opening your subtitle files in prior versions? If you want XySubFilter Beta2 to always be present in the graph even when no subtitles are detected, open the configuration dialog and set 'Main -> Loading' to "Always Load".
7th March 2014, 21:17 | #347 | Link |
Otaku
@cyberbeing
After testing with the files you have provided here's the results (file was always registered before testing): additiondraw = crash autoload = ok bugfix = ok merge = crash vs2010 = crash vs2013 = crash Maybe the autoload code and the bugfixes are "incompatible" (well at least in my system). Also here's the log generated by the logging build you provided. Hope this helps! Thanks Kado
7th March 2014, 21:30 | #348 | Link |
Broadband Junkie
Thanks. The "bugfix" reverted our bug fixes, but not the auto loader or addition draw. So it would seems one of our bug fixes is causing a new crash on your system.
I'll PM you so more builds in awhile, to see if we can track down the specific commit. Edit: PM sent Edit2: I notice from your log you are using "ffdshow Audio Processor". If you uninstall ffdshow, does it resolve your crash with Beta2? Edit3: You also appear to have set "Cache Size" to a very low 32MB. If you change this back to the default of -1 does it resolve your crash? (And yes, I realize text input for that Cache setting box behaves strangely, if it takes the -1 correctly, it should show "Auto" the next time used) Last edited by cyberbeing; 8th March 2014 at 00:54. |
8th March 2014, 00:48 | #349 | Link | |
The "Always Load" works fine! I messed around with settings yesterday and checked that too, but it didn't work maybe something interfered with it. Thank You for your help! |
8th March 2014, 09:55 | #350 | Link |
Some time ago, I complained about performance problems with xySubFilter in full resolution mode. I'm still seeing occasional heavy frame drops with xySubFilter in the beta 2 release. Looking at the execution of mpc-hc.exe under Process Explorer, I notice the GPU memory usage fluctuating heavily as though a lot of dynamic allocation was being performed. Is this expected?
8th March 2014, 10:36 | #351 | Link | |
Broadband Junkie
That's probably a better question for the madVR thread, or MPC-HC thread (if using EVR-CP's consumer). All XySubFilter does is send bitmaps when requested, beyond that GPU memory allocations are in the hands of the subtitle consumer. You could try adding a DWORD value "MAX_BITMAP_COUNT" under HKEY_CURRENT_USER\Software\Gabest\XySubFilter\Performance\ and play with the value to see if it changes this behavior at all. The default value is 8 (decimal), but not a lot of testing has been done to determine if this is the optimal value in terms of CPU & GPU load. |
8th March 2014, 17:01 | #352 | Link |
Otaku
@cyberbeing
Regarding cache those values were me messing around as they were at auto(511) before, also even without ffdshow it crashes. Did some tests and the file in folder "[2]/InsaneBorder" does not crash MPC-HC. Cheers! Kado
8th March 2014, 22:14 | #353 | Link |
Broadband Junkie
Thanks, I'll pass it along to our developer. That build reverted the two insane border support commits [1] [2], which was a separate enhancement from the bugfix for Issue #166 which should still be fixed.
I've created an entry on our bug tracker as Issue #181, and attached the XySubFilter Test Build you've stated resolved your crash. Last edited by cyberbeing; 8th March 2014 at 22:17. |
9th March 2014, 00:46 | #356 | Link |
Broadband Junkie
For standard DVD disc playback, I'm unsure it's possible with VSFilter-based filters in general unless you find a splitter which exposes a subtitle pin. DVD disc subtitles are normally rendered by the Video Decoder. The VSFilter VOBSUB format requires ripping subtitles from DVDs, at least as far as I'm aware. DVD playback is not my area of expertise. You may get a better answer in the MPC-HC thread, as the same would apply to their version of VSFilter.dll.
For Blu-ray playback, XySubFilter should be used normally to render the PGS subtitles directly embedded in the TS files on the disc, assuming LAV Splitter is used and no other subtitle renderer is enabled. Last edited by cyberbeing; 9th March 2014 at 00:49. |
9th March 2014, 00:49 | #357 | Link | |
Oz of the zOo
Also, as of now it's not possible to start watching a video without any subtitles (either internal or external) and later drag'n'drop/load arbitrary subtitles with xySubFilter, right? Last edited by wOxxOm; 9th March 2014 at 00:53. |
9th March 2014, 00:53 | #358 | Link | ||
Broadband Junkie
With MPC-HC, you'd actually need to open up XySubFilter settings during playback and use Main -> Open... to select your subtitle. Last edited by cyberbeing; 9th March 2014 at 00:58. |
9th March 2014, 01:03 | #360 | Link | |
Broadband Junkie
Only MPC-HC loads the ISR on-the-fly and doesn't use XySubFilter with drag'n'drop. Last edited by cyberbeing; 9th March 2014 at 01:08. |
