18th March 2016, 01:55 | #14281 | Link | |
here is the Virustotal.com scan result. looks like 3 out of 44 AV picked it up as malware.
19th March 2016, 12:55 | #14283 | Link |
open updater.ini in notepad and change that date to 2000-01-01 00:00:00
19th March 2016, 14:02 | #14284 | Link |
Hey Atak, I've been thinking about the trouble some guys are having with updates & version numbers.
With all due respect, may I suggest that with the next update, you could post a full setup (like you used to) and with a build number of, say, 1.19.4, and then after that, the auto updates continue for the new version for a time, then release another full version. It's just that if someone wants to start from stratch, they don't have to start with what is now a fairly old build of 1.19.2., and then have to get all the updates that were released since then. |
19th March 2016, 14:11 | #14285 | Link |
yes I will do that today but it won't be 1.19.4 but 'official 1.19.3'
19th March 2016, 23:55 | #14287 | Link | |
OK, I see that you have also added an audio amplification option, and I hate to be a PITA, but could you also have it go negative, as well, for files that are too loud ??? And what unit of measure are the adjustments ?? Sorry, and |
20th March 2016, 12:51 | #14288 | Link |
unit is multiplication.
negative number won't fix too loud sounds.
20th March 2016, 16:04 | #14291 | Link |
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 20th March 2016 at 16:08. |
20th March 2016, 16:11 | #14293 | Link |
20th March 2016, 16:25 | #14297 | Link |
Yet another stupid complain from retarded anti-virus software. I'm losing patience to this...
https://www.virustotal.com/en/file/1...is/1458487433/ I'm starting to think that currently it is impossible to write a program without any false positive alarms.
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 20th March 2016 at 16:27. |
20th March 2016, 21:36 | #14298 | Link |
Hi Atak_Snajpera!
Thx for the great work throu the years with development of RipBot264! Have a question that you might be able to answer... I have allways been able to use RipBot264 without any problems, but the recent 6 month my PC have started to freez so I have been forced to restart it fully to get it to work again. The problem ONLY appears with RipBot264 and it does freez in the first pass or in the beginning of the second. As it only affects RipBot264 and no other software I have, my thought is that it has something to do with that RipBot264 gets my processor to 100% on all cores. Any chance in RipBot264 that I can set it to ONLY use a certain amout of the processors Power, like only 80% or simular? Regards MaistroX |
21st March 2016, 00:04 | #14299 | Link | |
1st:- is your PC overclocked ??? Ripbot could be considered as a stress test, as it DOES run the CPU @ 100% most of the time. 2nd:- how clean is it inside your case & motherboard etc ?? Sounds like it might be overheating, check & clean the CPU fan(s), and video card(s) fan(s). I'm pretty sure that Ripbot can't be "throttled". |
21st March 2016, 00:58 | #14300 | Link | |
